Autosports Area
> Drag Racing
Like Tree4Likes
 Old 09-21-2011, 05:51 PM   #81
memin's Avatar
Posts: 994   (View Stats)
RESULTS!!!!!!!
 Old 09-21-2011, 09:08 PM   #82
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Originally Posted by runswithscissors View Post
I was joking douche boy!
Cry baby cry.. You're still butt hurt following me around like a sick puppy. I wasn't wrong about anything I stated in that other thread.
Get a life douche boy.
Jokes are usually funny. Faggot.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 09-21-2011, 09:41 PM   #83
Lurkers
runswithscissors's Avatar
Posts: 223   (View Stats)
runswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond repute
Groaned at 350 Times in 103 Posts
Don't be mad at me because you lack the intellect to discern a joke from reality. Douche Boy. Cry baby cry
runswithscissors is offline   Reply With Quote
The Following 5 Users Say NO Thank You to runswithscissors For This Un-useful Post:
adlpb (09-22-2011), breakfstincluded (11-15-2011), Easter Bunny (09-22-2011), ScarMS3 (09-22-2011), Tokay444 (09-22-2011)
 Old 09-21-2011, 10:27 PM   #84
ahskeetz's Avatar
Posts: 431   (View Stats)
ahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the world
Groaned at 7 Times in 5 Posts
now now children, no bickering in my thread.. Results will come, once we can get a day that fits both our schedules. Stay tuned.
2010 Black Mica MS3 |CP-E Nano.TIP.TMIC.RMM|1G DSM BPV|UR DP.TP|H&R springs|eBay camber arms|ITV-22|Ford XT-M5-QS|Sure Shortcut|PG shift weight|JBR Bushings|Maisonvi Chode Knob|MD OCC|Cobb AP tuned by me
2013 Kawasaki Ninja 300|15T sprocket|Yoshimura R77 full system| Area-P Tune
ahskeetz is offline   Reply With Quote
 Old 09-22-2011, 07:20 AM   #85
MSP611's Avatar
Posts: 2,291   (View Stats)
this is a misleading thread... 3 pages and still no race... fail!!! but u betta win!
In progress:
 Old 10-01-2011, 12:11 AM   #86
ahskeetz's Avatar
Results are in, track sucked today; only got 2 runs in because people breaking down left and right.
First run - me - 14.52 gen3.8 - 15.5
2nd run - me 14.7 gen3.8. - 15.3
I know the times are pretty bad lol, but at least I still beat him! He was complaining that his tires were spinning but i had the same prob and i beat him. I also raced my buddy's 16g eclipse gsx, both got 14.5.
warlord likes this.
The Following 2 Users Say Thank You to ahskeetz For This Useful Post:
sLow6 (10-01-2011), Tokay444 (10-01-2011)
 Old 10-01-2011, 12:33 AM   #87
jonspeed3's Avatar
Posts: 1,059   (View Stats)
jonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the world
Groans: 58
Groaned at 134 Times in 68 Posts
Good job, even tho its slow a win is a win.
Ask any real racer.
lulz.
US ARMY
07 True Red MS3 //Fully Bolted-Dizzy Tuned Wife drives the Speed now, I caught the gay, miata for me.
96 Red Miata // Not stock**
Missing home... Florida
jonspeed3 is offline   Reply With Quote
The Following User Says Thank You to jonspeed3 For This Useful Post:
ahskeetz (10-02-2011)
 Old 10-01-2011, 12:47 AM   #88
BobbleHead's Avatar
Posts: 2,237   (View Stats)
BobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the world
Groans: 186
Groaned at 33 Times in 25 Posts
well after a month of shit talking you backed it up congrats!
2012 BM MS3 w/ tech. Cobb AP V2b: Autotech CDFP internals: JBR 88d RMM: SURE 3" Aeros full intake: Ebay test pipe: Corksport TMIC: Turbosmart BPV: Bridgestone Potenza 235/40 tires: self tuned
BobbleHead is offline   Reply With Quote
The Following 3 Users Say Thank You to BobbleHead For This Useful Post:
ahskeetz (10-02-2011), DingoDave (10-01-2011), sLow6 (10-01-2011)
 Old 10-03-2011, 09:55 AM   #89
Codyjon2008's Avatar
Posts: 148   (View Stats)
Codyjon2008 has much to be proud ofCodyjon2008 has much to be proud ofCodyjon2008 has much to be proud ofCodyjon2008 has much to be proud ofCodyjon2008 has much to be proud ofCodyjon2008 has much to be proud ofCodyjon2008 has much to be proud ofCodyjon2008 has much to be proud of
good job man! rip the gen apart!
Codyjon2008 is offline   Reply With Quote
Drag Racing! Haltech Drag Racing 10 10-31-2013 09:15 AM
Drag Racing 2010 MS3 9900rpm 2010 MS3 - Dyno Sheets/Discussions 176 06-12-2010 10:36 PM
Page generated in 0.30234 seconds with 28 queries
