I Failed Miserably So I finally got to go to the track with the ole girl, and I fucking failed miserably. I have no doubt, however, that my car is a fuckin' 11 second car in the right hands. Things I was disappointed with:
Things I was ok with:
I say all that to say this: I didn't get 11s. I ran mid 12s sorta kinda consistently when I wasn't missing shifts. I couldn't get my 60' below a 2.0. That was killing me. I think I need to raise my LC settings, but I couldn't do it at the track because I forgot my laptop. I'm a fucking tard. My best run of the night was a 2.03 60', 118 mph trap, and a 12.5. Fairly mediocre. I'd love to post vids, but, as I mentioned previously, none of them are worth posting. http://184.72.239.143/mu/aefe008f-6583-8462.jpg http://184.72.239.143/mu/aefe008f-6595-4c4b.jpg http://184.72.239.143/mu/aefe008f-65a3-e554.jpg |
Give it time. You just got that tune, so it'll take some time to get used to it and learn to harness all that power. 60' times for an MS3 will always be tough to improve on, too. Especially with big power. |
One or two more times at the track and you should be at least in the very low 12s. But that is some very good mph!!! That thing will fly from a roll!!!! Does it feel like each gear the car pull harder the the last one and never lets up?? Good run buddy. When are you going to try it again? |
It felt so fucking good man. I raced a mustang in one of those, and he got like a 1.8 60', but by 3rd gear, I passed his ass. I'm hoping to get to a "local" (about 3 hours away) track sometime next month. We'll see. I think I want to do some suspension work first. Edit: http://youoffendmeyouoffendmyfamily....disappoint.gif |
Do you shift at redline or do you feel the power taper before then? What were you launching at. May be a newb? But does AP LC cut ignition to build boost? Were you dumping clutch at line? Burn outs are easy in a waterbox :) |
Edit: My first time up to the line, I had all sorts of jitters, so I accidentally put the car into reverse while I was in the water box... It was an experience... They laughed at me... |
I've only dragged this car with hockey pucks but, I'm pretty sure everyone says to dump the clutch with slicks. Did you stay in first till 6k or shift when you started rolling? |
Well done Joel. You'll get the hang of it once you're used to it. |
Not to shabby for ur 1st time out with the car in its latest setup, just a lil practice and u will be in the 11's..... fo show :) |
Yeah, don't be disappointed that you didn't cut an 11 sec 1/4 your first time out drag racing a high-hp fwd car with a big turbo that you had to launch at 4500 rpm. That shit is difficult and what I find more impressive is how your clutch and engine held up. I'm looking forwards to some more dyno sheets when you get to sea level, and then some timeslips once you get your setup sorted out. Even though you're claiming fail, this is still win in terms of us finding out the potential of our engines and drivetrains. |
haha what was running a 2.7 sec 60' and 18's? |
trapping 118 is impressive, if you can get that 60' down you will be mid 11s. Nice work. The power is there, give it a few more times. I imagine you are running some sort of drag radial? Are you getting tire spin on the launch? |
Nice man. Dump that clutch next time. The slicks will absorb the shock. What psi in the tires? The track is a totally different experience than the street, as im sure you found out. Its easy to get the hitters when you are on the spot. It took me 20+ passes to get a 13.5 on street tires :smokin: |
What gear are you in when you hit the traps? |
That's why I'm thinking that either A) I just suck that much B) I need to up my LC I honestly think it's a combination of the two though... Edit: I lied... We only took them down to 12 psi |
what was you're LC at anyway. Most people try like mid 4k and get owned. I say 5k minimum. When you get a good lunch its gonna feel like your spinning and sloshy but your actually covering good ground. |
We need to go to the track when u get back. That way I can coach u. Lol That's a decent 60 but a 1.8 can definitely be done I've seen it on skeet tires in an ms3. You actually need to lower your launch control as it is probably fucking your launch. Maybe even remove the LC and launch without it. I know it sounds gay. Launch control with the AP really sucks and it caused me to bog alot also when I was running the 12.8s or whatever I ran. Give it a few more tries at a local ish track ( i guess kc). And I u cant get it lower I'll take a stab at it haha:07::07: |
If I had my laptop, I could have experimented a little bit, but I'm a fucking dumbass... I'll definitely let you track her a couple times though. |
Ill preface by saying I have no experience with this car or FWD at the track But if you are bogging off the line, and running 12psi in your tires id say thats part of it. I also dont have experience with those particular radials either. But if you arent spinning, and are bogging down..id raise the PSI in the tires. Id keep filling them until you start spinning off the line. That will help eliminate your bogging issue and improve on trap MPH. You may pick up a mph or two. Now if you were spinning at 15psi or 12 psi..that would be a different story. If you just keep raises your launch RPM you are running out of gear and hp at the top of the RPM range. And you are also going to have more chance of clutch slip before it locks up good. But thats my opinion... On a side note in regards to launching at 4500rpm...has anyone ever broke front axles on these cars? |
U need to slip the clutch using launch control don't just drop it.. Every time I would drop at that high, I would bog and end up short shifting or missing a gear. |
My suggestion. Huge 2nd gear burnout, 11psi in tires, launch the shit out of that bitch at like 5500 and bang those gears. Do not for any reason slip the fucking clutch man. Shitty 60s and fucked clutch will shortly follow a slipping off the line. You will get many many different suggestion but only you can make it work. Ive bar far put the best 60fts down in this car and hope that has some weight, but take what everyone says with a grain of salt. Just go out there and learn for yourself. All cars and tracks are different and no one way is gonna stand true every time. Good luck pimpin. I have to wait 5 weeks now so i hope someone gets it before me, I really do. I dont plan on going out there an fucking around LOL |
You need a 2-step to really have control over launching the AP fails with its LC. I will give it a shot at the track! for sure. |
if you have a vid of your 12.5 run, i want to see it. |
Let's get a coach with better times ex: Driver. 12.5 on stock turbo compared to any 12 on big turbo owns all. I'm proud of u Joel. Everyone is gonna hate, screw em ur car is the fastest MS3 ON THIS FORUM AND THE WORLD they're just jealous my friend. Thanks for the attempt man you'll get it soon it's truly inevitable |
joel, the ONLY thing u failed at was being realistic with your expectations. its funny cuz anthony calls me up yesterday and hes asking me if u hit 11s lol....im like.."niggah, this ginger will come back with a 12.6 at high teens mph".... your car is def gonna run 11s....but it will take a few outings for u to chop a few tenths off the 60'....a couple of tenths off the shifting...and it will happen.....just be realistic.....how could anyone that hasnt drag raced this car possibly have done much better? congrats, u did a great job!!!!!!!!!!!!!! |
It's ok to groan me Brian 12.9 is pretty fail on big turbo I'll post my 12s on stock turbo when the time comes let ya know how it's done:) |
+1 for practice and getting used to the "new" car |
His car is way faster than mine ever was to begin with. It's definitly in the 11 second range and I have a few ideas for him for the next time he goes to the track tO help him hit that goal. |
What track was this? Even though you didn't hit 11's it's nice to see the those trap speeds. LOL at 17.91 @ 92.18 mph (and a 2.8 60') in the second pic. |
I'm not gonna compare dick sizes here u no longer own an MS3 so ur input is no longer valid for me. I ran a 13.7 with intake and ghetto ass Falkens. 12s will be cake when the time comes if it ever does. My car will be an autoX car this spring/summer not trying to make my fail wheel drive a drag car really wasn't ever what this car was meant for obviously. Ya need to get the stick outta your ass don't even know why u became such a hater towards me. To each his own:chairshot: This is Joels thread I'll debate no longer. Sorry Joel you'll get 11s within time big ups for all you've done and will continue to do for this platform |
Congrats Joel! You did really well for your first runs. I had the same issue with the misfires at the track. I was running the same tune for a week prior to the track with no issues. Almost every run I has I would misfire at mid to high range rpms. I'm looking for an ignition amp to help smooth that out. You should jump on one asap. |
I stretch my springs every time I go to the track. Seems to help alot. Ive yet to get any cut on this new motor. |
We'll see what happens. |
did you....FLAT FOOOOT!? |
You gotta double clutch |
Yeah he already said he was granny shifting |
/ in b4 the post of the thread look at the positive in life joel, at least this time u didnt stick your tongue in some dude's mouth. |
He is learning and needs more time behind the wheel drag racing. I do question the prep on that track. It was windy, moist and cold. I think he would of gotten damn near a 12.0 once we got the tire pressure down lower. We didnt have an airtank, so we had to creep down in PSI. I think he will start with 12 psi next time out the gate. I told him to fuck his LC, but Joel doesn't like every time he is coached. He will learn eventually :) |
good shit joel, 118 is nothing to be disappointed about esp if you managed it with the rest of your fail haha. lenny u need to take some launch advice from this mofo and stop cleaning out the MS3 after market of clutches haha |
isnt 118 the fast trap speed of any ms3 yet? |
He would of trapped 119 last night, i know it. |
Woulda coulda |
You are just a Ray of sunshine and a source of encouragement aren't you |
what about RR? hahahahahahahahahahaha |
Just work on it and as i do pay attention to what you are car is doing and what you are doing and alter it as you see fit when on each pass. good luck next time i know you will do it. also did you run with full interior? Did you weigh the car? if so what did it weigh? you said something about suspension, i believe suspension will help with weight transfer but i wouldn't look at that as the reason for bogging.. |
i do a data log! @ the track i bet dollar to doughnuts your hitting higher load, and going rich causing the blow out! my car does the same shit, ive seen it go into the 8s afr in first |
Congrats man. I have read both of the threads and fuck all the people talking shit or that hidden shit talk. Like good job man BUT. People here at times are just fucken jealous tools. The dude has THE fastest MS3 around, congratulate him and don't be a fucken hater. Think about all the potential for fail in any department with this car and this guy is putting out tons of fucken power and going for broke. Commendable in my book and hitting 11's with practice like everyone said will be possible. Fucken haters on these forums as of late. Edit: I want to see some videos of this thing pulling from a 40 please...please...lol |
Shit I didn't realize that was your first time at the track. I'll see if any of the videos I took are worth posting. The fucking camera wouldn't focus on the time but you can see the launches pretty well. |
Joel, lower your tire pressures down to around 9 to 10psi. If I'm not mistaken, you're running the Hoosier. I run those as well, and they don't hook too well, especially when there's too much air in them. I was skeptical running low pressures like that, but the tires will balloon anyway once they are heated up. Awesome mph. Keep up the good work! |
What rpm do you launch at? |
He has traction he just needs to find a sweet spot where he can spin alittle bit to fall into the beginning of his power band with out the bog. theres multipul was he can do this which has been suggested in this thread but your suggestion is like telling him to have someone spray VHT on the ground. Dude has traction already..... |
you must powaaaaaaaaashift |
Well, that's kind of a lie. My first 12.5 @116 was granny shifting. second 12.5 @ 118 was power shifting |
I tell you what to put this debate to rest put about 18 psi in your tires and do a nice smokey burn out to heat the tires up and launch it and see what you do in 2-3 passes and then do it at the suggested air pressure like 8 psi and see which one works for your set up. This also all plays a part on if they prep the track with enough VHT or is it dry.. crazy question i know this shouldn't be your problem but i have to ask is you are sure that you are taking the traction control off before you run right? Just asking as i have made this mistake plenty of times so it can happen due to your nerves. FYI i know that lower air pressure is BETTER than more air but the more are you let out the more traction you get. So it he is bogging then raise the pressure or raise the LC. Both to the point where you start spinning and then back it down...SWEET SPOT Also when you launch your car is your clutch pedal all the way to the floor when you are launching? If so then this might your problem by itself. The reason is the time it take you to lift your foot to engage your clutch your rpms may have dropped drastically thus causing you to bog... a lot of beginners do this as well. |
Just kidding :) |
I won't be getting slicks for a while so in street tires where should I start with psi for the track? |
I'm actually about to get new tires. I'm looking at a set of Nitto NT 555's for both my cars. I'd go to a more high end of Nitto's but they start to look like slicks and not street tires above these. |
Yeah I was looking at a different set of Nittos but then I saw I could get these for only 7 dollars more per tire so I'm going with them. They had slightly better reviews so I think it'll be worth it. |
wilks are you going to be doing a sea level dyno before your next track days. curious to see the diff from altitude... |
Congrats on the runs either way. It takes more than money to go fast. It takes time and you'll get there. Sent from my iPhone using Tapatalk |
good shit man....... Has anyone on here used any aftermarket EBCS other then the grimmspeed with there big turbos? The grimmspeed failed with big turbo kits. |
Cut it down to a 1.7 60ft you will be running 11s with no other changes. I have knocked off a full second from just learning how to drive, so don't get discouraged, keep at it and you will have elevens easy. |
And yes... burnouts were second gear |
Well, we need to set up a track day here soon! I really want to get my car to the track soon. Hopefully not to break anything. Good runs, but practice does make perfect. Car does have A LOT more in it! |
Jarod we got a thread going in the NATOR MO.....I guess KCIR does Test n Tunes on Saturdays |
2 Attachment(s) I only got two videos of Dustin and/or Joel before my battery died. Hopefully they work, my camera and editing programs are fucking gay and don't get along. I posted a few more videos in the PHX meet thread. |
Fuck, next time out, I may try the same shit. Just let the tires fry a little on the launch and see what happens. |
Just watched your videos. The car sounds nasty!! I like it. So yeah, your launches needs more revs. Does look like you're launching with not much behind it. How does the LC on the AP work? Does it only let you set rpm, or can you make adjustments, such as retarding timing? I know in my Evo, on the AEM EMS, I can make those adjustments, and the thing will build 25psi at the line, and sounds like gun shots. |
Dude it was great meeting you man. You and those tiny weiners at the irish pub cracked me up big time. I feel your pain at the track as well. It was my first time with my car there and I was getting good trap speeds for stock turbo at 102mph vs everyone else was like 97-99mph. I just couldnt break into 13's because of my poor launch abilities. Give us both a few more times at the track to figure out what we need to do and you'll be hitting your 11's and i'll be in the mid to low 13's :) Thanks again for the journey to AZ. Was great putting a face to the avatar :) |
Just watched the vids. You are coming out of the hole way soft. I say quickly slip the clutch at 5-5.5K and let the big dog eat. Remember .1 at the 60' is usually worth .2 at the 1/4 stripe. |
The issue is that I was bogging because I was launching at 4.5k |
What boost were you holding at the line? |
the run with you and dustin looked pretty damn clean man, car sound nasty too. kinda sounded like you short shifted a little between 1-2 maybe i dunno? ps when are you getting your pussy? |
So ok i seen dustin run so what time did he run? he looked really slow when he ran so where you just playing around? |
Edit: Ugh.... That second video was one of my worst runs of the night. I didn't expect the tree to go until Dustin was up to the line, but it went regardless haha... That's why my launch was so horrible in that one. |
you gotta hit 5th gear, so many shifts. you really gotta be on your game, and it seems like you pretty much were. powershifting is where its at though, it helps a lot. damn cant wait till the track up here opens. ha not gonna be for a while though... |
| All times are GMT -7. The time now is 05:49 AM. |
