Autosports Area
> Drag Racing
Like Tree2Likes
 Old 02-28-2011, 03:20 PM   #81
MS3 Abuser
9900rpm's Avatar
Posts: 784   (View Stats)
9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world9900rpm is the leader of the world
Originally Posted by jwilkins88 View Post
That'd be awesome man! Much appreciated!
Thanks man!
What rpm do you launch at?
On the BT, I was launching at 4krpm and it was falling flat on it's face. At 4200, it was better. Next time out, I will try around 4600rpm or so. Since you have 2 step, start at 4400rpm or so (depends on how much boost, if any, it builds on the line). The launch characteristics of these cars on stock turbo vs. BT is totally different. You are doing your burnouts in 2nd gear, right? If you say no, that is a part of your problem. A tire spinning at 50mph for 5 seconds will heat up better than a tire spinning at 20mph for 10 seconds. Feel me?
Yeah don't do this Joel lol.
He has traction he just needs to find a sweet spot where he can spin alittle bit to fall into the beginning of his power band with out the bog. theres multipul was he can do this which has been suggested in this thread but your suggestion is like telling him to have someone spray VHT on the ground. Dude has traction already.....
He said he's bogging on the launch, which means he's launching too low. If he launches higher, which he should, he will spin, so to counter that, he needs to lower tire pressure.
Originally Posted by KiddMnKy View Post
I won't be getting slicks for a while so in street tires where should I start with psi for the track?
Slip the clutch out (don't dump it, or you will get wheel hop then serious spin) at around 2700rpm or so, depending on track conditions. You want your tires to chirp slightly, but not fry on the launch. Lower your tire pressure to 25 to 28psi. Do your burnout quick, not a smokey one. Just like a 2 second burnout to kick the rocks off. Street tires will heat then glaze, making them slippery, if you burn out for a long time, which fucks up your 60 foot times. Bring a tire gauge. Remember to put air back in your tires when you leave the track.
12.653 @ 109.90mph, Stock K04
2010 MS3
9900rpm is offline   Reply With Quote
The Following 2 Users Say Thank You to 9900rpm For This Useful Post:
jwilkins88 (03-01-2011), mtnrunner (04-11-2011)
 Old 02-28-2011, 03:46 PM   #82
OneBAMFpog's Avatar
Posts: 642   (View Stats)
OneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the worldOneBAMFpog is the leader of the world
Groaned at 25 Times in 11 Posts
Yeah, that was something I've got to look into. I haven't seen any of the tracks out here but I'm sure they have the capability to reinflate tires. (Last track I was at didn't) I know about the burnout and slipping the clutch. I'm glad you addressed the air pressure though because I was not sure about it. Also, are you saying that I should be revved to about 2700 rpm as I launch while slipping off the clutch? My first run with my 2010 MS3 was a 13.8. I'll pull out the timeslips and upload it. My reaction time was TERRIBLE!
2010 Black Mica Mazdaspeed 3 Stock
2010 Velocity Red Mica Mazdaspeed 3
Current Mods:
COBB SRI -- TIH -- ACCESSPORT -- EBCS
CP-E DP AUTOTECH FP INTERNALS CORKSPORT 80 MM DUAL EXHAUST
JBR SOLID SHIFTER BUSHINGS -- 88 DURO RMM -- TMM -- PMM--TIG AND COOLANT BYPASS FORGE BPV
ACT ZX5-HDG6 CLUTCH KIT DEVIL'SOWN METH KIT
EDDIE BAUER CARSEAT MOD
DJ tuned: 302 whp and 339 wtq
"YOU PULLED ON ME LIKE A FREIGHT TRAIN!"
OneBAMFpog is offline   Reply With Quote
 Old 02-28-2011, 04:56 PM   #83
jwilkins88's Avatar
Posts: 3,675   (View Stats)
jwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the worldjwilkins88 is the leader of the world
Groans: 126
Groaned at 59 Times in 47 Posts
I was launching at 4500 and that was too low. Next time I'm at the track, I'm gonna try 5k. If that doesn't work, I'll try 5300.
And yes... burnouts were second gear
jwilkins88 is offline   Reply With Quote
The Following User Says Thank You to jwilkins88 For This Useful Post:
djuosnteisn (03-01-2011)
 Old 02-28-2011, 04:58 PM   #84
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Well, we need to set up a track day here soon! I really want to get my car to the track soon. Hopefully not to break anything. Good runs, but practice does make perfect. Car does have A LOT more in it!
2008 MazdaSpeed 3 AWD big turbo...blah blah blah
Jarods7920 is offline   Reply With Quote
 Old 02-28-2011, 10:36 PM   #85
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Groaned at 25 Times in 25 Posts
Jarod we got a thread going in the NATOR MO.....I guess KCIR does Test n Tunes on Saturdays
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
 Old 03-01-2011, 10:06 AM   #86
wankular's Avatar
Posts: 4,343   (View Stats)
I only got two videos of Dustin and/or Joel before my battery died. Hopefully they work, my camera and editing programs are fucking gay and don't get along. I posted a few more videos in the PHX meet thread.
2009 MS3 sport MGM
The Following 2 Users Say Thank You to wankular For This Useful Post:
djuosnteisn (03-01-2011), jwilkins88 (03-01-2011)
 Old 03-01-2011, 10:11 AM   #87
MS3 Abuser
9900rpm's Avatar
Another thing; if they do have an air hose at the track, bump the rear tire pressure up to 50psi. Less rolling resistence.
Joel, when you say too low, does it spin tires for half a second, then fall flat on it's face, or just takes off slowly? Also, does it spin slicks in 2nd and 3rd?
Fuck, next time out, I may try the same shit. Just let the tires fry a little on the launch and see what happens.
2010 MS3
The Following User Says Thank You to 9900rpm For This Useful Post:
 Old 03-01-2011, 10:18 AM   #88
MS3 Abuser
9900rpm's Avatar
Just watched your videos. The car sounds nasty!! I like it.
So yeah, your launches needs more revs. Does look like you're launching with not much behind it.
How does the LC on the AP work? Does it only let you set rpm, or can you make adjustments, such as retarding timing? I know in my Evo, on the AEM EMS, I can make those adjustments, and the thing will build 25psi at the line, and sounds like gun shots.
2010 MS3
 Old 03-01-2011, 11:12 AM   #89
Matrix311's Avatar
Posts: 2,133   (View Stats)
Matrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the worldMatrix311 is the leader of the world
Dude it was great meeting you man. You and those tiny weiners at the irish pub cracked me up big time. I feel your pain at the track as well. It was my first time with my car there and I was getting good trap speeds for stock turbo at 102mph vs everyone else was like 97-99mph. I just couldnt break into 13's because of my poor launch abilities. Give us both a few more times at the track to figure out what we need to do and you'll be hitting your 11's and i'll be in the mid to low 13's Thanks again for the journey to AZ. Was great putting a face to the avatar
Eric Schlaht - Arizona Phoenix Photographer
http://www.esimaging.net - http://www.facebook.com/esimaging
2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14**
**9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp
**11/19/13** Forged engine built and started up the car for the first time, success!
**3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno
**6/24/15** Sold the Mazdaspeed 3
**7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package
Matrix311 is offline   Reply With Quote
The Following 2 Users Say Thank You to Matrix311 For This Useful Post:
 Old 03-01-2011, 11:25 AM   #90
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
I was at 100-101 hooker! But you were the fastest I believe, I was the quickest We'll set up a meet some time. Hopefully by then I can stop the motor from dancing around in my engine bay and easily crack into the 13's. What were your best 60ft, best i managed was a 2.27
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 03-01-2011, 12:40 PM   #91
Thermonuclear Skeet
FantasmoNegro's Avatar
Posts: 2,810   (View Stats)
FantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the world
Groans: 188
Groaned at 333 Times in 222 Posts
Just watched the vids. You are coming out of the hole way soft. I say quickly slip the clutch at 5-5.5K and let the big dog eat. Remember .1 at the 60' is usually worth .2 at the 1/4 stripe.
El Fantasmo Del Negro
Helicopter Cat LIVES
FantasmoNegro is offline   Reply With Quote
 Old 03-01-2011, 02:04 PM   #92
jwilkins88's Avatar
Groans: 126
I was slipping the clutch pretty damn quick. On my last run, I straight dropped the clutch.
The issue is that I was bogging because I was launching at 4.5k
 Old 03-01-2011, 02:46 PM   #93
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
What boost were you holding at the line?
2012 WRX HB w/mudflaps yo!
 Old 03-01-2011, 03:23 PM   #94
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Fagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the world
Groans: 75
Groaned at 57 Times in 37 Posts
the run with you and dustin looked pretty damn clean man, car sound nasty too. kinda sounded like you short shifted a little between 1-2 maybe i dunno?
ps when are you getting your pussy?
Last edited by Fagwagon; 03-01-2011 at 03:23 PM. Reason: MSF Database - Automerged Doublepost
Fagwagon is offline   Reply With Quote
 Old 03-01-2011, 05:46 PM   #95
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
So ok i seen dustin run so what time did he run? he looked really slow when he ran so where you just playing around?
track weight 3220
street weight 3370
 Old 03-01-2011, 06:36 PM   #96
BrianZX10R's Avatar
Posts: 1,163   (View Stats)
BrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the world
Groans: 88
Groaned at 121 Times in 75 Posts
dustin was at 35 psi wot POWER SHIFTING AND DOUBLE CLUTCHING..!! SPEED3'S USUALLY make 6's look that slow
1995 honda civic. 1.6L slow
2007 Kawasaki ZX10r
BrianZX10R is offline   Reply With Quote
The Following 2 Users Say Thank You to BrianZX10R For This Useful Post:
djuosnteisn (03-02-2011), jwilkins88 (03-01-2011)
 Old 03-01-2011, 08:21 PM   #97
jwilkins88's Avatar
Groans: 126
He was trying to get his tune dialed in. He was also having some serious issues with spark blowout
Only like 2-3psi
Edit: Ugh.... That second video was one of my worst runs of the night. I didn't expect the tree to go until Dustin was up to the line, but it went regardless haha... That's why my launch was so horrible in that one.
Last edited by jwilkins88; 03-01-2011 at 08:25 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-01-2011, 08:59 PM   #98
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
the cool thing about the track that people forget a lot is that your time won't start until you actually move. Sometimes its nice to get a run, when you want to go, like a second or two after you see the lights go. Your reaction time will suck, but when youre trying to get a solid time, this is best way to do it, I think.
'08 CWP MS3 w/ T3 3071r
The Following 2 Users Say Thank You to 802MS3 For This Useful Post:
FantasmoNegro (03-01-2011), jwilkins88 (03-01-2011)
 Old 03-01-2011, 09:06 PM   #99
jwilkins88's Avatar
Groans: 126
Yeah man. I knew that in the back of my head, but I kept forgetting about it because of noob jitters. Next time will be so much better.
 Old 03-01-2011, 09:19 PM   #100
rabble rabble
802MS3's Avatar
Groans: 221
you gotta hit 5th gear, so many shifts. you really gotta be on your game, and it seems like you pretty much were. powershifting is where its at though, it helps a lot.
damn cant wait till the track up here opens. ha not gonna be for a while though...
The Following User Says Thank You to 802MS3 For This Useful Post:
 Old 03-01-2011, 09:21 PM   #101
jwilkins88's Avatar
Groans: 126
Yeah... Our local track is closed, so I'm gonna have to go to KC to track my car next time around... Tracking a car like mine on a stock clutch when you're not close to home is scary as fuck.
As the night went on, my transmission just got louder and louder until it sounded like a fucking midget was under my hood banging on shit with a hammer.
Then I drove the 1500 miles home....
 Old 03-02-2011, 11:53 AM   #102
MS3 Abuser
9900rpm's Avatar
With a stock clutch, dump it out. Reason being that the stock disc heats up quicker than aftermarket. If you slip the stock clutch out on a powerful car, it's cooking a lot of material off, and won't hold as well later. Do it a lot, and it will lock you out of gear.
Stock clutch disc is sprung anyway, and stock flywheel is dual mass. You need that force to get everything moving. Rev high, dump it out, don't look back!
2010 MS3
jwilkins88 (03-02-2011)
 Old 03-02-2011, 12:34 PM   #103
Jarods7920's Avatar
Joel, we need to get to KCIR one night when it warms up!
The Following User Says Thank You to Jarods7920 For This Useful Post:
 Old 03-02-2011, 02:02 PM   #104
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
yeah, i was just rolling off the line and doing 3rd and 4th gear pulls for datalogs.
@triplejumper18 your such a fucking feggot puss
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 03-02-2011, 02:45 PM   #105
jwilkins88's Avatar
Groans: 126
We're planning a KCIR trip when the weather warms up. I think it's in the NATOR MO section
 Old 03-03-2011, 09:37 PM   #106
driver311's Avatar
Posts: 1,769   (View Stats)
driver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the world
Exactly. This is how I get my mid 1.7s in the speed3.
2008 Mazdaspeed3, Fully built then fully parted. Sold
2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily
Mazdaspeed
12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp
11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp
driver311 is offline   Reply With Quote
 Old 03-04-2011, 11:40 AM   #107
Posts: 9,484   (View Stats)
Anthony,
Where is that 11.xx slip?
 Old 03-05-2011, 06:42 AM   #108
driver311's Avatar
Havent went yet bro. Sacramento closed due to supposedly rain. Stupid. Car was extremely fast at sea level.
Mazdaspeed
 Old 03-05-2011, 10:16 AM   #109
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
Groaned at 39 Times in 27 Posts
gjdm
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
 Old 04-09-2011, 07:53 PM   #110
driver311's Avatar
In before the 12.3@117 run.
Mazdaspeed
The Following User Says Thank You to driver311 For This Useful Post:
4G63 (04-15-2011)
 Old 04-10-2011, 02:58 AM   #111
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
hahaha..... agreed!!!
 Old 04-10-2011, 10:33 AM   #112
jwilkins88's Avatar
Groans: 126
I'll put both you cocky motherfuckers in your place as soon as I get my fueling issues worked out.
Lenny - You should run 12s before you talk shit... Just saying
 Old 04-10-2011, 10:38 AM   #113
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
niggah fuck my 12s .....i can (and most likely am the slowest motherfucker alive) still talk shit.
and fyfin
The Following User Says Thank You to rodrigo For This Useful Post:
jwilkins88 (04-10-2011)
 Old 04-10-2011, 10:43 AM   #114
rabble rabble
802MS3's Avatar
Groans: 221
lol. Lenny is the most humble person here when it comes to drag racing. A little poke shouldn't hurt anyones feelings.
 Old 04-10-2011, 11:14 AM   #115
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
joel is just a sensitive cunt (n/m he traps over 10mph higher also) ......maybe if we put a transtesticle at the 1320ft he would get there quicker
The Following 4 Users Say Thank You to rodrigo For This Useful Post:
802MS3 (04-10-2011), Dano (04-10-2011), DingoDave (04-12-2011), jwilkins88 (04-10-2011)
 Old 04-10-2011, 11:36 AM   #116
one at 60ft as well...
nah he may be able to see an adams apple at 60'...wait no...he can't see one sitting at the bar right next to him...yes put a testicle at 60'
DingoDave (04-12-2011), djuosnteisn (04-25-2011), jax ms3gt (04-10-2011), jwilkins88 (04-10-2011)
 Old 04-10-2011, 11:41 AM   #117
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
Wait did joel get alittle sensitive over Lennys comment?
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 04-10-2011, 11:43 AM   #118
jwilkins88's Avatar
Groans: 126
I'm always a sensitive cunt
The Following 2 Users Say Thank You to jwilkins88 For This Useful Post:
Dano (04-10-2011), djuosnteisn (04-25-2011)
 Old 04-10-2011, 12:09 PM   #119
jax ms3gt's Avatar
Posts: 1,151   (View Stats)
jax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the world
Groaned at 23 Times in 12 Posts
lolz, very quotable. There only a few of us who don't suck at drag racing on this platform, and most of them aren't near your power level. So your not doing that bad..practice, practice and hope everything keeps holding up so you can get 11's consistently
CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC
PERM TUNED
Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around
2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP
jax ms3gt is offline   Reply With Quote
The Following User Says Thank You to jax ms3gt For This Useful Post:
Dano (04-10-2011)
 Old 04-10-2011, 03:10 PM   #120
haha
I am just bustin his balls....
I would love to see an AP car be the first into the 11's....
engine mount failed tomanz MazdaSpeed 3 - Engine, Transmission & Driveline 8 11-20-2010 04:55 PM
Failed Thread essejkcamraw MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 57 11-17-2010 11:16 AM
NATOR Failed FP Internals Install bioevolve MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 28 02-22-2010 09:13 AM
My failed LED experiment Daddy Exterior 10 01-14-2010 05:58 PM
Can 'Government Motors' succeed where GM failed? Haltech Automotive News 0 05-31-2009 12:20 PM
Page generated in 0.60465 seconds with 41 queries
