Autosports Area
> Drag Racing
  • 1 Post By rodrigo
 Old 05-20-2011, 07:49 PM   #1
MazdaGaragePat's Avatar
Posts: 75   (View Stats)
MazdaGaragePat is the leader of the worldMazdaGaragePat is the leader of the worldMazdaGaragePat is the leader of the worldMazdaGaragePat is the leader of the worldMazdaGaragePat is the leader of the worldMazdaGaragePat is the leader of the worldMazdaGaragePat is the leader of the worldMazdaGaragePat is the leader of the worldMazdaGaragePat is the leader of the worldMazdaGaragePat is the leader of the worldMazdaGaragePat is the leader of the world
Default I haven't managed to break the wall tonight... ET 12.01
First I want to beg your pardon for no evidence.
Track employee with my camera decided to stop the record somewhy
But unlike the unicorn (and one known company not to be mentioned) I'll definately get back to the track and make some 'full' videos of new runs.
So let me tell you the full story.
As was told earlier, in October, 2010 I've managed to do three runs (12.85, 12.58 12.50) with my new 3076 setup which was the best known ET worlwide for that fall. The videos of two last runs are available in the corresponding thread (Mazda6 MPS 12.501 (October, 2010) - Mazdaspeed Forums). That was full interior car w some 1/2 of fuel tank, but the trunk was gutted (spare, carpet, jack).
This year I've installed the Snow Performance water-methanol injection kit and raised the boost to average (for quarter mile run) 1.5 bar (22 psi). Also I've advanced the ignition a lot thanks to methanol. So yesterday I've stripped the car (jack, spare, carpet, back seat, passenger seat, console between front seats), filled 1/3 of fuel tank and dropped the WOT box no-lift-shift time from 325 ms to 225 ms. Then I've done and logged two runs on the road, observed noticeable dynamics improvement and decided to go to dragstrip. There I had time to do only one run unfortunately and its video is shown above. My run was the last in the whole session of event.
So I am happy to improve my time by 0.49 sec with the first attempt.
But I am disappointed simultaneously. Cause it lacked only 0.02 sec to break the 11 sec wall ! I believe it is my bad luck - my best time with my previous car (Nissan 200SX aka 240SX in the US) was 12.003 !!!
Track and weather facts can be found in description of my youtube video.
Cause it is 5.00 am at the clock already, not today but tomorrow I'll post my own OBD-II logs corresponding to all my runs (13.09, 12.85, 12.58, 12.50, 12.01) for comparison.
European Mazda6 MPS - 10.944 @ 129 mph
GTX3582R 0.82 TiAL . MG top mount manifold . TiAL 44 mm EWG . MG DP . MG dual CBE . TiAL Q BOV . Turbosmart BPV . MG 24x12x3" FMIC kit w 2.5" piping . MG 4" intake . HKS M40LF . K1 rods . CP Pistons 9.5:1 . ARP studs . wet sleeved block . PnP head works . lightened valves . CP-E HPFP . ACT 6-puck clutch . DSS rear axles . CP-E rear engine mount . MG passenger & front engine mounts . MG diff mounts . MG front strut bar . MG rear interior brace . KW Variant2 coil-overs . Autoexe FSB . Whiteline RSB . Hardrace trailing arms bushings & adj camber arms . Rotora slotted rotors . Ferodo DS3000 front and Autoexe Sports rear BP . Techna-fit brake lines . Red Line Oil (5w50, MT-90, LightWeight Shockproof) . STRI gauges . WOT Box . DashHawk . Turbo Garage EBC . HKS AFK . MAC 3-port solenoid . speed density . Snow Performance methanol injection . GramLights 57F 18x8.5 ET45 and Kosei K1 17x7.5. Federal 595 RS-R 235/40 and BF Goodrich Drag Radial 225/45 . Muteki nuts . Sparco Evo II seat . ECU reflash myself
MazdaGaragePat is offline   Reply With Quote
The Following 18 Users Say Thank You to MazdaGaragePat For This Useful Post:
-cj- (05-20-2011), aaronc7 (05-20-2011), AZSPEED3 (05-22-2011), Ckmazdaspeed3 (05-21-2011), Decepticon (05-20-2011), DingoDave (05-21-2011), jwilkins88 (05-24-2011), Lex (05-20-2011), manelscout4life (05-21-2011), MPSdriver (05-23-2011), predapio (05-21-2011), PunjabiPlaya (05-21-2011), rfinkle2 (05-20-2011), SJP0tato (05-22-2011), speed23 (05-20-2011), spiker98 (05-21-2011), triplejumper18 (05-23-2011), wette460 (05-22-2011)
 Old 05-20-2011, 08:04 PM   #2
What was the trap speed?
 Old 05-20-2011, 08:50 PM   #3
so you have no slip? or proof of clock?
what was your 60'?
 Old 05-20-2011, 10:56 PM   #4
Decepticon's Avatar
Posts: 1,221   (View Stats)
Decepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the world
Groaned at 43 Times in 28 Posts
time slip atleast?
06 MS6, Cobb AP, -TUNED on corn mix, KMD v2 fp internals, NGK Iridium IX sp, Cp-e Xcel NANO, PG tip, SU bpv, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback, Altered Custom fmic, H&R springs...
R.I.P. 08.5 MS3, Cobb Ap, KMD v2 fp internals, Denso ITV22 sp, Cobb Sri, TurboXS bpv, SU rear mm, SU shifter bushings, ETS TMIC, SU boost tubes, Cp-e catted dp, Enkei EKM3.
Decepticon is offline   Reply With Quote
 Old 05-20-2011, 11:48 PM   #5
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
btw i ran 10s last night...no one saw it, i have no video, no timeslip...track was empty , but i ran 10s ..flat 10 at that....
please thank me...can i post my time in drag racing section?
OneBAMFpog likes this.
The Following 7 Users Say Thank You to rodrigo For This Useful Post:
jmhinkle (05-23-2011), nighthawk358 (05-22-2011), OneBAMFpog (05-22-2011), PapaSmurf (05-20-2011), SJP0tato (05-22-2011), superskaterxes (05-22-2011), wette460 (05-22-2011)
 Old 05-20-2011, 11:51 PM   #6
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Groans: 112
860whp/677wtq
2.7 V6 Ecoboost
 Old 05-21-2011, 08:33 PM   #7
Guys, I already apologized for no proof in the first post. I am sad much more than you cause of that.
Now I understood that if I would hit 11.XX w/o evidence and post that here you'll just throw me away from the Forums
So, as I told earlier, I'll definately do more runs and post the results with proofs.
But since I've done this my first run this year I wanted to inform you about the result and MS6 platform potential with my setup.
So let me return to the subject.
TIMESLIP:
Our dragstrip team doesn't print timeslips, LCD only.
60 FT:
They don't install 60 ft sensors as well. As far as 1/8 mile ones.
SPEED TRAP:
188 kmph (117 mph).
I log every run with our own software through OBD-II port. Algorithm, accuracy and sampling rate are similar to Dashhawk and other CAN loggers. But accuracy depends on sampling rate. And sampling rate depends on qty of parameters being logged. In my logs sampling rate usually equals 4 Hz. And below is the assembly of logs of my runs:
Speed in charts is measured in KMPH (1 KMPH = 0.62 MPH). I converted some to MPH right hand of the charts.
1) Stock turbo. Fully bolted except exhaust manifold. 1.32 bar (19 psi) spike, 1.15 bar (17 psi) hold.
2) GT3076R. 93 pump gas. 1.25 bar (18 psi) spike, 1.1 bar (16 psi) hold.
3) GT3076R. 93 pump gas. 1.34 bar (19 psi) spike, 1.2 bar (17 psi) hold.
4) GT3076R. 93 pump gas. 1.37 bar (20 psi) spike, 1.25 bar (18 psi) hold.
5) GT3076R. 93 pump gas. Water-methanol injection. Test on slightly uphill public road before driving to dragstrip and run number 6. 1.6 bar (23 psi) spike, 1.5 bar (22 psi) hold.
6) GT3076R. 93 pump gas. Water-methanol injection. 1.55 bar (22 psi) spike, 1.5 bar (22 psi) hold.
Since sometimes I hit 60 kmph in wheelspin, times up to 0-70 kmph sometimes don't show real dynamics, but traction and launch power.
In the fifth run I've finished at 4th gear with 0-180 kmph = 10.656 sec
In the sixth run I've finished at 5th gear with 0-180 kmph = 11.104 sec
So I feel no sense to shift-up to 5th gear until the 4th gear would be maxed out.
The Following User Says Thank You to MazdaGaragePat For This Useful Post:
 Old 05-21-2011, 09:16 PM   #8
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
no slip it didnt happen
and especially when u are brown....
besides we got a 12,0 already at 112 so > u
weed a talk
The Following User Says Thank You to rodrigo For This Useful Post:
 Old 05-22-2011, 03:15 AM   #9
wette460's Avatar
Posts: 385   (View Stats)
wette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the world
hmmm <sniff sniff> ...smells like Race Roots bullshit to me all over again.
T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels
wette460 is offline   Reply With Quote
 Old 05-22-2011, 09:44 AM   #10
Do you make me apologize the third time ?
No timeslip or proof on clock = it didn't happen. I agree.
Let the 12.24 be the best MS6 time tor today, no problem.
As far as you all can see, I didn't edit my signature or else cause no proof !
Unlike 'famous 12.00 time MS3 owner' I won't photoshop any timeslip cause I have no real one and won't cheat you.
Just wait a while and I'll make new run(s) with full video including proof on clock.
With this thread I just wanted to share my observations with other guys on the MSF that are hunting for 11 seconds. I hope my logs would be some kind useful for somebody.
Guys, what 60 ft time have I hit in that run on the video, on your opinion ?
 Old 05-22-2011, 09:46 AM   #11
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
congrats on the good times and good luck getting into the 11s!
just get a video or slip or some sort to shut up all the haters in here.
then maybe you can have the title of "world's fastest ms6"
The Following User Says Thank You to aaronc7 For This Useful Post:
MazdaGaragePat (05-22-2011)
 Old 05-22-2011, 10:40 AM   #12
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
AZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the world
Groans: 65
Congrats man on the great time. Next time out you will break in to the 11's.
I have seen your previous videos you have posted and have no doubt you ran 12.01
AZSPEED3 is offline   Reply With Quote
The Following 2 Users Say Thank You to AZSPEED3 For This Useful Post:
mason (05-22-2011), MazdaGaragePat (05-22-2011)
 Old 05-22-2011, 10:25 PM   #13
driver311's Avatar
Posts: 1,769   (View Stats)
driver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the world
You make it sound like I photoshopped my timeslips lol I guess my vids are good enough back also. Keep at it, your 11s will come.
2008 Mazdaspeed3, Fully built then fully parted. Sold
2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily
Mazdaspeed
12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp
11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp
driver311 is offline   Reply With Quote
 Old 05-23-2011, 03:34 AM   #14
No way !
I meant race roots 12.006
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f232/i-haven-t-managed-break-wall-tonight-81278/
mazdaspeed has reached 10's This thread Refback 07-29-2012 05:19 AM
Ran 13.63 and three 13.7s tonight. Nataphen Drag Racing 70 06-06-2011 04:06 PM
The Tonight Show with Conan O'Brien welcomes 2010 Taurus SHO tonight! Haltech Automotive News 0 10-29-2009 02:50 PM
Page generated in 0.36091 seconds with 29 queries
