wrong. weight loss = get back to dating = see u never assholes = you're stuck with sub par humor:lew: |
When are you niggas gonna learn that drag racing this car is fucking worthless. |
i can never get enough of phil's dancing, shit never gets old............ ^^^ hahahah |
alright, well i did the standard de glazing procedure.... hold e brake, bring rpm above tq peak, release clutch pedal slowly until it starts dropping rpm and hold for about 10 seconds. this grinds off material from both clutch and flywheel without over heating because i immediately park the car. did this 3 times today, and then went out for 2 mild 30 mile drives. car is responding decently, i can drive at 20-25% throttle input in all gears and the car seems to hold the correct speed for the rpm. i will keep driving no more than 25% throttle for another 200 miles or so. once that is done , i will try again going more aggressively to see if it actually holds the gear under WOT conditions. not looking good...but ill know by end of week. i still dont think the clutch is gone, i think its super glazed and just cannot provide enough friction to hold peak torque.....if i let go of the clutch in first it still grabs at the same rate in low rpm.... so i have to believe it still has life. we ll see.... ill post results. |
fuck ACT |
hmmmmmmm i dont understand this, are you on the street disc or 6 puck? my OEM clutch never hated me at the track and ive made LOTS of passes at 400+ wtq. im also doing 4.5k launches on awd would is WAYYYYY worse for a clutch because you have no wheel slip to take some abuse off the clutch. when you say the ACT wont let you power shift, why arent you using FFS? glad to see you made some progress man but your slowly falling into dark lips territory haha. |
I plan on staying stock until the clutch will no longer engage in first gear... |
seriously josh, its up to u now to represent cali. cuz julio and i are stuck on slow. the only other good car will be roys cuz hes getting built. but i think slicks and BT on u would be epic win. |
??? wat about me?? what happened to julios car on the last run, did he poop off the coupler? |
nh he couldnt get into second gear..... im telling u...ACT clutches are dogshit. |
on the drive to carls j man, fuck, forget about exhaust drone that chatter is intense |
the noise is unbearable, why u think i sold him the trz tranny m. |
lol you guys are silly. I will come back from 1 year without my car and run a 12.9 on the k04 to save Cali Speeds. Dont worry. I have it all planned out. |
when you hitting up famoso? I',, be down to meet up, but can't run since fuel pump went bye bye :doh: |
| All times are GMT -7. The time now is 06:05 AM. |
