Vadim, did you also increased the capacity of the engine to 2.4l or more or it's still around 2261-2290cm3? Also, did you use pistons with the same compression ratio or you lowered it to 9 or even 8.5? |
stock capacity. pistons CP on 9.0 ratio + cometic gasket. so it was about 8.5 ratio later, now about 8.8. We've checked this. |
my virtualdyno month ago whp k=1. real size of wheel on road in dynamic, real weight. boost 1.8bar 3rd gear roll from 20kmph https://e-a.d-cd.net/8f0fc1cs-960.jpg 4gear after 3rd gear with shift no lift https://b-a.d-cd.net/108fc1cs-960.jpg boost 1bar to rmp on 3rd gear https://d-a.d-cd.net/7a7fc1cs-960.jpg max boost 1.8bar to rmp on 3rd gear https://d-a.d-cd.net/67fc1cs-960.jpg mass air flow on 3rd and 4th gears https://h-a.d-cd.net/f67fc1cs-960.jpg |
2-3gears of spinning till 130-140kmph, u can hear |
Good to see you're still as crazy as ever haha , great work. |
Gettin sideways with AWD. Nasty!!! Fuck the transfercase lol |
rarely I drift in summer time |
4 316 in intake mani 1 830 in pipe before throttle https://d-a.d-cd.net/ee0e872s-960.jpg https://b-a.d-cd.net/c10e872s-960.jpg |
Awesome stuff! But you have to know, that car is the dirtiest I've ever seen by all standards! :) |
thats tore up. i bet that was a scary sound when it blew. |
That is some epic transfer case carnage! |
updates ? :D |
I have some problems with 4wd and also some problems with money (sanctions and oil, u know)))) so for the first tests we'll use 4 nozzles, 312ml each. 5th is blocked. and only 3" intake, but then, if is OK, we'll use 4'' intake. https://b-a.d-cd.net/206e28as-960.jpg https://g-a.d-cd.net/4a6e28as-960.jpg https://b-a.d-cd.net/ea6e28as-960.jpg tuned manifold is too expensive so https://a-a.d-cd.net/334b28as-960.jpg https://b-a.d-cd.net/342b28as-960.jpg https://e-a.d-cd.net/d42b28as-960.jpg https://e-a.d-cd.net/532b28as-960.jpg https://f-a.d-cd.net/eb2b28as-960.jpg https://a-a.d-cd.net/2ce28as-960.jpg https://c-a.d-cd.net/5ece28as-960.jpg https://h-a.d-cd.net/61ce28as-960.jpg https://d-a.d-cd.net/9dce28as-960.jpg https://c-a.d-cd.net/4bce28as-960.jpg |
i love this dude no homo.. get sideways in AWD and makin shit happen!! |
fullweight (+140kg) boost 1.9b, need to retune 60ft https://c-a.d-cd.net/185d1cas-960.jpg 0-100kmph https://f-a.d-cd.net/445d1cas-960.jpg 0-100 now(red) and good lightweight (blue) https://h-a.d-cd.net/f9c31cas-960.jpg |
So did you remove the differential clutch and now run permanent awd or just replace it? |
He replaced it with something which looks a bit beefier... |
was https://g-a.d-cd.net/bd2abcas-960.jpg became https://g-a.d-cd.net/732abcas-960.jpg ignition was 500 0 1000 0 1500 0 2000 4 2500 8 3000 11 3500 14 4000 16 4500 18 5000 20 5500 21 6000 22 6500 22 7000 22 7500 22 8000 22 became 500 0 1000 0 1500 0 2000 3 2500 8 3000 9 3500 11 4000 13 4500 14 5000 16 5500 17 6000 18 6500 19 7000 19 7500 19 8000 19 test on light tune full weightcar https://e-a.d-cd.net/396abcas-960.jpg whp boost 1.85bar https://e-a.d-cd.net/536abcas-960.jpg going to 2.4bar of boost |
light test with kawa ninza 900cc 139hp i'm with passenger and failing on launch without passenger and good launch = victory) https://f-a.d-cd.net/81d65cas-960.jpg https://b-a.d-cd.net/41d65cas-960.jpg |
first vid was kinda shaky but still cool... keep it up |
Mazda MPS 6 GTX 3076 vs yamaha R6 150hp tuned https://b-a.d-cd.net/6e89fcas-960.jpg first run 11.0s 206kmph, low ignition(18-19) and low boost 1.9b https://pp.vk.me/c628620/v628620588/...zCsVnttH4o.jpg https://pp.vk.me/c628620/v628620588/...VKsqmIwcqg.jpg https://pp.vk.me/c628620/v628620588/...QhInu1gTgM.jpg https://pp.vk.me/c628620/v628620588/...2pHyvh5NEs.jpg https://pp.vk.me/c628620/v628620588/...UNc62a6o4k.jpg second run was with some my fails... 11.1s 203.4rmph reached him on finish https://pp.vk.me/c628620/v628620588/...fRzUXXLSHI.jpg https://pp.vk.me/c628620/v628620588/...3chJzJoM1w.jpg |
This run was less than 11s but Racelogic shows 10.96+ as 11s, and i pushed the brake before the finish((( https://pp.vk.me/c628620/v628620588/...pJnMD9GvWk.jpg https://pp.vk.me/c628620/v628620588/...NHlb9xG1xE.jpg https://pp.vk.me/c628620/v628620588/...krf_aWbwCM.jpg https://pp.vk.me/c628620/v628620588/...hcnlutnJWQ.jpg https://pp.vk.me/c628620/v628620588/...0EFf_JgvKc.jpg |
sweet vids yet again |
2-3-4 100-200 100,00 0 0,00 110,00 0,63 18,33 120,00 1,16 35,32 130,00 1,66 52,64 140,00 2,21 73,39 150,00 2,85 99,14 160,00 3,74 137,33 170,00 4,47 170,70 180,00 5,25 208,81 190,00 6,13 253,94 200,00 7,16 309,72 3-4 100,00 0 0,00 110,00 0,46 13,46 120,00 0,95 29,07 130,00 1,46 46,96 140,00 2,04 68,71 150,00 2,71 95,58 160,00 3,66 136,12 170,00 4,37 168,79 180,00 5,16 207,46 190,00 6,04 252,79 200,00 7,08 308,74 100,00 0 0,00 110,00 0,48 14,13 120,00 0,98 29,89 130,00 1,49 47,80 140,00 2,06 69,06 150,00 2,78 98,04 160,00 3,70 137,46 170,00 4,42 170,62 180,00 5,11 204,30 190,00 6,00 250,03 200,00 7,04 305,99 |
https://pp.vk.me/c629400/v629400447/...4aYGd310Qo.jpg https://pp.vk.me/c629400/v629400447/...IBRyNw9Iao.jpg https://pp.vk.me/c629400/v629400447/...YaLY3GIA4I.jpg https://pp.vk.me/c629400/v629400447/...U9LFcjY0rw.jpg https://pp.vk.me/c629400/v629400447/...RdLGf5JDh0.jpg https://pp.vk.me/c629400/v629400447/...vRYMxR8E28.jpg |
yesterday on two Racelogics . 4 nozzles 312 test https://c-a.d-cd.net/533342as-960.jpg https://a-a.d-cd.net/733342as-960.jpg https://c-a.d-cd.net/a73342as-960.jpg |
Why two racelogics? |
ign 18, boost 2.0-2.1bars, 85% meth and 4 312 nozzles and 1 900ml\min 1 km 20.8s 256.8kmph (160mph) . but 0-100 3.6s, too cold and VERY BAD start (u can compare 1gear and 2gear acceleration) 1\2 mile 18.0s и 244.4kmph (152mph). 1\4 mile only 11.5s and on 5gear https://g-a.d-cd.net/d81a9aas-960.jpg with rollout 0sm 1 0,00 0 0,00 1 10,00 0,24 0,44 1 20,00 0,65 2,10 1 30,00 1,08 5,09 1 40,00 1,43 8,48 1 50,00 1,78 12,95 1 60,00 2,10 17,73 1 70,00 2,68 27,79 1 80,00 2,99 34,26 1 90,00 3,34 42,61 1 100,00 3,76 53,55 1 110,00 4,51 75,76 1 120,00 5,04 92,54 1 130,00 5,53 109,69 1 140,00 6,09 130,69 1 150,00 6,74 156,71 1 160,00 7,84 204,13 1 170,00 8,53 235,98 1 180,00 9,29 272,84 1 190,00 10,16 317,41 1 200,00 11,96 415,52 1 210,00 13,06 477,81 1 220,00 14,26 549,47 1 230,00 15,63 635,50 1 240,00 17,32 745,79 1 250,00 19,36 884,72 1 256,58 21,00 1000,00 1 260,00 22,14 1082,28 |
I listened to all that videoclip, I can tell you were a bit sad but not mad because there was none of those words :) Weather is weather, and the results are still impressive. |
the result is not bad, but could be much better in good weather conditions. There was no aim in standing record. Just test 200+kmph dynamic. |
ign 18-19, 4nozzles 312+ 1 900ml\min meth 90% BOOST, MORE BOOST... https://e-a.d-cd.net/525cbaas-960.jpg 1 100,00 0 0,00 1 110,00 0,45 13,12 1 120,00 0,90 27,63 1 130,00 1,42 45,41 1 140,00 1,97 66,11 1 150,00 2,64 93,19 1 160,00 3,66 136,91 1 170,00 4,35 168,73 1 180,00 5,14 207,11 1 190,00 5,99 250,72 1 200,00 7,01 306,04 https://g-a.d-cd.net/985cbaas-960.jpg 1 100,00 0 0,00 1 110,00 0,43 12,56 1 120,00 0,88 26,85 1 130,00 1,37 43,89 1 140,00 1,92 64,70 1 150,00 2,56 90,57 1 160,00 3,49 130,26 1 170,00 4,12 159,11 1 180,00 4,82 193,17 1 190,00 5,62 234,14 1 200,00 6,56 285,37 https://d-a.d-cd.net/f89cbaas-960.jpg 1 100,00 0 0,00 1 110,00 0,40 11,54 1 120,00 0,81 24,94 1 130,00 1,28 41,00 1 140,00 1,79 60,31 1 150,00 2,42 85,47 1 160,00 3,40 127,71 1 170,00 4,03 156,53 1 180,00 4,72 190,02 1 190,00 5,50 230,12 1 200,00 6,43 280,50 |
Have you ever thought about getting a bigger turbo? |
why he already spanks everyone out there and is running fast |
woooo movin on the gtx3076... keep it up |
Man... are you using that car for plowing as well? :) At least now it has both bumpers on :) |
preparing for next season to run less 11s on telemetry. it's -15C degree now in Russia) |
some updates? |
2 mins ago) https://c-a.d-cd.net/b02b186s-960.jpg |
Oh wait, it has both front and rear bumpers! Nice mod ! :) |
Did you have any problems with the Sleeves in cylinder? |
If the sleeve was installed properly then you'll be fine. The weak part of these engines before the cylinder walls (or the sleeves in your case, assuming it's a good one) are the rods and pistons. Next time you open the engine just bore all cylinders and install some good sleeves in all of them (Darton?). |
Beautiful car! |
https://d-a.d-cd.net/2a63116s-960.jpg Honda CBR900 https://g-a.d-cd.net/1436d16s-960.jpg https://f-a.d-cd.net/36d16s-960.jpg https://a-a.d-cd.net/4936d16s-960.jpg https://e-a.d-cd.net/9276d16s-960.jpg BMW 1000RR newby biker 1st run i won, 2nd - he had falsestart https://h-a.d-cd.net/5136d16s-960.jpg https://a-a.d-cd.net/8536d16s-960.jpg https://e-a.d-cd.net/e236d16s-960.jpg ET+RT=11,509s RT=0,477s ET=11.032s 203.1 kmph https://pp.vk.me/c633730/v633730568/...jgFEhqNGck.jpg https://pp.vk.me/c633731/v633731568/...mQSq3tufmQ.jpg https://pp.vk.me/c633731/v633731568/...EJQoTo9NUo.jpg next time i'll try to beat 11s. |
Fuckin Sik!!! Sent from my SM-G930V using Tapatalk |
| All times are GMT -7. The time now is 05:47 AM. |
