![]() | | #201 | ![]() |
Groans: 111
| Not Ranked : 0 score
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI |
![]() | | #202 | ![]() |
![]() Join Date: Oct 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 66
(Thread Starter) | Not Ranked : 0 score stock capacity. pistons CP on 9.0 ratio + cometic gasket. so it was about 8.5 ratio later, now about 8.8. We've checked this. |
| The Following User Says Thank You to Vadim aka ScooteR For This Useful Post: | mituc (10-30-2014) |
![]() | | #203 | ![]() |
(Thread Starter) | Not Ranked : 0 score my virtualdyno month ago whp k=1. real size of wheel on road in dynamic, real weight. boost 1.8bar 3rd gear roll from 20kmph ![]() 4gear after 3rd gear with shift no lift ![]() boost 1bar to rmp on 3rd gear ![]() max boost 1.8bar to rmp on 3rd gear ![]() mass air flow on 3rd and 4th gears Last edited by Vadim aka ScooteR; 11-25-2014 at 01:02 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #204 | ![]() |
(Thread Starter) | Not Ranked : 0 score 2-3gears of spinning till 130-140kmph, u can hear Last edited by Vadim aka ScooteR; 12-05-2014 at 12:47 AM. |
| The Following 6 Users Say Thank You to Vadim aka ScooteR For This Useful Post: | atvfreek (12-10-2014), mituc (12-05-2014), MSP611 (09-15-2015), RE-ACTIONENGSPEED3 (12-05-2014), shaneski (12-05-2014), SpeedRebirth (12-06-2014) |
![]() | | #205 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Good to see you're still as crazy as ever haha , great work.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
| The Following User Says Thank You to shaneski For This Useful Post: | Vadim aka ScooteR (12-05-2014) |
![]() | | #206 | ![]() |
| The Following User Says Thank You to Vadim aka ScooteR For This Useful Post: | mituc (12-06-2014) |
![]() | | #207 | ![]() |
Groans: 111
| Not Ranked : 0 score ...And you're saying this after racing on ice!
![]() | | #208 | ![]() |
![]() | | #209 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score Gettin sideways with AWD. Nasty!!! Fuck the transfercase lol
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
![]() | | #210 | ![]() |
(Thread Starter) | Not Ranked : 0 score it was rather cold , about -8C. rarely I drift in summer time |
| The Following 4 Users Say Thank You to Vadim aka ScooteR For This Useful Post: |
![]() | | #211 | ![]() |
| The Following User Says Thank You to Vadim aka ScooteR For This Useful Post: | cocoanton (01-08-2015) |
![]() | | #212 | ![]() |
| The Following 6 Users Say Thank You to Vadim aka ScooteR For This Useful Post: | Hammology (07-15-2015), Mauro_Penguin (07-15-2015), mituc (07-16-2015), mxlplx71 (07-15-2015), RE-ACTIONENGSPEED3 (07-15-2015), Rich990 (08-11-2015) |
![]() | | #213 | ![]() |
Groans: 111
| Not Ranked : 0 score Awesome stuff! But you have to know, that car is the dirtiest I've ever seen by all standards!
![]() | | #214 | ![]() |
![]() | | #215 | ![]() |
(Thread Starter) | Not Ranked : 0 score ![]() before tunning ![]() ![]() ![]() getting engine out for changing transferbox and clutch ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() another surprice!) ![]() ![]() ![]() ![]() |
![]() | | #216 | ![]() |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score thats tore up. i bet that was a scary sound when it blew.
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
| The Following User Says Thank You to mxlplx71 For This Useful Post: | Vansquish (07-31-2015) |
![]() | | #217 | ![]() |
![]() Join Date: Jul 2013 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,661
Groans: 36
| Not Ranked : 0 score That is some epic transfer case carnage!
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port |
![]() | | #218 | ![]() |
![]() Join Date: Feb 2013 Location: Anchorage AK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
Groaned at 9 Times in 4 Posts
| Not Ranked : 0 score updates ?
__________________ YEEMARKS SP63 Built Engine. 5858. Meth. Old Time in S3: 12.4 @ 111 Parts needed to install: JMF, HTP 4.0", HKS BOV |
![]() | | #219 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have some problems with 4wd and also some problems with money (sanctions and oil, u know)))) so for the first tests we'll use 4 nozzles, 312ml each. 5th is blocked. and only 3" intake, but then, if is OK, we'll use 4'' intake. ![]() ![]() ![]() tuned manifold is too expensive so ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Vadim aka ScooteR; 09-07-2015 at 05:50 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Vadim aka ScooteR For This Useful Post: | mituc (09-07-2015) |
![]() | | #220 | ![]() |
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,687
Groans: 33
| Not Ranked : 0 score Looks like you need to get the nozzles a bit further down into the manifold runner or it could destroy the spray pattern if it hits the walls of the hole before entering the runner. The meth could form drops and that is not good for the combustion
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi |
| The Following User Says Thank You to SpeedRebirth For This Useful Post: | BLKSTIG (09-07-2015) |
![]() | | #221 | ![]() |
(Thread Starter) | Not Ranked : 0 score we'll test, but now it looks fine. Later we'll raise the boost. |
![]() | | #222 | ![]() |
Groans: 33
| Not Ranked : 0 score Test the spay with the manifold off, if the spray is anywhere near the walls of the hole it could be pushed into the wall once the air flows quickly through the runners (boosting)
![]() | | #223 | ![]() |
| The Following User Says Thank You to Vadim aka ScooteR For This Useful Post: | mxlplx71 (09-15-2015) |
![]() | | #224 | ![]() |
| Not Ranked : 0 score i love this dude no homo.. get sideways in AWD and makin shit happen!!
![]() | | #225 | ![]() |
(Thread Starter) | Not Ranked : 0 score fullweight (+140kg) boost 1.9b, need to retune 60ft ![]() 0-100kmph ![]() 0-100 now(red) and good lightweight (blue) |
![]() | | #226 | ![]() |
![]() Join Date: May 2010 Location: Stockholm, Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 646
| Not Ranked : 0 score So did you remove the differential clutch and now run permanent awd or just replace it? |
![]() | | #227 | ![]() |
Groans: 111
| Not Ranked : 0 score He replaced it with something which looks a bit beefier...
![]() | | #228 | ![]() |
![]() | | #229 | ![]() |
(Thread Starter) | Not Ranked : 0 score was ![]() became ![]() ignition was 500 0 1000 0 1500 0 2000 4 2500 8 3000 11 3500 14 4000 16 4500 18 5000 20 5500 21 6000 22 6500 22 7000 22 7500 22 8000 22 became 500 0 1000 0 1500 0 2000 3 2500 8 3000 9 3500 11 4000 13 4500 14 5000 16 5500 17 6000 18 6500 19 7000 19 7500 19 8000 19 test on light tune full weightcar ![]() whp boost 1.85bar ![]() going to 2.4bar of boost |
| The Following User Says Thank You to Vadim aka ScooteR For This Useful Post: | SpeedRebirth (09-19-2015) |
![]() | | #230 | ![]() |
(Thread Starter) | Not Ranked : 0 score light test with kawa ninza 900cc 139hp i'm with passenger and failing on launch without passenger and good launch = victory) ![]() |
| The Following 2 Users Say Thank You to Vadim aka ScooteR For This Useful Post: | mituc (09-19-2015), SpeedRebirth (09-19-2015) |
![]() | | #231 | ![]() |
| Not Ranked : 0 score first vid was kinda shaky but still cool... keep it up
![]() | | #232 | ![]() |
(Thread Starter) | Not Ranked : 0 score Mazda MPS 6 GTX 3076 vs yamaha R6 150hp tuned ![]() first run 11.0s 206kmph, low ignition(18-19) and low boost 1.9b ![]() ![]() ![]() ![]() ![]() second run was with some my fails... 11.1s 203.4rmph reached him on finish ![]() |
![]() | | #233 | ![]() |
(Thread Starter) | Not Ranked : 0 score This run was less than 11s but Racelogic shows 10.96+ as 11s, and i pushed the brake before the finish((( ![]() ![]() ![]() ![]() Last edited by Vadim aka ScooteR; 09-20-2015 at 10:22 PM. |
| The Following User Says Thank You to Vadim aka ScooteR For This Useful Post: | Hammology (09-21-2015) |
![]() | | #234 | ![]() |
(Thread Starter) | Not Ranked : 0 score 100-200kmph 3-4gears 1) ![]() ![]() ![]() 2) |
![]() | | #235 | ![]() |
| Not Ranked : 0 score sweet vids yet again
![]() | | #236 | ![]() |
(Thread Starter) | Not Ranked : 0 score 2-3-4 100-200 100,00 0 0,00 110,00 0,63 18,33 120,00 1,16 35,32 130,00 1,66 52,64 140,00 2,21 73,39 150,00 2,85 99,14 160,00 3,74 137,33 170,00 4,47 170,70 180,00 5,25 208,81 190,00 6,13 253,94 200,00 7,16 309,72 3-4 100,00 0 0,00 110,00 0,46 13,46 120,00 0,95 29,07 130,00 1,46 46,96 140,00 2,04 68,71 150,00 2,71 95,58 160,00 3,66 136,12 170,00 4,37 168,79 180,00 5,16 207,46 190,00 6,04 252,79 200,00 7,08 308,74 100,00 0 0,00 110,00 0,48 14,13 120,00 0,98 29,89 130,00 1,49 47,80 140,00 2,06 69,06 150,00 2,78 98,04 160,00 3,70 137,46 170,00 4,42 170,62 180,00 5,11 204,30 190,00 6,00 250,03 200,00 7,04 305,99 |
| The Following 2 Users Say Thank You to Vadim aka ScooteR For This Useful Post: | mituc (09-22-2015), RE-ACTIONENGSPEED3 (09-21-2015) |
![]() | | #237 | ![]() |
| The Following User Says Thank You to Vadim aka ScooteR For This Useful Post: | mituc (09-22-2015) |
![]() | | #238 | ![]() |
(Thread Starter) | Not Ranked : 0 score ![]() ![]() ![]() ![]() ![]() |
![]() | | #239 | ![]() |
| The Following 3 Users Say Thank You to Vadim aka ScooteR For This Useful Post: |
![]() | | #240 | ![]() |
(Thread Starter) | Not Ranked : 0 score yesterday on two Racelogics . 4 nozzles 312 test ![]() ![]() |
| The Following User Says Thank You to Vadim aka ScooteR For This Useful Post: | SpeedRebirth (09-23-2015) |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f232/mazda-6-mps-gtx3076-1-06-tial-157068/ | ||||
| ?????? | This thread | Refback | 08-29-2014 03:06 AM | |
| Mazda 6 MPS GTX3076 - ???????? 483 - 500+ ??? - ??????-???? | This thread | Refback | 07-02-2014 04:22 AM | |
| HGP Golf R 3.6 (Miker) vs Evo GTX3076 (Matrox) - ???????? 14 - 500+ ??? - ??????-???? | This thread | Refback | 03-18-2014 04:54 AM | |
| Articole interesante despre masini - Pagina 24 - Cafenea - Club Mazda | This thread | Refback | 01-18-2014 03:13 AM | |
| Mazda 6 MPS GTX3076 1.06 tial | Vadim aka ScooteR | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 4 | 10-15-2013 12:51 AM |
| PABLO Built, PERM Tuned, GTX3076 Motor | beno72 | 2010 MS3 - Big Turbo Builds | 2 | 03-13-2013 01:36 PM |
| Mazda MX-5 Miata gets Black Tuned for Japan | Haltech | Automotive News | 3 | 10-10-2011 10:25 AM |
| Mazda spped3 cobb tuned. | Japtrix | MazdaSpeed 3/6 - ECU Computer Tuning | 26 | 07-25-2009 11:14 AM |
