-   -   MS3 13.1 @ 103 w/ DP, I, and DR's (http://www.mazdaspeedforums.org/forum/f232/mazdaspeed-3-13-1-103-w-downpipe-24019/)
oneslowxa 04-02-2009 09:29 AM
how many 1.9 passes did you cut? I feel that the ms3's clutch starts to smell at anything around 2.1x's or better...
MGMSIII 04-02-2009 11:37 AM
I had 3 passes in the 1.9's. 1.95,1.95 and 1.91. Clutch wasnt bad that night at all bc I wasnt slipping it that much due to the DR's.
MGMSIII 04-03-2009 07:58 PM
Well got the WOT box hooked up and works great and had the DR's mounted and ready to go and as I pulled in the track it started pouring so no go on gettin 12's. Maybe next week...
ms3jake 04-03-2009 08:44 PM
Bummer
sleeper3 04-28-2009 03:00 PM
dude let me know when you plan to go next! I will join you. It will be nice to have another respectable MS3 out there!
psi 05-14-2009 07:52 AM
Originally Posted by Decepticon (Post 187053)
nice...i think that maybe the fastest time with intake/downpipe/dr's only...
FMOS racing ran 12.9 with just a CAI/MM/DR's. But these times are still very good.
It just shows the best mod to this car is a good driver.
psi 05-14-2009 08:03 AM
Originally Posted by MGMSIII (Post 187235)
Yea I flatshifted on all my runs and best launch was about 3500 slipping the clutch briefly-basically almost a clutch dump. I shifted between 5500-5700.
I thought the numbers looked a little high too but my previous best with just intake and mm on stock tires was 13.7 @ 105 so the track times seem to prove the dyno #'s. Freak car I guess :eek5:
I think your high trap speeds are indicative of flat shifting more than a "freak" car. Flat shifting will increase your trap speeds and decrease ET's everytime.
Also, the high dyno numbers don't mean much without knowing other information about the dyno, correction factors, etc.
No doubt your car is putting out a lot of horsepower for your mods, but I wil say it again with this car, DR's or better and a good driver are the two most important things to running fast ET's.
I see a lot of people throw tons of mods at their car, still run street tires, and and can't get near these times you are running.
ms3jake 05-14-2009 08:06 AM
Yup, lol when he goes against that 9.0sec car, his ms3 looks slow. Traction is the worst enemy for this car. Imagine if he had a bigger turbo...
802MS3 05-14-2009 08:15 AM
^^damn! thats crazy. he should come over here and start a thread.
I wonder if he only has the rear MM, because I would think he'd snap his trans mount doing launches like that.
psi 05-14-2009 04:20 PM
I read a thread over on 247 where he explained his techniques in more detail. He runs FD RX-7 wheels, MT or Hoosier 225/50/16 DR's, powershifts the whole way. He only has an Injen CAI/ and rear motor mount, not sure what type or durometer though.
To pre-stage, he puts it in 2nd gear, bounces it off the rev-limiter and dumps the clutch to heat up the DR's. From there, he just goes on experience because he has been racing for like 20 years or something. He said he launches around 3 slipping the clutch.
That's all I remember from his post from 247, I'll try to dig it up and post everything he wrote if anyone is interested.
ms3jake 05-14-2009 06:43 PM
Sounds abusive but impressive none the less .
DaleNixon 05-14-2009 08:44 PM
Pretty much drag racing summed up right there, no?
SpdFreak 05-14-2009 09:46 PM
YouTube - Bolt-on Mazdaspeed 3 doing IRP
His tires allow him to use the torque this little car produces.
I wounder if he's doing this all on stock shifter bushings.
clos561 05-15-2009 10:48 AM
fds r the way to go(i have them), cheap and some of the lightest rims u can find (13lbs).
nice times btw
AK-speeder 05-20-2009 11:38 AM
Originally Posted by MGMSIII (Post 187037)
You talking about the side mounts? I check them every time I have the car on the lift but yea Ive read all the horror stories. If this is what your talking about which ones do you recommend?
I am also going to try out the WOT box and the correct tire press sometime next week to hopefully crack 12's.
man im thinkin about full motor mount set up with drag radials now...im one of maybe 3 speed 3's in alaska racing an i only have 3 events all summer were i live then have to drive 460miles to my nearest track...so hopefully i will be able to keep up with you in times by the end of summer on minimal mods...im runnin 13.7 @ 100.23mph dumping at 2900-3000 rpm on MSCAI and SU rear MM on stock clutch w/ 24kmiles and 30+ passes and original tires that came on the car when purchased with 17 miles...
Mike Bove 05-30-2009 05:03 PM
I think an aftermarket tranny clutch is a must if you're going to be racing a lot. It really makes a difference.
FMOS needs to add some more mods, I want to see him running low 12's!
94jedi 05-30-2009 08:52 PM
screw this...I"m getting a set of FD RX-7 wheels. anyone know the cheapest place to find them?
and who has the best pricing on some hoosier or nitto dr's?
1mpg 06-01-2009 05:51 PM
I got my 555Rs for under $300, heat cycled too! I put mine on Mustang wheels. We will see what happens soon!
1mpg 06-27-2009 04:55 PM
No good times yet, same as before...I dont think I am heating up my tires enough. Is it safe to start the burn out in second gear? how long should I redline this shit for? I redline in first for about 5 seconds before I go, and it does nothing impressive. And only launching at 3K seems low, but I guess I will try it again. Otherwise these will be on sale after next track day. I cant afford new trannies, clutches and axles.
sleeper3 06-29-2009 06:03 AM
lol
If at first you don't succeed, give up!
Torque South 07-22-2009 01:12 PM
good job very impressive
tomspeed 08-09-2009 06:18 PM
thats some quick times
Page generated in 0.21364 seconds with 11 queries
