Autosports Area
> Drag Racing
Like Tree42Likes
 Old 10-09-2011, 05:15 PM   #1
driver311's Avatar
Posts: 1,769   (View Stats)
driver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the world
Default The quest is over! 11.7@119
Well boys and girls what I have been fighting for, for two years has finally happened. Mods to car are fully bolted with atp gtx3071r compliments of mark at streetunit and running 4g e85 to 8g of pump. Self tuned by me with help from the one and only DJ. Boost was 21-22psi on all runs. First run was at 21psi with 17 degrees peak timing. Car ran 11.9@116. Fuck ya I was pumped. Next pass I went 22psi and rocked down a 11.8@117. OMG i was beyond happy. Then I decided to take timing from 17 to 18.5 peak. Adding roughly 1-2 from 4000-7000. The car liked it going 11.8@118. Let the car cool down for an hour took another shot at it and knocked down a 11.7@119. All in all Im very very happy with this setup. Car never seen over 22psi today and it loved the added timing. Going from 15-18.5 degrees changed the car. I still havent even pushed my setup. The gtx3071 pulled so hard up top. I love this turbo. More to come hopefully by end of month Ill try to get back out on 24psi and some oxygenated gas. I still have one more goal. GEt the car booted from the track.
Mods
Atp gtx3071 iwg 14psi spring
dnp exhaust mani ceramic coated
atp dp
high flow cat
cs 80mm exhaust
atp 3in intake
cpe inlet
ptp cdfp
Cobb Ap Tuned on 40% e85
txs fmic
ts 50/50 bov
ported intake mani with vtcs delete
itv22 plugs
matt damon catch can w/cv
ptp egr delete
breater filter on vc
ptp intake mani gasket
coolant bypass on tb
Stock clutch 60k miles
stock motor 5k miles
stock axles 60k miles
stock motor mounts with rear one urethane filled
This car is pretty stout and I have raced this car more than any two members. I have over 150 dyno pulls on it, probably 50 pulls down the track, lots of hard autocross, time attacks and hillclimbs. Not counting the hundreds of freeway logs Ive taken. This car has been through the ringer and runs kick ass. Im very impressed with what mazda did with this car.
2008 Mazdaspeed3, Fully built then fully parted. Sold
2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily
Mazdaspeed
12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp
11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp
driver311 is offline   Reply With Quote
The Following 200 Users Say Thank You to driver311 For This Useful Post:
-cj- (10-11-2011), 09Speed3Z (10-15-2011), 11cruzito11 (10-10-2011), 2k4_8 (10-10-2011), 4G63 (10-09-2011), 801MS3 (10-09-2011), 802MS3 (10-09-2011), 86AmishMs3 (10-09-2011), adlpb (10-10-2011), AJ713 (10-10-2011), alien_sporez (10-10-2011), Alpha (10-10-2011), alphasaur (10-15-2011), ArcticSpeed3 (10-10-2011), ARES28 (10-10-2011), asall667 (10-09-2011), atvfreek (10-09-2011), austin102085 (10-25-2011), AZRushki (11-04-2011), AZSPEED3 (10-09-2011), banditscout (10-16-2011), BeastMS3 (10-10-2011), BeeZaa (10-20-2011), BigJimMs3 (10-10-2011), BigjohnB20 (10-10-2011), Black Metal (10-09-2011), Blackspeed (10-10-2011), BlueStreak (10-09-2011), bms3mtb (12-26-2011), bmylez (10-14-2011), BobbleHead (10-09-2011), Boost Addict (10-09-2011), Boosted Beluga (10-10-2011), breakfstincluded (10-10-2011), Broxer (10-10-2011), burntRice (11-11-2011), bwspeed (10-09-2011), Caboose (10-10-2011), Cataphract_40 (10-09-2011), Chief_Wiggum (10-10-2011), Chriscote (10-09-2011), CJM (06-07-2012), Ckmazdaspeed3 (10-10-2011), cld12pk2go (10-09-2011), crazyp (10-09-2011), daafisch (10-10-2011), Dahouse702 (10-10-2011), Darksun280 (10-09-2011), Dash08 (10-15-2011), Decepticon (10-09-2011), DingoDave (10-09-2011), DISIindahead (10-10-2011), dizwhoadayjohn (10-09-2011), dizzydtrain (10-09-2011), djthom (10-09-2011), djuosnteisn (10-10-2011), Docnox (11-18-2011), DONOTBUGME (10-09-2011), doubleflusher (10-09-2011), dr_banano (10-10-2011), Easter Bunny (10-09-2011), ELiTeNeSs (10-17-2011), emag remrofni (10-10-2011), Erich (10-09-2011), essejkcamraw (10-09-2011), Evan@COBB (10-10-2011), EwMPS (11-12-2011), Fatguy729 (10-10-2011), Ferg (10-17-2011), FightaX (10-17-2011), Fobio (10-09-2011), frodaddyweez (10-09-2011), GLORIFIEDBOZO (10-18-2011), GODO (02-01-2012), gtlaw (12-06-2011), Hamilton69 (10-09-2011), harryclay (10-11-2011), Hectik1 (10-10-2011), helmetface (10-09-2011), hyun (10-10-2011), i8urgti (10-11-2011), Ihatefwd (10-16-2011), ilyams3 (10-09-2011), IshiKage (10-14-2011), J-Liss (10-09-2011), JacksonMS30 (10-10-2011), Jeremy M (10-09-2011), jlink38 (10-13-2011), josurr (10-10-2011), jracer (10-10-2011), Jsn_Rob (01-06-2012), JTMS3 (10-09-2011), kabobulate (10-09-2011), kgb (11-19-2011), kmac (10-09-2011), kngeducate (10-09-2011), Kydizzle (10-09-2011), Lex (10-10-2011), LiEast (10-11-2011), ljudgeii (10-10-2011), m4tic (10-09-2011), maisonvi (10-09-2011), manelscout4life (10-10-2011), Manny (10-13-2011), MarkyMark (10-11-2011), Mase (10-13-2011), mason (10-16-2011), mazda.speed3 (10-13-2011), MazdaGaragePat (10-10-2011), mazdamx3freak (10-10-2011), Meder (10-09-2011), MGM_GT3 (12-26-2011), mituc (10-16-2011), Monotonous ONE (10-14-2011), MS3-a(sore)ASS-rex (10-10-2011), ms3bamf (10-09-2011), MSFer87 (10-09-2011), mtnrunner (10-10-2011), MurderedOutMS3 (10-17-2011), mzr0818 (10-10-2011), Nataphen (11-18-2011), Nazarite (10-10-2011), Neverlift (10-10-2011), nighthawk358 (10-12-2011), nindoja (10-09-2011), NJSPEED3 (10-09-2011), NoRegrets (10-13-2011), Novej (10-11-2011), Ntahndagirl (10-09-2011), paulfitipauldi (01-29-2012), Pendarus (10-09-2011), phate (01-09-2012), Phoenix Speed3 (01-17-2012), Post pwned (10-09-2011), predapio (10-10-2011), Pu Manchu (10-17-2011), qtrmile beast (10-11-2011), QwkEVO (12-27-2011), Raider (10-09-2011), Realgib3 (10-10-2011), RedBliss (11-04-2011), redmnsterut (10-27-2011), rfinkle2 (10-09-2011), rghispanic88 (10-09-2011), RhoadBlock (11-04-2011), RichieRichness (10-13-2011), ridenfish39 (10-10-2011), rigor (10-11-2011), Roddiy (10-16-2011), ruthless013 (11-02-2011), Sacrilicious (10-09-2011), ScarMS3 (10-09-2011), Scribbles (10-11-2011), shawn. (10-09-2011), silvapain (10-09-2011), slo4now (10-10-2011), SLOWHATCH (10-09-2011), snailD (10-09-2011), Snyeed (10-09-2011), speed14 (11-02-2011), speed23 (10-09-2011), SpeedNess (10-13-2011), SpeedSixxx (10-14-2011), SpeedyTater (10-12-2011), Spirry (10-10-2011), stang9779 (10-10-2011), stokes620 (10-09-2011), stp (10-10-2011), superskaterxes (10-10-2011), super_pablo_ (10-09-2011), surebOOst (10-11-2011), Swagerwagon03 (10-10-2011), symkaz (10-09-2011), tbot (10-10-2011), tddvrrn (10-09-2011), Teethkikr (10-09-2011), TexasSpeed3 (10-14-2011), TheHitman (11-07-2011), themytb (10-11-2011), TheStig1989 (10-16-2011), titusdrake (11-04-2011), tman (10-12-2011), Tokay444 (10-09-2011), tomek_46 (10-15-2011), trf5000 (10-10-2011), triplejumper18 (10-09-2011), TurboDreams (10-09-2011), uncorked11 (12-11-2011), Vader (10-11-2011), WAHBAM (10-10-2011), wankular (10-10-2011), warlord (10-10-2011), wette460 (10-10-2011), Whiteboy (10-13-2011), whoosh@Realtune (10-10-2011), wolly6973 (10-11-2011), xdm88 (10-17-2011), xhymer (10-09-2011), zlatan (10-09-2011), _Toxic_ (10-17-2011)
 Old 10-09-2011, 05:18 PM   #2
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
DONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the world
Groans: 266
Groaned at 83 Times in 60 Posts
congrats, did you by chance get video?
Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next.
DONOTBUGME is offline   Reply With Quote
 Old 10-09-2011, 05:18 PM   #3
driver311's Avatar
Sorry here it is rotated.
crazyp likes this.
Mazdaspeed
The Following 3 Users Say Thank You to driver311 For This Useful Post:
Boosted Beluga (10-10-2011), crazyp (10-09-2011), Fatguy729 (10-10-2011)
 Old 10-09-2011, 05:18 PM   #4
driver311's Avatar
yes Ill post it soon.
Mazdaspeed
The Following 4 Users Say Thank You to driver311 For This Useful Post:
DONOTBUGME (10-09-2011), helmetface (10-09-2011), Meder (10-09-2011), MS3-a(sore)ASS-rex (10-10-2011)
 Old 10-09-2011, 05:19 PM   #5
swampthigger's Avatar
Posts: 328   (View Stats)
swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger
Groaned at 83 Times in 28 Posts
Congrats brotha!!
swampthigger is offline   Reply With Quote
 Old 10-09-2011, 05:28 PM   #6
JLee1469's Avatar
Posts: 1,195   (View Stats)
JLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the world
Sick times, was the car about to take off without the wing?
JLee1469 is offline   Reply With Quote
The Following User Says Thank You to JLee1469 For This Useful Post:
 Old 10-09-2011, 05:31 PM   #7
crazyp's Avatar
Posts: 1,093   (View Stats)
crazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the worldcrazyp is the leader of the world
Groans: 68
Groaned at 22 Times in 9 Posts
in for vids! awsome job
2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC
crazyp is offline   Reply With Quote
 Old 10-09-2011, 05:34 PM   #8
symkaz's Avatar
Posts: 124   (View Stats)
symkaz has a reputation beyond reputesymkaz has a reputation beyond reputesymkaz has a reputation beyond reputesymkaz has a reputation beyond reputesymkaz has a reputation beyond reputesymkaz has a reputation beyond reputesymkaz has a reputation beyond reputesymkaz has a reputation beyond reputesymkaz has a reputation beyond reputesymkaz has a reputation beyond reputesymkaz has a reputation beyond repute
Groaned at 3 Times in 1 Post
Nice!!
symkaz is offline   Reply With Quote
 Old 10-09-2011, 05:34 PM   #9
ScarMS3's Avatar
Posts: 2,088   (View Stats)
ScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the world
Groans: 97
Groaned at 31 Times in 25 Posts
Good work, 10's next right? Or are you going to part out now?
ScarMS3 is offline   Reply With Quote
The Following 4 Users Say Thank You to ScarMS3 For This Useful Post:
Black Metal (10-09-2011), helmetface (10-09-2011), MicaBlackMS6 (10-16-2011), silvapain (10-09-2011)
 Old 10-09-2011, 05:35 PM   #10
Wolfgang5884's Avatar
Posts: 236   (View Stats)
Wolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond repute
damn, you're lucky. when I lived in Jersey, they would boot anyone running less than 12s that didn't have a full roll cage and other safety requirements.
Wolfgang5884 is offline   Reply With Quote
 Old 10-09-2011, 05:37 PM   #11
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Groaned at 64 Times in 49 Posts
Woo hoo congrats man!
Payne Racing 67 is offline   Reply With Quote
 Old 10-09-2011, 05:48 PM   #12
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Awesome, so happy that it was a MS3 first to 11's in America. Keep up the good work.
 Old 10-09-2011, 06:03 PM   #13
maisonvi's Avatar
Posts: 3,490   (View Stats)
maisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the world
Groans: 75
Awesome! Subbed for the vid!
Franken Turbo, built motor, meth.
DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more.
"Your signature should just say, I'm the shit." -LynzeC
maisonvi is offline   Reply With Quote
 Old 10-09-2011, 06:03 PM   #14
driver311's Avatar
Im super happy with this setup. In my eyes the gt3071 is the best option for this car. I really like the smaller back half and this just proves there is no need to spend all that money on ewg setups. This is a bolt on atp turbo. How simple can it get. Im fully bolted and only on 22psi. Thats just great. No crazy setup here just good driving and the right parts. Anyone can have this setup from the shelf. Afrs were at 11.9 also.
Mazdaspeed
The Following 14 Users Say Thank You to driver311 For This Useful Post:
802MS3 (10-09-2011), AJ713 (10-10-2011), Alpha (10-10-2011), AZSPEED3 (10-09-2011), daafisch (10-10-2011), Darksun280 (10-09-2011), Decepticon (10-09-2011), DingoDave (10-09-2011), jracer (10-11-2011), Post pwned (10-09-2011), predapio (10-10-2011), Pu Manchu (10-17-2011), SpeedSixxx (10-14-2011), stang9779 (10-10-2011)
 Old 10-09-2011, 06:09 PM   #15
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
NOICE, what was your tire setup?
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
 Old 10-09-2011, 06:11 PM   #16
Post pwned's Avatar
Posts: 799   (View Stats)
Post pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the world
Groans: 52
Groaned at 16 Times in 12 Posts
Very nice man!!
2010 Mica Black
RMM/RSB/SRI+TIP
Post pwned is offline   Reply With Quote
 Old 10-09-2011, 06:16 PM   #17
driver311's Avatar
I had h&r 1.25 spacers in front with raceline 15x7.5 wheels wrapped in toyo 25x9x15 slicks!
I cut consistant 1.7 60fts and ran 11.5-12.5 pressure in them. I thought about next time i go out running 18psi in them for one pass to get my 120 trap. I know the car has it, especially on 1-2psi more.
Mazdaspeed
phate (11-27-2011), Phoenix Speed3 (02-22-2012), Raider (10-09-2011)
 Old 10-09-2011, 06:18 PM   #18
Rustysocket's Avatar
Posts: 263   (View Stats)
Rustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the worldRustysocket is the leader of the world
Subscribed for vids. Nice runs
2011 MS3 Liquid Silver with Tech Package - Corksport SRI // TRZ RMM
Ethanol Free Fuel database - http://pure-gas.org/
Rustysocket is offline   Reply With Quote
 Old 10-09-2011, 06:20 PM   #19
Posts: 20,650   (View Stats)
Groans: 1,443
Congrats!
I knew you'd be the first to do it.
Beanfab / Tuned by Nishan
 Old 10-09-2011, 06:23 PM   #20
tuners's Avatar
Posts: 114   (View Stats)
tuners is a splendid one to beholdtuners is a splendid one to beholdtuners is a splendid one to beholdtuners is a splendid one to beholdtuners is a splendid one to beholdtuners is a splendid one to behold
Excellent work
Mazdaspeed CAI & CBE // UR test pipe // ETS TMIC // Corksport MM // OZ Ultraleggeras // Bridgestone 235/40/18's // Cobb springs // Koni yellows // TWM shifter bushings // Hotchkiss swaybars // Defi boost gauge w/Mearcat pod // Cobb AP // Cobb turbo inlet // HKS SSQV // PTP fuel pump internals // Denso plugs
tuners is offline   Reply With Quote
 Old 10-09-2011, 06:26 PM   #21
driver311's Avatar
Congrats!
Thanks for having faith brotha
Mazdaspeed
 Old 10-09-2011, 06:26 PM   #22
BrianB6's Avatar
Posts: 400   (View Stats)
BrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the world
Groans: 28
way to go man, very consistent times
taking off spoiler = win
2016 - WRX -Cobb AP - Perrin Shift Stop - Perrin Trans Mount - Whiteline Positive Shift Bushings
2006 - MS6 - Dead RIP
BrianB6 is offline   Reply With Quote
 Old 10-09-2011, 06:27 PM   #23
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
I want video!
Great stuff man, super siked for ya!
 Old 10-09-2011, 06:28 PM   #24
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
gj, man...it's good to finally see someone in the 11s!
 Old 10-09-2011, 06:34 PM   #25
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
Carry on citizens....
10.7 @ 133 auto 1G DSM
The Following 18 Users Say Thank You to Darksun280 For This Useful Post:
AJ713 (10-10-2011), atvfreek (10-09-2011), Ckmazdaspeed3 (10-10-2011), crazyp (10-09-2011), emag remrofni (10-10-2011), Ferg (10-17-2011), JacksonMS30 (10-10-2011), josurr (10-10-2011), MS3-a(sore)ASS-rex (10-10-2011), Neverlift (10-10-2011), nighthawk358 (10-12-2011), Post pwned (10-09-2011), predapio (10-10-2011), Pu Manchu (10-17-2011), ScarMS3 (10-10-2011), SLOWHATCH (10-09-2011), SpeedSixxx (10-14-2011), TheHitman (11-07-2011)
 Old 10-09-2011, 06:39 PM   #26
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Excellent. Congrats.
In b4 everyone starts taking off their spoilers / wing
The Following 3 Users Say Thank You to SLOWHATCH For This Useful Post:
DingoDave (10-09-2011), GoSpeed3Go (10-09-2011), SpeedSixxx (10-14-2011)
 Old 10-09-2011, 06:39 PM   #27
kabobulate's Avatar
Posts: 1,146   (View Stats)
kabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the world
Excellent!
I gotta say... if you didn't have slips I would call you a damn liar for saying that taking your wing off added 1.5mph to your trap. Good job!
2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe, TMM Inserts | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR SSB, EGR Plate
2008 Silver MS3: Sold
kabobulate is offline   Reply With Quote
The Following User Says Thank You to kabobulate For This Useful Post:
 Old 10-09-2011, 06:42 PM   #28
Ranyard's Avatar
Posts: 146   (View Stats)
Ranyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond reputeRanyard has a reputation beyond repute
thats awsome! Nice job!
"The eagle never lost so much time as when he submitted to learn from the crow" ...nobody
Ranyard is offline   Reply With Quote
 Old 10-09-2011, 06:43 PM   #29
atvfreek's Avatar
Posts: 7,787   (View Stats)
Epic win man, Congrats! Not only was I pumped to see 11's, but even more pumped to see 119 trap speed. That's flying man.
Sent from my Desire HD using Tapatalk
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 10-09-2011, 06:56 PM   #30
driver311's Avatar
Dude when I got my slip and it said 11.7 I was like wtf! Then I showed my buddy and he was like, dude 119!! I had to take a double look, the wing actually worked lol. Makes sense though. The evo guys gain 2-3mph on 130 trapping cars. It adds all that downforce for high speed track racing. So taking it off eliminates that down force. Who knows I might be on crack. No matter how you look. 119 is fast as fack and at 3000ft track.
Mazdaspeed
802MS3 (10-09-2011), Alpha (10-10-2011), atvfreek (10-09-2011), AZRushki (11-04-2011), crazyp (10-09-2011), daafisch (10-10-2011), helmetface (10-09-2011), i8urgti (10-11-2011), josurr (10-10-2011), Pu Manchu (10-17-2011), qtrmile beast (10-11-2011), rfinkle2 (10-09-2011), Sacrilicious (10-09-2011), SLOWHATCH (10-09-2011)
 Old 10-09-2011, 06:58 PM   #31
pewpew
ya, it makes sense. the wing was always a handling thing. that and staying on the ground thing. at 120, it's not like you're gonna take off and fly, so as long as you're just going in a straight line, all it's doing is acting like a parachute.
 Old 10-09-2011, 07:00 PM   #32
asall667's Avatar
Posts: 1,017   (View Stats)
asall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the world
Groans: 56
Groaned at 37 Times in 18 Posts
I think if you try and lighten up the car a bit, you will be knocking on 10s doors....Congrats man glad you are part of this great community
2007 CBM MS3 GT 66K
Mods:
--Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV----
New VVT as of 50K miles Thanks Young Mazda
New K04 Turbo as of 57K miles Thanks Young Mazda
asall667 is offline   Reply With Quote
The Following 3 Users Say Thank You to asall667 For This Useful Post:
DingoDave (10-09-2011), Post pwned (10-09-2011), rfinkle2 (10-09-2011)
 Old 10-09-2011, 07:03 PM   #33
Snyeed's Avatar
Posts: 743   (View Stats)
Snyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the worldSnyeed is the leader of the world
Groaned at 8 Times in 4 Posts
Awesome job driver! time to hit up sea level and get those 10's.
417whp 428tq 12.037@117.2mph
Snyeed is offline   Reply With Quote
 Old 10-09-2011, 07:14 PM   #34
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
Hell yes man!
We all knew you were going to hit it.. just waiting for the track day..
Great job!
As of the now the plan is for a few of us to come up for the next event.. maybe we'll have another 11 sec ms3 very soon.
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
 Old 10-09-2011, 07:21 PM   #35
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
AZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the world
Groans: 65
Congrats man, have been waiting for this day for a while. I knew it would happend with
all the BT MS3's out there. Awesome to see that you were the first with all the hard work you have put in to getting there. Keep up the progress for us MS3's.
AZSPEED3 is offline   Reply With Quote
 Old 10-09-2011, 07:21 PM   #36
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Drag is drag no matter how you look at it.
GG.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-09-2011, 07:25 PM   #37
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Hell yes Driver.
I was just speaking about your thread and your input into other threads today.
NJspeed3 mentioned you broke into the 11's and I'm not surprised.
Congratulations.
 Old 10-09-2011, 07:31 PM   #38
Ntahndagirl's Avatar
Posts: 598   (View Stats)
Ntahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the world
Congratulations Anthony! I will post videos as soon as I get back home. Thanks again for helping me out with the bov.
Ntahndagirl is offline   Reply With Quote
 Old 10-09-2011, 07:38 PM   #39
rghispanic88's Avatar
Posts: 3,131   (View Stats)
rghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the world
Groans: 263
Groaned at 73 Times in 43 Posts
Fucking nice. congrats
when i saw that you were on 12 flat, i knew u were trying to get to the 11s ASAP and u did.
Now for 10s at sea level
YOU CAN DO ITTTTTTT
2010 Black Mica
2004 EVO 8 Green Monster The "7up"
rghispanic88 is offline   Reply With Quote
The Following User Says Thank You to rghispanic88 For This Useful Post:
Alpha (10-10-2011)
 Old 10-09-2011, 07:43 PM   #40
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Nice! Cant wait for vids
FREEKTUNE
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f232/quest-over-11-7-119-a-94000/
&bull; View topic - The quest is over! 11.7@119 This thread Refback 11-12-2011 11:19 AM
A DIY fuel pump kit, with all the parts you need! - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-20-2011 08:50 AM
??????? ?????, ?????? ??????, ????? ? ????????... - Opel Performance Center Club Russia - ???????? 959 This thread Refback 10-12-2011 08:19 AM
Boise local hits 11.7 @ 119 in MS3 This thread Refback 10-11-2011 04:48 PM
/ / FFClub :) This thread Refback 10-11-2011 03:10 AM
?????? ? ????????? MPS This thread Refback 10-11-2011 03:00 AM
Quest for a 1.6" Tech/Sales@EM MazdaSpeed 6 - Engine, Transmission & Driveline 30 08-24-2011 04:42 PM
Wheel quest bioevolve MazdaSpeed 3/6 - Wheels & Tires 14 03-07-2009 10:02 AM
Page generated in 0.61350 seconds with 53 queries
