Autosports Area
> Drag Racing
Like Tree42Likes
 Old 10-10-2011, 07:48 PM   #81
Ntahndagirl's Avatar
Posts: 598   (View Stats)
Ntahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the world
You were definitely having more fun driving than I was recording. Good job Anthony!!
Ntahndagirl is offline   Reply With Quote
 Old 10-10-2011, 08:11 PM   #82
Decepticon's Avatar
Posts: 1,221   (View Stats)
Decepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the world
Groaned at 43 Times in 28 Posts
congrats dude!! i knew you were gonna be the first to hit 11's for the ms3's. Keep up the good work, man!!
06 MS6, Cobb AP, -TUNED on corn mix, KMD v2 fp internals, NGK Iridium IX sp, Cp-e Xcel NANO, PG tip, SU bpv, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback, Altered Custom fmic, H&R springs...
R.I.P. 08.5 MS3, Cobb Ap, KMD v2 fp internals, Denso ITV22 sp, Cobb Sri, TurboXS bpv, SU rear mm, SU shifter bushings, ETS TMIC, SU boost tubes, Cp-e catted dp, Enkei EKM3.
Decepticon is offline   Reply With Quote
 Old 10-10-2011, 09:05 PM   #83
Well, not that it means much to you, but I was there, and witnessed it first hand. So, yeah it's all legit. There were also about 15-20 other people off our local forum there who saw. Sorry the videos sucked, but all I had was a phone to record with.
 Old 10-10-2011, 09:09 PM   #84
driver311's Avatar
Posts: 1,769   (View Stats)
driver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the world
Originally Posted by H3R3TIC View Post
So you have witnesses, and I personally believe (the cars in the other lanes on the slips match up to what's happening in the vids imo), but the stuff you scanned is barely readable and it sucks that none of the vids so far have a shot good of the clock/e.t.'s.
No disrespect, I'm just sayin cause I'm sure there's someone else lurking here thinking these things.
LOL ok dude. Would you like me to blow it up for you? How bout i send a hard copy over to your house directly. Go ahead and post your address on this thread and Ill get that out right away. Look at my race number on the slips. YOu think i found someone who runs exactly what I was hoping for with the same race number as me? 311 and dont forget it. LOL
2008 Mazdaspeed3, Fully built then fully parted. Sold
2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily
Mazdaspeed
12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp
11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp
driver311 is offline   Reply With Quote
The Following 13 Users Say Thank You to driver311 For This Useful Post:
atvfreek (10-12-2011), BobbleHead (04-17-2012), Don06speed6 (10-10-2011), Ferg (10-17-2011), J-Liss (10-10-2011), jracer (10-11-2011), Ntahndagirl (10-11-2011), predapio (10-15-2011), rfinkle2 (10-11-2011), taf0422 (10-15-2011), Teethkikr (10-11-2011), TheHitman (11-07-2011), wolly6973 (10-17-2011)
 Old 10-10-2011, 09:20 PM   #85
H3R3TIC's Avatar
Posts: 303   (View Stats)
H3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the worldH3R3TIC is the leader of the world
LoL - calm down. Like I said, I believe you. All I'm askin for here is a camera with a zoom function. Probably should have sent it in a pm to begin with <shrug>
H3R3TIC is offline   Reply With Quote
 Old 10-10-2011, 09:28 PM   #86
wette460's Avatar
Posts: 385   (View Stats)
wette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the world
uh oh, here is goes! lol
Congrats Anthony! Way to represent the MS3's. Is this your original stock clutch or did you do an OEM replacement? I remember you saying that yours was slipping badly a while back.
T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels
wette460 is offline   Reply With Quote
 Old 10-10-2011, 09:46 PM   #87
driver311's Avatar
Still the same one. LOL It apparently was just mad at me that day. Havent done a second gear burnout since. The toyo slicks dont take much to get hot. Im super super impressed with these tires. Extreme hook up for a short geared heavy fwd car making over 400ftlbs. 60k hard hard ridden miles on this clutch and still grabbin like a mofo. LOL
Mazdaspeed
The Following 2 Users Say Thank You to driver311 For This Useful Post:
J-Liss (10-10-2011), wette460 (10-11-2011)
 Old 10-10-2011, 09:51 PM   #88
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Originally Posted by driver311 View Post
Thanks pimp. Would have happened years ago if I didnt take two off for motocross. First year back in the game and I finally get it. Ill tell you what this car isnt easy to do it in either LOL, but now that I have it kinda figured out its game on. If my motor was built the track would be in trouble. If I put skinnis on the rear and turned it up to 24psi alone the car would go 11.4-11.5@123-124
Use the spare tires as skinnis.
Any weight reduction?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 10-10-2011, 09:57 PM   #89
driver311's Avatar
I tried to borrow some skinnies from my buddy but they were to tall. 26s and the offset put them right at the fender. I would of had to put my coilovers way up. Gonna try and get some for the 29th. last event of the year and I think 11.4-11.5 isnt out of the question for that day. Take wing off for whole day, skinnies in rear, passenger and back seats out, very little gas in tank, 24psi, a lil more timing and see what the fuck happens. If I can atleast get 120 traps Ill be sooo pumped. But I think thats being conservative. YOu can clearly see I was only hitting 21psi up top and small spikes. I think if I get the gs ebc dialed in I can elimate any spike and just run 24psi solid instead of worrying about 26-27psi spikes. LOL Also dial back boost to 18psi in 1st and 2nd then game on from there. Though peeps that were track side said the car was clearly spinning the slicks in 3rd and grabbing chrrps in 4th and 5th. I was fucking shifting like a possessed maniac. LOL
Boosted Beluga likes this.
Mazdaspeed
Decepticon (10-11-2011), wolly6973 (10-17-2011)
 Old 10-10-2011, 10:07 PM   #90
driver311's Avatar
After looking over the slips Im not sure if taking the wing off did much. I trapped 118.4 the pass previous and then took wing off and trapped 119.04. So it could have just been a 1mph tail wind or 1mph less head wind. Or it could have been the wing. I just dont want 100 peeps to take the wing off their car expected miracles. LOL Just sharing my thoughts here guys. Its worth a try and it makes sense. Ill definately be taking it off again next time out. Maybe its my lucky charm LOL
Boosted Beluga and SLOWHATCH like this.
Mazdaspeed
SLOWHATCH (10-16-2011), wolly6973 (10-17-2011)
 Old 10-10-2011, 11:52 PM   #91
Groans: 50
Sounds good man. Maybe lifting the rear up wouldn't be such a bad idea, and make it really stiff. Help keep more traction on the front wheels.
Good luck though. I'm pullen for you.
P.S. I wouldn't take my wing off for 1 mph, unless I was trying to reach a certain mph lol
08 Mazdaspeed 3
The Following User Says Thank You to Boosted Beluga For This Useful Post:
 Old 10-10-2011, 11:54 PM   #92
MSFer87's Avatar
Posts: 1,162   (View Stats)
MSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the world
Groans: 83
BTW I just wanted to clear things up and say THE QUEST IS NEVER OVER! I know you hit 11s which is def. a mile stone for the MS3 but remember my chilrens. No matter how fast you go you will always want to go faster there is no limit for that. We gotta get these other BT guys to man up like you and put some slicks on their cars, and make shit happen.
-#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo
-1970 Chevelle - Needs full resto
MSFer87 is offline   Reply With Quote
The Following 2 Users Say Thank You to MSFer87 For This Useful Post:
 Old 10-11-2011, 03:21 AM   #93
Jackis's Avatar
Posts: 428   (View Stats)
Jackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the worldJackis is the leader of the world
Greets from russian community. We're all impressed here! Good result! And the truth is - you can be faster, and you know it! Keep it up man!
Does your MS3 start when it's -30C (-22F)?
Forged, bolted, tuned, gtx30/tial/ewg. Thanks.
Jackis is offline   Reply With Quote
The Following 12 Users Say Thank You to Jackis For This Useful Post:
802MS3 (10-11-2011), Alpha (10-11-2011), atvfreek (10-12-2011), BobbleHead (10-13-2011), JacksonMS30 (10-11-2011), josurr (10-13-2011), predapio (10-15-2011), Pu Manchu (10-17-2011), rfinkle2 (10-11-2011), SLOWHATCH (10-16-2011), TheHitman (11-07-2011), triplejumper18 (10-11-2011)
 Old 10-11-2011, 03:54 AM   #94
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Just remember to mail us all hard copies of the time slips next time.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
BeastMS3 (10-11-2011), DingoDave (10-11-2011), MSFer87 (10-11-2011), Pu Manchu (10-17-2011), wolly6973 (10-17-2011)
 Old 10-11-2011, 01:06 PM   #95
BlueStreak's Avatar
Posts: 1,467   (View Stats)
That thing gets out of the hole damn fast.
'07 CWP MS3
Forged.
 Old 10-11-2011, 01:31 PM   #96
Novej's Avatar
Posts: 354   (View Stats)
Novej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the world
Congratulations to a very deserving individual.....I salute you good sir!
2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex
Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN
Novej is offline   Reply With Quote
 Old 10-11-2011, 07:54 PM   #97
driver311's Avatar
Suprising it does very well out of the hole. This was on a street tire day also. So the rubber on the track wasnt the best. I think I can get 1.6 60fts and Ill have to work on that next.
Mazdaspeed
BlueStreak (10-12-2011), wolly6973 (10-17-2011)
 Old 10-11-2011, 10:55 PM   #98
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
was this with LC and ffs?
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
 Old 10-11-2011, 11:08 PM   #99
driver311's Avatar
No I dont use LC and I shift so fast there is no need for ffs. As you can clearly see its not needed and I prefer no LC cause no launch is never the same. Gotta be by feel and if you look at my logs I shift so fast the AP can barely pick the lifting of my foot up on acc. poss. It works for me but for others ffs is a good feature. I just dont like the idea of missing a gear and being wot or the added stress on drivetrain. I know some will say that I would have gone faster with ffs or lc but if thats the case than someone get in my car and prove me wrong. LOL
Mazdaspeed
The Following 9 Users Say Thank You to driver311 For This Useful Post:
Alpha (10-12-2011), atvfreek (10-12-2011), BobbleHead (10-13-2011), DingoDave (10-12-2011), kabobulate (10-12-2011), kmac (10-13-2011), SLOWHATCH (10-16-2011), SpeedNess (10-13-2011), wolly6973 (10-17-2011)
 Old 10-13-2011, 03:49 AM   #100
BobbleHead's Avatar
Posts: 2,237   (View Stats)
BobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the world
Groans: 186
Groaned at 33 Times in 25 Posts
I agree. Good driver > LC
IMS I assume?
2012 BM MS3 w/ tech. Cobb AP V2b: Autotech CDFP internals: JBR 88d RMM: SURE 3" Aeros full intake: Ebay test pipe: Corksport TMIC: Turbosmart BPV: Bridgestone Potenza 235/40 tires: self tuned
Last edited by BobbleHead; 10-13-2011 at 03:49 AM. Reason: MSF Database - Automerged Doublepost
BobbleHead is offline   Reply With Quote
The Following User Says Thank You to BobbleHead For This Useful Post:
 Old 10-13-2011, 05:08 AM   #101
kmac's Avatar
Posts: 1,792   (View Stats)
I just use the lc for the spool , my turbo is too big not to.
The Following User Says Thank You to kmac For This Useful Post:
 Old 10-13-2011, 05:43 AM   #102
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
Very impressive job driver!
uncorked11 is offline   Reply With Quote
 Old 10-13-2011, 06:41 AM   #103
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
driver what engine mounts do you have?
'08 CWP MS3 w/ T3 3071r
 Old 10-13-2011, 06:42 AM   #104
driver311's Avatar
Thank you sir. More to come guys dont you worry. I havent even turned the boost up yet, this was just my street setting. LOL The 29th cant come fast enough.
Mazdaspeed
Alpha (10-13-2011), JacksonMS30 (10-13-2011)
 Old 10-13-2011, 08:04 AM   #105
driver311's Avatar
Stock and they work just fine. The only thing I did was fill the rear mount with urethane. So my suggestion is to just get a nice rear mount.
Mazdaspeed
The Following User Says Thank You to driver311 For This Useful Post:
 Old 10-13-2011, 08:30 AM   #106
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
just wanna say congrats, i know you've been working hard at this for quite awhile
 Old 10-14-2011, 11:33 AM   #107
J-Liss's Avatar
Groans: 81
not entirely the case, you could do BETTER if you had ugraded mounts, i noticed huge diff on passenger mount.
2004 mazda 3-Daily
2008 mazda 6-Wife
 Old 10-14-2011, 03:32 PM   #108
Manny's Avatar
Posts: 1,185   (View Stats)
Manny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the world
Groans: 320
Groaned at 78 Times in 45 Posts
wow, that was with a filled RMM? def need those side mounts man.
Manny is offline   Reply With Quote
 Old 10-14-2011, 04:43 PM   #109
J-Liss's Avatar
Groans: 81
on theee way.
2004 mazda 3-Daily
2008 mazda 6-Wife
 Old 10-14-2011, 05:53 PM   #110
johnnyspeed6's Avatar
Posts: 1,364   (View Stats)
johnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the world
That log you posted is pretty
2008 HG Bullitt Mustang. Long Tube headers, SCT tuner,MGW short throw, FRPP hot rod cams high flow cats, charge motion plate delete
johnnyspeed6 is offline   Reply With Quote
 Old 10-14-2011, 06:10 PM   #111
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
Good job. Invest in a go-pro next time around.
BNR3-FREEK-PU-398HP
I lost track of the mods in my car.
dereeek is offline   Reply With Quote
 Old 10-14-2011, 08:52 PM   #112
I know your real secret, it was the shoes. Or the fact that I was in your car before you made those runs. lol.
 Old 10-15-2011, 07:50 AM   #113
Novej's Avatar
Hey Driver311 do you think you could get an in car vid of you running??? I'd like to see how a 11 sec run looks from inside the car
 Old 10-15-2011, 11:33 AM   #114
Tokay444's Avatar
Groans: 793
Demodded.
The Seals
Novej (10-15-2011)
 Old 10-15-2011, 11:58 AM   #115
Novej's Avatar
Thanks Tokay I should have been more clear. I wanted to see and hear what his car is like
The Following User Says Thank You to Novej For This Useful Post:
Tokay444 (10-15-2011)
 Old 10-16-2011, 12:40 AM   #116
TheStig1989's Avatar
Posts: 98   (View Stats)
TheStig1989 has a brilliant futureTheStig1989 has a brilliant futureTheStig1989 has a brilliant futureTheStig1989 has a brilliant futureTheStig1989 has a brilliant futureTheStig1989 has a brilliant futureTheStig1989 has a brilliant futureTheStig1989 has a brilliant futureTheStig1989 has a brilliant futureTheStig1989 has a brilliant futureTheStig1989 has a brilliant future
HOLY cow did anyone else see that was a Diesel that beat the DSM in the video? fucker was rolling on the coal seriously.
bethelaunchedin4wdLOL
Pierced Pooters
TheStig1989 is offline   Reply With Quote
The Following User Says Thank You to TheStig1989 For This Useful Post:
Tokay444 (10-16-2011)
 Old 10-16-2011, 11:14 AM   #117
Tokay444's Avatar
Groans: 793
That's for that @runswithscissors faggot who thinks hp wins drag races, not torque.
Demodded.
The Seals
Easter Bunny (10-18-2011)
 Old 10-16-2011, 01:01 PM   #118
BobbleHead's Avatar
Groans: 186
hp is useless without vtak right?
 Old 10-16-2011, 02:04 PM   #119
Tokay444's Avatar
Groans: 793
Totally. Vtak and a fresh charge of intercooler freon.
Demodded.
The Seals
 Old 10-16-2011, 02:19 PM   #120
Posts: 9,484   (View Stats)
A W E S O M E !!
Very happy for ya man!
Tappin
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f232/quest-over-11-7-119-a-94000/
&bull; View topic - The quest is over! 11.7@119 This thread Refback 11-12-2011 11:19 AM
A DIY fuel pump kit, with all the parts you need! - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-20-2011 08:50 AM
??????? ?????, ?????? ??????, ????? ? ????????... - Opel Performance Center Club Russia - ???????? 959 This thread Refback 10-12-2011 08:19 AM
Boise local hits 11.7 @ 119 in MS3 This thread Refback 10-11-2011 04:48 PM
/ / FFClub :) This thread Refback 10-11-2011 03:10 AM
?????? ? ????????? MPS This thread Refback 10-11-2011 03:00 AM
Quest for a 1.6" Tech/Sales@EM MazdaSpeed 6 - Engine, Transmission & Driveline 30 08-24-2011 04:42 PM
Wheel quest bioevolve MazdaSpeed 3/6 - Wheels & Tires 14 03-07-2009 10:02 AM
Page generated in 0.56791 seconds with 42 queries
