After my 12.5 run and me flashing the ticket like "woo woo" he stopped talking to me. lol Quote:
+1 to having truck and trailor. The tow truck bill for that guy who broke his Ion's axle was over $200. |
I'm running 10.1@135 next time that I go out. 5.0 Mustangs, feel my turbo minivan wrath. |
Give me a shout the next time you guys are heading out. I might even make a few passes to make you guys feel better about yourselves. |
We need to go back pretty soon before it gets too hot. I want to try some of the advice posted earlier in this thread. Raise redline to 7k, don't shift to 5th, and maybe see if I can work out the launch control/FFS problem I've been having. I would like to be able to crack off a 12.9 (at least) as the car sits now (don't know if its possible but I'd like to try at least one more time before it gets hot). |
I'm getting a 12.9 before you, sir. I'll stab your tires. |
Challenge accepted! And I'll steal your intercooler! :swordfight: |
Im down for another test n tune. I think the track ws pretty warm when we arrived also we had been driving for a while, so i have a feeling my best runs were early on and it all turned to shit when it started cooling down. Just for shits im gonna get my cats hacked off before i go back and see if i can accel a catless mustang into the 11's on street tires. Im confident due to the fact my 12.5 run was done with 30 PSI in the rear tires :) drop em to 20PSI, catless and a revised tune and i might be able to squeeze a high 11. |
Count me in for the next track day. My car had a fever but she's feeling a whole lot better now :) |
I checked the weather, and it looks like we're having rain Saturday as of now. Maybe the weatherman will be wrong. |
This weekend is probably a stretch just cause were still in the spring, but summer is pretty close and here within the next month im sure there will be a weekend or two where we can get another group together. Maybe this time we can organize lunch and cruise where we can actually all stay together instead of everyone hauling ass through traffic and others getting stuck. I mean we all got to the track about the same time anyway no use risking it haulin balls. |
I want to do this again soon but not to soon. Maybe the first or second weekend of may would be good. It will probably start getting hot by may 15th or so so before then if possible. PS: Nate, your vid is 31% loaded to youtube as I type this. I'll just stick it here and in your original post as well when I get it loaded... EDIT: Added one of Nate's vids to the op. |
i did 13.71 and trapped 102 with intake, rmm and springs...am i missing something here? |
i wonder why you guys are running slower or equal with more mods than the first gens with less mods... im currently being tuned by DJ right now...hes adjusting my timing now. just received my first map for timing this morning but im going tomorrow, should have my 2nd timing map tonight or tomorrow but im going to the track tomorrow to see with the car is doing now vs what it will do once my tune is dialed in. all i care aboout is trap though, to see how much power im making |
240, we'll see if my adjustment to the tune so that I can stay in 4th helps knock off a tenth or so and add a couple of MPH. I'm not claiming to be the best driver either, I'm just consistent. You can be consistently bad, LOL. |
yeah. im bad. when i ran my 13.71, i was running with a moded 135 and all i focused on was getting of the line with him and trying to keep up. POOF! i had a 13.71 and that was the only time i hit it...i dont go to the track often either but im going to start going more often. plus all i care about when i go to the track is an improved trap speed |
Improved trap is great when you're wanting your car to have more power, but I don't really care how powerful it is unless I can push it as far as it can go. I'd rather have a quick ET and a low MPH, because it shows that I'm a good driver. :D |
yeah, i know but i dont frequent the strip enough so i just dont see myself becoming a good drag racer or even decent. well, i guess i can, just going start practicing from street lights...ha |
Perfect example, last weekend i couldn't understand why Cameron(other 5.0L driver for your on lookers) was hitting 116 to 118 trap speeds and never getting under 12.5 1/4's. I never got a trap speed above 113MPH and was cutting similar and faster times when i wasn't making the back end slide around. His traps were indicating high 11's low 12's. Then again his 60 FTs never drop below 2.0 with drag radials. |
The 60' makes or breaks the run, that's something that you have to learn early. If there was a way to get a bad ass launch on the MS3, we'd see a lot more of them in the 12s because they pull like hell on the top end. When I used to hit the track all the time, if my 60' didn't flash up on the board as lower than 1.8, I just babied the car after that. No reason to break the car to get a shitty run because I already know that I can shift just fine. |
...hes def gotta get a retune. my 60' was 2.14 on my run(13.71) trapping 102.4(intake only.) who tuned your natahpen? or are our running the OTS map with minor tweaks b.c those OTS maps are super slow. you stock tune with those mods would be faster, i know my was. |
Not with a fuel pump that you're having to tune around to keep it from crapping out on you. Why don't we just reserve judgement until I make it out again? There were a couple of things that I obviously did wrong, so I'm sure that the car has more in it. I would hope that you had better 60' times than I did with stock boost by gear in 1-2. I'm trying BBG now. Keeping the tires from going up in a blaze was a task. I'm tuning the car myself, but I still haven't touched OTS timing because my stock HPFP is right at the limit. Alan, my best 60s were the 2.2s in the OP. |
My best 60' on stock tune was low 2.1's. With the OTS Stage1 tune I pulled a couple 2.0's but still I could only manage a 13.91 ET. I never powershifted 1st-2nd though. I'll probably give that a try next time at the track. I know there's still time wasted on that 1st-2nd gear shift. |
Do you log your drag strip passes? |
http://www.mazdaspeedforums.org/foru...-2011-a-76823/ Logs are attached on OP. Mods are CPE CAI, CPE TIP, CPE 75 RMM, and OTS Stage1 cpCAI 93oct BT v100. |
I was looking at your 1/8th mile mph and it's the same as yours. So I have to imagine it's roughly the same. Crappy 2.4 60ft's ftl, though. Ugh... tracks that aren't prepped ftl, too. Doesn't show your 1000 mph, though. Mine was 93.50... I wish I hadn't let off. That would have been the run of the day. |
| All times are GMT -7. The time now is 05:49 AM. |
