If I don't do it, Dustin will do it. If Dustin doesn't do it, Charles will do it. If Charles doesn't do it, Anthony will do it. It's gonna happen. It's just a matter of who does it at this point. |
you guys arent allowed to go to the track until I get back from Afghanistan. Its just not fair! |
soooo charles... who is going to have dibs on going first at the track to see what they can do?????? hahaha. will it be me? anthony? or you? |
Well I heard a rumor that someone was going to the track next weekend??? tic toc tic toc! |
Either you and me or you and anthony or anthony and me will run at the sametime!!!! Then the other guy runs the winner!! Im almost done with tom's intake. I just have to do the throttle area and i am done!! |
Superskater, sixual panda and myself are going next friday!!! |
Bastards Im going next saturday. Ill keep my fingers crossed. LOL |
You guys are all 6s right? I truely wanna be the first 3. It truely doesnt make sense to compare our cars. They are completely different. The short gearing is a huge benefit for the awd platform and a huge disadvantage for the fwd platform. Thats the reason the srt is such a monster at the track. The tall gearing pairs well with the big torque. With short gearing and big torque its really hard to put the power down. Ill keep my fingers crossed that the hoosiers hold up. I have my doubts. |
Driver I don't think anyone elses ms3 is even close to you as far as going for an 11 second pass |
Will do Lenny thanks pimpin. I just hope these 6s take it easy on me. LOL Quote:
With your hp you should get into the 120+ mph easy!! Quote:
I am a 3! I think i have a very good chance of hitting the 11s mark. |
Dammit Driver!!!! I didn't know you were going so soon. I'm a 3, so I'm gonna be shooting for the 11s, but at the end of the month. I always knew that you'd be the first... deep down, I knew... Good luck to everybody! Quote:
ive yet to see anyone come with even 1.8s on a 3.... other than anthony...so 11s gonna be a mighty big task unless u trapping 120+ |
The end of the month will tell the tale |
in b4 u guys realize what it takes to get 1.8s ..let alone 1.7s lol on a 3 |
im sure u will. but i doubt anyone with a 3 will turn an 11 without 11.7s and mid and upper teens of trap or 1.8s and 120s traps but...not like i know shit obviously hahaha |
tell u what ive learned..... BURNOUT BURNOUT BURNOUT. that shit needs to last a while to get proper heat....and then try 4500 launch no slipping just gun it... if u spin...either drop rpm a hair or just do a longer burnout for more heat. i fried my clutch because i was slipping out of the hole a little bit because i didnt have enough confidence yet that it would grab immediately...so my best were 1.9s on a shitty track. but i learned a ton...at a price but worth it for me |
yeah....basically if u got enough heat in the tires it will work. if you spin too much (u will spin out of the hole regardless or u will bog so its needed) lower rpm launch or increase heat in tires or lower psi on em. i practically floored it in 1st (just a hair slippage) and didnt spin in first running mbc full psi.....my last pass was at 10.5 psi tires, 4500 launch....shit takes time to learn especially if u are worried about over spinning and screwing up the launch. we should all be calling anthony for tech support at the track....i do every time im out there lol....... nothing funnier than him saying " god damnit lenny, you are not listening to me!!!! " |
What i would do is tighten the hell out of my rear suspension and also raise it so more weight is over the front wheels. This will help big time in the 60ft and also your shift to second would be less spin and more grab!! If you don't have coilovers then get some 18s in the rear and maybe some 17-16s on the front... |
We should start a thread that gives us fwd guys some tips and pointers. If I lived in a warmer climate I'd be practicing right now. |
You can also tune your boost to come on later in the RPMs so that you have less spin out of the hole... |
Mbc ftw |
hahahah yeah...mbc kinda makes u grow a set in a hurry. full boost in 1st ftw hahah i wouldnt change it ...fuck ebc lol |
Just trying to help with spinning.... |
Seriously it does take some learning. Especially with a lightweight flywheel believe me :). I think it makes you "one" with the car. I recommend a very thin sole racing shoe :). DC makes a nasty pair... http://184.72.239.143/mu/183dd974-5026-1d38.jpg |
shitty track inconsistent burnouts novice at drag racing manuals +fwd lack of confidence in the track and prep like i said..every time i go , i knock off 2-3 tenths... so im happy. this time i learned a lesson in avoiding clutch slippage when using slicks for the sake of the clutch and harder launch. next outing i will improve the 60ft to a mid to high 1.8 ... im sure of it. |
A good start would be to actually listen to me next time> and dont slip the clutch at all. 4-5k launch no slip on the gas. That is all for todays lesson. LOL |
| All times are GMT -7. The time now is 05:58 AM. |
