![]() | | #81 | ![]() |
![]() Join Date: Mar 2008 Location: Oceanside, CA
Rep Power: 2852 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 676
Groans: 106
| Not Ranked : 0 score
__________________ 13.2@111 CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
http://jpnutritionandfitness.blogspot.com/ Sponsored By: CP-E | |
![]() | | #82 | ![]() |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
(Thread Starter) | Not Ranked : 0 score i'll race ya!!!!!! LOL
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" ![]() 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
![]() | | #83 | ![]() |
Groans: 106
| Not Ranked : 0 score it wouldnt be any fun if there werent other people trying to get to 11's faster!!
![]() | | #84 | ![]() |
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" ![]() 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport | |
| The Following User Says Thank You to qtrmile beast For This Useful Post: | SIXual Panda (02-08-2011) |
![]() | | #85 | ![]() |
| Banned ![]() Join Date: Nov 2010 Location: Valley Park, Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,461
Groans: 126
Groaned at 59 Times in 47 Posts
![]() | | #86 | ![]() |
Groans: 106
| Not Ranked : 0 score what clutch are you fast guys using? Still on stock?
![]() | | #87 | ![]() |
Groans: 126
| Not Ranked : 0 score I think that most of us are still on stock clutch. I'm actually talking to spec right now about possibly sponsoring me |
![]() | | #88 | ![]() |
(Thread Starter) | Not Ranked : 0 score ACT 6 puck.. spec is some shhhhhhhhhhhhhhhhhhhhhhh the other guys are all on stockers.. Also with the AWD thing you also have to realize that we are about 300+lbs heavier than you ms3 guys so the awd just allows us to get where you guys with your lighter weight can already do. Up until the big power is being made and then the AWD becomes more of the advantage in the case of traction.. When we have the weigh of a speed3 and that ability of AWD to go with it THEN we will surpass where you guys are... Even with slicks..
GOOD LUCK!!!!!!
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" ![]() 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport Last edited by qtrmile beast; 02-08-2011 at 11:31 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #89 | ![]() |
Groans: 126
| Not Ranked : 0 score |
![]() | | #90 | ![]() |
Groans: 106
| Not Ranked : 0 score ACT 6 puck huh. sprung?
![]() | | #91 | ![]() |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 582 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score Thats what i used in my build was an ACT 6 puc sprung.
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
![]() | | #92 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well i put a spec in my when i first built my motor and while in brake in period i notice with anything over 5 psi the clutch would slip under light load. I think i know why at least mine slipped but i still dont like spec and their design.. Also i am using the 6 puck sprung clutch.. Well if you are pushing 400+ to the wheels, if you can put it to the ground then you should be able to run low 12 high 11's EASY!!! You mph should be in the 120's. When i drove robbies car down the track the one and only time it went, with the car acting up in first and second gear i was still able to run 115mph!!! I know for a fact that it would have done an 11 if the problems were not there!!!
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" ![]() 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport Last edited by qtrmile beast; 02-08-2011 at 02:40 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to qtrmile beast For This Useful Post: | jwilkins88 (02-08-2011) |
![]() | | #93 | ![]() |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score hope u guys the best. my money is on anthony (311) though to hit 11s first...(ms3 anyways)
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
![]() | | #94 | ![]() |
(Thread Starter) | Not Ranked : 0 score what state is 311 in? I saw B town.... if he is close to maryland when maybe he can join us in the battle!!! This would be fun!!!
![]() | | #95 | ![]() |
Groans: 356
| Not Ranked : 0 score he is from idaho me thinks. and prolly has more experience racing fwd's than all of us put together. he 's just buttoning up his tune to be able to run consistently at the track
![]() | | #96 | ![]() |
AND THE PLOT THICKENS!!!!!! who will it be curtain A or curtain B....
![]() | | #97 | ![]() |
Groans: 356
| Not Ranked : 0 score haha.... u know what i mean. how the fuck am i gonna know how much experience anyone has here lol i just know from experience...the guys that are the best are ALWAYS the guys that have that ability to nail the 60fts...... the rest its kinda "easier" if there is such a word
![]() | | #98 | ![]() |
Groans: 126
| Not Ranked : 0 score Well shit... I've been talking to the guys at Spec, and the guy told me that he could hook me up with a clutch that they aren't even selling yet. Supposedly, it's a complete redesign of their old clutches. It'll hold 600 ft-lb tq, so it's more than enough clutch for me. I'm not sure what it's going to retail for, but their "special introductory price is 1100 bucks. I've done some talking and worked some magic, and they're going to give me the clutch + flywheel + everything else I need for much, much less than that. I think that's what I'm going to do. |
![]() | | #99 | ![]() |
I found the reason that MY clutch was slipping was my disc was tooo thin for the flywheel and when the pressure plate was trying to grab it the disc was to far into the concave of the flywheel and thus didn't have the clamping force needed. So if i had sanded down the wall of the flywheel down a few thousandths then i would have had better clamping force on the disc. Is this the problem with all the specs (shrug) but i know there are a lot of people that have had a slipping clutch within the first 1000 miles of installation just like myself!!!! Outside of the broken finger issue that i have heard a couple of people go through the ACT has been a tried and true clutch so far... i have not heard of one slipping yet...
![]() | | #100 | ![]() |
Groans: 126
![]() | | #101 | ![]() |
Groans: 356
| Not Ranked : 0 score slipping?? hahahah if i floor it at 3500 in 3rd and up might as well be in neutral..rpms climb as fast and zero acceleration bai bai clutch
![]() | | #102 | ![]() |
(Thread Starter) | Not Ranked : 0 score 1 of .................................................. ..
![]() | | #103 | ![]() |
| Not Ranked : 0 score So where am i going to fit into all this at. MS3 and AWD....am i just an outlier? lol I am having trouble getting my last axle for the car, apparently they only want to sell me the set and i already have a custom left side! This is some BS! My Suspension from Ksport is being worked at as we speak and should be ordered as soon as they find me the correct spring for the rear. Now if only out local track would be bought by someone!
![]() | | #104 | ![]() |
![]() Join Date: Mar 2009 Location: LONG ISLAND, NY
Rep Power: 305 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 629
| Not Ranked : 0 score my motor is in a million peices right, sent out the block, getting bored as we speak looking put it back together blah blah blah.. in a couple months as my funds recover looking to do steedspeed top mount mani 7555 percision turbo wana hit 450 with AP also.
__________________ 2008 RED MS3 GT>>>T3 GT35R .82 A/R>>>Tial 44 EWG dumping>>>SteedSpeed T3 Mani>>>Built Motor PERM! |
![]() | | #105 | ![]() |
Well you are just a lightweight speed6 then LOL i should be about your weight by next week!!!! Good luck with your axle!! I can't wait to see that thing run!!! make sure you have video when you go!!
![]() | | #106 | ![]() |
Groans: 126
| Not Ranked : 0 score I'm just citing an instance of a slipping ACT clutch. I'm sure there are more.
![]() You're boring your block??? I didn't know that was possible with these blocks | |
![]() | | #107 | ![]() |
| Not Ranked : 0 score What is in Arizona and when?
![]() | | #108 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have mine bored .20 over i forgot what the max was. Also CPE is selling sleeved blocks..
![]() | | #109 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
Groans: 105
| Not Ranked : 0 score .020?
__________________ 2012 WRX HB w/mudflaps yo! |
![]() | | #110 | ![]() |
| Not Ranked : 0 score yea .020 just so its a clean cut.
![]() | | #111 | ![]() |
Groans: 126
| The Following User Says Thank You to jwilkins88 For This Useful Post: | I Love Brownies (02-09-2011) |
![]() | | #112 | ![]() |
| Not Ranked : 0 score Mine was done .020 A's well. Think clearance was set at .005
![]() | | #113 | ![]() |
Groans: 106
| Not Ranked : 0 score ACT 6 puck sprung sounds like what I am going to buy.
![]() | | #114 | ![]() |
Groans: 356
| Not Ranked : 0 score ok i didnt wanna say shit because i dont want more pms than i already receive daily. but since i see alot of anticipation and hopes and dreams on this thread i will disclose information i have been holding off for a few days. after going to the track saturday , i made a decision. it will take approximately 3-5 weeks to implement, but I am certain I will succeed. rather than try to get a 12.9 I am instead now going to skip 12s altogether and just shoot for 11s. ill keep you guys posted in 2 weeks.
| The Following 4 Users Say Thank You to rodrigo For This Useful Post: | djuosnteisn (02-10-2011), jwilkins88 (02-09-2011), qtrmile beast (02-09-2011), SIXual Panda (02-09-2011) |
![]() | | #115 | ![]() |
Groans: 106
| Not Ranked : 0 score ill have 1000hp in two weeks. standby.
![]() | | #116 | ![]() |
Groans: 356
| Not Ranked : 0 score yes , i like your strategy josh. mine involves this, calculator paper roll, printer to line up w/e i want to type up, and a computer to implement this. 2 weeks and i ll have some impressive slips. lol im just watching u guys man, i suck on fwd. lol
| The Following User Says Thank You to rodrigo For This Useful Post: | djuosnteisn (02-10-2011) |
![]() | | #117 | ![]() |
Groans: 106
| Not Ranked : 0 score lol...maybe not 1000hp but at least 950.
![]() | | #118 | ![]() |
(Thread Starter) | Not Ranked : 0 score GO FOR IT LENNY "YOU CAN DOO WIT" nice goal as that is what i wanted to do but i missed it by .3 i have only done (3) 12 sec passes and i am in the low 12's!!!!!
![]() | | #119 | ![]() |
Groans: 356
| Not Ranked : 0 score im not giving up.... i have a lot of fun drag racing. every outing i knock off .200 from et.... would love to have some mph..but the car will do what it will do. once i hit bakersfield i have zero doubts ill grab me a measly 12.9.... im just excited to see u guys chop that 11 sec tree down
![]() | | #120 | ![]() |
| The Following User Says Thank You to qtrmile beast For This Useful Post: | SIXual Panda (02-09-2011) |
| Upgrade/Better BOV to go faster? | bbonkboy | MazdaSpeed 3/6 - Turbo Induction | 8 | 05-17-2010 07:09 PM |
| PSA: Buy a Dodge Challenger, get $2,000 in Mopar bucks for go-faster (or look faster) bits | Haltech | Automotive News | 0 | 03-16-2010 08:10 AM |
| Which is faster | TXspeed3 | Mazdaspeed3/6 General Discussion | 136 | 05-15-2009 10:07 PM |
| Faster Farbio GTS 400 on its way | Haltech | Automotive News | 0 | 11-27-2008 06:00 AM |
