![]() | | #1 | ![]() |
![]() Join Date: Mar 2008 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 510
Groaned at 7 Times in 5 Posts
(Thread Starter) | Not Ranked : 0 score best mph was a 97.81, best ET of the night was a 14.889 @ 96.95 with a 2.412 60 ft. edit - that et came with about 25 psi in the fronts. first 3 runs were with 35 in the fronts, normal street pres. I'll scan the 4 slips later today... WTF can I do to get a better 60ft?!?!?!? Mods on the car right now are MSCAI, AP Stg1 + MSCAI, CS MM. This is really getting frustrating. I've made 7 passes in this car now and I still can get a decent time. |
![]() Join Date: Mar 2008 Location: Oceanside, CA
Rep Power: 2852 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 676
Groans: 106
| Not Ranked : 0 score what exactly is your strategy. how do you launch?
__________________ 13.2@111 CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
http://jpnutritionandfitness.blogspot.com/ Sponsored By: CP-E | |
![]() Join Date: Mar 2008 Location: Bells, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
| Not Ranked : 0 score If your running regular street tires make sure you avoid the water box and do not do a smokey burnout. You can spin the tires a couple times to get any debris of them but making them smoke is a waist of good tread. I know lowering the air pressure a little may assist in traction but remember regular street tires have been engineered to run best at a certain psi. If you raise or lower that psi to much you are effectively changing the contact patch. This could allow you to sacrifice some traction. Just play with the air pressure in 1/2 pound increments until you find the sweet spot. FWD cars are by far the hardest to launch so lots of practice will help out a ton. I am sorry if you already know most of this but I am sure with time and practice your 60ft times will drop. Get some slicks and really watch them drop.
__________________ [SIGPIC][/SIGPIC] |
![]() | | #4 | ![]() |
![]() Join Date: Mar 2008 Location: Victoria TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
| Not Ranked : 0 score also dont got wot in 1st
__________________ Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW! |
![]() | | #5 | ![]() |
Groans: 106
| Not Ranked : 0 score i think it all does come down to practice. also a good 1/2 shift. if you have a DH just find somewhere you can log some 0-60 runs and take a look at the logs. when i had just an intake, my best 0-60 was slipping the clutch at 2k, feathering the throttle in 1st to minimize spin and shifting into 2 early at ~5400. Feather 2nd till spin is gone and then foot to the floor for the 2-3-4-5 shifts.
![]() | | #6 | ![]() |
(Thread Starter) | Not Ranked : 0 score thanks for the tips guys...I think not going WOT in 1st and partially 2nd (esp after the 1/2 shift) is key. On one run, I blew away the tires through 3/4 of 2nd. No wheel hop, no drama, just spin. A kid watching said he saw them actually smoke lol. I definitely avoid the water box as best as I can. I was basically bouncing the revs between 1800 and 2300 then dropping the clutch and trying to mitigate wheel spin w/ the throttle but obviously having zero luck at it. I did try a short shift (5400rpm) into 2nd and damn if it didn't feel good but it didn't produce any better time in any part of the 1/4 mi. |
![]() | | #7 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Kent, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,649
Groaned at 32 Times in 14 Posts
![]() | | #8 | ![]() |
Groans: 106
| Not Ranked : 0 score i started at 5.6 0-60 with just an intake. now i have a TRZ poly and ETS TMIC. Hoping to get as close to 5.0 as possible
![]() | | #9 | ![]() |
| Not Ranked : 0 score |
![]() | | #10 | ![]() |
(Thread Starter) | Not Ranked : 0 score Also, in what gear are you guys crossing the finish line? I'm just over 6500 at the line, should I be shifting to 5th? Fawk these damn short gear tranny's. |
![]() | | #11 | ![]() |
Groans: 106
| Not Ranked : 0 score yes, shift to 5th. you should be shifting at ~5800 for all gears past 1st-2nd.
| The Following User Says Thank You to SgtP For This Useful Post: | MadOzodi (06-20-2008) |
![]() | | #12 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, shite. I was holding 4th across the line. now I feel dumb lol. Maybe that's what was keeping my trap in the same realm as before I had the AP? I consistently saw approx a 1 ~1.5 mph gain w/ the AP and Stg1 + map so I thought, "all else being equal, there's my 10-15 hp gain" lol. |
![]() | | #13 | ![]() |
| Not Ranked : 0 score Yea, my traps went up ~3-4mph when I started shifting to 5th |
![]() | | #14 | ![]() |
![]() | | #15 | ![]() |
| Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,602
Groans: 244
| Jed, you would probably be a good candidate for VHT.. Seeing as you are still learning how to drive the car, this may help you out. You can buy a 1 gallon jug of it from summit or jegs.. When you get to the track, have a buddy running out with a squirt bottle a puddling it in front of your tires AFTER you drive around the water box.. Than do a light burnout in it for 5 seconds and move to the line. This may get you into the 2.1 to 2.0 territory. Just remember, to wash the car within 12 hrs of using it because it splatters up on the paint and is a pain in the ass to get off.
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | |
![]() | | #16 | ![]() |
(Thread Starter) | Not Ranked : 0 score that's a thought Haltech....VHT...really the track should use it for prep. Hell, maybe I'll try the Cecil mod if I can get Chris and a few other semi-locals to come out to Cecil's Dragstrip. |
![]() | | #17 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groans: 57
| Not Ranked : 0 score fuck the et...ure mph is far off, which cobb map version are you running. Intake and a flash that ups boost you should be in the 103-105 range |
![]() | | #18 | ![]() |
Groans: 106
| Not Ranked : 0 score hes not shifting to 5th which hurts his trap time probably.
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score yea, I fucked up not shifting to 5th. I'm a hair away from redline when I cross the finish in 4th. I was so focused on 60ft that I forgot to try 5th on my next few runs. |
![]() | | #20 | ![]() |
![]() Join Date: May 2008 Location: ME, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,600
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm down whenever...just let me know. I might even take the initiative and try to organize something... |
![]() | | #22 | ![]() |
Groans: 57
| Not Ranked : 0 score how are you a hair away from redline when redline is like 107 |
![]() | | #23 | ![]() |
![]() | | #24 | ![]() |
Groans: 57
| Not Ranked : 0 score 67xx in 4th is well over 100 |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
![]() Join Date: Apr 2008 Location: Baltimore MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 199
![]() | | #27 | ![]() |
| Not Ranked : 0 score Its what they say but idk, i have not gone down there with a level. |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score sounds good guys...the next 2 weeks are going to be difficult for me but maybe the week after. |
![]() | | #29 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score Let me ask you a question. Do you have your clutch pedal all the way to the floor when you stage? If so then by the time the clutch gets to the ingadgement point your rpms are about 1500-2000 higher then before. you should have the pedal to the point where you can almost feel the car vibrating and then stage it. If you learn how to slip the clutch then you can launch it higher than some 2000 rpms. I know it is a little harder with a speed3 but i my best time for my speed in the 60 is a 1.71. I launch at 4000-4500 As for shifting I shift my speed6 at 5800, well that is going to change now that i can shift at 6500 now, but i lost 1.5 mph when i took 4th to redline. |
![]() | | #30 | ![]() |
I also made the mistake of taking 4th to redline across the finish. I was pissed that the AP was only giving me ~ 1 mph better trap which could easily be human error or some other variable. Is there a gearing difference in the 3/6 tranny's? I guess the final drive plays a role as well. I'm just wondering if there's a way to accurately see how much trap mph I lost by redlining 4th across the finish line.
__________________ BONE STOCK. | |
| GM confident in Volt launch; battery tests positive | Haltech | Automotive News | 0 | 06-16-2008 01:30 PM |
| Volkswagen Tiguan diesel launch delayed in the U.S.? | Haltech | Automotive News | 0 | 05-19-2008 08:40 AM |
| Volkswagen Tiguan diesel launch delayed in the U.S.? | Haltech | Automotive News | 0 | 05-17-2008 12:00 PM |
| Verizon to Launch Femtocells in 2008 | Haltech | Computers & Technology News | 0 | 04-04-2008 08:20 AM |
| NVIDIA, AMD Launch New Video Cards | Haltech | Computers & Technology News | 0 | 04-01-2008 08:50 PM |
