Autosports Area
> Auto-X / Road Racing / Time Attack
Like Tree44Likes
 Old 03-04-2015, 02:43 PM   #121
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,774   (View Stats)
Originally Posted by cnyms6 View Post
Love the cooling mods and discussion. Can you describe the operation and plumbing of the aux oil cooler more? What are you thinking for the aux cooling circuit and extra radiator?
See last post below for gheyness.
A History Of Violence
MAKE LOVE TO THE CANVAS
Mauro_Penguin (03-04-2015)
 Old 03-04-2015, 07:47 PM   #122
cnyms6's Avatar
Posts: 138   (View Stats)
cnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the world
Very cool extra radiator and circuit. Very clever to avoid the need for another expansion tank and other complexity.
Are you willing to share your design genius on the aux oil cooler also? I was under the impression that these were two separate systems, but I'm slow.
2006 MS6 BCM
JBR SSP, CP-E RMM, CP-E Rear Diff mount, RSB, AT internals, Full Race Intake, TR8 FMIC, EGR delete, AP V3, Stratified tune, Carbotech pads, TLT springs, Bilsteins
SpeedPerformance rebuild, EFR 7163, Full Race Ex Mani & DP
Street: Conti DWS 225/50-17 on 17x7 et 45, Track: Nitto NT-05 255/40-17 on Enkei RPF1
137,000 miles of driving fun
cnyms6 is offline   Reply With Quote
 Old 03-05-2015, 07:11 AM   #123
Bob Ross Fanclub
Tomas's Avatar
You are correct, they are two separate systems.
You can find more info on the oil cooler set up here in in post 47 here
Head Fails with Aplomb
The Following 4 Users Say Thank You to Tomas For This Useful Post:
btstarcher (03-05-2015), cnyms6 (03-05-2015), Enki (03-05-2015), Mauro_Penguin (03-05-2015)
 Old 03-07-2015, 07:56 AM   #124
cnyms6's Avatar
so many fins! Have you done any investigation to look for ways to increase air through the coolers?
These guys have a simple testing based approach to map differential pressures on the underbody (AutoSpeed - Undertrays, Spoiler & Bonnet Vents, Part 3) and found simple and inexpensive ways to increase air flow through the fins and out of the engine bay. I'm planning to try this once my car is back running.
But since you'll be in the heat sooner, thought either you'd be interested, or have already done similar.
Seems cooling capacity is going to be the limiting factor for power in track use of these cars. When we double the power, we also double the heat rejection. Even much higher power street cars do not reject heat for long periods like even low power track use.
2006 MS6 BCM
The Following User Says Thank You to cnyms6 For This Useful Post:
Tomas (03-10-2015)
 Old 03-09-2015, 07:28 PM   #125
Voltwings's Avatar
Posts: 3,713   (View Stats)
Not trying to insult anyone's intelligence here, but just for the sake of discussion:
Typical rule of thumb for a track car is to duct the radiator (as much high pressure pre radiator as possible) and vent the engine bay via the hood, venders... (creating as much low pressure in the engine bay as possible).
Basically, these pressure differentials are what "force feed" air through the intercooler / radiator, and actually improve the efficiency with which the heat is extracted from it. What makes this tricky in the case of the speed, is the stock setup is designed to plumb outside air into the engine bay for the TMIC. Really I imagine just blocking those vents off in the first place might be enough to make a large difference to underhood pressure if you haven't already. The next step would be just trying to duct the front as much as possible I guess to hit the pressure differential from that side ... Theres just going to come a point where shit is going to run hot though, the stock cooling system is not great ... even high horsepower street cars over heat. I had a guy I was tuning running mid 500's whp on a Gen2 and his coolant temps would get into the 250s doing street runs (couple of 3rd - 5th pulls against people) while we were out tuning.
Edit: I actually just realized I was proving my own point. We had the stock tmic duct wide open, just dumping air into the engine bay ... Pressure differentials. Here's where things really get tricky though; on my gen 2, I distinctly remember coolant temps being affected like 3-5 degrees having the tmic ducting in tact and directing air to the valve cover (when fmic) as opposed to just leaving it out and having the air just blow about.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
btstarcher (03-09-2015), Mauro_Penguin (03-10-2015), Tomas (03-10-2015)
 Old 03-30-2015, 01:59 PM   #126
Bob Ross Fanclub
Tomas's Avatar
I remember reading that article a few years back and totally forgot about it.
Will conduct some test soon.
$28 from ebay.
Code Monkey I dare you call my new springs girly.
I spit on your 1000 lbs springs! Who is loling at whose spring rate now huh !?!?!
I hais teh moar manly springs.
Got these for the rear.
AFCOIL Spring Lift Bar 5 Inch Outside Diameter Progressive Rate 10.5 Inch Length AFCO | AfcoDynaPro.com
Progressive / 2 step from 200 lbs to 2000 lbs. That's right. Thats two billion motherfucking pounds. Surprisingly, they feel pretty good. Really not harsh at all. They are 10.5" tall and the lower spring rate part is completly compressed so I am thinking they are mostly working in the 2000 lbs range. The car now has almost zero squat. Haven't taken it to the track to see how it behaves but will soon. Probably need to increase rebound (decrease rebound bleed) for the bils in the rear. That's the beauty of having take aparts. It takes time but you can tune in yo shit at least.
Also got some energy suspension isolators so the springs don't ride against the body metal-on-metal. But they sort of failed. God squashed like a soup sandwhich.
Also modified the top hats. Cuz I likes cushy ride. Poured so 80 duro urethane on the saucers.
after pouring
and debured.
Next in line I am going to try to convert the OE Bilsteins for the front into take apart meself. I have some ideas now on what needs to be done.
The Following 11 Users Say Thank You to Tomas For This Useful Post:
802MS3 (03-30-2015), Code Monkey (03-30-2015), Dano (03-30-2015), Easter Bunny (03-31-2015), Lex (03-31-2015), Mattyhawk1 (03-31-2015), Mauro_Penguin (03-30-2015), Nliiitend1 (03-30-2015), phate (03-30-2015), Voltwings (03-31-2015), WetzMS3 (03-30-2015)
 Old 03-30-2015, 02:43 PM   #127
Mauro_Penguin's Avatar
Posts: 1,996   (View Stats)
Mauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the world
Groans: 171
Interested to see how you incorporate those strappy heels with your higher spring rates.
-Fearless vampire killers, banned in DC, how low can a punk get?
-Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either.
-It is more fun to drive a slow car fast, than it is to drive a fast car slow
Mauro_Penguin is offline   Reply With Quote
The Following 5 Users Say Thank You to Mauro_Penguin For This Useful Post:
Code Monkey (04-01-2015), Dano (04-01-2015), Easter Bunny (03-31-2015), Tomas (03-30-2015), WetzMS3 (03-31-2015)
 Old 03-30-2015, 04:56 PM   #128
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Groaned at 7 Times in 6 Posts
Lemme know if you need help or advice on the takeapart/ conversion of the bils. I just successfully did this with my koni's.
Also, about those springs... at what compression point does coil bind/ spring destruction happen on those? Those are some wide coil loops.
-feejay
-wetzel
The Following 3 Users Say Thank You to zenit For This Useful Post:
Easter Bunny (03-31-2015), Mauro_Penguin (03-30-2015), Tomas (03-30-2015)
 Old 03-30-2015, 05:10 PM   #129
Code Monkey's Avatar
Posts: 7,657   (View Stats)
Enjoy the 4.5 / 5.0 Hz frequencies, should have poured a custom mouth guard while you were at it.... Also, invest in an under hood fire suppressant system, you know what happens when the hard fuel line vibrates too much..... I look forward toward your impressions.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
The Following 6 Users Say Thank You to Code Monkey For This Useful Post:
802MS3 (03-30-2015), Easter Bunny (03-31-2015), Mauro_Penguin (03-30-2015), Nliiitend1 (03-30-2015), Tomas (03-30-2015), zenit (03-30-2015)
 Old 03-30-2015, 07:18 PM   #130
rabble rabble
802MS3's Avatar
Posts: 5,311   (View Stats)
Groans: 221
awesome!
'08 CWP MS3 w/ T3 3071r
The Following User Says Thank You to 802MS3 For This Useful Post:
Tomas (03-30-2015)
 Old 03-30-2015, 09:08 PM   #131
Bob Ross Fanclub
Tomas's Avatar
Yes. Apparently I am a cordwainer now. I repaired my GF's shoes once with my micro nail gun. Her sister found out about it, and just like that dropped of a pair of shoes in my garage for me to repair. What the fuck I tell you.
Well yes. I can use some help. Why don't you make a thread if you haven't already done so?
The point of coil bind for the 2k part of the spring is lower than the hard bump stop for the LCA. In other words, if the hard rubber stop makes contact, the spring will not be fully compressed yet.
You can't calculate a frequency like that for progressive springs.
When the car dives during braking, and the rear end gets unloaded, the soft part of the spring comes into action. In other words you don't have to worry about the rear end trying to overtake you and kill your arse when you enter a corner while braking.
The stiff part of the spring comes into play during acceleration and partially during cruising. Also of course when you hit bumps.
The idea here is that on corner entry you won't get a very strong oversteer effect like you would have on a linear say 1000 lbs spring. On corner exit however, when you load the rear, you get the stiff part of the spring coming into action creating corner exit oversteer which is really what I am looking for. Not easy to achieve on AWD vehicles but we'll see. That's the idea at least. Have to admit I got zero proof that's what's gonna happen but experimenting is the whole point.
Mauro_Penguin likes this.
802MS3 (03-31-2015), Easter Bunny (03-31-2015), Mauro_Penguin (03-31-2015), WetzMS3 (03-31-2015)
 Old 03-30-2015, 09:22 PM   #132
Whatever, where are pictures of the gf and gf's sister?
Easter Bunny likes this.
2006 Mazdaspeed6
2017 Subaru BRZ
The Following 5 Users Say Thank You to Code Monkey For This Useful Post:
Easter Bunny (03-31-2015), predapio (03-31-2015), Tokay444 (03-31-2015), Tomas (03-31-2015), WetzMS3 (03-31-2015)
 Old 03-30-2015, 10:34 PM   #133
Posts: 9,484   (View Stats)
good stuff up in here I tell ya. I need some of that pour-able urethane to use on my stiffy tower mount...what did you use?
and if you tell me what you used I'll tell you a similar story to your "shoe repair" story above.
back story is, the wife is always "taking shoes to shoe repair" this week and again a few weeks later...with another pair of course...she has like 100...anyway, so one day she is bitching about yet another trip to get a 1/8th" rubber tip put onto the heel of a pair...I mistakenly commented that I could cut a piece off a sheet I have, contact cement that bitch on and tack it with a brad for good measure...her eyes widened....you already know how the rest of this story goes...hahahaha
I will say my repairs hold up much longer than "shoe repair's" do...I think I'll open up the shop on weekends for the neighborhood MILFs to drop by for a "repair". (que 70s porn music)
keep the good stuff coming.
The Following 6 Users Say Thank You to Dano For This Useful Post:
Code Monkey (03-31-2015), Easter Bunny (03-31-2015), Mauro_Penguin (03-31-2015), predapio (03-31-2015), Tomas (03-31-2015), WetzMS3 (03-31-2015)
 Old 03-30-2015, 10:37 PM   #134
Enki's Avatar
Posts: 7,539   (View Stats)
Groans: 189
que 70s porn music
Speaking of, still waiting for thread title to come to fruition.
The Following 6 Users Say Thank You to Enki For This Useful Post:
Dano (03-31-2015), Easter Bunny (03-31-2015), Mauro_Penguin (03-31-2015), predapio (03-31-2015), Tokay444 (03-31-2015), Tomas (03-31-2015)
 Old 03-31-2015, 06:18 AM   #135
You can use Flexane.
2006 Mazdaspeed6
2017 Subaru BRZ
Dano (03-31-2015), Easter Bunny (03-31-2015), Mauro_Penguin (03-31-2015), Tomas (03-31-2015), WetzMS3 (03-31-2015)
 Old 03-31-2015, 07:20 AM   #136
Bob Ross Fanclub
Tomas's Avatar
DEVCON Flexane 80 liquid is what I used.
And Dano.
No ones here believes you are married.
Everyone knows you are an incognito Catholic Bishop with a tendency to invite alter boys for a ride in your wagon.
The Following 9 Users Say Thank You to Tomas For This Useful Post:
802MS3 (03-31-2015), btstarcher (04-05-2015), ButtholeRedMS3 (12-27-2015), Code Monkey (03-31-2015), Dano (03-31-2015), Easter Bunny (03-31-2015), Mauro_Penguin (03-31-2015), predapio (03-31-2015), WetzMS3 (03-31-2015)
 Old 03-31-2015, 08:40 AM   #137
Thanks for the tip...and I that last comment couldn't be further from the truth my son.
Easter Bunny (03-31-2015), Mauro_Penguin (03-31-2015), Tokay444 (03-31-2015), Tomas (03-31-2015)
 Old 03-31-2015, 09:26 AM   #138
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
And Dano.
False you just have to make sure the fat one is on the bottom.
Unless you are into necrophilia.
Also guarantee the fat one will let you do ass to mouth.
"I wish I had fewer pussies to fuck" -said no one ever
I hugged rfinkle2
The Following 6 Users Say Thank You to Easter Bunny For This Useful Post:
ButtholeRedMS3 (12-27-2015), Code Monkey (03-31-2015), Mauro_Penguin (03-31-2015), predapio (03-31-2015), Tomas (03-31-2015), WetzMS3 (03-31-2015)
 Old 03-31-2015, 02:40 PM   #139
Bob Ross Fanclub
Tomas's Avatar
I have a phobia against asphyxiation.
If she decides to flip from the bottom. I'd die of fear alone.
 Old 03-31-2015, 02:49 PM   #140
I threw up in my mouth just reading EBs post....
Easter Bunny (03-31-2015), Tomas (03-31-2015)
 Old 03-31-2015, 03:14 PM   #141
Raider is mah Homie
Groans: 2,978
Be glad I censored my self in an attempt to keep things on topic.
I hugged rfinkle2
The Following 4 Users Say Thank You to Easter Bunny For This Useful Post:
 Old 03-31-2015, 03:28 PM   #142
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Since when has that stopped you?
What a lovable bunch we are!!
The Following 3 Users Say Thank You to predapio For This Useful Post:
Easter Bunny (03-31-2015), Tomas (03-31-2015), WetzMS3 (03-31-2015)
 Old 03-31-2015, 04:35 PM   #143
Raider is mah Homie
Groans: 2,978
You would be surprised/frightened by the shit I type and then don't post.
I hugged rfinkle2
The Following 7 Users Say Thank You to Easter Bunny For This Useful Post:
ButtholeRedMS3 (12-27-2015), Dano (03-31-2015), Mauro_Penguin (03-31-2015), predapio (03-31-2015), Tokay444 (03-31-2015), Tomas (03-31-2015), WetzMS3 (04-01-2015)
 Old 03-31-2015, 10:37 PM   #144
Devillish's Avatar
Posts: 9   (View Stats)
Devillish is on a distinguished road
2006 MS6 black cherry. (No mods yet) rzmzmzm girl
Devillish is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Devillish For This Un-useful Post:
Easter Bunny (04-03-2015), Tokay444 (04-01-2015)
 Old 04-01-2015, 06:59 AM   #145
Bob Ross Fanclub
Tomas's Avatar
What the fuck is an rzmzmzm girl?
can you climb a pole?
Mauro_Penguin (04-01-2015)
 Old 04-01-2015, 09:16 AM   #146
Ok...i'm slow but I think I just spotted Waldo in this post...lol
totally missed it the 1st time around even with Mauro's comment.
#shoerepair
The Following 5 Users Say Thank You to Dano For This Useful Post:
daafisch (04-02-2015), Easter Bunny (04-01-2015), Mauro_Penguin (04-01-2015), Tomas (04-01-2015), WetzMS3 (04-01-2015)
 Old 04-01-2015, 10:37 AM   #147
Raider is mah Homie
Groans: 2,978
also in this one
edit: also @Tomas; you need to cut back on the smoking
I hugged rfinkle2
Tomas (04-01-2015)
 Old 04-01-2015, 05:28 PM   #148
Bob Ross Fanclub
Tomas's Avatar
Fuck dude.
That, drinking and fucking around with cars are the only things left I still unconditionally enjoy in life.
Easter Bunny (04-03-2015), Mauro_Penguin (04-01-2015)
 Old 04-01-2015, 06:27 PM   #149
Raider is mah Homie
Groans: 2,978
Fuck dude.
uhh masturbating?
I hugged rfinkle2
 Old 04-03-2015, 05:47 AM   #150
Bob Ross Fanclub
Tomas's Avatar
not even close.
Mauro_Penguin (04-03-2015)
 Old 04-03-2015, 06:31 AM   #151
cnyms6's Avatar
When you begin testing with your magnehelic toy, would you please confirm that the slotted vent in drivers wheel well exhausts into the wheel well at all normal speeds?
2006 MS6 BCM
Tomas (04-03-2015)
 Old 04-03-2015, 10:05 PM   #152
Bob Ross Fanclub
Tomas's Avatar
yes
 Old 04-04-2015, 05:38 PM   #153
Raider is mah Homie
Groans: 2,978
not even close.
How could someone be so bad at jerking off as to not enjoy it?
I hugged rfinkle2
Tomas (04-05-2015)
 Old 04-05-2015, 07:08 AM   #154
Bob Ross Fanclub
Tomas's Avatar
You grossly underestimate my ability to excel at incompetence.
Easter Bunny (04-05-2015), Enki (04-05-2015), Mattyhawk1 (04-05-2015), Mauro_Penguin (04-05-2015)
 Old 04-05-2015, 11:06 PM   #155
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Mattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the world
Tomas, I learn quite a bit of useful things in your threads, but your anecdotes keep me coming back for more.
Mattyhawk1 is offline   Reply With Quote
The Following User Says Thank You to Mattyhawk1 For This Useful Post:
Tomas (04-06-2015)
 Old 05-16-2015, 04:07 PM   #156
cnyms6's Avatar
When you fit the 7163 and EFR manifold, did you need to cut back one of the manifold studs? And maybe clock the compressor a bit more than vertical to clear the valve cover vent? Did you need to do anything else to get it to fit?
2006 MS6 BCM
 Old 06-11-2015, 12:59 PM   #157
Bob Ross Fanclub
Tomas's Avatar
Yes. I had to grind to stud closest to the drivers side IIRC. And clocking of the compressor housing is also necessary.
Other then that I have a custom down pipe with cast elbow and flex pipe so I couldn't tell you if the full rape DP fits without a problem.
Intake should be very straight forwward.
The oil drain line for the terboh will also need to be custom made.
The OEM oil feed line works. You just have to bend it a bit so it points toward the turbo oil inlet port.
btstarcher (06-11-2015), Code Monkey (06-11-2015), Easter Bunny (06-12-2015)
 Old 06-12-2015, 07:09 AM   #158
Bob Ross Fanclub
Tomas's Avatar
Changed covers on the Corbeau seat and removed the 2000 lbs progressive springs. They were a bit too much.
Also the strut plate isolators failed miserably. Guess I should have laid shims on the studs and then pour the urethane just a hair line thicker than the shims.
I was also able to convert the front bills to take-aparts. Shit if I had known if was this easy I would just have gotten the OTS bills for the rear as well instead of the race shocks. Oh well.
Bilstein Race Shocks for the 6
I am not really a fan of the helper spring set up. There is definitely an increase in harshness as opposed to two rate/ progressive springs. As of now I don't have a better solution however since the progressive springs I've found in 2.5" ID have 450 lbs at the most.
The Following 6 Users Say Thank You to Tomas For This Useful Post:
Code Monkey (06-12-2015), Dano (06-12-2015), Easter Bunny (06-12-2015), Mauro_Penguin (06-12-2015), phate (06-12-2015), WetzMS3 (09-06-2015)
 Old 06-12-2015, 10:21 AM   #159
Raider is mah Homie
Groans: 2,978
aren't helper springs only there to keep the main spring locked in place when you jack the car up? ie. they are fully compressed when the car is on the ground?
I hugged rfinkle2
The Following 3 Users Say Thank You to Easter Bunny For This Useful Post:
Code Monkey (06-12-2015), Mauro_Penguin (06-12-2015), Tomas (06-12-2015)
 Old 06-12-2015, 11:51 AM   #160
Bob Ross Fanclub
Tomas's Avatar
That is partially correct.
If you go through a bump where the suspension compresses and then decompresses to the point where the helper spring starts to decompress, when the main spring comes down and drops on the helper spring after that, it can get harsh.
Not a problem on a race car.
Can be annoying on a DD.
Code Monkey (06-12-2015), daafisch (06-15-2015), Mauro_Penguin (06-12-2015)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f233/dildo-blitz-169330/
Reedy's Engine Rebuild Bonanza! - Page 20 Post #87 Pingback 03-04-2015 11:07 PM
Blitz K3T Twinturbo6 MazdaSpeed 3/6 - Big Turbo Builds 1 11-04-2013 02:34 PM
Blitz Air Filter USAFDentist 2010 MS3 - Turbo Induction 6 02-16-2012 01:05 PM
Blitz Type O1 clown_car MazdaSpeed 3/6 - Wheels & Tires 2 03-20-2009 01:26 PM
Page generated in 0.92386 seconds with 33 queries
