Autosports Area
> Auto-X / Road Racing / Time Attack
Like Tree46Likes
 Old 12-29-2015, 08:22 PM   #241
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,785   (View Stats)
without chopping on the body panels? How?
MAKE LOVE TO THE CANVAS
 Old 12-29-2015, 08:28 PM   #242
Code Monkey's Avatar
Posts: 7,664   (View Stats)
No, you would have to chop something up.
I have not looked into the exact location, but if you eliminate the evap system from under the spare tire hump, maybe you could route air underneath through that area?
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
Mauro_Penguin (12-30-2015), Tomas (12-30-2015)
 Old 12-30-2015, 09:49 AM   #243
Bob Ross Fanclub
Tomas's Avatar
Yes. May be.
But we are not that deep into the black anus yet.
Code Monkey (12-30-2015), Dano (12-30-2015), Mauro_Penguin (12-30-2015)
 Old 01-21-2016, 04:29 PM   #244
orion84gsl's Avatar
Posts: 1   (View Stats)
orion84gsl is an unknown quantity at this point
This certainly says racecar
orion84gsl is offline   Reply With Quote
 Old 04-23-2016, 04:46 PM   #245
cnyms6's Avatar
Posts: 138   (View Stats)
cnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the world
update please? any track tested results?
2006 MS6 BCM
JBR SSP, CP-E RMM, CP-E Rear Diff mount, RSB, AT internals, Full Race Intake, TR8 FMIC, EGR delete, AP V3, Stratified tune, Carbotech pads, TLT springs, Bilsteins
SpeedPerformance rebuild, EFR 7163, Full Race Ex Mani & DP
Street: Conti DWS 225/50-17 on 17x7 et 45, Track: Nitto NT-05 255/40-17 on Enkei RPF1
137,000 miles of driving fun
cnyms6 is offline   Reply With Quote
The Following User Says Thank You to cnyms6 For This Useful Post:
Mauro_Penguin (04-24-2016)
 Old 06-16-2016, 04:58 AM   #246
cnyms6's Avatar
@Tomas; I remember you were looking for a gasket upgrade between Full Race exhaust manifold and EFR. Did you find one? I just blew mine on track yesterday and ...
2006 MS6 BCM
The Following 4 Users Say Thank You to cnyms6 For This Useful Post:
Code Monkey (06-16-2016), Easter Bunny (06-20-2016), Mauro_Penguin (06-18-2016), Tomas (06-16-2016)
 Old 06-16-2016, 05:51 AM   #247
Bob Ross Fanclub
Tomas's Avatar
Give me a day or two to come back to this.
 Old 06-20-2016, 08:17 AM   #248
Bob Ross Fanclub
Tomas's Avatar
On the turbo gasket I ended up having using Inconel 625 as a material. Bought a sheet of ebay and had a guy cut them with a water jet. The sheet was good enough for 4 pieces and everything ended up costing about $80 for all the gaskets which isn't bad.
The original EFR gasket is standard stamped SS which might seal great but does not hold very long with track use. The other options would have been copper, which might have worked, or graphite which would have sealed best of all but would not have been very durable IMO.
Had another track day yesterday. Temps were around 85 and engine coolant temps went up to a max of 220 with the SP63 fan controller having then fans run at 100% duty cycle, the rear radiator water pump running, and the oil cooler fan running. I am ok with this as the temps really only got that high after about 20 minutes of driving like an animal. It was so bad I deformed another front tire so I only got 2 runs in the morning. Probably not going to run again this summer as there are a few things I want to get done before going back out.
Suspension: The FSDs are way underdamped for the 550 lbs front and 250/500 rear spring rate I am running. They work great on the street and provide a very plush ride + reasonably tight handling but over bumps at high speeds like in Sebring the car just gets too floaty.
I opened up a used FSD damper trying to see if the piston and valving system could be retrofitted into a monotube but it would just take too much work. There are also zero available resources on the web on how one go about tuning them. It's just too much of a project to take one with questionable potential.
I also replaced the bushing on the front forward LCAs and the boots for the ball joints.
While I was at it I planned on cutting myself some poly bushings for the steering rack but they OEM bushings are fairly stiff so I just re-ordered OEM even though they were still in perfect shape.
Another little test I ran was to try and fit rear CX-7 rotors on the 6. the rear CX7 rotors are about the same OD as the 6 but they are ventilated. Unfortunately the offset of the rotors is different and there is no easy way to modify the stock 6 caliper, or use a CX7 caliper on the rear knuckles of the 6.
[U
And finally something else I noticed. The CX-7 PS fluid reservoir has a raised opening which might prevent fluid from spilling over when the system gets hot. I can't use on the 6 due to my FMIC piping location but others might be able to.
Code Monkey likes this.
The Following 11 Users Say Thank You to Tomas For This Useful Post:
802MS3 (06-23-2016), cnyms6 (06-20-2016), Code Monkey (06-20-2016), CorkSport (06-20-2016), Dano (06-21-2016), Enki (06-20-2016), InkedInspector (06-22-2016), JSmith (06-21-2016), Mauro_Penguin (06-22-2016), WetzMS3 (06-20-2016), zenit (06-21-2016)
 Old 06-20-2016, 08:34 AM   #249
That's some crazy coolant temps. I have one more road racing run this weekend before I take off for the summer, it is supposed to be around 95 F, I will see what my coolant temps will be like, but they should stay around 190-200.
2006 Mazdaspeed6
2017 Subaru BRZ
CorkSport (06-20-2016), Tomas (06-20-2016)
 Old 06-21-2016, 04:54 AM   #250
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Groaned at 7 Times in 6 Posts
Interesting.
It looks like the FSD uses orifice type valving, like the koni yellows.
-feejay
-wetzel
 Old 06-21-2016, 02:13 PM   #251
cnyms6's Avatar
pm'd
2006 MS6 BCM
 Old 06-21-2016, 02:17 PM   #252
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Originally Posted by cnyms6 View Post
pm'd
Dick pics?
@Tomas; will respond to dick pics for sure.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
The Following 7 Users Say Thank You to WetzMS3 For This Useful Post:
Easter Bunny (06-22-2016), Gerbilo (06-21-2016), InkedInspector (06-22-2016), KiwiFlavor (06-29-2016), Mauro_Penguin (06-22-2016), monkey.bones.007 (06-21-2016), Tomas (06-22-2016)
 Old 06-21-2016, 02:46 PM   #253
monkey.bones.007's Avatar
Posts: 3,832   (View Stats)
Groans: 98
Originally Posted by WetzMS3 View Post
Dick pics?
Did someone say Dick pics?
tapatalk, it sucks
monkey.bones.007 is offline   Reply With Quote
The Following 6 Users Say Thank You to monkey.bones.007 For This Useful Post:
802MS3 (06-23-2016), Easter Bunny (06-22-2016), InkedInspector (06-22-2016), KiwiFlavor (06-29-2016), Mauro_Penguin (06-22-2016), Tomas (06-22-2016)
 Old 06-22-2016, 06:28 AM   #254
Bob Ross Fanclub
Tomas's Avatar
pm'd
No you haven't.
Dick pics?
Yes I will and I will revert with my own and then may be explosion of love will happen.
tapatalk, it sucks
Last edited by Tomas; 06-22-2016 at 06:28 AM. Reason: MSF Database - Automerged Doublepost
The Following 6 Users Say Thank You to Tomas For This Useful Post:
802MS3 (06-23-2016), Easter Bunny (06-22-2016), KiwiFlavor (06-29-2016), Mauro_Penguin (06-22-2016), monkey.bones.007 (06-22-2016), WetzMS3 (06-22-2016)
 Old 06-22-2016, 06:49 AM   #255
Groans: 98
Originally Posted by Tomas View Post
No you haven't.
tapatalk, it sucks
802MS3 (06-23-2016), Easter Bunny (06-22-2016), KiwiFlavor (06-29-2016), Mauro_Penguin (06-22-2016), Tomas (06-22-2016), WetzMS3 (06-22-2016)
 Old 06-22-2016, 07:01 AM   #256
Bob Ross Fanclub
Tomas's Avatar
tapatalk, it sucks
802MS3 (06-23-2016), Easter Bunny (06-22-2016), InkedInspector (06-22-2016), Mauro_Penguin (06-22-2016), monkey.bones.007 (06-22-2016), WetzMS3 (06-22-2016)
 Old 06-22-2016, 07:41 AM   #257
Groans: 98
tapatalk, it sucks
The Following 5 Users Say Thank You to monkey.bones.007 For This Useful Post:
802MS3 (06-23-2016), Easter Bunny (06-22-2016), KiwiFlavor (06-29-2016), Mauro_Penguin (06-23-2016), Tomas (06-22-2016)
 Old 06-22-2016, 07:47 AM   #258
Bob Ross Fanclub
Tomas's Avatar
tapatalk, it sucks
The Following 5 Users Say Thank You to Tomas For This Useful Post:
802MS3 (06-23-2016), Easter Bunny (06-22-2016), KiwiFlavor (06-29-2016), Mauro_Penguin (06-23-2016), monkey.bones.007 (06-22-2016)
 Old 06-22-2016, 07:58 AM   #259
Enki's Avatar
Posts: 7,539   (View Stats)
Groans: 189
Don't mind the spots; nothing wrong with it, promise.
802MS3 (06-23-2016), Easter Bunny (06-22-2016), monkey.bones.007 (06-22-2016), Tomas (06-22-2016), WetzMS3 (06-22-2016)
 Old 06-22-2016, 07:58 AM   #260
WetzMS3's Avatar
Groans: 430
Guise!!! This thread is about magical dildos, not actual Dicks.
Please stay on topic.
2013 MS3 Black Mica
The Following 4 Users Say Thank You to WetzMS3 For This Useful Post:
802MS3 (06-23-2016), KiwiFlavor (06-29-2016), Mauro_Penguin (06-23-2016), Tomas (06-22-2016)
 Old 06-22-2016, 09:46 AM   #261
Groans: 98
tapatalk, it sucks
802MS3 (06-23-2016), Easter Bunny (06-23-2016), KiwiFlavor (06-29-2016), Mauro_Penguin (06-23-2016), Tomas (06-22-2016)
 Old 06-22-2016, 12:41 PM   #262
Bob Ross Fanclub
Tomas's Avatar
I ran out of dick.
WetzMS3 likes this.
802MS3 (06-23-2016), Easter Bunny (06-23-2016), KiwiFlavor (06-29-2016), Mauro_Penguin (06-23-2016), monkey.bones.007 (06-22-2016)
 Old 06-22-2016, 01:05 PM   #263
Gerbilo's Avatar
Posts: 612   (View Stats)
Gerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the world
I ran out of dick.
2010 CBM Mazdaspeed3
Freektune 93
CorkSport SRI, TIP & Race Pipe
CP-E Stage 2 RMM & TMIC
Cobb Accessport V3
Autotech HPFP Internals
Pilot Super Sport 235/40/18 - Stock Pu
Pilot Alpin PA3 215/50/17 - Sport Edition CE
2016.5 MGM Mazda CX-5 Touring
Gerbilo is offline   Reply With Quote
The Following 5 Users Say Thank You to Gerbilo For This Useful Post:
Easter Bunny (06-23-2016), KiwiFlavor (06-29-2016), monkey.bones.007 (06-22-2016), Tomas (06-22-2016), Voltwings (06-23-2016)
 Old 06-22-2016, 01:36 PM   #264
Enki's Avatar
Groans: 189
There's a whole thread of it here.
Easter Bunny (06-23-2016), Mauro_Penguin (06-23-2016), Tomas (06-22-2016)
 Old 06-22-2016, 02:30 PM   #265
Groans: 98
I ran out of dick.
I've got a plethora of it. More than enough for all...
tapatalk, it sucks
802MS3 (06-23-2016), Easter Bunny (06-23-2016), Gerbilo (06-22-2016), KiwiFlavor (06-29-2016), Mauro_Penguin (06-23-2016), Tomas (06-22-2016)
 Old 06-27-2016, 03:07 PM   #266
Saturday official max temp was 91, coolant temps and max BAT across my four sessions (9am, 10:30am, 2:30pm, and 4pm) were as follows:
Code:
190-199		153
190-201		153
199-208		156
199-208		154
Sunday official max temp was 93, coolant temps and max BAT across my three sessions (9am, 10:30am, and 1pm) were as follows:
Code:
187-196		147
192-201		153
196-201		154
The 4pm Saturday session was certainly the hottest, all the other sessions were most likely mid to high 80's.
2006 Mazdaspeed6
2017 Subaru BRZ
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
Easter Bunny (06-29-2016), Mauro_Penguin (06-29-2016), Tomas (06-28-2016), WetzMS3 (06-28-2016)
 Old 06-28-2016, 11:27 AM   #267
Bob Ross Fanclub
Tomas's Avatar
How much timing and boost are you running at 6K+ rpm?
You removed your AC condenser right?
Code Monkey (06-28-2016), Mauro_Penguin (06-29-2016), WetzMS3 (06-28-2016)
 Old 06-28-2016, 04:43 PM   #268
10 at 6k, 11.25 at 6.5k, 12.50 at 7k, 21 psi of boost.
But I also have an aggressive ECT/BAT table, for example, pull 3.5 degrees of timing at 158 BAT and 212 ECT (less for lower values obviously, but no less than 1.2 degrees).
The condenser is gone and I am running 1 quart of 50/50 coolant mix, half a bottle of water wetter, and the rest distilled water.
2006 Mazdaspeed6
2017 Subaru BRZ
Easter Bunny (06-29-2016), Mauro_Penguin (06-29-2016), Tomas (06-29-2016), WetzMS3 (06-29-2016)
 Old 06-29-2016, 09:46 AM   #269
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
code monkey arent you on the BNR S3?
Tomas i believe is on a larger turbo, it would be better to compare mass air flow than pressure and timing, more air = more fuel = more boom = more heat
I hugged rfinkle2
Mauro_Penguin (08-21-2016), Voltwings (06-29-2016)
 Old 06-29-2016, 09:53 AM   #270
Yes.
2006 Mazdaspeed6
2017 Subaru BRZ
Easter Bunny (06-30-2016)
 Old 08-18-2016, 01:17 PM   #271
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
So I've been checking out the pictures/videos of yours (Tomas) and @Code Monkey;'s cars to try and figure out what engine parameters you're monitoring via gauges. And from what I can tell, not much.
The only thing I've personally wanted to add was an oil temp gauge, water temp, and maybe a boost gauge when I go BT. The temps are a concern now that I'm running all summer, and boost will be concern once I move beyond the K04. Otherwise I can't really think of anything that I'd want to be noting mid-run to shut it down before the engine popped.
Am I missing something obvious here?
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
 Old 08-18-2016, 01:37 PM   #272
I log everything and display boost, BAT, AFR, fuel pressure, KR, and ECT. I only look at ECT during my sessions though, and only on the main straight. An oil temp and pressure gauges would be nice.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 08-18-2016, 01:53 PM   #273
Bob Ross Fanclub
Tomas's Avatar
I think on MS6 temp gauges for engine oil, transmission and t-case are good ideas. The rear diff runs so cool it isn't really needed but it doesn't hurt.
 Old 08-18-2016, 09:35 PM   #274
Raider is mah Homie
Groans: 2,978
Imo oil pressure and coolant temp are most important. Oil temp is really something to log and check later. A stable setup shkuld have oil temps similar to water temp.
I hugged rfinkle2
Voltwings (08-19-2016)
 Old 08-20-2016, 01:33 PM   #275
ChaunceyM's Avatar
Good call on the oil pressure. Totally overlooked that one. And while a stable setup won't see oil temp issues, I'm still not convinced my engine isn't going to pop at every event. It's why I got the AAA upgrade; track is 65 miles from home and I'm sure I'll use that 100 mile radius towing one of these days...
I've got 3 events, some 2-day, in October. So I'm giving the car a solid beating right up until the end of the season.
CP-e: RMM
Cobb: AP
Ebay: Test Pipe
 Old 08-20-2016, 08:22 PM   #276
Bob Ross Fanclub
Tomas's Avatar
A stable set up won't see oil temp issues?
What the Virgin Mary's vagina is a stable set up? Having less pawa than stock?
If you want a stable set up drive a tricycle.
Code Monkey (08-21-2016), Mauro_Penguin (08-21-2016)
 Old 08-20-2016, 11:23 PM   #277
Enki's Avatar
Groans: 189
I find that higher RPM tends to warm the oil up faster than boost will.
Code Monkey (08-21-2016), Mauro_Penguin (08-21-2016), Tomas (08-21-2016), Voltwings (08-21-2016)
 Old 01-19-2017, 08:29 AM   #278
Mauro_Penguin's Avatar
Posts: 1,996   (View Stats)
Mauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the world
Groans: 171
So how did the Arm-Sissy work? Did you see any benefit at all in the transfer case temps?
-Fearless vampire killers, banned in DC, how low can a punk get?
-Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either.
-It is more fun to drive a slow car fast, than it is to drive a fast car slow
Mauro_Penguin is offline   Reply With Quote
 Old 01-19-2017, 11:04 AM   #279
Bob Ross Fanclub
Tomas's Avatar
Whats the arm sissy again?
Mauro_Penguin (01-20-2017)
 Old 01-20-2017, 07:51 PM   #280
Groans: 171
I thought it was a fairy like creature that lived in your rear bumper and slapped your ankles around with little weak arms whenever you took stuff out of your trunk.
The Following User Says Thank You to Mauro_Penguin For This Useful Post:
Tomas (01-25-2017)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f233/dildo-blitz-169330/
Reedy's Engine Rebuild Bonanza! - Page 20 Post #87 Pingback 03-04-2015 10:07 PM
Blitz K3T Twinturbo6 MazdaSpeed 3/6 - Big Turbo Builds 1 11-04-2013 01:34 PM
Blitz Air Filter USAFDentist 2010 MS3 - Turbo Induction 6 02-16-2012 12:05 PM
Blitz Type O1 clown_car MazdaSpeed 3/6 - Wheels & Tires 2 03-20-2009 12:26 PM
Page generated in 0.62403 seconds with 32 queries
