MSF Autosports
Autosports Area
> Auto-X / Road Racing / Time Attack
Notices
Like Tree2Likes
  • 1 Post By jakk
  • 1 Post By deuce_WI
 Old 09-13-2012, 01:23 PM   #1
jakk's Avatar
Posts: 614   (View Stats)
jakk has a reputation beyond reputejakk has a reputation beyond reputejakk has a reputation beyond reputejakk has a reputation beyond reputejakk has a reputation beyond reputejakk has a reputation beyond reputejakk has a reputation beyond reputejakk has a reputation beyond reputejakk has a reputation beyond reputejakk has a reputation beyond reputejakk has a reputation beyond repute
Groaned at 3 Times in 1 Post
Default Going to a track for the first time in October
Hey. I will be going to a track day at Road America in October. I just got my speed one month ago and I have zero autox/track experience and have been driving stick for a whopping one month. As I have never done anything like this before, I am just trying to get a feel for what sort of wear and tear I should expect on the car and if there is anything I need to do before the event to protect it. The car is my DD so I'm quite nervous about driving it hard for an extended period of time.
There will be instructors and I will take one with me on each of the 4 runs throughout the day. I will also be in the beginner group and I'm sure I will be driving like a grandma.
I'm mainly wondering if I will need to worry about replacing brake pads or tires after the event or if I need to buy a seperate set of brake pads. I should also mention that I am very new to working on cars, so things that I may need to check that would same obvious to most of the people on this forum may not occur to me.
Thanks for the help.
2012 Black Mica MS3|Autotech internals|SURE ID300 Full3 Aeros|ETS TMIC|UR TP|AP(stage 2 OTS tune)|NGK one step colder|Forge V2 BPV|JBR RSB|CP-E Stage 2 RMM|JBR shifter bushings
jakk is offline   Reply With Quote
 Old 09-13-2012, 01:25 PM   #2
Police Brutality...
CWP_MS3's Avatar
Groaned at 30 Times in 24 Posts
Disable SWAS or you'll surely be disappointed.
CP-e S2 RMM, Ghetto SRI, 3" ATP MAF housing, Ultimate Racing CBE, Ebay Downpipe, Cobb AP,
Autotech HPFP internals, PG TIP, TurboXS BOV, NGK Iridiums.
20% tint, HID headlights, LED License Plate Lights
Rich Tuned
E48 FTW!
326WHP and 361TQ
4-13-13 Moore Automotive
266hp and 298tq stock
11-10-12 Moore Automotive
Haters Gon Hate...
CWP_MS3 is online now   Reply With Quote
 Old 09-13-2012, 01:28 PM   #3
daafisch's Avatar
Posts: 1,792   (View Stats)
Groaned at 6 Times in 6 Posts
I wouldn't touch a thing. The brakes and tires will work out just fine for a first time track day. Also leaving it as is will give you a better understanding of the car.
2012 Black Mica : Cobb AccessPort <> CP-e Nano//Nviscid//HPFP <> Forge BPV v1 <> Kosei K4R 17x8 <> 235/45 ZII
OLD 2008.5 MGM : CP-e Nano//Nviscid//Downpipe//CBE//xFlex RMM Stage 1//xFlex PMM//xFlex TMM//Dashhawk Mount//Tow Plate <> SURE Countershift <> Cobb STS <> SeriouSpeed Slick Shift <> E4P Bushings <> Forge BPV v1 <> Koni Sports <> Swift Springs <> Progress RSB <> MSD Dashhawk <> Prosport Premium Boost <> RPM Ventpod <> Carbotech AX6 <> DBA 4000 T3 <> Technafit SS Brake Lines <> Brembo LCF 600 <> Kosei K4R 17x8 <> 235/45 Hankook RS-3 <> Stratified tuned
NATOR NY - Liquid Dinosaur Racing - liquiddinosaurracing.com
Lime Rock Park 01:06.0
Watkins Glen 2:23.608
Summit Point 1:28.895
NJMP Lightning 1:23.891
Pocono North 1:07.230
daafisch is offline   Reply With Quote
The Following 2 Users Say Thank You to daafisch For This Useful Post:
helmetface (09-13-2012), Nliiitend1 (09-14-2012)
 Old 09-13-2012, 01:34 PM   #4
jakk's Avatar
Ok, thanks. My main concern was that I would need different brakes and tires after the event due to the amount of wear that will be put on them, I wasn't planning to buy anything new for performance purposes seeing as I don't think I have the skill to push the car to any sort of limits in stock form.
 Old 09-13-2012, 01:40 PM   #5
daafisch's Avatar
You're going to get a little bit more wear on both pads and tires not to the point that you're going to need new ones though.
 Old 09-13-2012, 01:48 PM   #6
captain slow's Avatar
Posts: 1,656   (View Stats)
captain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the world
Groans: 306
Groaned at 44 Times in 29 Posts
Road America is a fast track with some long straights coming to some tightish corners. Your car is new and you shouldn't have to worry about brakes but if you're going to be doing lap after lap you will surely wear brakes quickly.
Just give it a once over before you head out and after each run.
2007 Sunlight Silver MS3 GT
CP-E SRI / CP-E TIP / Cobb AP Stage 1 slightly tweaked by me / JBR 88 RMM, SSP, SSB, Heavy Knob / Turbosmart Dual Port BOV 50/50 / Autotech internals
_______________________________________________
Sitting in my garage: ......
To be ordered: CorkSport TBE
captain slow is online now   Reply With Quote
 Old 09-13-2012, 01:51 PM   #7
deuce_WI's Avatar
Posts: 180   (View Stats)
deuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond repute
Groaned at 6 Times in 2 Posts
I'd look into at least a set of track pads for the front. Rears don't bother. Is your car brand new a month ago, or new to you? If it's new, the stock brake fluid will probably be alright, if it's new-ish but has some miles, fresh brake fluid is cheap and easy.
RA has 3 heavy breaking zones that you may see 120+ coming into. Brake fade downhill into turn 5 is not a good feeling. It also sucks to sit in the pits 1/2 the session with overheated brakes.
Also, don't lift in the kink.
What event are you running in? 1 day? 2 days?
deuce_WI is offline   Reply With Quote
 Old 09-13-2012, 01:58 PM   #8
jakk's Avatar
Thanks for all of the tips. The car is brand new. The event is the Drive for Babies event which consists of four runs throughout the day as I understand it. I get to go for free because my company sponsors the event which is why I jumped at the chance. I know I have seen the Hawk pads recommended in the past, and seeing as how they seem to be under $100 maybe it's not a bad investment so I can just beat on them without worrying. Like I said though, I really have no basis for these ideas. Should I also cover the front end with paitner's tape or something similar?
 Old 09-13-2012, 02:08 PM   #9
easy's Avatar
Posts: 502   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
remember to turn off DSC!! i always forget till i realize im getting major understeer half way through the first lap
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, Autolite XP5263
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Enkei GF1/Ferderal RS-R, Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms, ATE Super Blue Brake Fluid
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
 Old 09-13-2012, 02:43 PM   #10
deuce_WI's Avatar
Where around WI are you? For a 1 day charity event, I'd loan you my HP+ pads if you wanted to beat on them for a day if you're interested.
 Old 09-13-2012, 02:57 PM   #11
arielfall's Avatar
Posts: 20   (View Stats)
arielfall has a spectacular aura aboutarielfall has a spectacular aura about
Stock pads I'd imagine should be fine just be easy into turn 1,3,5 and 12. Runs are what 20 minutes?
My personal tips are just get all your braking and shifting done before turn in and you should be fine.
You'll want to slow down for the kink as deuce suggested but to clarify don't lift whilst going through it.
Have fun! Also make sure you have the right safety gear, helmet and long pants and shirt potentially. Some organizations/tracks make you wear long clothing.
2011 MS3
cp-e... FMIC, CAI, Catless turbo back exhaust, TIP, fuel pump, all three engine mounts
Cobb AP with custom cp-e tune by Sander
HKS BPV, Denso ITV22
282 WHP at 5150 RPM 322 WTQ at 3450 RPM with 18.5 psi on 93 oct on 4WD Mustang dyno
arielfall is offline   Reply With Quote
The Following User Says Thank You to arielfall For This Useful Post:
 Old 09-13-2012, 03:21 PM   #12
jakk's Avatar
Mukwonago area, although I do work im Milwaukee. Thanks for the offer, but I wouldn't feel comfortable beating on someone else's parts. Also, I have borrowed a helmet from one of my coworkers so I am all set.
 Old 09-13-2012, 08:06 PM   #13
Neverlift's Avatar
Posts: 3,117   (View Stats)
Groans: 542
Groaned at 181 Times in 120 Posts
Learn to rev match downshift.
'04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//OEM Hardtop//Bride Gias II//Autokonexion CF Trunk v2
'06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line//Spin On Oil Filter Conversion
'91 MR2: Planned 1MZ V6 or 3SGTE swap
Driver Mod Level: Focus ST Academy So Cal Champion '12
The Following User Says Thank You to Neverlift For This Useful Post:
easy (09-13-2012)
 Old 09-13-2012, 08:11 PM   #14
easy's Avatar
Groans: 27
agreed, at the very least i will say you would need to be able to do a rev match downshift so you don't upset the car right before a turn.
but don't stress to much about it ... its your first time just go have fun ...
08 MS3
 Old 09-13-2012, 09:54 PM   #15
jakk's Avatar
I try to practice rev match downshifts every day during my commute. I get some perfect and I miss some, but I figure if I do it enough it should become muscle memory. My main goal is just really to have a cool story to tell people and get a feel for what the car might really be capable of. I know it will probably be baptism by fire the first time, but I figure that I have to start somewhere and just not be worried about being the next Ken Block.
daafisch likes this.
 Old 09-13-2012, 10:01 PM   #16
Code Monkey's Avatar
Posts: 1,696   (View Stats)
Don't sweat it, show up, have fun, and learn as you go.
2006 Mazdaspeed6 GT
BNR S3|HPFP|SRI|TIP|TMIC|PnP TB&IM|DP|CBE
ACT 6 puck|R6|S6|Dreadnaught|Juggernaught
6ULR 17x9|Hankook RS3|DBA 4000|Carbotech XP12
freektuned
awaiting... FCM 3140 coilovers|cage+racing seats+harnesses
Code Monkey is online now   Reply With Quote
 Old 09-14-2012, 07:13 AM   #17
deuce_WI's Avatar
Have fun. It's just a fun trackday, not a competition. You won't set any lap records, and no one cares if you brake early or miss an apex.
And listen to your instructor and soak in as much info as you can. Those guys have been driving for years and have tons of experience. You'll probably learn more about driving and more about how your car handles from this one day then all of your previous driving experience put together.
The Following User Says Thank You to deuce_WI For This Useful Post:
 Old 09-14-2012, 07:20 AM   #18
Able
helmetface's Avatar
Posts: 4,416   (View Stats)
Groans: 124
Ken Block ain't even Ken Block.
helmetface is online now   Reply With Quote
 Old 09-14-2012, 06:53 PM   #19
RaPiER's Avatar
Posts: 45   (View Stats)
RaPiER is a glorious beacon of lightRaPiER is a glorious beacon of lightRaPiER is a glorious beacon of lightRaPiER is a glorious beacon of lightRaPiER is a glorious beacon of light
Didn't see it in the thread, don't use your e-brake after each session or you'll screw the brakes.
RaPiER is offline   Reply With Quote
The Following User Says Thank You to RaPiER For This Useful Post:
BPASPEED (09-14-2012)
 Old 09-15-2012, 01:56 AM   #20
jakk's Avatar
Ok, thanks for the tip. Why is that exactly? Does it have to do with how hot the brake will get?
 Old 09-15-2012, 03:45 AM   #21
GODspeed7's Avatar
Posts: 2,614   (View Stats)
Groaned at 46 Times in 31 Posts
As entertaining as his videos are, this is a true statement.
probably sent from a freight train at work
2012 Mazdaspeed3 Black Mica
HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete.
 Old 09-15-2012, 06:26 AM   #22
Yes, the rotors will get super hot, if you use the e-brake afterwards you can either warp them of create a nice weld.
2006 Mazdaspeed6 GT
freektuned
First time at the Track rghispanic88 Drag Racing 20 03-19-2012 03:38 PM
First Time @ the Track! 11cruzito11 Drag Racing 6 08-11-2009 07:35 AM
First time at a track xxandrossxx Drag Racing 13 08-09-2009 10:07 PM
First time at track TXspeed3 Drag Racing 27 07-30-2009 12:23 PM
1st time at the track... Renzokuken Drag Racing 33 09-18-2008 05:46 AM
Page generated in 0.49123 seconds with 31 queries
