Autosports Area
> Auto-X / Road Racing / Time Attack
Like Tree91Likes
 Old 02-21-2016, 06:02 AM   #41
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,458   (View Stats)
Groans: 2,978
For the subframe you could lower the leading edge of the diffuser and create a panel over the subframe. Youn might have to find a way to limit the droop travel in the rear.
You also don't have to trim the diffuser at all. Parts that stick out beyond the bumper can still be effective. And given the ankle cutters out front it may look more cohesive all around.
I hugged rfinkle2
 Old 02-21-2016, 11:11 AM   #42
brandon3212's Avatar
Posts: 421   (View Stats)
I'd have to see about limiting the travel. Not a fan of putting anything under there thats going to cause ground clearence issues. The car already scrapes on everything.
Maybe something like a thin sheet of UHMW plastic could work, that way it could flex and scrape all it wants and not get damaged. There still lies the issue of having a giant hump in the middle of a flat undertray.
07 Speed 3
Handling: H&R Springs, Koni yellow shocks, JBR .250 Competition RSB, Whiteline poly control arm bushings, Custom 1/2" rod end RSB links, JBR 88D Trilogy, steel RMM bushings, Sparco Pro 2000 race seat (driver), Kirkey race seat (passenger), shift plate, 18X10.5 +15 RPF1, 275/35 18" Nitto NT01
Brakes: Wilwood 6 piston calipers, Cobalt Friction XR1 race pads
Power: Custom 3.5" intake, Synapse Diverter valve, dual 3" Hood Exit, BNR S3, Treadstone 3126 core, 3 port EBCS, 3" custom cold pipe, 2.5" custom underroute hot pipe, Aquamist HSF4
 Old 02-21-2016, 11:35 AM   #43
Raider is mah Homie
Groans: 2,978
The whole undertay really needs to be lowered to clear the subframe without a hump.
I hugged rfinkle2
 Old 02-29-2016, 06:26 PM   #44
Spent an afternoon at Toronto Motorsports Park on Sunday
Unfortunately the car was plagued with suspension, braking and overheating issues. I could not drive and corner the way I wanted and the track way really too slow to properly feel any benefits of the aero, if it actually does anything at all. At least I know where my problems lie and fixes will be pretty simple. I was slow as fuck but the car was a huge hit with everyone at the track.
One good thing is that Potenza RE71R tires are fucking amazing and provide stupid amounts of grip. This was probably there 1 and only track day, they will spend most of their time as street tires, the cold grip is incredible so they should work really nice.
I do have some cool pictures to share, but thats all unfortunately.
redneck4Christ likes this.
07 Speed 3
The Following 4 Users Say Thank You to brandon3212 For This Useful Post:
Code Monkey (02-29-2016), Easter Bunny (02-29-2016), rolliepollie07 (01-05-2017), Z32_MS3 (03-04-2016)
 Old 06-03-2016, 01:16 AM   #45
impossible's Avatar
Posts: 720   (View Stats)
Groans: 30
Not my cup of tea but I can respect the work put in on your aero stuff
700hp Speed Solutions build underway...
 Old 01-11-2017, 07:43 AM   #46
So uhhh, guess what this isn't dead and never really has been
Here are some pictures of my diffusing front splitter I've been working on. it will mate up to a full flat floor and vent into the fenderwells.
Some rear diffuser work, still in the early stages.
Hood vented radiator progress. Still a bunch of sheet metal work to do.
07 Speed 3
ChaunceyM (01-12-2017), Code Monkey (01-11-2017), jtday (01-14-2017), Mauro_Penguin (01-19-2017)
 Old 01-11-2017, 07:45 AM   #47
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Send nudes?
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
The Following 3 Users Say Thank You to WetzMS3 For This Useful Post:
brandon3212 (01-11-2017), Easter Bunny (04-23-2017), KiwiFlavor (01-11-2017)
 Old 01-11-2017, 08:33 AM   #48
Definitely
07 Speed 3
The Following 10 Users Say Thank You to brandon3212 For This Useful Post:
ChaunceyM (01-12-2017), Crarrs (01-16-2017), Easter Bunny (01-14-2017), g00s3y (01-13-2017), jtday (01-14-2017), KiwiFlavor (01-11-2017), Mauro_Penguin (01-19-2017), MS3Shadow (01-11-2017), sharksinspace (01-11-2017), WetzMS3 (01-11-2017)
 Old 01-14-2017, 06:46 PM   #49
Raider is mah Homie
Groans: 2,978
On the rear diffuser you could use a different profile in the middle and be more agressive where you have the room
I hugged rfinkle2
 Old 01-16-2017, 11:30 AM   #50
I've joined a Facebook group called "time attack builders" and that vast amounts of information about aero setups. I've posted up a few times with my questions and ideas and so far everything seems to check out within reason. The goal at the end of the day is to have something that actually works to a reasonable extent and isn't just 50lb of cool looking plastic and wood.
This is what I've got so far
07 Speed 3
Code Monkey (01-16-2017), Easter Bunny (01-17-2017), Mauro_Penguin (01-19-2017), WetzMS3 (01-16-2017)
 Old 04-07-2017, 02:57 PM   #51
Front splitter just needs tome front mounting cables and an air dam and it'll be complete. I'm picking up some very thin aluminum do channel air through the opening of the bumper and into the rad.
Thinking of making a larger front splitter that will extend past the wheels that I can easily bolt up. More on that later.
Rear diffuser is also done other than custom crashbar with mounting points. Plates have been welded into the chassis so I can bolt up the mounting arms.
Fender vents just got here from the laser cutter. If I have time tomorrow I'll see what it's going to take to install them.
07 Speed 3
The Following 7 Users Say Thank You to brandon3212 For This Useful Post:
Code Monkey (04-07-2017), Easter Bunny (04-23-2017), jtday (04-07-2017), Mauro_Penguin (04-09-2017), Mr Wilson (05-10-2017), rolliepollie07 (04-08-2017), Varomnia (04-08-2017)
 Old 04-08-2017, 04:24 PM   #52
rolliepollie07's Avatar
Posts: 815   (View Stats)
rolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond repute
Canard template for 2 pp touches?
rolliepollie07 is offline   Reply With Quote
 Old 04-10-2017, 10:42 AM   #53
I'll post the CAD file when the new ones are done. The ones on the car are getting replaced
07 Speed 3
The Following User Says Thank You to brandon3212 For This Useful Post:
rolliepollie07 (04-10-2017)
 Old 04-10-2017, 11:01 AM   #54
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,703   (View Stats)
Groaned at 33 Times in 19 Posts
Fury Road Mazdaspeed.
MAKE LOVE TO THE CANVAS
brandon3212 (04-10-2017), Easter Bunny (04-23-2017), Mauro_Penguin (04-10-2017)
 Old 04-10-2017, 02:00 PM   #55
I wasn't even the one who started calling the car "Mad Max" lol, it was random people on facebook. It just caught on
07 Speed 3
 Old 04-11-2017, 07:29 AM   #56
Supports are mounted
07 Speed 3
The Following 5 Users Say Thank You to brandon3212 For This Useful Post:
ChaunceyM (04-11-2017), Code Monkey (04-11-2017), g00s3y (04-13-2017), Mauro_Penguin (04-20-2017), nindoja (04-11-2017)
 Old 04-11-2017, 02:25 PM   #57
This gives you a better idea of the scale of the diffuser
Hood progress, forgot to post these a while ago.
07 Speed 3
The Following 6 Users Say Thank You to brandon3212 For This Useful Post:
Code Monkey (04-11-2017), daafisch (05-10-2017), Easter Bunny (04-23-2017), Mattyhawk1 (04-19-2017), Mauro_Penguin (04-20-2017), Mr Wilson (05-10-2017)
 Old 04-11-2017, 09:26 PM   #58
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 267
Sent from my Pixel XL
ChaunceyM and AwAfrican like this.
The Following User Says Thank You to MS3Shadow For This Useful Post:
Tomas (04-12-2017)
 Old 04-17-2017, 06:28 AM   #59
Diffuser mounted
07 Speed 3
btstarcher (04-17-2017), ChaunceyM (04-17-2017), Code Monkey (04-17-2017), daafisch (05-10-2017), Mauro_Penguin (04-20-2017), nindoja (04-17-2017)
 Old 04-19-2017, 08:29 AM   #60
It's all together, fits great. Now to come up with some side aero ideas
07 Speed 3
Code Monkey (04-19-2017), daafisch (05-10-2017), Mattyhawk1 (04-19-2017), Mauro_Penguin (04-20-2017)
 Old 04-21-2017, 08:03 AM   #61
Placed an order for MCA XR series coilovers, these should be much better than my Koni/H&R combo.
David_Cudd likes this.
07 Speed 3
Code Monkey (04-21-2017)
 Old 04-21-2017, 08:39 AM   #62
Code Monkey's Avatar
Posts: 7,623   (View Stats)
What spring rates will you be running? I know of an MS3 that runs 1000/900 (18k/16k) springs at COTA.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
MCS coilovers|Brembo BBK|6UL 17x9|Nitto NT01
2000 E39 M5
2001 MR2 2ZZ
 Old 04-21-2017, 11:28 AM   #63
MCA suggested 10KG/6KG, not confirmed yet.
07 Speed 3
The Following 2 Users Say Thank You to brandon3212 For This Useful Post:
Code Monkey (04-21-2017), Easter Bunny (04-23-2017)
 Old 04-21-2017, 02:23 PM   #64
With the extra downforce, you most likely want to go way stiffer with valving to match.
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
brandon3212 (04-24-2017), btstarcher (04-23-2017), Easter Bunny (04-23-2017), Mauro_Penguin (05-01-2017)
 Old 04-23-2017, 06:37 AM   #65
Raider is mah Homie
Groans: 2,978
Agree, if everything works you will likely bottom out normal suspension very easily.
I hugged rfinkle2
The Following 4 Users Say Thank You to Easter Bunny For This Useful Post:
brandon3212 (04-24-2017), btstarcher (04-23-2017), Code Monkey (04-23-2017), Mauro_Penguin (05-28-2017)
 Old 04-24-2017, 07:30 AM   #66
That thought had crossed my mind actually
I'll shoot MCA an Email and see what they think
EDIT: I sent them an Email with more information and pictures of the setup, I will hopefully hear back tonight of tomorrow.
07 Speed 3
Code Monkey (04-26-2017)
 Old 04-26-2017, 06:44 PM   #67
MCA assures me that the XR coilovers can absolutely handle much stiffer springs if needed and it won't upset the valving.
They say that whats provided will more than likely be suitable. I guess we'll see haha
07 Speed 3
Code Monkey (04-26-2017), Easter Bunny (04-27-2017)
 Old 04-28-2017, 07:14 AM   #68
Radiator ducting lower half almost done, just need to get it fastened somehow.
07 Speed 3
Code Monkey (04-28-2017), daafisch (05-10-2017), Easter Bunny (05-09-2017), Mauro_Penguin (05-01-2017)
 Old 04-30-2017, 12:59 PM   #69
David_Cudd's Avatar
Posts: 23   (View Stats)
David_Cudd has a spectacular aura aboutDavid_Cudd has a spectacular aura about
Looks pretty sweet!
David_Cudd is offline   Reply With Quote
 Old 05-01-2017, 02:07 PM   #70
Giant prototype splitter, because reasons
Rad shroud mounted for fitment, still needs a bit more trimming in spots
07 Speed 3
Code Monkey (05-01-2017), daafisch (05-10-2017)
 Old 05-03-2017, 06:56 AM   #71
Hood is test fitted for ducting, ordering the rest of the steel today.
Bumper is marked out for trimming
07 Speed 3
ChaunceyM (05-04-2017), Code Monkey (05-03-2017), daafisch (05-10-2017), Easter Bunny (05-09-2017)
 Old 05-04-2017, 07:12 AM   #72
07 Speed 3
ChaunceyM (05-04-2017), Code Monkey (05-04-2017), daafisch (05-10-2017), Easter Bunny (05-09-2017)
 Old 05-09-2017, 10:43 AM   #73
Raider is mah Homie
Groans: 2,978
you need to spread your pictures out into multiple posts so i can give you more thanks.
please get a hood prop before you hurt yourself, i want to see this fucker finished.
I hugged rfinkle2
brandon3212 (05-23-2017)
 Old 05-09-2017, 01:58 PM   #74
David_Cudd's Avatar
Is that splitter made from abs plastic or composite?
 Old 05-23-2017, 01:48 PM   #75
hahaha, thanks man I'm glad you like it. I just remove the hood when I work on it, it currently doesn't close because the vent isn't done (hits things).
3/8" plywood, sealed and painted. Currently working on a composite model.
Bit of a delay as I was in Texas the last 2 weeks for work. I returned to boxes of parts that included MCA XR coilovers and I bunch or CS parts. I installed the coilovers up front and got the wheels mounted.
Coilovers up front weigh 13LB compared to the Koni's @ 17LB.
Wheels look awesome, front fenders are at my house getting the insides glassed to prevent flex and cracked flares. Doors are off so I can paint the car for the summer.
I think for the flat floor I'm going to do pink Styrofoam covered in fiberglass and west epoxy. It's light and easy to work with.
07 Speed 3
Code Monkey (05-23-2017), David_Cudd (05-24-2017), Easter Bunny (06-01-2017), Mauro_Penguin (05-24-2017), Mr Wilson (05-25-2017), thrisnospork (05-30-2017)
 Old 05-26-2017, 09:48 AM   #76
Pics from before install
07 Speed 3
Code Monkey (05-26-2017), Easter Bunny (06-01-2017), Mauro_Penguin (05-28-2017), thrisnospork (05-30-2017)
 Old 05-29-2017, 10:41 AM   #77
07 Speed 3
David_Cudd (06-01-2017), Easter Bunny (06-01-2017), Mauro_Penguin (05-29-2017), Mr Wilson (06-08-2017), thrisnospork (05-30-2017)
 Old 06-02-2017, 06:48 AM   #78
Pretty much all the plumbing is done. Just need to finish some coolant lines.
All the stuff is on order to build the flat floor. Should be in next week
07 Speed 3
David_Cudd (06-03-2017), Mr Wilson (06-08-2017)
 Old 06-19-2017, 07:11 AM   #79
Sorry for the delay in updates, I've been working nonstop on the motor getting the car running. Car is now running on the base map and all the bodywork is mounted. Flat floor should be done this week and the rest of the car should be painted.
07 Speed 3
ChaunceyM (06-19-2017), Code Monkey (06-19-2017), KiwiFlavor (06-19-2017), Mauro_Penguin (06-19-2017)
 Old 06-19-2017, 07:22 AM   #80
KiwiFlavor's Avatar
Posts: 2,315   (View Stats)
This turned out great.. better than giving Sara crap about putting 3 in the hurtin'!
What u gonna do with them Konis? lol
2012 NASA Spaceship Gray MS3
brandon3212 (06-19-2017)
Offset Effects license2ill MazdaSpeed 3/6 - Wheels & Tires 11 02-20-2015 04:17 PM
Effects of CC not being ventilated? Keko 2010 MS3 - Engine, Transmission & Driveline 14 10-08-2013 10:17 PM
Wash/wax effects on MPG 2k4_8 Gen2 MS3 General Discussion 40 07-29-2011 08:11 PM
Pics With Effects! HighSun_Murder Members Rides Gallery 34 04-14-2010 02:23 PM
Page generated in 0.67452 seconds with 30 queries
