Autosports Area
> Auto-X / Road Racing / Time Attack
Like Tree2Likes
  • 2 Post By Code Monkey
 Old 03-13-2017, 02:35 PM   #1
Code Monkey's Avatar
Posts: 7,642   (View Stats)
Default Toyota MR2 Spyder
Just picked up a red '01 as a replacement for my '91 Miata. The car has 220,000 miles, and about 75,000 miles on a 2ZZ engine. About 185hp with an 8,100 rpm redline, 6-speed transmission. Will use the Spyder as a cheap backup to the Racepig. At a minimum, the car needs a baffled oil pan (just ordered) and a roll bar before I test the car at the Texas World Speedway and decide on further upgrades.
Neverlift and redneck4Christ like this.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
Neverlift (03-14-2017)
 Old 03-13-2017, 03:02 PM   #2
Jakeypoo's Avatar
Posts: 214   (View Stats)
Jakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond repute
Rear engine, rwd. Should be fun. What do you think of the "trunk" under the hood?
2009 Mazdaspeed with 134,000 miles, Corksport Turbo, AT internals, CNT Turbo Back, AP, fully mounted, 3 bar, Freaktuned E25.
Jakeypoo is offline   Reply With Quote
The Following User Says Thank You to Jakeypoo For This Useful Post:
Code Monkey (03-13-2017)
 Old 03-13-2017, 07:56 PM   #3
When you remove the spare, there should be enough room for a duffel/gym bag.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 03-13-2017, 09:03 PM   #4
tegxsi's Avatar
Posts: 1,216   (View Stats)
Groans: 80
Any other goodies other than the 2zz swap?
2018 Audi RS3
2007 Acura TSX 6MT
Code Monkey (03-14-2017)
 Old 03-14-2017, 08:29 AM   #5
Neverlift's Avatar
Posts: 4,690   (View Stats)
Groans: 1,138
Noice.
Past Mazdas & Speeds
'99 BMW 328is: 18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50//KW Variant 3 w/ Vorshlag plates//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Sparco Ergo II w/ 6 point Schroth Clubman Harness//Bimmerworld Billet Floor Mount//ZSL Aluminum Radiator w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//Active Autowerke GenII Track Pipe & Catback //Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//Visionary Performance Custom Welded 4 Point Rollbar w/ Harness Bar & Gusseted X Brace//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//AKG M3 Adjustable FSB Endlinks w/ 95 M3 FSB//OBD1 M52B28 w/ 230+whp
The Following User Says Thank You to Neverlift For This Useful Post:
 Old 03-14-2017, 11:34 AM   #6
I do not think there is anything else done the car, but most importantly, all electronics work, there are no check engine lights, a/c is freezing cold. Just ordered a replacement soft top and will try fitting Lotus Probax seats which came from my Miata.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 03-14-2017, 02:13 PM   #7
Neverlift's Avatar
Groans: 1,138
There is an importer in Texas that gets the hardtops from the UK often.... hint hint, wink wink, nudge nudge.
 Old 03-14-2017, 05:39 PM   #8
Not going the hard top route this time. I had two Miata hard tops and they were always a pain in the ass to store and to worry about being stolen.
2006 Mazdaspeed6
2017 Subaru BRZ
The Following User Says NO Thank You to Code Monkey For This Un-useful Post:
Neverlift (03-15-2017)
 Old 03-16-2017, 04:56 AM   #9
redneck4Christ's Avatar
Posts: 1,801   (View Stats)
redneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the world
Groans: 24
Nice.
You flip cars like a used car lot it seems. Is the Civic still around or is it gone now too?
2007 Cosmic Blue MS3, Stage 0.75, baby hauler.
Originally Posted by TheFlash View Post
Sorry I couldn't make it out, I ran out of makeup so I didn't leave the house.
redneck4Christ is offline   Reply With Quote
The Following User Says Thank You to redneck4Christ For This Useful Post:
Code Monkey (03-16-2017)
 Old 03-16-2017, 05:02 AM   #10
My parents are still driving it, it will be for sale in a couple months though when they are gone.
2006 Mazdaspeed6
2017 Subaru BRZ
redneck4Christ (03-16-2017)
 Old 10-03-2017, 10:17 AM   #11
Sold the Civic the first weekend after the parents left, the Spyder is in the shop now getting a broken lift bolt extracted. I installed the Moroso oil pan a while ago and have a roll bar waiting at home, will install it when I get the car back from the shop.
2006 Mazdaspeed6
2017 Subaru BRZ
Here's the BMW i8 Spyder WITH its roof Haltech Automotive News 0 02-28-2017 03:10 PM
Here's the BMW i8 Spyder without its roof Haltech Automotive News 0 02-16-2017 08:10 AM
Take a POV hot lap in the Porsche 918 Spyder Haltech Automotive News 0 04-14-2014 05:30 PM
Rumormill: BMW i8 Spyder gets production nod Haltech Automotive News 0 12-18-2013 03:00 PM
Goblinize your Can-Am Spyder, get strange looks Haltech Automotive News 0 08-07-2009 02:50 PM
Page generated in 0.31212 seconds with 25 queries
