-   MazdaSpeed 3/6 - Troubleshoot/Diagnostics (http://www.mazdaspeedforums.org/forum/f293/)
-   -   07 Mazdaspeed 6-cranks but doesn't start (http://www.mazdaspeedforums.org/forum/f293/07-mazdaspeed-6-cranks-but-doesnt-start-214792/)
Ctown2Ctown 11-10-2017 09:28 PM
Hi all.
I had a brake line go out on me a few weeks ago. Being a full time student with a full time job (plus some part mix ups) I didn't get a chance to fix it until yesterday. I got the new line installed, the brakes fully bled and went to take it for a test drive. Unfortunately the battery was dead. No biggie, so I jumped it. It cranked for a bit, halfway started and then died. I had advance charge the battery for me and put it in last night. Since then it has done nothing but crank without starting. It was running great before I parked it.
I can hear the fuel pump and it smells like gas after cranking it a few cycles, so it's getting fuel. The other mystery is that it's not throwing any codes. I've checked all the fuses and none are burnt. The immobilizer light is acting like normal, and everything seems to be in good operating order it just won't start. I'm just wondering if there's anything blatantly obvious that I'm missing.
Djohns 11-11-2017 03:33 AM
Check the battery again. If it so happens it’s drained, you either have a bad battery or a bad alternator.
Fstrnyou 11-11-2017 06:01 AM
If you smell a lot of gas and think it might be getting flooded, hold the pedal to the floor while cranking to clear it out.
Ctown2Ctown 11-11-2017 02:24 PM
I let it sit for a whole day. I think it's fine but I'll try it tonight.
Page generated in 0.16666 seconds with 11 queries
