| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | | #41 | ![]() |
![]() Join Date: Apr 2008 Location: Salt Lake City, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
Groaned at 126 Times in 71 Posts
(Thread Starter) | Not Ranked : 0 score I am not sure what more I can do to reduce KR at this point. I am going to try a v103c & give it 50 miles to settle in before logging. |
![]() | | #42 | ![]() |
what are your LTFTs at this point? | |
![]() | | #43 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'll get a log of that. I just tested a v103 map, and it isn't helping. I'm going to go back to v102 & give it some miles. The thing that pisses me off is that I know of another guy with the same mods testing the same v103 maps & seeing way less KR than me. I am seriously close to selling this POS car before I throw a rod. |
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here are some 4th gear logs showing KR & fuel trims respectively on v102. Outside temps were low 50s & I have 30+ miles since flashing back to v102. |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here are a couple of 3rd gear logs of the same. KR is significantly worse (4.9) in 3rd. I also notice boost hitting 20 psi. |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score Fuel pressure looks good. Here's a log of 3rd & 4th, respectively. |
![]() | | #47 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 ![]() http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. | |
![]() | | #48 | ![]() |
| Not Ranked : 0 score Reseat the gasket from the stock plastic inlet pipe to the turbo inlet and then tighten it up good. I have a good feeling you will see a good improvement on knock. |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score I tightened all the clamps i could find. The ones on both ends of the blue Cobb intake hose, on both ends of the hose from the turbo to the intercooler, on both ends of the hose between the intercooler & the intake... I'll try to find where the stock plastic inlet pipe connects to the turbo inlet & check that next if I can find it. |
![]() | | #50 | ![]() |
Groans: 754
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 ![]() http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. Last edited by FreeFlyFreak; 11-11-2008 at 04:40 PM. | |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, I finally ripped the intercooler & battery out to get to the turbo inlet clamp. I tightened it down as far as I dare without stripping it. I didn't give it any miles, but I decided to take it for a run since this has helped so many others. Well, I'm still getting 1.4 KR in 4th & 4.9 KR in 3rd. Last edited by badams118; 11-20-2008 at 06:53 PM. |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Fucking a, I think I found the problem... |
![]() | | #53 | ![]() |
![]() Join Date: Nov 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,218
Groans: 94
Groaned at 38 Times in 19 Posts
| Not Ranked : 0 score |
![]() | | #54 | ![]() |
![]() Join Date: Mar 2008 Location: Earth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
__________________ 2008 Stage 3 Roush Mustang 302E 5.0L Stroker 647rwhp-620 rwtq |
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score Its the fuel pump. If you see the fuel pressure line, it falls on its face just as the boost passes 15 psi & KR kicks up. Its the engine trying to keep AF in line. It is classic fuel pump failure. I should have figured it out much earlier in hindsight. |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score One more thing. I believe this is also related to the P0421 CEL I have been seeing. It popped up again on that fuel cut run. I bet the exhaust is throwing the CEL because the AF is out of line going in. Id put money on it. |
![]() | | #57 | ![]() |
| Not Ranked : 0 score So what are you going to do?
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have a CP-E unit on order. |
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, I got the CP-E pump installed. I am paranoid shitless about it. The engine sounds like it has a slight tick (I only notice it with the hood up). It is also putting out a fair bit of white smoke (water vapor). There was a little water on the ground behind the exhaust. I took a log at idle & blipped the throttle (attached). There was no CEL. I am thinking about bringing it by the local shop just to make sure everything is a-ok. So many hoses & shit removing the intake & intercooler that I probably fucking forgot something... who knows. Updates to follow...
__________________ 2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI Whiteline F/R Sways | SPT SSK | TWM M1 Abrams |
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score Took it for a little drive around the neighborhood. Pressure is there & there is no KR. It seems to run normal, but A/F is not making me feel comfy.
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score Took another drive, went WOT in 3rd from 3k to 4k. AFR dropped nicely to ~10 & fuel pressure held, but KR jumped to 3.2. Definitely not the results I was looking for. A closer listen to the engine ticking definitely sounds like it is coming from where the FP is. Probably due to not oiling the spring before I put it it. I think it is safe enough to drive to work, though. I'm gonna give it about 50 miles, then run another log.
![]() | | #62 | ![]() |
| Not Ranked : 0 score These engines tick normally...the fuel injectors and the FP tick...
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think you're right. I am just so paranoid with all these blown engines. Right now I am just hoping that the KR will drop with some miles.
![]() | | #64 | ![]() |
| Not Ranked : 0 score Yeah, me too... Everytime I drive my car, I'm expecting the engine to blow... I want to get rid of this car just for that reason...this sucks... Regarding your knock, make sure you put 93 octane in there, if not, add some octane booster; I've used NOS Octane Boost Racing Formula. Works pretty good.
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score That's a good idea. I am going to do that on my next tank.
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, I threw some oct booster in the tank & filled it up. I drove around until I had over 50 miles since I bolted on the pump. I did a 3k - 4k in 4th, and it showed 1700+ FP, dropped to below 11 AFR & had 0.0 KR. So far, so good, even if the pump hasn't quieted down in the slightest... I'll venture a 3-6k run after lunch.
![]() | | #67 | ![]() |
| Not Ranked : 0 score Watch for knock as it usually comes on between 4.5-5.5K RPM. |
![]() | | #68 | ![]() |
(Thread Starter) | Not Ranked : 0 score So... I'm still getting KR as high as 3.5. So much for the fuel pump solution. Attached is a log of 3rd & 4th, respectively.
![]() | | #69 | ![]() |
But you have the AP. Can you do a log showing timing advance, 4th gear pull just like you did it here? | |
![]() | | #70 | ![]() |
Either way, I'll get another v102 log showing timing adv for you after.
__________________ 2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI Whiteline F/R Sways | SPT SSK | TWM M1 Abrams Last edited by badams118; 12-03-2008 at 03:15 PM. | |
![]() | | #71 | ![]() |
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah, I get more KR on v103. It would make sense assuming I have an air leak between the maf & the turbo, and that v103 is giving me more sustained boost. I decided to play it save & flash back to v102 for now. Once Cobb releases their turbo inlet, I'm gonna bolt it on & put t-bolt clamps everywhere from the filter to the intake. If that doesn't fix it, I give up...
![]() | | #73 | ![]() |
(Thread Starter) | Not Ranked : 0 score I've begun wondering if it isn't possible that this could be a leak coming from my BOV? The only hoses without worm clamps are the ones from the BOV to the inlet. Maybe the BOV itself is leaking? I need to find a way to test this theory out.
![]() | | #74 | ![]() |
| Not Ranked : 0 score A leak from the BOV won't cause it since it would mean less boost that you are running and the air would return to the intake of the turbo anyways. |
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score But it is unmetered air, right?
![]() | | #76 | ![]() |
| Not Ranked : 0 score It is you LOSING metered air - not you taking in unmetered air. |
![]() | | #77 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here's a log of 3rd & 4th respectively including spark adv.
![]() | | #78 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I had a mechanic look at the car yesterday. The only thing he suggested was a thermostat that opened at a lower temp...
![]() | | #79 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
Groaned at 24 Times in 6 Posts
| Not Ranked : 0 score Man these cars are a bitch. |
![]() | | #80 | ![]() |
These engines run with pretty tight tolerances, putting in a cooler thermostat will induce premature engine wear.
__________________ 2008 Stage 3 Roush Mustang 302E 5.0L Stroker 647rwhp-620 rwtq | |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f293/2-1-kr-should-i-worry-14026/ | ||||
| How to cure high KR? - Utah Mazdas | This thread | Refback | 05-07-2009 01:36 AM | |
| CPE PNP Harness - Page 6 - Mazda CX-7 | This thread | Refback | 11-10-2008 05:59 AM | |
| Seeing a lot of knock... - COBB Forums | This thread | Refback | 10-29-2008 11:02 PM | |
| Seeing a lot of knock... - COBB Forums | This thread | Refback | 10-29-2008 03:44 PM | |
| Seeing a lot of knock... - COBB Forums | This thread | Refback | 10-28-2008 09:16 PM | |
| Seeing a lot of knock... - COBB Forums | This thread | Refback | 10-28-2008 07:29 PM | |
| Seeing a lot of knock... - COBB Forums | This thread | Refback | 10-28-2008 06:31 PM | |
| Suppliers: Chrysler jury a worry | Haltech | Automotive News | 0 | 09-21-2008 10:20 PM |
| Looming cuts worry L-M dealers | Haltech | Automotive News | 0 | 08-24-2008 10:30 PM |
