 Old 06-07-2018, 05:01 AM   #1
SPACExCASE's Avatar
Posts: 3   (View Stats)
SPACExCASE will become famous soon enough
Question About to buy a speed3 but is giving these codes
Hey all, looking at buying a 2008 speed3 about 97k miles. Had a mechanic look at it before further pursuing this car and its giving these codes:
B2212
U1900
B1318
U2516
Has no engine light on (as of me, then mechanic looking it over). Any idea what could be wrong, and if it's worth asking the dealer to fix it or if I should walk away?
Thanks
Edit: tried Google but couldn't find a definitive answer
SPACExCASE is offline   Reply With Quote
 Old 06-07-2018, 05:52 AM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
If you type those codes into Google followed.by the word Mazda it will give you an idea. We don't memorize codes, so a little work on your end would help us help you
The Following 4 Users Say Thank You to kTaLgsTo For This Useful Post:
InkedInspector (06-07-2018), JSmith (06-07-2018), Pu Manchu (06-07-2018), SPACExCASE (06-07-2018)
 Old 06-07-2018, 05:59 AM   #3
SPACExCASE's Avatar
Oh sorry, here's what I found on Google, but every site seems to be different
B2212-Panel Dim Switch Out of Range
U1900- (CAN) communication bus fault
B1318-Battery Voltage Too Low
U2516-(CAN) Bus Off - Transmit Error
Thanks again, appreciate any help
The Following User Says Thank You to SPACExCASE For This Useful Post:
kTaLgsTo (06-07-2018)
 Old 06-07-2018, 06:23 AM   #4
MSMS3's Avatar
Posts: 2,327   (View Stats)
Groans: 126
Sounds like it either needs a new battery or that the alternator is not keeping the battery charged. Also need to check for a short in the electrical system that might be draining the battery.
The Following 3 Users Say Thank You to MSMS3 For This Useful Post:
InkedInspector (06-07-2018), SPACExCASE (06-07-2018), Vansquish (06-07-2018)
 Old 06-07-2018, 06:40 AM   #5
kTaLgsTo's Avatar
If it isnt just a battery (low/bad batteries can cause some weird things with these cars) then I would walk away personally. A car with actual can bus problems and or body control module problems can be a real pain.
The Following User Says Thank You to kTaLgsTo For This Useful Post:
 Old 06-07-2018, 10:43 AM   #6
tegxsi's Avatar
Posts: 1,235   (View Stats)
Groans: 87
Seems like non-powertrain stored DTC possibly triggered by a low battery voltage at one point in time... If all the interior accessories work then it's probably fine.
You can go through the process of deleting the codes to see if they come back.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 06-07-2018, 12:34 PM   #7
SPACExCASE's Avatar
Thanks everyone, appreciate the help!
So are we giving up on ATR? InclementDeath MazdaSpeed 3/6 - ECU Computer Tuning 2 07-25-2017 11:57 AM
Thanks giving specials? subydoored CorkSport 31 11-28-2014 09:42 PM
code giving me the run around. Johnasaurus 2010 MS3 - Troubleshoot/Diagnostics 25 03-31-2014 07:08 PM
Page generated in 0.27003 seconds with 23 queries
