Notices
 Old 01-26-2010, 09:08 PM   #1
bc2292's Avatar
Posts: 44   (View Stats)
bc2292 is a glorious beacon of lightbc2292 is a glorious beacon of lightbc2292 is a glorious beacon of lightbc2292 is a glorious beacon of lightbc2292 is a glorious beacon of light
Default Ac Compressor Clutch Fail
I was out at the track this weekend. And after i launched, the track manager kindly came over to me and handed me what turned out to be my Ac Compressor Clutch. I read that this has happened to other people. I was wondering what bolts i need and possibly washers?
and pics or tutorials for remounting it would be awesome.
Thanks
bc2292 is offline   Reply With Quote
 Old 05-05-2011, 03:22 PM   #2
digitalskillz's Avatar
Posts: 4   (View Stats)
digitalskillz will become famous soon enough
My AC flywheel fell off a few weeks ago too! What did you end up doing? Did you find just the bolt, or was the compressor siezed up? I'm desparate here. Dealer wants like $1,500 to replace everything.
digitalskillz is offline   Reply With Quote
 Old 05-05-2011, 03:25 PM   #3
PunjabiPlaya's Avatar
Posts: 5,140   (View Stats)
PunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the world
Groans: 131
Groaned at 45 Times in 17 Posts
donate
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
PunjabiPlaya is offline   Reply With Quote
 Old 12-25-2011, 01:43 PM   #4
qtrmile beast's Avatar
Posts: 1,953   (View Stats)
mine failed a couple of days ago any updates on this?
track weight 3220
street weight 3370
fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//dnp manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport
qtrmile beast is online now   Reply With Quote
 Old 12-25-2011, 09:58 PM   #5
jroc's Avatar
Posts: 1,418   (View Stats)
jroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the world
Groaned at 6 Times in 6 Posts
rhoadblock has an ac compressor unit for sale iirc
Sitting on jackstands due to ZZB: 2006 LP MS6
Sitting herrafrush in the driveway: 1990 Miata - new track slut
PARTING OUT ENTIRE SPEED6. LET ME KNOW IF YOU NEED A PART.
jroc is offline   Reply With Quote
 Old 12-28-2011, 09:13 AM   #6
Here are a couple of pic of mine. In the quest for trying to find the right size bolt that fit in there i used a zip tie to figure out the depth of the hole which is about 2 inches at least that is where the zip tie stopped.
The bolt hole is the same wight as the zip tie so it is a really small and short bolt...
track weight 3220
street weight 3370
 Old 08-01-2012, 10:43 PM   #7
Mastacurly22's Avatar
Posts: 1   (View Stats)
Mastacurly22 is an unknown quantity at this point
Default AC CLUTCH BOLT PART# MAZDA OEM BOLTS
I found the bolt part #'s after some serious searching. As far as the washers go, I am just going to buy a variety and see which work best. Here are the Part #'s
BP4K-61L14 and GJ6A-61-L14
They are both bolts for the AC compressor clutch. Dealer was unsure which one was needed (EVEN THEY DON'T KNOW!) so I ordered both. They wanted to charge me $90 bucks to diagnose the problem as I handed them the damn part that fell off...diagnosis in hand.
REMEMBER: You also need a couple washers too to get the shimming of the magnetic clutch right.
Go to Genuine Mazda Parts at Wholesale Prices and search by part #. They're 3 and 4 bucks a piece....might be a good idea to order extras! Couldn't find the washers on there.
Best of luck with this BullS**t problem! TORQUE A DAMN BOLT MAZDA!!!!
Mastacurly22 is offline   Reply With Quote
 Old 08-02-2012, 07:28 AM   #8
aaronc7's Avatar
Posts: 7,048   (View Stats)
Groans: 357
Groaned at 151 Times in 125 Posts
Mine fell off back in the day.... I used some random 10mm bolt I had lying around. Put a little loctite on it and it was golden. I was lucky and found my clutch sitting on the undertray.
'99 Miata | engine delete mod | GTX2867R | ARTech exhaust | Tein Flex 9/6 kg | C3M 15x9 225/45 RS3 | DIYPNP
Compressor Mapping mkriebs MazdaSpeed 3/6 - Turbo Induction 12 02-03-2010 05:35 AM
Compressor surge v2 Dash08 MazdaSpeed 3/6 - Turbo Induction 6 05-31-2009 07:21 AM
Compressor surge babcockxmx MazdaSpeed 3/6 - Turbo Induction 25 05-17-2009 10:00 AM
compressor surge? k0m MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-30-2009 09:21 AM
Page generated in 0.30251 seconds with 26 queries
