MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Sep 2018
Rep Power: 0 ![]() ![]() ![]() Thanks: 5
(Thread Starter) | ![]() ![]() ![]() The AFR on my accessport V3 is stuck at 14.85. I noticed the problem when it would intermittently peg at 14.85 but then work normally. I know the car isn't actually running lean and in fact is running rich for many reasons; the exhaust smells like fuel, the spark plugs are carbon fouled, my fuel consumption is really high and my LTFT are pegged at 20. This is because the 14.85 AFR is being read and trying to be corrected. Im getting the codes: P2187 - lean at idle P2177 - lean at off idle and the code for o2 sensor low voltage which I forgot the code for I've replaced the o2 sensor already and need more ideas on what to look for. Is it possible I bought a dud o2? Is the problem with my harness? |
![]() | ![]() | #2 | ![]() |
Police - Grammarhead ![]() Join Date: Sep 2009 Location: Metro Detroit, MI
Rep Power: 3731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,715
Groans: 1,906
| ![]() There are two O2 sensors. If your AFR is pegged at 14.85, then it is probably your primary O2 sensor that has failed. If you only replaced the secondary, then that wouldn't have addressed the issue with the primary sensor. Also, did you buy a new O2 sensor, or was it used? If it was the latter, there's every chance that the sensor was already fouled by the time you got it.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! ![]() |
![]() | ![]() | #3 | ![]() |
The Following User Says Thank You to Witness For This Useful Post: | Vansquish (12-03-2019) |
![]() | ![]() | #4 | ![]() |
![]() Join Date: Nov 2019 Location: Tucson, AZ
Rep Power: 5 ![]() ![]() ![]() ![]() Thanks: 6
| ![]() ![]() ![]() Have you captured logs of and/or monitored O2 voltage? I think it should be like a waveform going up and down on the primary if i recall... If your AFR is static I would assume the signal would be as well coming from the O2 sensor. Also, what intake are you running? I had crazy high LTFTs (15-20) w/ the MSCAI, adding the air straightener brought it down to 5 in less than 5 min idling. My exhaust wreaked of gas too, super rich. Last edited by C-love; 12-03-2019 at 07:07 PM. Reason: MSF Database - Automerged Doublepost |
![]() | ![]() | #5 | ![]() |
And I think my LTFTs are so high because for some reason my ecu is reading an AFR of 14.85. If the problem was with the AP for example, the car would run normally because the o2 sensor is actually working, but the AP is not. | |
![]() | ![]() | #6 | ![]() |
Groans: 1,906
| ![]() The AP is not the problem, though your tune could be an issue. Could you please post a full list of your modifications? That may help us assist you in diagnosing your issues. In fact, if you could put your full mod list in your signature, that would streamline future diagnoses.
![]() | ![]() | #7 | ![]() |
__________________ 2007 MS3 Stock Turbo - Wiseco Pistons - Manley H-Beam connecting rods - Autotech high pressure fuel pump internals - ARP cap bolts - ARP main studs Balance shaft delete - JBR EGR delete - COBB intake - COBB front mount intercooler - COBB rear motormount - COBB electronic boost controller - COBB access port V3 - COBB blow off valve - Catless downpipe | |
The Following User Says Thank You to Witness For This Useful Post: | Vansquish (Yesterday) |
![]() | ![]() | #8 | ![]() |
Groans: 1,906
| ![]() OK, and if I recall correctly, you're running a Cobb OTS stage 3 93 tune. That tune is, at least theoretically, reasonably appropriate for the modifications on your car. So... That brings us back to electrical issues (i.e. sensor/wiring harness/harness connections/etc.). You might want to check out this thread: AFR stuck at 14.85 There are a couple of possible solutions in there, ranging from replacing a bad fuse or changing spark plugs, to having to replace the ECU. As a place to start, you might want to try checking the ENGINE BAR fuse.
The Following User Says Thank You to Vansquish For This Useful Post: | C-love (Yesterday) |
![]() | ![]() | #9 | ![]() |
| ![]() ![]() ![]() Where do we get our AFR data, is that not from the 02 sensor? |
![]() | ![]() | #10 | ![]() |
Is there a thread that explains how to test if the female connectors on the wiring harness are good or bad? I'm guessing testing for continuity or something?
![]() | ![]() | #11 | ![]() |
![]() | ![]() | #12 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Is it possible the person at autozone sold me the wrong o2 sensor? Could someone tell me what the part number is for the primary o2 sensor for a gen 1 ms3?
![]() | ![]() | #13 | ![]() |
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 39 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| ![]() ![]() ![]() you might want to return that, drop more coin and get an oem sensor.
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
The Following User Says Thank You to LenSpeed6 For This Useful Post: | Vansquish (Today) |
![]() | ![]() | #14 | ![]() |
(Thread Starter) | ![]() ![]() ![]() cant return it because I've installed it already and drove with it on. So that was $200 that could've gone towards a tune. Anyone know which one I should get from rock auto? They have many options.
![]() | ![]() | #15 | ![]() |
| ![]() ![]() ![]() I feel like you might be jumping the gun here, have you made any efforts to see if there is valid sensor output yet? Beyond the AP or a BT adapter you can probably back-probe a connector. |
![]() | ![]() | #16 | ![]() |
| ![]() ![]() ![]() So correct me if I'm wrong but isn't there a bunch of threads stating to stay away from aftermarket O2 sensors? Maybe it's just me and I'm full of shit but keep wasting time and money on a different aftermarket ones or just buy an oem one and be done if that is indeed your problem. I get it they are expensive and it'd be nice to put that money on towards a tune.
![]() | ![]() | #17 | ![]() |
I might be jumping the gun, but I have no idea how to back-probe the connector to check for valid sensor output.
__________________ 2007 MS3 Stock Turbo - Wiseco Pistons - Manley H-Beam connecting rods - Autotech high pressure fuel pump internals - ARP cap bolts - ARP main studs Balance shaft delete - JBR EGR delete - COBB intake - COBB front mount intercooler - COBB rear motormount - COBB electronic boost controller - COBB access port V3 - COBB blow off valve - Catless downpipe Last edited by Witness; Today at 12:07 PM. Reason: MSF Database - Automerged Doublepost | |
The Following User Says Thank You to Witness For This Useful Post: | Vansquish (Today) |
![]() | ![]() | #18 | ![]() |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| ![]() ![]() ![]() NGK/NTK and Denso are fine.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
The Following User Says Thank You to tegxsi For This Useful Post: | Vansquish (Today) |
![]() | ![]() | #19 | ![]() |
(Thread Starter) | ![]() ![]() ![]() so this means either I bought a dud or the problem is with the harness or ECU (?)
![]() | ![]() | #20 | ![]() |
Groans: 1,906
| ![]() Could you post a couple of datalogs including some at idle, and at least one WOT log from ~3000rpm to at ~6000rpm?
![]() | ![]() | #21 | ![]() |
https://cobbtuning.atlassian.net/wik...talog+Monitors And to log: https://cobbtuning.atlassian.net/wik...How+To+Datalog | |
Display Modes | |
AFR STUCK! | mariosalguero | Mazdaspeed3/6 General Discussion | 6 | 06-25-2016 10:28 PM |
AFR stuck at 14.85 | maisonvi | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 29 | 03-06-2016 06:19 PM |
HU stuck | sega_rt | MazdaSpeed 3/6 - Car Audio & Electronics | 0 | 06-14-2013 11:32 AM |
