| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | | #1 | ![]() |
![]() Join Date: Jul 2009 Location: Jacksonville, Florida
Rep Power: 0 ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score My boyfriend does all of the work to my car and ever since the downpipe install I've had the "smoking issue" that I know many others have had too. I have heard that upgrading the fuel pump internals fixes this problem from a couple other mazda owners but my boyfriend is not convinced that the fuel pump has anything to do with the issue and therefore won't fix my problem. I have already purchased an oil restrictor bolt which my bf installed but it didn't help my problem. The next step is to purchase an access port so that we can raise the idle to try to fix the problem. If that doesn't fix it then I'm honestly not sure what I'm going to do. Does anyone have any recommendations on where I should look for an access port for a good price? I'm willing to purchase a used one as well if anyone knows someone selling one. Also has anyone else heard that upgrading the internals to fix the smoking turbo problem? I have already had the PCV system replaced under warranty by mazda which included the new valve cover and all that to attempt to fix this issue but I'm still smoking after idling for a while. If you are curious I previously recorded it here on youtube. [Link: http://youtu.be/x3OrwdB0EUI Any help is much appreciated. Thank you!
__________________ Blake Kerstin @designwithpink www.HelloBlake.com [SIGPIC][/SIGPIC] 2007 MazdaSpeed 3 // K&N Intake // AP // Exhaust Depot Front Mount // HKS BOV // ATP 3" Long Downpipe // CNT RACING Catback Exhaust // 18" Kazera KZ-J Wheels Last edited by arrestmered07; 07-31-2012 at 06:36 PM. Reason: broken link |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 199 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 940
Fuel pump has nothing to do with smoking. Raise the idle with an AP. You can buy them on here once you become a member (then you can see the for sale section). welcome!
| The Following User Says Thank You to speed23 For This Useful Post: | arrestmered07 (07-15-2012) |
![]() Join Date: Oct 2008 Location: MD
Rep Power: 105 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 240
| Not Ranked : 0 score Smoke at idle fixes, my thoughts and notes Long history. Reducing back pressure increases likihood of turbo smoking. Oil is seeping through the turbo seals and into the exhaust.
__________________ 06 MS6, Blk Mica, MS wheels 18x7.5, Yoko ENvigor P225/45-18, Magnaflow CB, SU MM, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, MPI Upgraded K04, TT Diff Frt mount & Rear Bushings, SP slotted rotors, Hawk rear pads, Whiteline RSB, Steedspeed mani, JBR Thermal Gaskets. Cobb AP RPM: Sport Springs, Shark Fin, LED side markers HKS: BOV CP-e: CDFP, TIP, Xcel CAI, Catted DP, BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, MZR DISI Stage 1 clutch |
![]() | | #4 | ![]() |
__________________ Blake Kerstin @designwithpink www.HelloBlake.com [SIGPIC][/SIGPIC] 2007 MazdaSpeed 3 // K&N Intake // AP // Exhaust Depot Front Mount // HKS BOV // ATP 3" Long Downpipe // CNT RACING Catback Exhaust // 18" Kazera KZ-J Wheels Last edited by arrestmered07; 07-15-2012 at 01:25 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #5 | ![]() |
| Garage Queen ![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 2744 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,331
Groans: 53
Use rotella t6 oil. It is thicker and will not seep thru the seals as easily. Also if you have a dp installed you might want to get something to monitor your fuel presaure.
__________________ 2010 MS3 W/tech pkg Liquid Silver-Still Slower Then An Asthmatic Snail Cobb:Ap,Sri,Tip//JBR:Egr,Rsb,IM/TB Tigs,Rmm,Tmm//ATP:Catless long DP ETS:3.25" TMIC//M/D:OCC//Forge:v.2 BPV//AutoTech:FP Internals//PTP:Seals&studs Bosch:3-Bar//Grimmspeed:3-port EBCS//Stratified:G.A.//KW:Coilovers//RotaGrids:18x9.5 Meth/E85/Nitrous TUNING BY LEX |
![]() | | #6 | ![]() |
| lowspeed ![]() Join Date: Jun 2009 Location: Tally, FL
Rep Power: 1753 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,689
Two ways of addressing the smoking stock K04 turbo- 1) Guaranteed permanent fix- change turbos to a design that doesn't smoke -or- 2) thoroughly address the symptoms- -A) Raise idle -B) Better quality, heavier oil (Shell Rotella T6 5w40) -C) Oil Restrictor Bolt, often referred to here as the 'bnoon bolt' Higher idle speed increases vacuum at idle to help pull oil ffrom the turbo Better, thicker oil helps keep it from pushing through the seals Oil restrictor bolt to prevent excessive amount of oil in turbo so the first two work even better. Is a three legged stool, and needs all three to balance properly.
__________________ Mazdaspeed6 GT #3476 TiGray slicktop Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, TB Coolant Bypass, SU Billet RMM TWM Stage II STS & JBR SSB, Prosport Mech Boost RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued 405/394 AWD - cf1.01 e38 BNRs3 315/372 AWD - cf1.01 e38 k04 |
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | arrestmered07 (07-15-2012) |
![]() | | #7 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks, I'll look into that Oil. I currently use 5w-30 Mobil One Synthetic.
__________________ Blake Kerstin @designwithpink www.HelloBlake.com [SIGPIC][/SIGPIC] 2007 MazdaSpeed 3 // K&N Intake // AP // Exhaust Depot Front Mount // HKS BOV // ATP 3" Long Downpipe // CNT RACING Catback Exhaust // 18" Kazera KZ-J Wheels |
![]() | | #8 | ![]() |
Groans: 53
| Not Ranked : 0 score Yeah you might want to change. It is super thin oil that shears quickly and is prone to oil dilution. It really is the worst choice for a disi motor. Switch over and Im sure the smoking will be instantly gone. A local here decided to switch to mobil for some reason and he had the whole smoke screen in affect. Switched to rotella and on first crank left his car idleinf for an hour because he could not believe fixxed it that easily and quickely.
| The Following User Says Thank You to Sid3wayS For This Useful Post: | Black Metal (07-17-2012) |
![]() | | #9 | ![]() |
__________________ Blake Kerstin @designwithpink www.HelloBlake.com [SIGPIC][/SIGPIC] 2007 MazdaSpeed 3 // K&N Intake // AP // Exhaust Depot Front Mount // HKS BOV // ATP 3" Long Downpipe // CNT RACING Catback Exhaust // 18" Kazera KZ-J Wheels | |
![]() | | #10 | ![]() |
Groans: 53
Used by almost everyone here is the blue/purple bottle labled t6 I think it's 5w-40. It says on the package that it is for diesel and the guy behind the counter will probably try to talk you out of it but dont let it bother you.
![]() | | #11 | ![]() |
Thank you!
![]() | | #12 | ![]() |
![]() Join Date: Sep 2011 Location: miami/norfolk
Rep Power: 142 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
Groaned at 9 Times in 5 Posts
the bnoon bolt helped me with that issue. also, i have a cpe catless. the cobb ap will do wonders for you. after the AP, upgrade the rmm and see if you can get it tuned by the tuners here, the over the shelf tunes that cobb provides arent the best but is good for beginer users and beginer tuners-(in my opinion). lastly, welcome
__________________ Daily/project: 1972 Volkswagen Super Beetle performance:cams,exhaust, upgraded carburetor. baby driven until built motor parts in: 2008 MS3 gt mica black EL NATOR DE Virginia/Florida 260whp/324wtq mustang dyno 4/7/2013 Zoom mods: Injen CAI,CP-e catless Dp, Cobb TIH,PG piping kit with custom IC, and hks catback exhaust Cool mods: CP-e triple gauge pod boost, oil pressure, egt, HKS ssqv with rec. valve, independent yellow fog mod, RA mudflaps,Evo wheels 245/40/18, kSport rr coilovers 16k spring rates In-check mods: Cobb AP,CP-e fuel pump, BNOOB bolt,NGK's 1 step colder plugs, CP-e rmm, CP-e transmission mount,SU aluminum shift bushings, JBR SSP, T6 oil ,MOBIL 1 synt. trans. fluid Spc rear camber arms, MD stg2 OCC, su passenger mount future mods- brakes upgrade, clutch upgrade, summer tires, tuning of some, GS ebcs also on hold to install- , Cp-e safe seals, JBR TIG- IM & TB, .--fuck this is a list!!!!i need to stop buying shyt. Update: possible ringland failure. Bottom end buildup soon to come. |
![]() | | #13 | ![]() |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 1611 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
hey, just a heads up: you probably will want fp internals.. you had dp/internals linked in your mind because adding a dp usually increases the airflow, which increases fuel demand. this can max out your fuel pump's ability to keep up with demand, hence the rule of thumb on here that, when you get a dp, you usually need fp internals as well.. i'm sure you read that, but forgot exactly why the fp and dp were linked.. an ap is a great idea for you, though. with the dp/intake/fmic, you really should have a tune..
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows ![]() ![]() |
| The Following User Says Thank You to tddvrrn For This Useful Post: | 2008speed3 (07-17-2012) |
![]() | | #14 | ![]() |
![]() Join Date: Nov 2011 Location: Corona, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 220
1. Get AP and fuel pump internals, then tune. 2. Stop listening to your boyfriend when it comes to your car. 3. Donate 4. Meet up with local nator guys so they can help you fix it. Especially if you need new seals.
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . |
![]() | | #15 | ![]() |
I just heard from someone who I briefly described my problem too that internals would fix the smoking issue that is why I posted the original question. && my Access port came in the other day I'm going to raise the idle and see if that fixes my problem. After that I do plan on upgrading the fuel pump internals and getting it tuned. Those are on my list for sure. Thanks!
![]() | | #16 | ![]() |
![]() Join Date: Nov 2009 Location: Westchester NY
Rep Power: 233 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 561
read post 50 in this, and post 52 has pics, this has worked for me, smoked like it did for a couple weeks after i installed it, then completely went away and has not come back since no matter how long i idle for or how long/hard i drive it for smoothing out my tune i only installed the one on top from the valve cover vent since i have an OCC with a check valve already
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge |
![]() | | #17 | ![]() |
Just do what we are telling you to do before you blow shit up.
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . | |
![]() | | #18 | ![]() |
yes it does reduce back pressure, but this doesnt have anything to do with injector seals. it has to do with turbo seals and the crankcase venting system. you're turbo smoking at idle after a min or so is not going to cause you to blow up, it will just cause your engine to get dirty and lose power. injector seals dont have anything to do with oil. the help keep combustion chamber pressure, which in turn will help piston rings seal better as well as having a good working crankcase venting set up that keeps the crankcase in vacuum.
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge | |
| The Following User Says Thank You to speedms6 For This Useful Post: | bigriver (07-19-2012) |
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
Groans: 103
so, if you open up the exhaust and that was the point of restriction in the system, it will increase airflow throughout the whole system up to the level where the next limiting factor is. does that make sense?
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows ![]() ![]() | |
![]() | | #21 | ![]() |
I've got my access port and the ATR I'm just not exactly sure what I'm supposed to change to raise my idle. Anyone know where I can find a thread on how to do this, or have tips? I have tried searching but most people just say raise the idle and I haven't found details on how to do that yet. I attached a picture of what I'm looking at. Thanks again for the help & direction.
![]() | | #22 | ![]() |
Rep Power: 0 ![]() Thanks: 0
I'll be polite since I don't post here really, just read, but I love it, you tell her not to listen to me, but just by the following post it's easy to see how much anyone should listen to you. Fortunately someone else came in and corrected your complete fallacy of a post. Then you make demands to donate, when your advice wasn't worth .02 I don't claim to know a ton about these direct injection engines, but I certainly know that a fuel pump isn't going to solve oil being pushed past the shaft seals. Or that a backpressure has anything to do with oil leaking past injector seals.. I was really surprised/disappointed when the restrictor bolt didn't fix the problem, but hopefully adjusting the idle with AP today will. Thank you to everyone else who actually had valuable input to the situation, these cars seem to not follow the path of "conventional" tuner cars..
__________________ 1990 TSi AWD - 523 AWHP - Stock bottom end. Last edited by BigBoost; 07-20-2012 at 11:51 AM. Reason: Typo | ||
![]() | | #23 | ![]() |
<<sigh>> for the 9,264,721st time - DI engines have a high pressure fuel pump since we run 1700-1800 PSI at WOT - the OEM HPFP is pretty much maxed out in stock trim - adding a DP is a known killer of the HPFP as it allows enough air flow to require more fuel than the OEM HPFP can handle. Add to that the K04 turbo relies on back pressure to maintain seal integrity and prevent oil seepage. So, having a DP can & will cause problems with the HPFP and trigger the smoke symptoms. To resolve the smoking symptoms there are two things to do 1) replace the turbo with a design that does not smoke -or- 2) address the symptom with three steps 2a - raise idle for higher vacuum at idle 2b - use high quality thicker oil such as Shell Rotella T6 5w40 2c - use a better design of oil restrictor bolt Higher vacuum to pull oil out better at idle better thyicker oil to help prevent seeping past the seals bolt to help prevent excess oil to begin with. So, you can see that these things are indeed tied together you can also see that this ain't your momma's small block. Learn the platform, or step away before you blow her engine. .
![]() | | #24 | ![]() |
2. Obviously the K04 has been used in plenty of cars before the MS3, all of which can run free flowing downpipes without smoking issues, it's Mazda's inability to remove oil from the turbo with vacuum alone. That's one of the first things I noticed about this car is how little vacuum it pulls at idle. Now, no where did I question the fact of needing a new CDFP to account for the DP? I know that it's pretty much required. Some local with an MS3 is who told me to replace the CDFP to stop the car from smoking, so I'll pretty much refrain from listening to them. I already read your first post, which I understand, and completely agree with so I don't know why you felt the need to post it again. The only thing I pointed out was the guys post being completely wrong, which it was, as one of your other members corrected him. Not sure why your getting all huffy, nothing I said was in any way directed at you. And no SBC here bud
__________________ 1990 TSi AWD - 523 AWHP - Stock bottom end. Last edited by BigBoost; 07-20-2012 at 11:38 AM. | |
![]() | | #25 | ![]() |
As your post reads currently I may indeed have been a bit quick on the trigger. It's a common reaction unfortunately since so many expect this engine to follow normal behavior patterns only to discover the hard way that's not the case.
![]() | | #26 | ![]() |
![]() But I understand, trust me, I was one of those that expected it as well, but I quickly learned that it unfortunately not the case. I consider us lucky to have been running the car with the mods that it has for over a year without any problems(aside from the smoke).
__________________ 1990 TSi AWD - 523 AWHP - Stock bottom end. | |
![]() | | #27 | ![]() |
Lolz- it's not an "unfortunately" thing- it's a good thing once you get over the learning curve.... Much like making the transition from carb to fuel injection, DI brings a lot of good things to the party. I suspect that if your TSi isn't a fluke, then once you get your head wrapped around the MZR engine you'll have a field day with it. Should have been here 2, 3, 4 years ago..... The last year has been remarkably good to us, and there are great things going on. Not too mention some disturbingly talented folks in here
![]() | | #28 | ![]() |
I agree, I think that for what the MS3 is out of the box is pretty impressive for a 2.3 on a tiny turbo. I've never really owned a car on the " bleeding edge " of new tech so I'm sure the curve is something to overcome, and having to deal with a relatively limited aftermarket is certainly a challenge as well. I've just always questioned their ability to handle massive power on the stock bottom end, and with a lack of any aftermarket injectors (for now at least, temporary I'm sure) it's got to be difficult to make big power, unless you can do it with fuel pressure alone. (Which for all I know you can) Not only that but the 2-3-4 years ago you mention, I was reading forums/interwebz of these things going tits up left and right in stock or virtually stock trim so I never really gave them much thought and cast them aside as "weak". It's good to see that the following is large enough to drive new innovations/solutions to their inherit challenges.
![]() | | #29 | ![]() |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 391
Groaned at 9 Times in 7 Posts
__________________ 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Next: TMIC(WTB PM me); meow DP Official 60-100mph Times Official Youtube Channels | |
![]() | | #30 | ![]() |
Yeah, setting the idle it can be tough- the idle tables in ATR are craftily hidden away in a folder called, get this, Idle Tables I know, crazy right? 4 tables to change Idle Base AC - A (set all cells to 900) Idle Base AC - B (set all cells to 900) Idle Speeds Base - A (replace lowest 3 cells with 900) Idle Speeds Base - B (replace lowest 3 cells with 900) Save map, load new map to AP, flash car easy peasy
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Weazsel (07-29-2012) |
![]() | | #31 | ![]() |
![]() Join Date: Jun 2012 Location: Petawawa/Oshawa Canada
Rep Power: 34 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
I wish I could mount my old E16g turbo from my talon ![]() It sits in my trunk to remind me of faster days |
![]() | | #32 | ![]() |
![]() Join Date: Dec 2011 Location: Dartmouth, N.S., Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 6 Times in 4 Posts
Do you have the ventilation upgrade that Mazda officially offered to fix the smoking problem? Mine was smoking at idle but once they put on the new ventilation kit it stopped and hasn't smoked since. That was 8 months ago. I'm going to assume that any mods keep that "fix" from being effective though?
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
I have flashed the ECU and raised the idle to 1100RPM in the Idle Base AC - A and AC - B tables and I changed the lowest numbers in the Idle Speeds Base - A and Base - B to 1100RPM && amazingly, I still smoke. I also did an oil change the other day I am using Rotella T6 oil and I still get the smoke at idle when the compressor kicks on. It seems to be at 17vac it smokes but when I shut off the air it goes to 20vac and stops smoking. I'm ordering a fuel pump this week (taking suggestions on which brand to get) and I'm looking into upgrading my turbo since I believe that will fix my problem.
| smoking issue | dadon1985 | 2010 MS3 - Troubleshoot/Diagnostics | 11 | 05-01-2012 07:41 PM |
| Smoking K04 Issue with some info by dealer | asall667 | MazdaSpeed 3/6 - Turbo Induction | 81 | 10-24-2011 09:13 PM |
| Found what my smoking issue was | turd burglar | MazdaSpeed 3/6 - Turbo Induction | 1 | 01-31-2010 01:47 PM |
| Smoking turbo issue - Gone for me! | kgb | MazdaSpeed 3 - Engine, Transmission & Driveline | 16 | 05-27-2009 02:56 PM |
| Smoking Issue-Another Theory | Speedy3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 10-14-2008 11:30 AM |
