 Old 03-16-2017, 11:04 PM   #1
mituc's Avatar
Posts: 3,423   (View Stats)
Groans: 107
Default BNR S3, high boost/high WGDC and low air flow
So I'm trying to help a friend get his setup sorted out for a local event and then before he reaches out to a professional e-tuner.
He just got his BNR S3 and meth kit on and for some reason the boost we see from his BNR compared to the targeted load is pretty high for what I was expecting.
The setup is pretty much like this:
- custom TMIC;
- BNR S3;
- eBay catless downpipe;
- AEM meth kit spraying through a 500cc/min nozzle;
- HTP 3" intake;
- 3BAR MAP sensor;
I attached a 3rd-4th gear pull log, mind that the load targets are not hit even in the mid range (say 5000rpm).
The MAF cal was scaled down 5% to compensate for the meth spray and apart from slightly higher target load we don't have any major deviations from an OTS versatuner tune.
What can cause this significant strain on the turbo (both boost and WGDC) without seeing air flow values accordingly? We never had in mind 24PSI on this turbo, more like 21-22, but that's where it landed after targeting load values which are perfectly attainable o exceedable even on a stock K04 with similar flow mods.
File Type: csv 3MPS_BL-Data log - 2017-03-15 15.21.23.csv (17.5 KB, 8 views)
2008 Cosmic Blue Mazda 3MPS
StratiVersaTuned FTW to 28PSI, self-tned to 31PSI
SU TMIC, Autotech HPFP internals
Versatuned
 Old 03-17-2017, 10:08 AM   #2
tek_88's Avatar
Posts: 93   (View Stats)
tek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to behold
Groaned at 13 Times in 2 Posts
3bar map sensor, the map scalar tables need to be adjusted.
2006 Titanium Grey MS6
Power
BNR S3 // Stock downpipe (hollowed) // Test pipe // Magnaflow CBE // Cp-e Tmic // 3" HTP // JBR Boost Tubes // JBR Thermal Gaskets // 3Bar Map // Corksport BPV // Egr Block-off // VTCS Disabled // AEM 100% meth (1000cc nozzle) // Cobb Ap V3 // Autotechs // GS 3-port // NGK 6510 // CA 91 oct
PurpleDrank Tuned by Will
Hardware
Cp-e Rear Diff Mount // SURE Juggernaut Front Diff Mount // AWR PMM // Cp-e RMM // Corksport TMM Inserts // DSS Axles // ACT 6-puck w/ Streetlite FW
Cosmetics
TRS Retrofit Bi-Xenon Projectors // 18x8.5 +35 XXR 557 // H&R Lowering Springs // S204 Lip
tek_88 is offline   Reply With Quote
The Following 2 Users Say Thank You to tek_88 For This Useful Post:
mituc (03-18-2017), Vansquish (03-17-2017)
 Old 03-17-2017, 06:50 PM   #3
sheston's Avatar
Posts: 1,844   (View Stats)
I found that running Meth messed up my cfm and loads, depending on how you scaled your MAF etc. I tried loading that run in Vdyno real quick, but couldn't get it to make sense. You might try that, but cutting it down to one gear.
I just made it so my AFRs were dialed in, my CFM is below 300 but Vdyno says I hit over 350 whp. I left it like this, because it was running well, etc
Run it thru Vd and see if the same is happening to you.
The Following User Says Thank You to sheston For This Useful Post:
mituc (03-18-2017)
 Old 03-18-2017, 05:53 AM   #4
mituc's Avatar
Groans: 107
Ok, we'll try some new values next time, however the high WGDC and low air flow remains.
ALso when WGDC exceeds like 90% we start seeing KR at the same loads and BATs where previously we had clear runs, which makes me think that the turbo indeed works hard and all that air flowing through the turbo only (less than 10% goes around it through the wastegate) is the source of knock.
Fortunately in this case all was consistent... We've seen the same cfm (well, g/s) before meth and after adding meth prior to scaling the MAF. And now the current runs are consistent with what we've seen before adding meth, just that the turbo seems to work very hard to get those. It did work hard before meth as well, but now when we tried to extract more load we had the unpleasant surprise to see that the numbers we've seen before were actually the limit of the whole setup as it was then and as is now.
Versatuned
 Old 03-18-2017, 07:29 PM   #5
sheston's Avatar
Something blocking the exhaust or TMIC flow? Air straightener come loose?
 Old 04-26-2017, 01:45 AM   #6
mituc's Avatar
Groans: 107
So this is getting weirder.... The MAP scalars in the logging screen are correct, the g/s are still quite low from what we'd expect from this turbo.
A day ago or so I saw commanded AFRs in the stoich range while the actual AFRs were into the 9s, that in the middle of a WOT pull (begins at line 52 in the attached log).
The MAF g/s could be better especially high in the rev range at that boost (still around 22PSI).
From what I see the turbo (BNR S3) simply doesn't perform as it should, but it's hard to say frankly since I didn't encounter anything like this before.
Please let know what you guys think or what we should look at.
Versatuned
 Old 04-26-2017, 04:19 AM   #7
BuddySpeed3's Avatar
Posts: 418   (View Stats)
BuddySpeed3 has disabled reputation
Groaned at 7 Times in 4 Posts
In regards to the rich AFR, Maybe the OL Fuel Trims are trying to command less fuel to compensate for the meth?
And in regards to the low g/s, maybe the meth is taking up space in the intake manifold which reduces space for air from the intake to fit. It's kind of like when the EGR kicks in on a diesel, The inert gases reduce the g/s reading from the Maf sensor because they take up space.
Maybe try turning the meth off, reduce timing, and then try a pull?
Edit; Nvm, just read that it was doing it even with it off.
Like @sheston; said, it sounds like a blockage, preventing exhaust from exiting. How does the PCV system look?
- 2009 Speed 3 - BNR S4 v2 - HTP 3" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM Vented Catch Can - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Unplugged Egr - Koni Yellow Shocks - Eibach Springs - 94 Oct w/ In Tank Methanol (2 Gallons) - Stock Fuel System (Installing 6th Port Soon) -
The Following User Says Thank You to BuddySpeed3 For This Useful Post:
mituc (04-26-2017)
 Old 04-26-2017, 06:14 AM   #8
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
The oddest thing is why is it targeting stoich? Was that run with the meth turned off?
Try making a new maf curve without the meth
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
mituc (04-26-2017)
 Old 04-26-2017, 06:37 AM   #9
mituc's Avatar
Groans: 107
Yes, that's the weirdest thing that happened so far. The MAF cal is called down about 5-6% so even if it runs out of meth things will not go too bad.
The OL trims are disabled, they are in place up to load 1.06 or something, so I would normally not expect any adjustments but I guess some threshold was exceeded on something which lead to this behaviour. It's like one of those cases when because of boost creep the WGDC go to 0. In this case the AFRs went a bit richer so the system targeted stoich.
Running without meth usually results in a bit of knock sometimes. It happens also because the gas there has a lower octane than advertised but I also suspect that the restriction is on the exhaust somewhere, and because of the strain on the hot side of the turbo we get this knock. An exhaust restriction would explain a few things including the poor performance.
Versatuned
 Old 04-26-2017, 01:45 PM   #10
Poachersun's Avatar
Posts: 20   (View Stats)
Poachersun has a spectacular aura aboutPoachersun has a spectacular aura aboutPoachersun has a spectacular aura about
Thanks for your help guys. This is my car
OK so ill pull the exhaust off over the weekend and inspect the DP with an inspection cam and check the wastegate. The Ebay downpipe looks OK enough to flow but who knows. Also will check exhaust leaks if any.
I did change from my custom intercooler (3" core, stock end tanks) now to a CPE intercooler TMIC, as i thought maybe my custom one was reducing flow. The issues we are seeing have been pretty much from the start, i added meth to try fix the issue because we were getting knock as early as 8deg timing on pump.
The 98 octane/pump fuel shouldn't be an issue now as i am using a known quality 98 octane (93US i think?) which also has e10 (ethanol 10%) so it should be fine.
Poachersun is offline   Reply With Quote
 Old 04-26-2017, 03:45 PM   #11
I'm somewhat skeptical of a restriction with a catless downpipe. It's also odd you're seeing knock with that low of timing. Something's not adding up.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 04-26-2017, 04:00 PM   #12
Poachersun's Avatar
That knock may have been the original fueling i was using. Comparing old logs we found a major difference and i think their claimed "98" (93us) was actually 95 or 91 US which dropped the octane giving knock. Temperatures may have been slightly higher too. I don't go to that gas station anymore as the Gull 98 with e10 which i am using now and other use have had no issues with.
Although we are still having issues now so who knows.
I will also check the spark plugs, although i replaced them 4-5000kms ago NKG 1 step colder plugs, gapped to .26. Ill check the gap and how they look
It's just so frustrating, especially for Victor when it's potentially something simple causing the issues(well, hopefully) we just can't narrow down what it is. It's meaning countless hours logging and testing.
 Old 04-26-2017, 04:14 PM   #13
.26? Be sure they're .026-.028". It's pretty common that gets mixed up. Anyway I doubt that's your issue.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
High KR WOT-high boost, high load c_bye MazdaSpeed 3 - Engine, Transmission & Driveline 13 06-28-2016 08:11 PM
Weird high RPM WGDC and Boost issues crutch77 MazdaSpeed 3/6 - ECU Computer Tuning 33 03-09-2014 05:08 PM
High WGDC bms3mtb 2010 MS3 - ECU Computer Tuning 4 03-04-2012 08:25 AM
0 WGDC, High Load, Low Boost RJTSi
Cobb ATR Support
6 01-19-2010 09:04 AM
Page generated in 0.35214 seconds with 26 queries
