 Old 07-21-2019, 10:44 AM   #1
njdurkin's Avatar
Posts: 55   (View Stats)
njdurkin is an unknown quantity at this point
Default Boost leak test method
I am trying to test for boost leak. At 5psi, i get air leaking from around a connector on top of the valve cover. I have the air line going to the valve cover closed off completely but still appear to be building pressure inside the valve cover. Is this bad for the valves or should i keep turning up the pressure to identify boost leaks. I cannot find any good information about this.
njdurkin is offline   Reply With Quote
 Old 07-21-2019, 03:45 PM   #2
Sensei's Avatar
Posts: 318   (View Stats)
Sensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the world
Some of the intake valves will be opened when you pressurize the system you are unlikely to hurt anything. Many people run 20 psi plus of boost into the engine while it is running. If the tube from the VC to the TIP is leaking then replace it and put some clamps on it.
2009 MS3: Freektune 280/330, CS SRI+TIP, 3" Test Pipe, TR8 FMIC, AT internals, APv3, JBR SSP/CW/SB, JBR RMM 88a, JBR PMM 80, Koni FSD/Stock Springs
Sensei is offline   Reply With Quote
 Old 07-22-2019, 05:35 AM   #3
njdurkin's Avatar
When intake valves are open it allows air into the valve cover?
 Old 07-22-2019, 08:14 AM   #4
Jeff23spl's Avatar
Posts: 2,009   (View Stats)
yes air goes from maf tube, turbo, ic right into the intake. then it goes thru the opened valve down to the piston, past thru the tiny ring gap. From the engine bloc, it get back to the VC
But this should be just a little air because there is just few mills of an inch to let air flow by the rings.
All that assuming you disconnect and plug the tube going from air intake to the VC or connect your boost tester closer to the turbo..... If not, it is like sending pressure thru the oil dip stick....
if you have a massive leak, it may be your pcv...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-26-2019, 09:04 AM   #5
njdurkin's Avatar
https://ibb.co/0FbwSmc
This is the current setup. I get air out of the metal opening where the hose goes to and the small hose that connects to the bpv. At 5psi i get a decent flow of air. At 15lbs it is too much flow for my compressor to keep up. Should i block the air from leaking or is it bad to pressurize the valve cover?
 Old 07-26-2019, 03:25 PM   #6
Sensei's Avatar
What are you calling the "metal opening where the hose goes" is that the breather/crankcase vent that goes from the valve cover to the turbo inlet pipe?
It sounds like you've got some air leaking in the piston rings and/or valve seals. But you don't have any traditional boost leaks between the turbo and the throttle body. A compression and leakdown test would be the next step for evaluating engine health. I'm not quite clear on what you are trying to figure out here or accomplish. Do you have a specific concern?
 Old 07-26-2019, 09:10 PM   #7
njdurkin's Avatar
The main thing was to learn how to do a boost leak test and figure out why i was building pressure in my valve cover. The reason i am doing this is because i am only hitting 10 or 11 pounds of peak boost when my targets are over 15.
 Old 07-26-2019, 09:15 PM   #8
Police - Grammarhead
Vansquish's Avatar
Groans: 1,894
What tune map are you running?
 Old 07-27-2019, 08:35 AM   #9
Sensei's Avatar
I just fixed my car having only spring pressure boost levels and high waste gate duty cycle. The boost control solenoid was broken and always closed. Test the Boost control solenoid. You could also have a clogged line going to or from the BCS. Replace the 4mm line that runs from the top of the wastegate actuator to the BCS and the 4mm line that runs from the BCS to the TIP. Also replace the 6mm line that runs from the turbo compressor housing to the bottom of the wastegate actuator. Secure the lines with the proper sized clamps. Use thick walled silicone lines. Rubber lines will crack and break do to the heat and pressure from the turbo.
It could also be a wiring issue or problem with the PCM not sending the signal to the BCS. There's a test procedure in the FSM I attached the pages.
 Old 07-28-2019, 04:42 AM   #10
njdurkin's Avatar
Thank you for your help. I will try your suggestions.
Btw i am running the Stage1+ with IC 93 v234 tune right now. Ive tried different stage 2 and stage 1 tunes with no difference.
Boost leak test caused an oil to leak from dipstick shazy MazdaSpeed 3/6 - Turbo Induction 13 08-06-2019 05:27 AM
Doing A Boost Leak Test Luke@corksport CorkSport 1 01-11-2018 10:00 AM
Page generated in 0.30456 seconds with 24 queries
