MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | ![]() | #1 | ![]() |
![]() Join Date: May 2017
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | ![]() ![]() ![]() 3 were broken and split on the ceramic and 1 was OK. Changed all the plugs and is now running about 100%. Any idea on the plug scenario?? Sent from my EML-L09 using Tapatalk |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Jun 2015 Location: Santa Cruz, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 978
Groans: 203
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
The Following User Says Thank You to Thor Hammer For This Useful Post: | slimmka (02-06-2019) |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 1041 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,234
Groans: 131
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2, EPL tune, JHM overdrive crank pulley, ZF8 TCU tune, aFe/034 intake, modified air box. Sold 1/25/2019: Sunlight Silver '08 MS3 GT Mods: BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. | |
![]() | ![]() | #4 | ![]() |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2447 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 807
Groans: 56
| ![]() ![]() ![]() Used to be a common issue with denso plugs.
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks Soon to be installed: ST manifold w/ port injection : Raduim Engineering PCV Plate : Radium Engineering PCV valve : Radium Engineering Fuel filter : Aeromotive FPR : DCR VVT : TI Automotive F90000274 Fuel Pump : NX 15718 : Split Second AIC |
![]() | ![]() | #5 | ![]() |
I think we all know what that smell is?? I had denso's in previously but the tips used to burn away after a while. I must hold my hands up to a ropey re map at one point, but I did myself off it with a new ecu!! Sent from my EML-L09 using Tapatalk | |
![]() | ![]() | #6 | ![]() |
![]() Join Date: Oct 2015 Location: Central Jerz
Rep Power: 49 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| ![]() ![]() ![]() Never trust pregaps
__________________ 2010 MS3 - Tuned By Nishan Autotech Fuel Pump Internals OBX R Custom Exhaust Cobb SF Intake & TIH w. Blitz Filter CP-e TMIC Corksport Dual VTA BPV |
Display Modes | |
oil on spark plugs | dereeek | 2010 MS3 - Troubleshoot/Diagnostics | 13 | 10-22-2012 12:09 PM |
Spark Plugs | jerseymazda | CX-7 > General Lounge + New Member Welcome | 18 | 09-11-2011 06:07 PM |
best spark plugs for the car | reconbygod12 | Mazdaspeed3/6 General Discussion | 13 | 06-02-2011 10:26 AM |
spark plugs | speedster 3 | Mazdaspeed3/6 General Discussion | 32 | 10-22-2008 06:01 PM |
Are these spark plugs ok? | Meder | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 10-09-2008 12:21 PM |
