 Old 06-14-2017, 04:42 PM   #1
Bingo's Avatar
Posts: 684   (View Stats)
Groaned at 9 Times in 7 Posts
Default Burning oil, low compression, next steps
Alright so a couple days back I did my routine oil change (T6). This time, I was able to measure how much I took out, and it measured out to 3 qt's (in 5.5k miles + I have the spin on). Yes I know I'm stupid and careless for letting it get that low, and trust me that's not happening again.
Upon doing the oil change, I notice that there is oil buildup where my intake meets the turbo (I noticed it from under the car on the rubber coupler. My car is at 102k miles and this is likely the original K04. Additionally, there was no oil in the recirc hose from the BPV. However, I have seen absolutely no smoke on startup (possibly due to my having both the factory cats still in place).
From there I did a compression test. Not good.
#1 : 160
#2 : 140
#3 : 115
#4 : 150
I would imagine that with oil around the turbo combined with this compression that I would be losing oil faster than that. Now, I would also like to add that the spark plugs were clean, I'm not throwing any codes, and otherwise the car shows no signs of problems. At this point I've already braced myself for the worst (rebuilding + new turbo), but now I'm digging into alternatives. I know the factory injector seals don't last too long, but in the threads I've read it's not often suggested as a possible cause (why is that?). I suppose I'd like some insight based on current symptoms (or lack thereof). Again, other threads I've come across with even higher compression than mine often involve misfires or spiking fuel trims, neither of which I'm exhibiting. Thanks in advance.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Moog endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges.
 Old 06-14-2017, 04:48 PM   #2
Thor Hammer's Avatar
Posts: 1,396   (View Stats)
Groans: 127
I would perform a leak down test next.
Waiting for Install: BNR S3/HTP 3.5 Intake/Damond OCC/ CS Injector Seals/ WMI/MAPerformance Rev3 Intake Manifold
 Old 07-01-2017, 02:09 PM   #3
Bingo's Avatar
Alright, so the leak-down tester I used belonged to my father and is likely 20 years old or so. Cylinders 1 and 4 were tested without issue, but 2 and 3 gave some problems. Putting a thin piece of rod down the plug hole and turning the crank until it was at its highest didn't produce any back-pressure (according to the gauge). So, for those 2 cylinders, I left them pressurized at 30 psi and turned the crank for an entire cycle and the results below are the highest they were able to hold constant. Anyway, this is what I found:
#1 : 92/96
#2 : 24/29
#3 : 9/29
#4 : 84/91
I'm assuming I'll just have to do it with another tester, but that's what happened. Again, I'd like to emphasize that aside from burning ~1 quart every 2.5k (ish) miles, the car appears and behaves fine.
 Old 07-03-2017, 02:00 PM   #4
Bingo's Avatar
Well given everything I've found and stated, the only things holding me back from fully accepting a rebuild is the fact that I'm not consuming as much oil as I think I would given that compression and leak-down (but I could be wrong) and the plugs were all clean.
 Old 07-05-2017, 09:24 AM   #5
Bingo's Avatar
I should've also noted that in cylinder 3's cycle, I could feel air coming from the oil cap. Upon further reading that can only mean rings. So at this point, I'm leaning towards just rebuilding it when I can get a 2nd car and swapping the turbo for an S3 or CS. If anyone has any comments or suggestions, I'm open to them.
 Old 07-05-2017, 03:04 PM   #6
Groans: 127
Originally Posted by rachel stinson View Post
8 Reasons why oil burns:
1) Worn valve guides
2) Bad valve seals
3) Pressurized oil pan
4) Worn piston pan
5) Diagnostic the problem
6) Check the oil
7) Worn piston rings
8) Check the exhaust.
These are the reasons why oil burns and it is harmful to the vehicle.
Troll. GTFO.
impossible (07-21-2017)
 Old 07-05-2017, 08:04 PM   #7
zenit's Avatar
Posts: 1,354   (View Stats)
Groans: 56
Groaned at 7 Times in 6 Posts
Originally Posted by Thor Hammer View Post
Troll. GTFO.
Nope, this is real.
I need to replace my piston pan, it's almost worn out, too
It's a serious problem.
-feejay
-wetzel
Thor Hammer (07-06-2017)
 Old 07-06-2017, 08:31 AM   #8
Groans: 127
Originally Posted by zenit View Post
Nope, this is real.
Think mine is acting up too. Where is the piston pan again? In the valve cavity or under the front right spark column? But don't forget to first "diagnostic the problem."
zenit (07-06-2017)
 Old 07-06-2017, 10:27 AM   #9
aackthpt's Avatar
Posts: 1,444   (View Stats)
aackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the world
I think my problem is "6) Check the oil". No wonder I burn so much, I'm never checking that shit again. I'm never checking my exhaust either, especially if they mean hip checking, though I might stuff a $50 check into it, maybe that counts as "checking" though?
2013 'speed3, silver
Stage Bro
aackthpt is offline   Reply With Quote
The Following 2 Users Say Thank You to aackthpt For This Useful Post:
Thor Hammer (07-06-2017), zenit (07-06-2017)
 Old 07-08-2017, 02:06 PM   #10
Mazduhspeed6's Avatar
Posts: 149   (View Stats)
Mazduhspeed6 is a glorious beacon of lightMazduhspeed6 is a glorious beacon of lightMazduhspeed6 is a glorious beacon of lightMazduhspeed6 is a glorious beacon of lightMazduhspeed6 is a glorious beacon of light
Groaned at 17 Times in 6 Posts
If thiz is serious, i ran into this only 3k miles on a fresh motor, turned out i had some ringlands let go, its common from alot of tuners ive talked too, almost had the exact same compression reading as you. Dropped in another motor, since i used a friendly garage, they didnt care about the aftermarket turbo and other parts n tune and sent me for another motor, this one broke in perfect, sitting at almost over 7k miles 160 across all 4, and barely burns anything. Sorry bud, but im gonna lean towards ringlands....so your rings took a shit.
2007 Mazda Speed6 GT
Power: rebuilt stock motor*
JBR full power path stage II intake w/JBR TIP*
ATP catted downpipe w/ second cat delete*
Corksport HPFP internals*
Corksport BeCuse injector seals*
Corksport Turbo*
Corksport 3.5 Bar MAP sensor*
Corksport EBCS*
Treadstone Tr8 w/ RPM CX racing piping kit*
Suspension: Corksport Lowering Springs
Brakes: Still stock
Driveline: Sure Motorsports R6*
Sure Motorsports Juggernaut*
Sure Motorsports Dreadnaught*
Sure Motorsports shifter bushings*
Corksport weighted Black shift knob
Electronics: Cobb Accessport V3 w/ tune by Will at PD tuning*Purple Drank Tuning*
Mazduhspeed6 is offline   Reply With Quote
 Old 07-08-2017, 02:41 PM   #11
Bingo's Avatar
Yep that's what I've concluded. I'm not disappointed about it really, I knew it was just a matter of time, and since I have no plans to ever sell this thing, I knew I'd have to rebuild it eventually.
 Old 07-17-2017, 07:54 AM   #12
Bingo's Avatar
Alright guys, I'd like some opinions. My engine needs a rebuild, and my turbo is smoking. I'm set on rebuilding the engine myself with my father and brother at the beginning of next summer (when I can get a 2nd car). I want this car to last for another 10 years for reasons which I don't think need justification, so here are my thoughts: I don't ever want to deal with a smoking turbo again. I don't have too much of a desire for BT power because FWD. However the BNR S1 to me is just too much money for stock power levels. To my understanding, the K04 rebuild kits out there don't permanently fix the smoking problem. Additionally, I'm assuming it isn't smart to toss a BT onto a freshly rebuilt engine, and therefore it's likely the turbo won't be replaced until a few months after the rebuild. While I don't want to go all out and buy all of the expensive things, money is not the limiting factor, rather it's long term reliability. Also, this car will remain my daily and I'd like it to remain child-friendly (still a family car). I feel like I'm kind of in awkward position here in where to go with my car. So for those that have been here before, if you had to do it again, what would you do?
 Old 07-17-2017, 09:42 AM   #13
As for Fwd, im not sure what you mean, or are you in a speed3? Otherwise your speed6 is Awd. Now to a turbo, Im running a rebuild with a Corksport turbo on, which between the s3 N corksport turbo they are pretty similar, Im not sure what power the s3 is good for, but my corksport turbo is good for between 250 and they say 450 but id say an easy 400 at least. MY tuner Will from Purple Drank tuning says the efficiency of the CS turbo just starts at around 21 psi which im holding at 22.5 all day, and my car is running great, and have put about 8k miles and that was with the fresh motor n this turbo off the bat. I think personally for the price, the corksport turbo is an awesome choice, for cost, power ability and spool up time. Dunno much about the s3 all i believe it does require alil more modification for the drop in, i may be wrong. But as far as stock power levels, you can go way above stock power levels with either of those turbos. And as far as rebuilding the k04 dont they are junk like that, if yoir absolutely sold on the k04 then buy a new one...but at that point id say go with the CS turbo or S3
Corksport Turbo*
Corksport EBCS*
Brakes: Still stock
 Old 07-21-2017, 06:15 PM   #14
tmillner's Avatar
Posts: 613   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
In my opinion I would go with the closest equivalent turbo to the k04. If longevity is more of a factor then power, I would rebuild with stock components, pistons, rods, bearings etc. They are made more for longevity, while forged is more for power and can have adverse affects on the block.
What's your goals power wise?
Sent from my SM-T587P using Tapatalk
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 07-21-2017, 08:21 PM   #15
Bingo's Avatar
Realistically I don't have much desire for more than 300 wheel. But at the same time, it's tough to justify $900 for an S1 when I can get an S3 for $1100. But the long plan is to keep the MS3 as the reliable family car. So maybe an S1 is the way to go. I'm gonna try cleaning the valves before a rebuild and redo the compression test.
 Old 07-21-2017, 08:33 PM   #16
tmillner's Avatar
If 300 wheel is all you want I would go back stock parts completely and s1. I can't justify the s3 when the s4 is like $150 more. Just my opinion
Sent from my SM-G935P using Tapatalk
 Old 07-21-2017, 09:36 PM   #17
impossible's Avatar
Posts: 720   (View Stats)
Groans: 30
If you need long life and durability I would suggest researching piston alloys. My advice is to do Mahle 4032 pistons from SP63 (number in the name is for the alloy used in this case), Manley h beam rods, OEM headbolts or h11/L19 headstuds (NOT ARP2000), oem headgasket with new dowel pins, oem bearings for mains and rods, new oem valve seals, 65lb crower valve springs because they are cheap insurance if your high mileage valve springs have gotten softer with wear. At just over 100k they are likely fine but might as well do it while engine is apart since they are a wear item. Your OEM mainbolts can be re-used as well if they aren't stretched while is unlikely on k04. This combo should last 100k+ miles with proper assembly and maintenance and take 550whp+ if you want to step it up later. Make sure to get your injectors cleaned and tested by someone like InjectorRX in Houston, TX while engine is apart. Good luck.
Forged, keyed, ported, and Port injected build underway...
 Old 08-07-2017, 04:11 PM   #18
Bingo's Avatar
Alright, I think I've decided the S1 is the way to go. I think I'll just keep with an OEM engine rebuild and call it good. I want this car to be a daily for another 10 years at least. Once again, I won't be tearing into it until next summer, and until then I get to search for a second car.
Suggestions? It just has to be reliable and because I'll likely own it for less than a year, I'd like it to be cheap and not lose much value. Again, I won't be purchasing one until probably April. The leading cars I'm considering are a Crown Vic or 2010ish Focus. Both can be had for under 4k right now.
 Old 08-07-2017, 08:16 PM   #19
Fstrnyou's Avatar
Posts: 1,430   (View Stats)
Originally Posted by Bingo View Post
It just has to be reliable, cheap and not lose much value.
Does anyone else read, "old Toyota"?
2006 MS6 GT - 152k Miles
Versatuner, 3-bar MAP, ITV22's
Russian Bushings in Back, Magnaflow CBE
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/Stage 2 OCC
Forged build ongoing. Manley H-Tuff & 2618, King Bearings
Other rides:
History:
Montezemolo steps down, Marchionne steps up as chairman of Ferrari Haltech Automotive News 0 09-10-2014 06:20 AM
Fisker CEO Tony Posawatz steps down, Bernhard Koehler steps in Haltech Automotive News 0 08-26-2013 09:30 AM
Bad Compression 'MERICA MazdaSpeed 6 - Engine, Transmission & Driveline 14 08-08-2012 11:55 AM
Low compression MaverickX3 MazdaSpeed 6 - Engine, Transmission & Driveline 55 12-10-2010 03:41 PM
Laurens van der Acker steps down as Mazda design chief, Ikuo Maeda steps up Haltech Automotive News 0 04-01-2009 08:30 AM
Page generated in 0.39423 seconds with 27 queries
