Like Tree37Likes
 Old 08-24-2013, 02:08 PM   #1
Trebor379's Avatar
Posts: 60   (View Stats)
Trebor379 has a reputation beyond reputeTrebor379 has a reputation beyond reputeTrebor379 has a reputation beyond reputeTrebor379 has a reputation beyond reputeTrebor379 has a reputation beyond reputeTrebor379 has a reputation beyond reputeTrebor379 has a reputation beyond reputeTrebor379 has a reputation beyond reputeTrebor379 has a reputation beyond reputeTrebor379 has a reputation beyond reputeTrebor379 has a reputation beyond repute
Neutral  +5 score
Default A/C compressor clutch Finally a cheap Fix!!
I searched all over the forums and was unable to find A solution for fixing a messed up A/C compressor clutch without either replacing the entire compressor for 460 bucks or buying the whole clutch assembly from Mazda for 260 bucks. Not wanting to spend that kind of money I Began to do some Research and found out how to fix the clutch for 23 bucks. Here is how i did it.
Step 1, I jacked up the car, removed the passenger side front wheel and removed the inner fender liner to reveal the A/C clutch.
Step 2, I proceeded to remove the 10mm Bolt holding the A/C clutch on, at the same time you must use a flat head screw driver as a wedge to keep the pulley from spinning as you remove the bolt. ( Much easier than it sounds)
Step 3, Now you should be able to remove the clutch by just pulling, I used a flat head screw driver to pry it off. Be care full not to loose the 2 shims on the back side of the clutch they are very important.
Step 4, Now you will be able to remove the C-clip holding the pulley on, and pull the pulley off. I had to use a gear puller to pull mine off due to the fact that the bearing in the clutch pulley was so warped i couldn't pull it out by hand.
Step 5, This was the hard part.. Autozone List a bearing for our A/C compressor clutch online as MT2233.. THIS IS THE WRONG BEARING!!!! So I Take The broken Bearing to a local Bearing Shop and try to buy the exact bearing... The Bearing is a NSK 35BD219DUM1 The bearing shop said they could order me the bearing but it would cost 70 bucks... screw that so i measured the dimensions of the bearing the bearing measures out to be 35x55x20 So I did some more research and found that auto zone carries a bearing in this size But does not list it for our car. THE CORRECT BEARING IS MADE BY SANTECH AND ITS PART NUMBER IS MT2021!! Total cost of the bearing was 23 bucks..
Step 6, i took bearing home and it was already late so i threw the new bearing in the freezer and let it freeze over night. so that it would shrink a bit and be easier to press into the pulley.
Step 7, set pulley on a wood block and use a rubber mallet to gently tap the bearing into place. MAKE SURE TO PRESS BEARING FULLY INTO ITS SEAT ON THE BACK SIDE OF THE PULLEY.
From here, re install in the reverse order and be happy
I will attach pictures of the steps along with a video of how the car sounded with the faulty bearing I hope this is useful and saves a lot of you guys a good chunk of change.
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
Trebor379 is offline   Reply With Quote
The Following 56 Users Say Thank You to Trebor379 For This Useful Post:
albone (09-23-2014), Angr-E1 (08-24-2013), ArmanRus (08-24-2013), aromig (06-29-2014), Atticaz (06-14-2017), bertrand_CX_7 (03-07-2014), BigRedSpecial (09-14-2013), bluedjin419 (05-16-2015), BlueMetalJacket (06-27-2014), bob^3 (08-25-2013), btstarcher (08-24-2013), c0d3man (04-19-2015), Caldazar (03-04-2014), Code Monkey (08-25-2013), cyclist20 (06-15-2016), Darth_Nuruodo (10-31-2014), DTKII (03-05-2014), Easter Bunny (08-24-2013), Ebdiggity (07-29-2015), enkiddu (04-04-2017), Gary-L (12-09-2013), j.ferger (10-04-2013), jack_hammer (12-02-2013), Javi (09-06-2013), justint5387 (08-05-2014), kritz (08-28-2013), LatinKraze (08-24-2013), localnj (08-03-2015), Martin (08-06-2016), MattJackson86 (08-28-2013), Mauro_Penguin (09-27-2013), meicalnissyen (11-20-2013), melly mel (02-14-2014), memin (08-24-2013), mrmonk7663 (08-24-2013), MSMS3 (07-16-2014), Nitr0EngiE (09-16-2013), p057 (09-27-2013), PhillyCheese (08-24-2013), Raider (01-28-2015), Rich990 (01-05-2016), rob ms6gt (08-17-2015), robertof (09-24-2013), Roddiy (09-08-2013), roth4fun (09-25-2013), silvapain (08-25-2013), simply_pandora (08-24-2013), SofaKingAwesome (06-05-2015), SR388 (08-28-2013), SrananBuru (09-14-2013), tastysi2004 (07-28-2014), thanox2 (08-28-2013), theschrum (10-28-2014), Uberfly (09-30-2013), Visual7 (09-14-2013), ZoomZoom06 (08-22-2014)
 Old 08-24-2013, 02:22 PM   #2
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,458   (View Stats)
Groans: 2,977
@Raider; sticky?
I hugged rfinkle2
BigRedSpecial (09-14-2013), p057 (09-27-2013)
 Old 08-24-2013, 02:34 PM   #3
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Excellent job Robert. This will save folks some cash.
2011 Speed3-BT and shit
 Old 08-24-2013, 02:36 PM   #4
Trebor379's Avatar
Thanks Mike!
 Old 08-24-2013, 05:02 PM   #5
simply_pandora's Avatar
Posts: 2,605   (View Stats)
Thank you so much! I noticed my a.c. clutch bearing rattling yesterday and was already dreading having to buy a new compressor. This will certainly save people a lot of money.
Sent while melting in >100° weather :|
memin and Trebor379 like this.
Status: Comatose
 Old 08-24-2013, 11:15 PM   #6
shifter48's Avatar
Posts: 361   (View Stats)
shifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the worldshifter48 is the leader of the world
Groaned at 6 Times in 4 Posts
Great job Robert!!! A lot of people will benefit from this.
Trebor379 likes this.
67 yrs young..2012 MS3 with Tech, Cobb AP, JBR 88 dogbone, JBR Rear Swaybar,Autotech Internals..JBR 88TMM & 80PMM, HTP 3" tip with a custom fab MAF housing, UR FMIC, TWM short shifter assembly, Sure SSP and Weight, UR CBE, UR metal catted DP, UR res. TP, Synapse DV, Grimmspeed EBC, Bosh 3 bar map sensor, Denso ITV22's, FoMoCo Trans Fluid, Corksport aluminum skid plate, Sonic ST8's 18X8.5X40 running PSS 245/40's, Nitrogen filled tires, GoPro Hero, Hero-2 (For those moments, adds 20+driverhp) TUNED BY: mrmonk7663
_______________________________
Team LBN BEERS--FYCN
TEAM MUMFORD---FYCN
shifter48 is offline   Reply With Quote
 Old 08-25-2013, 10:46 AM   #7
lcspeed6's Avatar
Posts: 31   (View Stats)
lcspeed6 has a brilliant futurelcspeed6 has a brilliant futurelcspeed6 has a brilliant futurelcspeed6 has a brilliant futurelcspeed6 has a brilliant futurelcspeed6 has a brilliant futurelcspeed6 has a brilliant futurelcspeed6 has a brilliant futurelcspeed6 has a brilliant futurelcspeed6 has a brilliant futurelcspeed6 has a brilliant future
Thanks for the info, because my compressor is starting to sound like a can of screws.
2013 MS3 Silver - Stock
2006 Mazdaspeed 6-Sold
lcspeed6 is offline   Reply With Quote
 Old 08-25-2013, 10:50 AM   #8
Trebor379's Avatar
Your welcome man that's exactly what mine did make sure you fix it soon because if it seizes you will be left stranded
The Following User Says Thank You to Trebor379 For This Useful Post:
mrmonk7663 (08-25-2013)
 Old 08-28-2013, 08:52 PM   #9
SR388's Avatar
Posts: 127   (View Stats)
SR388 has a reputation beyond reputeSR388 has a reputation beyond reputeSR388 has a reputation beyond reputeSR388 has a reputation beyond reputeSR388 has a reputation beyond reputeSR388 has a reputation beyond reputeSR388 has a reputation beyond reputeSR388 has a reputation beyond reputeSR388 has a reputation beyond reputeSR388 has a reputation beyond reputeSR388 has a reputation beyond repute
Wow, this is super timely! My A/C has been rattling all summer, and I wasn't sure what the issue was. No more A/C till I can do this fix on Monday. I presume not running the A/C will prevent any damage until I can replace the bearing?
Have I ruined the compressor by having it rattling so long? Or is it only damaged when the bearing is seized?
Many thanks btw!
SR388 is offline   Reply With Quote
 Old 08-28-2013, 08:56 PM   #10
Trebor379's Avatar
Mine was rattling for quite some time before I fixed it and it is doing fine now. It won't ruin your compressor the only thing it might do is wear out the clutch plate a bit faster but I will post a link to the clutch plate it only cost 40 bucks.
But like I was saying my bet is everything will be fine bud
 Old 08-28-2013, 09:14 PM   #11
SR388's Avatar
I presume you are talking about not running the A/C? Would the bearing still seize if I don't run the A/C at all?
Sorry I am a bit confused. I just don't want to risk getting stranded or making a more expensive repair.
 Old 08-28-2013, 09:25 PM   #12
thanox2's Avatar
Posts: 1,236   (View Stats)
thanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the worldthanox2 is the leader of the world
Groans: 639
Groaned at 39 Times in 29 Posts
You can get that bearing from Amazon for 30 bucks or so. I'm buying one first thing tomorrow morning.
This is why I love MSF! bringing simple solutions to common expensive problems.
"Asking the front wheels of a car to do their normal job of steering while handling more than 170hp is like asking a man to wire a plug while juggling... penguins... while making love... to a beautiful woman while on fire, on stage... in front of the Queen. It's all going to go wrong." Most people would have just called it "wrong-wheel drive."
thanox2 is offline   Reply With Quote
 Old 08-28-2013, 10:22 PM   #13
Trebor379's Avatar
Auto parts has it for 23 bucks
 Old 08-29-2013, 09:49 AM   #14
Trebor379's Avatar
Yes the bearing can still seize if the ac is off because the pulley never stops spinning. The clutch just disengages from the pulley when the compressor isn't running.
 Old 08-29-2013, 04:52 PM   #15
SR388's Avatar
Ok, thanks. Well it's lasted me for the past three months, hopefully it will hold up for about 500 more miles till I can get it fixed on Monday!
 Old 08-29-2013, 08:19 PM   #16
SR388's Avatar
Well, I have it a try tonight and failed miserably, when I was loosening the ac compressor to remove tension from the belt, one of the bolts snapped. I also can't get the bearing out. Bummer. Gonna have to stop by mazda or another shop and have them finish the job.
 Old 08-29-2013, 08:26 PM   #17
Trebor379's Avatar
What bolts are you talking about? To take the belt off you put a wrench on the tensioner pulley and loosen it and pop the belt off at the same time. There is only one bolt that needs to be removed on the pulley that is right in the middle
To remove the bearing you either need a press or use a hammer and punch on the outer race of the bearing
Last edited by Trebor379; 08-29-2013 at 08:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-29-2013, 08:36 PM   #18
SR388's Avatar
Well darn, I didn't know that. I searched through google and was lead to believe I had to remove the condenser to relieve the tension. It would have been for naught though. I can't get that bearing out to save my life.
 Old 09-06-2013, 05:49 PM   #19
quicksilver celle's Avatar
Posts: 23   (View Stats)
quicksilver celle has much to be proud ofquicksilver celle has much to be proud ofquicksilver celle has much to be proud ofquicksilver celle has much to be proud ofquicksilver celle has much to be proud ofquicksilver celle has much to be proud ofquicksilver celle has much to be proud ofquicksilver celle has much to be proud ofquicksilver celle has much to be proud ofquicksilver celle has much to be proud of
@Trebor379 I was able to replace the bearing. But the clutch still stops... You mentioned you would post a link for a replacement?
quicksilver celle is offline   Reply With Quote
 Old 09-14-2013, 12:00 PM   #20
Roddiy's Avatar
Posts: 5,384   (View Stats)
Roddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the world
Groans: 279
Groaned at 58 Times in 47 Posts
How did you take off the A/C clutch man? I took off my belt, and when I turn the 8mm nut on the A/C the clutch just spins.
I've tried using a flathead to wedge between the clutch and the pulley but then the whole thing spins and I still can't break that nut.
2010 LSM Speed3
Bolted + Corn + Meth + ACT 6-Puck
#BakeryTuned
Roddiy is offline   Reply With Quote
 Old 09-14-2013, 12:47 PM   #21
Trebor379's Avatar
On the clutch you will see 3 protruding sections use the screwdriver as a wedge between 2 of the raised sections while turning the bolt out
There is a good picture of this in the online mazda shop manual
Last edited by Trebor379; 09-14-2013 at 12:47 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-14-2013, 04:41 PM   #22
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
BigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the world
Groans: 56
Groaned at 6 Times in 6 Posts
SOMETHING on my engine is making a huge racket; I assumed it was the tensioner and/or idler pulley but for the sake of $30 I'll do the AC at the same time.
Thanks for the writeup!
Amazon fucking pisses me off. $50 shipping for a $30 bearing. I can ship an intercooler for that.
2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's
Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals
Winter Beater: 96 GMC K1500 5 speed 4x4
Needed: Driver mod
BigRedSpecial is offline   Reply With Quote
 Old 09-15-2013, 11:51 AM   #23
Roddiy's Avatar
Groans: 279
Mmmm, what page of the manual? I'm searching here and can't find it.
2010 LSM Speed3
#BakeryTuned
 Old 09-24-2013, 08:32 AM   #24
brett's Avatar
Posts: 1   (View Stats)
brett is an unknown quantity at this point
Im having the same problem. I'm trying to get the clutch off but it's not coming off easy and I'm afraidof damaging it even more.did it take a lot of force to pry it off
brett is offline   Reply With Quote
 Old 09-27-2013, 08:19 PM   #25
SrananBuru's Avatar
Posts: 85   (View Stats)
SrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond reputeSrananBuru has a reputation beyond repute
How did you get the bearing out? I think I need to find a shop with a press tomorrow. Can't seem to get the bearing out otherwise.
SrananBuru is offline   Reply With Quote
 Old 09-27-2013, 08:44 PM   #26
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
awesome info. Tampa NATOR has had two people have their AC's bearings and/or clutch fail miserably and fuck their cars up a bit. especially their wallets.
I'll keep this bookmarked. thanks dood!
 Old 09-30-2013, 01:17 PM   #27
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
there was some promise of some part links and video of bad bearings, may we haz pl0x ???
 Old 12-02-2013, 10:26 PM   #28
josey17's Avatar
Posts: 2   (View Stats)
josey17 will become famous soon enough
Default How to reinstall pulley?
Thanks for the repair info. Same thing happened to my A/C and I'm in the middle of the repair now. I was able to pull the clutch plate without issues. I had a very difficult time pulling the pulley. I had to use a puller, but I didn't have enough access to align it straight on so it had to go on at angle. Needless to say, I bent the puller and pulley while ripping it out.
I corrected the bent pulley as best as I can and I'm ready to install it back in the car. Issue I'm having is how to install the pulley back on. The thing won't go on. I tried pulling the pulley in the oven (170F) and it's nowhere near enough. I don't want to go hotter as I may damage the sealed bearing seals.
How did you reinstall the repaired pulley on to the compressor? I don't see a good way to press it back on. I don't have much access to tap in either. Any tips or suggestions based on your experience?
Thanks!
josey17 is offline   Reply With Quote
 Old 12-03-2013, 04:00 AM   #29
btstarcher's Avatar
Posts: 4,848   (View Stats)
Groans: 112
If the pulley is bent, how exactly is it repaired? Sorry but that's just a bad idea. It needs to be perfectly straight or it will fail pretty quickly.
SnailTune in progress
jack_hammer (12-03-2013)
 Old 12-05-2013, 01:13 AM   #30
josey17's Avatar
I used the arbor press to try to get the pulley back in shape. Same press used to remove and install the bearing. I had help from an experience machinist and got the pulley round within 0.008" and flat within 0.020". I figured I'd try to install it and if it didn't work, it has to be replaced.
I got it installed by using the clutch plate and hammering with an 11" extension. I put the belt on and before installing the clutch plate I ran the car. It seemed fine and finished the install and everything including the A/C seems to working fine.
I have to say this quite a challenge as the pulley is not designed to be pulled with the compressor still mounted to the car. Thanks to Trebor379 for doing all of the dirty work in finding the right bearing.
The Following User Says Thank You to josey17 For This Useful Post:
btstarcher (12-05-2013)
 Old 12-08-2013, 09:19 AM   #31
Gary-L's Avatar
Posts: 7   (View Stats)
Gary-L is just really niceGary-L is just really niceGary-L is just really niceGary-L is just really niceGary-L is just really nice
I just joined the forum as I came across it in a Google search for the possibility of repairing just the compressor bearing. The one in my car started making occasional grinding sounds a few weeks ago.
So far, this forum appears to be comprised of people who actually work on vehicles as opposed to sticking carbon fiber on the dash or consistently telling people, "I dunno. Take it to the dealer."
Anyway, I found the bearing the OP mentions, on e-Bay: SANTECH IND MT2021 A/C Clutch Bearing-A/C Compressor Clutch Bearing - $13 free standard shipping. Just FYI, but the compatibility section states it is not compatible.
Thank you for the informative write-up and accompanying pictures.
SR388 and redneck4Christ like this.
2006 Mazda 3 Hatchback, 2.3L
Gary-L is offline   Reply With Quote
The Following 5 Users Say Thank You to Gary-L For This Useful Post:
aromig (06-29-2014), btstarcher (12-08-2013), Ebdiggity (07-29-2015), jack_hammer (12-09-2013), Mauro_Penguin (12-11-2013)
 Old 01-11-2014, 02:46 PM   #32
solort's Avatar
Posts: 3   (View Stats)
solort is an unknown quantity at this point
What did you use to get the snap ring pliers onto the snap ring (c ring)? or did you use a screwdriver and a lot of 4 letter words? Did you have to unbolt compressor from car to use the puller? Any help is greatly appreciated. Thx
solort is offline   Reply With Quote
 Old 02-14-2014, 01:24 PM   #33
melly mel's Avatar
Posts: 277   (View Stats)
melly mel is the leader of the worldmelly mel is the leader of the worldmelly mel is the leader of the worldmelly mel is the leader of the worldmelly mel is the leader of the worldmelly mel is the leader of the worldmelly mel is the leader of the worldmelly mel is the leader of the worldmelly mel is the leader of the worldmelly mel is the leader of the worldmelly mel is the leader of the world
Sorry to bring thread back but I was reading this and saw mention that the OP found that the incorrect bearing was listed on Autozone for his 2008 MS3 as PN MT2233. Looking at this link there are 2 different compressors listed for the 08; one with a 105mm clutch and another for a 129mm clutch; whereas Autozone only has one listed.
I have a 2006 MS6 and Autozone lists the same bearing dimensions as OP stated of 35x55x20. PN is MT2021 listed here for $21.99. Hope that helps for those that were wondering if this How-To would work for the MS6. I've yet to tackle the project but same dimensions so it should work.
melly mel is offline   Reply With Quote
The Following 2 Users Say Thank You to melly mel For This Useful Post:
btstarcher (02-14-2014), Mauro_Penguin (02-14-2014)
 Old 03-07-2014, 02:13 AM   #34
Blackriver's Avatar
Posts: 20   (View Stats)
Blackriver will become famous soon enough
Groaned at 17 Times in 7 Posts
my whole clutch assembly fell off the car as I was driving is there any other vehicle's clutch that will work, also my serpentine belt keeps on falling off belt part number 6PK2315
Blackriver is offline   Reply With Quote
 Old 03-10-2014, 10:27 AM   #35
rpaniagua's Avatar
rpaniagua is a splendid one to beholdrpaniagua is a splendid one to beholdrpaniagua is a splendid one to beholdrpaniagua is a splendid one to beholdrpaniagua is a splendid one to beholdrpaniagua is a splendid one to behold
Default A/C compressor clutch replacement
Adding more pictures showing the location of the serpentine belt tensioner, which need to released in order to loose the belt and remove the clutch pulley.
As Trebor 379 mention, the bearing dimensions 35x55x20, I got mine from Ebay ($9.99).
I bought the serpentine belt removing kit and the stands at HarborFreight.
Just in case, do a mark of the tensioner position before release it.
Take a picture of the belt position (belt route) or draw it to easily remember the belt position later.
To remove the pulley is necessary to remove the C clip first, then hit it from the back.
The pulley has a nest were the bearing is seated, means the bearing could be take a part only if HIT it from one side ( clutch face).
Install the new bearing,remember to close the small flap locks for the bearing locate in the pulley, yellow circles highlighted.
Install in the reverse mode, and you saved some money.
File Type: jpg serpentine belt tool kit_and _jack stands_.jpg (24.5 KB, 283 views)
rpaniagua is offline   Reply With Quote
The Following 13 Users Say Thank You to rpaniagua For This Useful Post:
aromig (06-29-2014), aviator79 (05-16-2014), bob^3 (04-14-2014), c0d3man (04-19-2015), Ebdiggity (07-29-2015), Gary-L (07-31-2016), gweedo007 (06-11-2016), impossible (02-01-2016), melly mel (03-10-2014), mrmonk7663 (04-14-2014), Raider (01-28-2015), Rich990 (01-05-2016), Rivak (06-30-2016)
 Old 03-17-2014, 10:34 AM   #36
Mazdazilla6's Avatar
Posts: 3,654   (View Stats)
So if my a/c pulley is seized do I need to replace the bearing, clutch or both?
It's not making any sound except for the belt sliding over the pulley.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 04-14-2014, 10:25 AM   #37
josel's Avatar
josel is an unknown quantity at this point
My 04 3s is making the same grinding noise and a bad smell is coming out like burned wire. So I lifted the car yesterday while changing the oil and decided to check if the a/c compressor is indeed the problem. Told my son to turn the a/c while I was under and to my surprise the damned thing started shooting sparks. I'll try to remove the clutch and see what type of damage it got.
josel is offline   Reply With Quote
 Old 04-14-2014, 10:40 AM   #38
mrmonk7663's Avatar
Nice first post
The Following User Says Thank You to mrmonk7663 For This Useful Post:
btstarcher (04-14-2014)
 Old 05-16-2014, 06:11 PM   #39
wojowojo16's Avatar
wojowojo16 is an unknown quantity at this point
I just did this with bearing MT2021 and it was TOO big...thoughts?
wojowojo16 is offline   Reply With Quote
 Old 05-16-2014, 06:49 PM   #40
aviator79's Avatar
Posts: 3,915   (View Stats)
Groans: 67
I only get a clanky noise when I turn AC on. Does this point to AC or who knows? replace this bearing and go ahead and replace this bearing, tensioner and idler pully?
TIA.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f293/c-compressor-clutch-finally-cheap-fix-153663/
Design's Long Term Ownership/Build Thread - Page 8 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-19-2015 06:50 PM
signs of bad ac clutch - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 09-19-2015 05:12 PM
Bearing de poulie pour la clutch de l'air climatisé - Mazda 3 Quebec This thread Refback 09-02-2015 08:59 PM
Peladero del único y verdadero Mazda Team 2015 :shocky: :SonoraDinamitaStyle: - Página 11 - VelocidadMaxima.com This thread Refback 06-19-2015 09:50 AM
08 Mazdaspeed 3 clattering noise : mazda This thread Refback 07-02-2014 08:40 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
a/c compressor clutch tried to sneak away TiGraySpeed6 Mazdaspeed3/6 General Discussion 28 09-03-2014 06:21 AM
Ac Compressor Clutch Fail bc2292 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 05-07-2014 09:55 AM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Page generated in 0.50425 seconds with 46 queries
