 Old 04-16-2014, 12:08 PM   #1
15driley15's Avatar
Posts: 184   (View Stats)
15driley15 is the leader of the world15driley15 is the leader of the world15driley15 is the leader of the world15driley15 is the leader of the world15driley15 is the leader of the world15driley15 is the leader of the world15driley15 is the leader of the world15driley15 is the leader of the world15driley15 is the leader of the world15driley15 is the leader of the world15driley15 is the leader of the world
Default Car cranks, won't start
2006 ms6 100% stock. 113k.
Went into a gas station a couple days ago, came back, car wouldn't start. Did some reading thought it was an electrical issue, jumped the neutral safety switch, and got the car to start/run for about 45 seconds. To my dismay, the car dies. I find that the connection I made was no good, attempt to quickly repair it, but the car never started again.
So i tow the damn thing to my house, and crawl back up under the dash and legitimately bypass the NSS so that I know it's good. (Car cranks without use of the clutch pedal now) ...but the car will not start. I just changed spark plugs today. Car is behaving the same.
My next suspicion is fuel pump? Anyone have a way to potentially test an hpfp?
I need this thing running and I'm pretty frustrated.
2006 Velocity Red Mica Mazdaspeed6 GT #04425
Stocked out and hella slow...
15driley15 is offline   Reply With Quote
 Old 04-17-2014, 09:13 AM   #2
15driley15's Avatar
Bump... Really could use suggestions here
 Old 04-17-2014, 09:32 AM   #3
Koke382's Avatar
Posts: 4,361   (View Stats)
Groans: 32
Wish i could help, hope u get it sorted out bud
Sent from my LG-LS980 using Tapatalk
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
Koke382 is offline   Reply With Quote
 Old 04-17-2014, 12:38 PM   #4
Spec's Avatar
Posts: 4,472   (View Stats)
Well, it's going to be spark, fuel, air. Fine out which one you don't have. You mentioned you changed your plugs. See if they're hitting.
 Old 04-17-2014, 01:03 PM   #5
ihasmazda's Avatar
Posts: 1,011   (View Stats)
ihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the world
what are the odds that it could be the in-tank fuel pump? i never hear about problems with them on these cars though, I'm just throwing something out there...
keep us posted on this, always good to know about issues and the resolution...
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
ihasmazda is offline   Reply With Quote
 Old 04-19-2014, 06:57 AM   #6
CW42's Avatar
Posts: 216   (View Stats)
CW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant future
I assume your lights and dash light up and you hear the various start up electrical noises? The same thing you're describing happened to me last week and it was the white wire that connects to the starter. This happens a lot from what I've read in here. It's the first thing I thought of when my car wouldn't start and that's exactly what it was. I'm not sure if it happens a lot on the 6 or not. It might be worth checking.
CW42 is offline   Reply With Quote
 Old 04-23-2014, 01:24 PM   #7
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
that starter remote wire does like to come lose i ended up zip tying that wire to the harness to make sure it stays on the starter, next time i get IM off i will replace the spade connector on the wire to one that holds stronger
you really need to get with someone who has an AP and check fuel pressure and see if there are any silent check engine lights hidden without triggering the light
 Old 04-23-2014, 02:25 PM   #8
aviator79's Avatar
Posts: 3,930   (View Stats)
Groans: 67
From what he is saying the starter is turning but the car wont start. Listen for fuel pump under rear seat driver side. Take rear seat bottom out if have to, should be able to hear it. report back if you hear it or not.
 Old 04-23-2014, 03:51 PM   #9
Donut's Avatar
Posts: 131   (View Stats)
Donut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the worldDonut is the leader of the world
Yes try to listen for the fuel pump noise:
Check the fuse of fuel pump too, had a similiar problem with my RX-8 previously. Once I have replaced the fuse there has been no more issues.
2004 Mazda RX8 - Bone Stock - SOLD
2010 Mazda 3 MPS
K&N SRI | GFB BPV | Cobb TIH | Cobb AP v3 - Freektuned |CS Internals|OBX Cat Back + Test Pipe | JBR 70a RMM | JBR RSB|JBR EGR block off plate|JBR SSP + Solid Bushings |Denso ITV 22| Ultra Racing Front Strut Bar| Ultra Racing Rear Strut Bar | Bridgestone RE002 225/40/R18 Tyres|CS Brake Pads|H&R Lowering Springs| DBA T3 Slotted Rotors |Goodridge SS Braided Brake Lines
Non performance parts: 35% Tint | Blacked Emblems | Painted Wheels |JBR Heavy Shift Knob | CS Tow Plate |
Donut is offline   Reply With Quote
Ms6 cranks but wont start maniospeed6 Mazdaspeed3/6 General Discussion 4 03-26-2013 08:08 PM
Car cranks but doesn't start after valve clean InfamousSpeed6 Mazdaspeed3/6 General Discussion 11 11-29-2012 05:17 PM
GM cranks up no-frills car output in China Haltech Automotive News 0 11-18-2012 05:50 AM
Coda cranks up battery-car sales after California 'soft' start Haltech Automotive News 0 09-12-2012 10:40 AM
Toyota cranks up N.A. output Haltech Automotive News 0 08-12-2012 09:10 PM
Page generated in 0.29409 seconds with 27 queries
