 Old 12-22-2008, 05:45 AM   #1
6-Speed-6's Avatar
Posts: 336   (View Stats)
6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute
Default Car is shaking violently above 55
This is what happened. I had to go into work on Sunday and it was -5 outside in Chicago. I started the car, let it warm up for a minute. I put it in gear and let the clutch out and it was like the parking brake was on. I lifted the parking brake and set it back down and tried to go again. It hesitated for a second like the brake was on and then there was a pop or a snap, but the car started moving. Everything was fine until I got on the highway and after 55, it starts shaking. 65 is nearly undrivable. I have an appointment with a local dealership, but I am curious if this has happened to anyone before. I don't trust any dealerships and I'm afraid they will come back and says its something I did and it's not covered under warranty.
2007 MazdaSpeed 6
Low and Slow!
6-Speed-6 is offline   Reply With Quote
 Old 12-22-2008, 05:51 AM   #2
fbpem1's Avatar
Posts: 1,159   (View Stats)
fbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the world
Groaned at 47 Times in 40 Posts
any chance that you have ice build up on your driveshaft? ice in your wheels, threw your wheels weights? do you have your wheels balanced at regular intervals?
fbpem1 is offline   Reply With Quote
 Old 12-22-2008, 06:25 AM   #3
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
^^ He's onto something with the ice build-up (although in your case maybe not). Slush will build-up in the wheel well and then freeze in there and cause vibration when your speeds get up ... I've seen it lots of times and even had it happen to me on Sat night.
It get's behind the plastic liner somehow too and I've got a nice bulge intruding into the wheel well area.
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 12-22-2008, 07:07 AM   #4
+1 on the ice in wheels
 Old 12-22-2008, 08:08 AM   #5
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
Are you guys shitting me? I live in Miami and always have. I am moving up north in about a year. This is the shit I am going to have to deal with?!
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 12-22-2008, 08:13 AM   #6
6-Speed-6's Avatar
I am going to pull it into the shop and see if I can defrost it a little. I will let you guys know what happens. Thanks for the ideas!
2007 MazdaSpeed 6
Low and Slow!
 Old 12-22-2008, 09:17 AM   #7
kingpin748's Avatar
Posts: 2,611   (View Stats)
kingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the world
Groans: 78
Groaned at 48 Times in 31 Posts
With the right weather you can get ice build up. Warmer temps during the day cause the slush which freeze solid a night. I pound of ice on one side of the wheel tends to through off the balance.
It's not a big deal, just run it though a car wash or park it inside at a mall while you do some shopping.
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 12-22-2008, 09:28 AM   #8
6-Speed-6's Avatar
It's in our dock and I turned up the heat. I will drive it home tonight and let everyone know if this was it. There is definately hard solid ice packed inside the wheels.
2007 MazdaSpeed 6
Low and Slow!
 Old 12-22-2008, 10:36 AM   #9
fbpem1's Avatar
=D
i see this whenever it snows
 Old 12-22-2008, 04:58 PM   #10
6-Speed-6's Avatar
I actually got stuck in the snow the other day and was spinning the tires trying to get out. I had way more ice in the wheels than I thought. After I let it defrost about 2 hours, I was punching ice out between the wheel spokes that were 3 to 4 inches thick. I drove it home and everything was good. Thanks for everyone's input.
2007 MazdaSpeed 6
Low and Slow!
 Old 12-22-2008, 05:01 PM   #11
yay!!! all better
 Old 12-26-2008, 01:50 PM   #12
buttons's Avatar
Posts: 142   (View Stats)
buttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to behold
Groaned at 20 Times in 4 Posts
Yeah, very common problem. Thats the only nice thing about having hubcaps instead of wheels. Hubcaps keep ice from building up on the wheels and throwing your balance off.
2006 White Mazdaspeed 6 Sport - Sold
2007 Blue Mazdaspeed 3 GT - Sold
2006 Red Mazdaspeed 6 GT - I/TIH/SU TMIC/3 port BC/Springs/Wheels
buttons is offline   Reply With Quote
 Old 12-26-2008, 02:27 PM   #13
phailerider's Avatar
Posts: 4,639   (View Stats)
phailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the world
Groans: 49
Groaned at 179 Times in 125 Posts
better ice than, decaying vermin. glad it all worked out.
phailerider is offline   Reply With Quote
 Old 12-26-2008, 05:11 PM   #14
fbpem1's Avatar
yeah not really, dosn't matter what it is it can happen and i have seen it happen, ice or mud dosn't matter.
 Old 12-26-2008, 06:23 PM   #15
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
ice/snow in the wheel wells is common for me in the winter time.
it is possible to drive with the shaking/imbalance, but i do worry that it can damage moving parts.
Page generated in 0.37481 seconds with 27 queries
