MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Sep 2011 Location: Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
(Thread Starter) | ![]() ![]() ![]() 1.) It's hard to reproduce, but it seems to be easier to get going when everything is fairly cold. 2.) It occurs more often during a slight left or right turn, but I can also get it to occur when lightly accelerating in 1st or 2nd or letting off the gas in the same manner. 3.) It's one to three "clicks", almost every time. It's nearly IDENTICAL to the clicks you hear when you are tightening lug nuts. I've checked all my lugs, they seem pretty torqued down, but since the noise has been happening, the wheel has been replaced by hand (no torque wrenches or impact). I always, always torque lug nuts until they click a few times. I've always heard this is a good indication that it's torqued efficiently. Anyone have any similar experience? |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Jul 2009 Location: Philadelphia Metropolitian Area
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 578
| ![]() ![]() ![]() It might be the axle clicking Trouble shooting needed.
__________________ 2008 Mazdaspeed3 GT 2.206 ~ 13.330 @ 107.98 MPH (I & AP only, DSC ON) Cobb SRI | Cobb AP (Stage 2+ v200) | OBX TP | Hankook Ventus V12 Evos | Hawk HPSoftpenis Pads | Duplicolor Black Stock Wheels | 15% Tint | SuperRiceLEDs 9500k | SURE RMM Race | TRZ TMM | JBR PMM 80a | JBR Shifter Bushings | Fidanza Flywheel | Koni Sport Shocks ![]() |
The Following User Says Thank You to JNR5005 For This Useful Post: | metalmatt (10-03-2011) |
![]() | ![]() | #3 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Thank you for the info. Took it to Mazda today, and told them to regrease and retorque the axle nut. They looked at me like I was nuts, but it solved the problem. So far it's been 2 hours, will update if need be. Services performed: Remove, grease and retorque driver's side front axle nut. 30$. |
The Following User Says Thank You to metalmatt For This Useful Post: | Docnox (10-03-2011) |
![]() | ![]() | #4 | ![]() |
![]() Join Date: Nov 2010 Location: Lakeland, WA
Rep Power: 1208 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 875
Groans: 266
Groaned at 83 Times in 60 Posts
| ![]() ![]() ![]() It's a bomb under your car....get out
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. |
![]() | ![]() | #5 | ![]() |
(Thread Starter) | ![]() ![]() ![]() |
![]() | ![]() | #6 | ![]() |
rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3142 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,375
Groans: 221
| ![]() ![]() ![]() needz some lube. dealer will do it under warranty if theyre cool like that.
__________________ '08 CWP MS3 w/ T3 3071r |
![]() | ![]() | #7 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Definitely. Today was a good day, got two res's out and fixed the noise. This forum = FTW |
![]() LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f293/clicking-noise-front-driver-s-side-wheel-93291/ | ||||
Posted By | For | Type | Date | |
[SA] New MPS Owner - Page 2 | This thread | Refback | 05-08-2014 04:28 AM | |
Clicking noise??? - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 01-10-2012 08:57 AM |
Display Modes | |
2006 MS6 Clicking noise from LR wheel area????? | fastfive_ogt | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 08-03-2011 10:57 AM |
Squeal From Front Driver Side Wheel | vtak07 | MazdaSpeed 3/6 - Suspension & Brakes | 9 | 07-28-2010 05:38 PM |
Passenger Side Clicking Noise | xmysacredoathx | MazdaSpeed 3 - Engine, Transmission & Driveline | 12 | 05-08-2009 12:47 AM |
Clicking noise | Tcman2006 | Mazdaspeed3/6 General Discussion | 12 | 03-24-2009 03:44 PM |
Clicking noise | MStempted | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 08-26-2008 07:55 AM |
