 Old 12-02-2019, 12:38 PM   #1
grammates's Avatar
Posts: 9   (View Stats)
grammates is an unknown quantity at this point
Default Clunking noise/ possible suspension noises??
Not too sure what the noise is here Iíve looked around here and there seems to be a lot of different culprits just looking for any insight! Much appreciated!
https://imgur.com/olA803C
grammates is offline   Reply With Quote
 Old 12-02-2019, 08:29 PM   #2
MSMS3's Avatar
Posts: 2,746   (View Stats)
Groans: 154
I do not get sound when playing that video.
Even if I could, I would need to know where on the car the noise is coming from. Front, rear, center, left or right? This matters.
 Old 12-03-2019, 12:38 AM   #3
grammates's Avatar
How would I post a video with sound for you to hear and sounds around the wheels generally mainly the front
 Old 12-03-2019, 07:26 AM   #4
MSMS3's Avatar
Groans: 154
Around the wheels? Left or right side? Describe the sound in words. Try to be very specific and detailed. Is it constant when in motion, or does it happen only when going over a bump, pothole or such? Does it change in pitch with car speed? Is it a sharp instant bump, or a longer grind? It is high pitched? Any descriptive terms would help.
I don’t know how you can post a sound clip.
You should be able to directly post most common audio and video files like mp3, mp4, avi, wav and wmv files.
 Old 12-03-2019, 07:42 AM   #5
grammates's Avatar
I donít know how you can post a sound clip.
Here you go sir I think Iíve figured out a way for you to listen!
 Old 12-03-2019, 12:43 PM   #6
MSMS3's Avatar
Groans: 154
Clunking. Look at the sway bar end links - inexpensive and easy to replace. Also check the sway bar bushings, also inexpensive but a bit harder to get to.
Is the car jumping up and down too on level ground?
I still have no idea where you are hearing the sound coming from. That is really important to know. Left, right, front or back.
The rear sway bar end links tend to loosen over time. Simply tightening them with Blue Loctite or similar mild thread locker might solve the problem if the sound is from the back.
The front end links are easy to get to and easy to replace.
These are common suspension issues as the cars get miles on them.
More difficult would be the top hats/strut bearings on the front struts. Again, these are pretty cheap, but there is quite a bit of work involved. It could also be the blown struts in front or shocks in back, or even a broken spring, all in the differential analysis.
Vansquish (12-03-2019)
Suspension rattling/clunking neptune03 MazdaSpeed 3/6 - Suspension & Brakes 15 11-07-2012 11:24 AM
Clunking in the rear, no suspension mods urville 2010 MS3 - Suspension & Brakes 7 09-02-2011 12:32 AM
rear suspension, annoying noises chriscarron MazdaSpeed 3/6 - Suspension & Brakes 28 01-30-2011 10:29 PM
Creaking/Crunching Rear Suspension Noises Joeboy 2010 MS3 - Suspension & Brakes 3 02-08-2010 10:13 PM
Page generated in 0.26483 seconds with 21 queries
