  • 1 Post By brandonnicholson
 Old 10-20-2015, 08:29 PM   #1
Pagan47's Avatar
Posts: 18   (View Stats)
Pagan47 is a glorious beacon of lightPagan47 is a glorious beacon of lightPagan47 is a glorious beacon of lightPagan47 is a glorious beacon of lightPagan47 is a glorious beacon of lightPagan47 is a glorious beacon of light
Default Crank But No Start
Alright guys, yes I have searched the forum and haven't had anyone give any answers to this problem. About a month ago VVT failed on my built MS6. Just got done doing the replacement of the VVT and now the car will crank but will not spark any cylinders. I have tried a new Cam position sensor, crank position sensor, new VVT, new coil packs, checked all grounds, etc. the car ran before with the failed actuator, but now will not start or fire any spark plugs. This has been very frustrating especially since the car has been down 9 months being built and it only drove for a month before having problems again. Any input would be great, ideas to try, etc. fuses to check, etc. I've checked most engine and in cabin fuses that could be related and can't find anything blown it disconnected. HELP
Pagan47 is offline   Reply With Quote
 Old 10-20-2015, 08:50 PM   #2
mxlplx71's Avatar
Posts: 3,265   (View Stats)
Groans: 128
Grounds? Especially the ones by the hpfp , Codes?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
frothy (10-20-2015)
 Old 10-20-2015, 08:56 PM   #3
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Its the ground by the Hpfp. @frothy; beat you to this one.
I hugged rfinkle2
frothy (10-20-2015), mxlplx71 (10-20-2015)
 Old 10-21-2015, 11:04 AM   #4
Pagan47's Avatar
It is grounded. Only code is P0091. Everything visible is grounded and connected. Possibility it could be crank position sensor?
 Old 10-21-2015, 11:39 AM   #5
mxlplx71's Avatar
Groans: 128
do you have an accessport? check out fuel pressure.
can you hear the in tank pump come on?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 10-21-2015, 11:45 AM   #6
frothy's Avatar
Posts: 1,067   (View Stats)
P0091:
The Following 4 Users Say Thank You to frothy For This Useful Post:
Easter Bunny (10-21-2015), MS3Shadow (10-21-2015), mxlplx71 (10-21-2015), WetzMS3 (10-21-2015)
 Old 10-21-2015, 06:26 PM   #7
Gawel30's Avatar
Posts: 9   (View Stats)
Gawel30 is on a distinguished road
If you have a accessport check to see if you have rpm showing up, if not its probably something to do with crank sensor. You didn't happen to forget to put the trigger wheel on behind the crank pulley did you? (I haven't had one of these engine apart in a while but I believe they had a trigger wheel separate from the crank pulley)
Gawel30 is offline   Reply With Quote
 Old 10-21-2015, 08:04 PM   #8
frothy's Avatar
It's all one piece on these cars. There's no trigger wheel behind the crankshaft pulley.
The Following User Says Thank You to frothy For This Useful Post:
 Old 10-21-2015, 08:12 PM   #9
davychronic's Avatar
Posts: 1,154   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
Im not positive but I doubt the spill valve code would cause a no start, and that coil ground has to almost be on there perfect so i would double and triple check that bitch of a wire. Did you happen to remove it because normally you should leave it on the bracket?
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
 Old 10-21-2015, 08:32 PM   #10
brandonnicholson's Avatar
Posts: 1,699   (View Stats)
brandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the world
Check the actual wire to the fuel pump ground. @Lakespeed6; had his connected and if i remember correctly we used a piece of wore from the battery to the pump to check and it started right up. Dont remember exactly... It was a while ago.. He could hive some insight.
Lakespeed6 likes this.
brandonnicholson is offline   Reply With Quote
The Following User Says Thank You to brandonnicholson For This Useful Post:
mazdaspeed 6 crank no start Mazdaspeedmike07 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 10-11-2015 10:48 AM
Hard Start, Long Crank, Rough Idle red ghost MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 10-07-2014 11:24 PM
Long Crank at cold start maikell77 2010 MS3 - Troubleshoot/Diagnostics 4 03-13-2013 08:54 PM
Page generated in 0.31089 seconds with 26 queries
