 Old 09-19-2015, 07:25 PM   #1
BigRed06's Avatar
Posts: 96   (View Stats)
BigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to all
Default cranks but wont start
hey guys so heres a lil back ground on the car
06 speed6 120k miles
mods: AP, 3.5" intake, hpfp, gt3076 atp ewg, xs power mani, 3" catlesss dp, 3" exhaust dump, cxracing fmic, Mac 4port boost controller, small port job on intake mani, vtcs delete, Toyota injector seals
so heres my problem I recently just installed the Toyota injector seals (today actually) went slow putting everything back together so as I wouldn't forget something. GO to start the car for the first time and nothing, cranks over like normal but wont run.
I have been researching for hours and still haven't been able to find anything that has helped. Ive checked and double cheked everything I can see and feel everything seems to be plugged in and hooked up. All fuses under the hood are good and I checked the relays and I believe they are working (watched vids and got some pointers from friends). Another thing I checked was the hpfp act pressure on the AP with key on and it came back between 1-4 psi, had a friend check his and his was around 60 psi
Any help is appreciated sorry I'm sure this has happened before ive been off here for prob 3yrs as I sold my last ms6 and got this one almost a year ago
MODS: AP V3, 3.5" intake, 3bar, gt3076 atp ewg, 38mm wg, SS turbo lines, 3" catless dp, 3" exhaust dp, hpfp, egr delete, vtcs delete, Mac 4port, lil intake mani port work, cxracing fmic, 51R battery cut stock battery tray, Toyota injector seals
BigRed06 is offline   Reply With Quote
 Old 09-20-2015, 09:39 AM   #2
BigRed06's Avatar
Anyone :/
 Old 09-20-2015, 11:06 AM   #3
BigRed06's Avatar
Well pulled the fuel line from the rail and almost no fuel came out, so I'm not getting fuel like I thought that's y AP only was reading 1-4 psi with key on
Now all the relays are working I here them click and can feel it also, all fuses look good and I checked to see for power at the in tank pumps and the plug on top of the hpfp all have 11.6v
What else can I check I'm completely lost
MS6 Cranks but won't start HELP!!! KingJames MazdaSpeed 6 - Engine, Transmission & Driveline 16 03-23-2015 05:38 AM
Car cranks, won't start 15driley15 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 04-23-2014 03:51 PM
Ms6 cranks but wont start maniospeed6 Mazdaspeed3/6 General Discussion 4 03-26-2013 08:08 PM
Car cranks but doesn't start after valve clean InfamousSpeed6 Mazdaspeed3/6 General Discussion 11 11-29-2012 05:17 PM
Cobb AP Wont work car wont start boosted_speed6 Mazdaspeed3/6 General Discussion 30 05-09-2011 10:11 PM
Page generated in 0.23793 seconds with 21 queries
