  • 1 Post By GroceryGtr
 Old 03-13-2018, 11:14 AM   #1
turbskies's Avatar
Posts: 177   (View Stats)
turbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to behold
Groaned at 9 Times in 6 Posts
Default Cylinder 1 and 4 appear wet
Tried some one step colder plugs to help with knock retard, didn't help, if anything it is worse. I went to take out my plugs to see what they are like and looking into the spark plug hole cylinder 1 and 4 seem to look wet and shiny.
My turbo is shot and I burn a quart every 500 ish miles just FYI.
Any ideas on why the cylinders would appear wet?
The bottom/left spark plug represents cylinders 1 and 4, the top/right spark plug represents cylinders 2 and 3.
Sent from my SM-N950U using Tapatalk
turbskies is offline   Reply With Quote
 Old 03-13-2018, 11:23 AM   #2
Jerome.mps's Avatar
Posts: 18   (View Stats)
Jerome.mps will become famous soon enoughJerome.mps will become famous soon enough
Do a compression test
Sent from my MHA-L09 using Tapatalk
Jerome.mps is offline   Reply With Quote
 Old 03-13-2018, 11:29 AM   #3
turbskies's Avatar
I did about 2 months ago : 155, 150, 150, 155 , idk how accurate the actual valve stem was on psi but it was at least solid accross the board.
 Old 03-13-2018, 01:04 PM   #4
5doorsoffury's Avatar
Posts: 1,086   (View Stats)
Groans: 74
Oil lowers the octane so that is prob the source of the kr...
They are wet looking because of the oil. I mean you did say you burn a quart per 500 miles. You are literally burning a entire oil change worth of oil inbetween the changes them selfs. Eather the turbo is shot and is blowing oil into the intake mani or you have massive blowby.
Do another comp test and add oil into the spark plug hole. If it shoots up a lot then you need to do a leakdown test.
MECP
2012 BM
Rfinkle tune in progress
The Following User Says Thank You to 5doorsoffury For This Useful Post:
MD1032 (03-15-2018)
 Old 03-13-2018, 01:31 PM   #5
turbskies's Avatar
Will do, gonna get a replacement turbo in about a month
 Old 03-13-2018, 04:57 PM   #6
Fstrnyou's Avatar
Posts: 2,231   (View Stats)
I did about 2 months ago : 155, 150, 150, 155 , idk how accurate the actual valve stem was on psi but it was at least consistant accross the board.
Fixed.
I would do a leakdown regardless.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 03-14-2018, 05:41 AM   #7
GroceryGtr's Avatar
Posts: 472   (View Stats)
I'm betting the leak down comes back bonkers. If you are dumping that much oil you are most likely doing 2 things:
1. Youre blowing out the spark and/or severly lowering the octane of hte fuel with the added oil in the cylinders.
2. Your oil addition has made your dry comp test a wet comp test, which means your results aren't accurate and you need to do a leak down.
FYI - Only a dry comp test is accurate for compression. If this comes back low or inconsistent, you would add a cap full of oil to seal the rings and then run again to see if it improved. IN your case you skipped straight to the wet most likely masking a ring problem. You either need to do the leakdown test or wait a few days and then rerun the comp tes once all that oil has a chance to settle out.
If the leakdown comes back fine then its #1 and you get the opportunity to add more power If it comes back off kilter then you need a shortblock from one of our nice vendors and a basic head refresh while its apart.
turbskies likes this.
turbskies (03-14-2018)
 Old 03-14-2018, 08:46 AM   #8
Jeff23spl's Avatar
Posts: 1,746   (View Stats)
with that much oil consumption can the valves and runner be clogged to the point of making problems ? less air for same fuel = too rich ?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 03-14-2018, 10:06 AM   #9
Fstrnyou's Avatar
Less air won't make it rich unless it is introduced through a vacuum leak.
Other rides:
History:
 Old 03-14-2018, 10:19 AM   #10
turbskies's Avatar
Afr is fine
 Old 03-14-2018, 12:12 PM   #11
Jeff23spl's Avatar
Right if all runners are restricted equally
I had in mind one may get worse than others even if the maf reading and average AFR read good....But yes, it is probably not the case.......
Wife drive 2010 CX7
 Old 03-14-2018, 04:43 PM   #12
turbskies's Avatar
Put the tune back to stage 0 (stock), seems to not be knocking almost not at all (peaked at 1.75 at wot just before redline).
Was running stage 1 Stratified etune.
 Old 03-15-2018, 06:22 AM   #13
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Fixed.
You spelled consistent wrong.
I would also recommend a leakdown test. Most likely the motor has cracked ringlands.
2007 Mazdaspeed3 GT
 Old 03-15-2018, 07:23 AM   #14
Fstrnyou's Avatar
Well played.
Other rides:
History:
 Old 03-15-2018, 10:12 AM   #15
turbskies's Avatar
Thanks for the headups
Ms6 Cylinder 1 & 4 wet Mofford12 MazdaSpeed 3 - Engine, Transmission & Driveline 3 08-19-2014 12:22 PM
Supplier testing 3-cylinder engines with cylinder deactivation Haltech Automotive News 0 07-14-2014 02:50 PM
Cylinder#1 Turbo4banger MazdaSpeed 3 - Engine, Transmission & Driveline 1 01-26-2014 06:01 PM
Cylinder 2 misfire Help!!! gt5 MazdaSpeed 3 - Engine, Transmission & Driveline 7 03-27-2010 02:55 PM
Page generated in 0.36351 seconds with 26 queries
