Like Tree2Likes
  • 1 Post By WetzMS3
  • 1 Post By WetzMS3
 Old 08-30-2015, 08:35 PM   #1
Jaxon's Avatar
Posts: 31   (View Stats)
Jaxon is a splendid one to beholdJaxon is a splendid one to beholdJaxon is a splendid one to beholdJaxon is a splendid one to beholdJaxon is a splendid one to beholdJaxon is a splendid one to beholdJaxon is a splendid one to behold
Default cylinder misfires and KR
07 ms3
cobb fmic
autotech internals
cs turbo back catless
cs turbo inlet and 3' intake
forge bpv v2
damon motorsports occ
denso itv22
91 tune
plugs gapped to .028
I am experience a very high kr. Yesterday I did a 3-5 pull and got a misfire cylinder 1. I got home and pulled my plugs and they seemed to be alright.
Today I did a pull and experienced multiple cylinder misfires with high kr and a fucked up spark plug.
Now I am thinking injector seals, injectors, coils, timing chain? I am not too experienced with this and would like some help. Thank you
compression test reads 170-170-178-175
zoom.
Jaxon is offline
 Old 09-02-2015, 02:48 PM   #2
Jaxon's Avatar
I put fresh plugs in, got a cyl 2 misfire.
I am having a ton of knock and ill post another log.
zoom.
Jaxon is offline
 Old 09-02-2015, 03:22 PM   #3
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Is this on the same tank of fuel or separate fill ups?
Have you verified mechanical timing to see if it possibly slipped?
Is the timing chain making odd sounds or feel loose?
A leakdown test could rule out or point to injector seals.
monkey.bones.007 likes this.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
WetzMS3 is offline
 Old 09-02-2015, 03:49 PM   #4
aeMS3's Avatar
Posts: 33   (View Stats)
aeMS3 is a splendid one to beholdaeMS3 is a splendid one to beholdaeMS3 is a splendid one to beholdaeMS3 is a splendid one to beholdaeMS3 is a splendid one to beholdaeMS3 is a splendid one to behold
Check for vacuum leaks, clean maf sensor, stretch coil springs by hand, I think I've also read that the egr could cause this as well so might want to pull out and clean. Swap ignition coil from cylinder 2 with another and see if code follows
V-Dyno: 303WHP 353WTQ FREEKTUNE
Autotech: HPFP Internals
Cobb: V3 AP
Corksport: Stage 2 SRI, TIH, Eyelids
CP-E: 75 Duro RMM, TMIC
Forge: BPV
H&R: Lowering Springs
JBR: Stage 2 OCC, SSP, Counter Weight, Bushings, BPV Hose, Camber arms
NGK: One Step Colder Spark Plugs
OBX: Catless Turbo Back Exhaust
Torque Solution: EGR Delete Kit
Miro: 398 18x8.5 +35
Michelin: Pilot Super Sport 255/35r18
aeMS3 is offline
 Old 09-02-2015, 06:44 PM   #5
Jaxon's Avatar
My vacuum is consistent at -9 at idle would that rule out a vacuum leak?
Timing chain isn't making any weird noises and doesn't feel abnormally lose, just a tad bit of play which I am assuming is normal?
I cleaned maf sensor and I am going to stretch coil springs this evening. Its pouring rain so I cant really do a proper run yet.
zoom.
Jaxon is offline
 Old 09-02-2015, 07:59 PM   #6
WetzMS3's Avatar
Groans: 430
Is it a stock motor? What's you pcv setup?
On a stock block, OEM pcv to catch can, that's low vacuum.
Sent from my XT1254 using Tapatalk
2013 MS3 Black Mica
WetzMS3 is offline
 Old 09-03-2015, 06:41 PM   #7
Jaxon's Avatar
Yep stock motor.
catch can was installed before I bought the car, I am assuming its a stock pcv. to the dm cc.
zoom.
Jaxon is offline
CEL during road trip, random cylinder misfires? AveryPlaysBass 2010 MS3 - Engine, Transmission & Driveline 0 10-06-2014 10:06 AM
MS6 P0302 CEL, other misfires, stuttering. SirChodesly MazdaSpeed 3/6 - Troubleshoot/Diagnostics 16 08-28-2014 12:28 PM
P0300 Random / Multiple Cylinder Misfires txmedic83 CX-7 > Issues & Troubleshooting 9 08-13-2013 01:45 PM
How Toyota misfires with Chinese buyers Haltech Automotive News 0 11-04-2012 07:10 AM
multiple misfires detected after sea foam McKinley MazdaSpeed 3 - Engine, Transmission & Driveline 26 03-08-2012 08:55 AM
Page generated in 0.29875 seconds with 23 queries
