 Old 01-21-2011, 09:11 PM   #1
Revyspeed's Avatar
Posts: 14   (View Stats)
Revyspeed can only hope to improve
Groaned at 6 Times in 1 Post
Default Engine starts and then dies
My first guess is that it is my air filter on the CAI. I haven't cleaned it in a while and it might be getting clogged more than usual during the current winter. If this is the case, what do I need to detach from the car (i.e. panels and such) to get to the actual air filter? I have a fujita cai.
If this is not the problem, anybody else have ideas? On warmer days of about 30 degrees, the car starts up fine. It's just on really cold days...it'll start, then die. But each time I start it again, it lasts a few seconds longer. It only stays on when I give it more gas. But even then, sometimes it won't stay on. Ideas? I'm crossing my fingers that it isn't something more serious. Thanks in advance!
Revyspeed is offline   Reply With Quote
 Old 01-22-2011, 11:03 AM   #2
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
i have never lived in a cold enough place to know for sure but I assume if your saying its that cold the cylinders could be having trouble moving, you may have to restart it several times to get it going like a 2 stroke engine i.e weed eater, kinda like a new engine take quite a few times to finally get it going.
if u wanna try the filter all u have the do is take the 3 screws out of that small panel that folds out of the way on underside of car and pull flap open and u have direct access to filter, you will want to raise car tho
how long does it crank b4 it starts, does it start every time, i woulda prolly just kep restarting it until it got warm enough to stay on.
 Old 01-22-2011, 11:15 AM   #3
jeb8699's Avatar
Posts: 122   (View Stats)
jeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to beholdjeb8699 is a splendid one to behold
i know this isnt really to useful but my truck did this to me the other day after batt died it would not stay running unless i gave it gas but it ended up working itself out after a half dozen tries. i think it was something in my computer but idk
jeb8699 is offline   Reply With Quote
 Old 01-22-2011, 11:30 AM   #4
Revyspeed's Avatar
Thanks guys for your help! Yeah i initially thought it was a cold weather thing...but this didn't happen as often last year. AT most it would have to restart once or twice.
I just removed the filter today from the side panel and cleaned it out. It is currently drying yay! hope this works...
 Old 01-28-2011, 06:16 PM   #5
oodavo's Avatar
Posts: 46   (View Stats)
oodavo is a glorious beacon of lightoodavo is a glorious beacon of lightoodavo is a glorious beacon of lightoodavo is a glorious beacon of lightoodavo is a glorious beacon of light
mine has done the same thing on the really cold days (15 and under), stalls as soon as i let off the clutch when starting. Just hold in the clutch for 20 seconds and it will be fine
oodavo is offline   Reply With Quote
engine built starts today austin102085 MazdaSpeed 3 - Engine, Transmission & Driveline 17 01-11-2011 07:26 AM
Starts then dies bnoon MazdaSpeed 3 - Engine, Transmission & Driveline 9 01-06-2010 07:24 AM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 02:30 PM
Pa. dealer dies while torching his vehicles Haltech Automotive News 0 03-09-2009 11:10 AM
Page generated in 0.25589 seconds with 23 queries
