 Old 06-07-2012, 08:30 PM   #1
speed23's Avatar
Posts: 1,469   (View Stats)
Default engine/tranny shudder when shifting under load
Since I bought my car, I've had a "shudder" in the engine/tranny when I shift gears under high load. Its worst in lower gears. At first I thought it was a tranny issue, but I am starting to wonder if its a mount.
Anyone have a similar experiance? or ideas?
speed23 is online now   Reply With Quote
 Old 06-12-2012, 02:02 PM   #2
btstarcher's Avatar
Posts: 4,850   (View Stats)
Groans: 112
If you have stock motor mounts I would say that's your problem.
SnailTune in progress
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
Black Metal (06-12-2012), speed23 (06-12-2012)
 Old 06-12-2012, 02:07 PM   #3
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
Groaned at 6 Times in 6 Posts
If you are on stock mounts replace the RMM I bet your issues will go away. Also make sure you depress the clutch prior to fully lifting off the gas when you shift.
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
The Following User Says Thank You to Black Metal For This Useful Post:
 Old 06-12-2012, 02:09 PM   #4
m4tic's Avatar
Posts: 4,922   (View Stats)
If it's the 2-3 shift stutter it won't go away without a tune.
2007 MS6 w/ Cheez
The Following 2 Users Say Thank You to m4tic For This Useful Post:
 Old 06-12-2012, 02:23 PM   #5
Groans: 78
Yea you need to be a little more clear on exactly what you're experiencing.
@speed23
- 6MT - Stock -
 Old 06-12-2012, 04:21 PM   #6
speed23's Avatar
Thanks guys. I already have a rear motor mount and a tune. When I shift, I practically smash the clutch into the floor so its fully depressed.
More info: Under high load/WOT in first and second, the whole car shakes suddenly as soon as I push in the clutch to shift gears. Almost feels like the clutch doesnt disengage completely as black metal suggested. I have adjusted the clutch pedal so its not the peddle adjustment.
I am starting to think that a mount somewhere (engine or diff) is bad and allowing the engine/diff to torque while under load, then when I let off the load by pushing in the clutch, it shoves back in place and shakes the car? Is this plausable or is it a clutch/tranny issue?
Thoughts?
Thanks
 Old 06-12-2012, 05:00 PM   #7
btstarcher's Avatar
Groans: 112
Tranny mount would be my guess. The bushing in mine was ripped almost completely out, just 1/2" of rubber left hanging on. I remember feeling that clunk all too well. It was always the 1-2 shift.
 Old 06-12-2012, 05:07 PM   #8
speed23's Avatar
That's what I am leaning towards, followed by a diff mount. No clunking though, only the shaking.
 Old 06-13-2012, 06:40 AM   #9
btstarcher's Avatar
Groans: 112
It wouldn't hurt to replace all your mounts...or at least inspect them. I don't know about the MS6, but mine were fairly simple. And they were also all damaged to some degree.
speed23 (06-13-2012)
 Old 06-13-2012, 11:42 AM   #10
speed23's Avatar
I think youre right. I am gonna start with the tranny mount and then maybe the other MM. If that doesnt help maybe diff mounts.
I went for a drive to find out when it shakes the most and its the worst when I push in the clutch without letting off the gas a bit first- that may point to mounts...
Ordering mounts today and should be able to put them in by next weekend. Will report back. Thanks guys.
 Old 08-10-2012, 04:35 PM   #11
speed23's Avatar
Update: Replaced Tranny mount....however exisiting one was still in great shape, so that wasnt the issue
Its either the diff mount or the tranny itself (although Diff mount look fine from what I can see). I think I ll just live with this. I can stop the shuddering if I let off the gas before I push in clutch anyway at WOT, so I ve just learned to drive this way.
 Old 08-10-2012, 04:49 PM   #12
BrianB6's Avatar
Posts: 400   (View Stats)
BrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the worldBrianB6 is the leader of the world
Groans: 28
Could be the passenger side motor mount. How many miles do u have?
Mine started leaking a fluid out the bottom of the mount a few months back
The thing I have noticed since then is more cabin vibes during WOT.
I'm holding out for the SURE mounts to be released.
2016 - WRX -Cobb AP - Perrin Shift Stop - Perrin Trans Mount - Whiteline Positive Shift Bushings
2006 - MS6 - Dead RIP
BrianB6 is offline   Reply With Quote
 Old 08-10-2012, 08:21 PM   #13
speed23's Avatar
I thought of that, but cant see any fluid leaking, so I am assuming its ok?
 Old 09-27-2012, 04:07 PM   #14
speed23's Avatar
UPDATE: The problem was a seriously worn out passenger motor mount even though there was no leakage.
I am so friggen happy to have found this, car feels 1000% times better!
Engine Lugging / Shifting at low RPM breakfstincluded Mazdaspeed3/6 General Discussion 15 05-31-2011 01:42 AM
engine knock under load cbspeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 07-17-2010 07:32 PM
NEW ENGINE/TRANNY sp33dy6 MazdaSpeed 6 - Engine, Transmission & Driveline 0 10-28-2009 01:37 PM
Engine shudder/vibration when cold SRTie4k MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 10-02-2009 07:08 AM
engine knocking under load allmotor95pgt MazdaSpeed 3 - Engine, Transmission & Driveline 100 12-08-2008 09:52 AM
Page generated in 0.32885 seconds with 24 queries
