 Old 07-17-2019, 01:33 PM   #1
Speed3kid93's Avatar
Posts: 59   (View Stats)
Speed3kid93 has a spectacular aura aboutSpeed3kid93 has a spectacular aura about
Groaned at 18 Times in 7 Posts
Default Extremely confusing issues need help from pros
I am in need of some major help.
I am having 2 major issues I canít figure out.
The first issue is regarding my fuel economy.
I had my intercooler and radiator support replaced recently and ever since my mpgs have been pathetic. I have been getting between 12-14 mph city and 18 highway when I used to get 30-32 mph highway and 22-24 city. The weird thing is my fuel trims and afrs are still perfect. Which is the part thatís confusing me the most. I have tried all the basics including cleaning the maf, fuel system cleaner and reloading my tune. The only thing i havenít done yet is replaced my spark plugs. They are a little old at this point but I havenít had any breaking up or driveability problems and I donít think old spark plugs would bring my mpgs from 32-34 down to 18. Thatís almost cut in half.
My mods Are
Intake and tip
Rear motor mount
Cobb front mount
E30 tune from purple drank.
Recirc valve
Downpipe and full exhaust
Hpfp internals
I am working on getting some logs to post up here as I know that problems are much easier diagnoses with logs but Iím hoping someone can at least start to point me in the right direction.
The next problem involves my a/c.
The a/c will work fine and blow cold sometimes but then randomly stop working for a half hour or so and then start working again.
When the a/c is working the compressor clutch will spin fine and then stop for 5-10 second and then start spinning again. When itís not working the compressor wonít kick on at all.
The cooling fan is working fine as well.
I had the Freon professionally drained and refilled to the correct amount and checked for leaks and they didnít find any leaks.
The local mechanics are stumped and basically told me to start replacing everything until something works which is extremely costly and ridiculous advice.
I know a lot of you will say bring it to the dealer and have them hook up their scan tools but My local dealer wonít hook my car up to their high tech computers because they say they donít work on modified cars. So thatís not an option.
I am stumped on both issues and neither seems to make any sense to me.
HPFP, Corksport Dp to CBE, cobb SRI and TIP, Cobb big front mount intercooler, corksport RMM, eibach lowering springs, accessport v3 with e50 tune by Will @ pd tuning 22 psi 11.8 AFR
Speed3kid93 is offline   Reply With Quote
 Old 07-17-2019, 02:06 PM   #2
Jeff23spl's Avatar
Posts: 2,009   (View Stats)
for the ac, you may check when it quit working if the 12v is at the clutch but it isn't turning...there is common problem of worn bearing/clutch.
for your mpg, i would start with a boost leak under real pressure. if there is air leak that is read by the maf, it will send fuel for it but won,t be used.
You may also check for anythng wrong with wheel/tires/ stuck brakes
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
The Following 2 Users Say Thank You to Jeff23spl For This Useful Post:
MSMS3 (07-17-2019), whatsabrooklyn (07-22-2019)
 Old 07-17-2019, 03:08 PM   #3
SpoolinSpeed3..757's Avatar
Posts: 48   (View Stats)
SpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of light
Being that you just had an intercooler and radiator support replaced I would do a once over on the clamps and couplers to make sure everything got hooked up properly
Sent from my SM-N960U using Tapatalk
SpoolinSpeed3..757 is offline   Reply With Quote
The Following User Says Thank You to SpoolinSpeed3..757 For This Useful Post:
Vansquish (07-22-2019)
 Old 07-17-2019, 03:43 PM   #4
MSMS3's Avatar
Posts: 2,586   (View Stats)
Groans: 144
AC issue: Sounds like the solenoid operated ac clutch is probably going out. This tends to show up first as working when the engine is cold and then stopping when it is warmed up. There is an air gap that is needed for the clutch to move when it gets the signal from the solenoid. Over time, that gap gets out of spec.
The solution is to install a new solenoid/clutch unit on the front of the ac compressor. You do not need to replace the entire compressor and deal with evacuating and refilling the compressor. Replacement solenoid/clutch unit is available. I did this several years ago. It was not difficult. If I recall, it just bolts on. I don't think I needed to use a gear puller. There may even be threads here on this. I've not looked.
First, make sure that you are getting 12 volts when the AC is turned on. Even if it's not turning, if the AC is on, you must be getting 12v to the solenoid, or it is some other problem.
Low fuel mileage: As to the low mileage issue, we really would benefit from some logs. Have you excluded bad gas? Perhaps change sources and make sure you are running 93 octane if available. Maybe your ethanol mix is off? I know little about it, but I know that ethanol mileage is lower than 93, and if you are running too much ethanol, or water contamination, that could possibly be a part of the problem.
 Old 07-17-2019, 09:29 PM   #5
The a/c compressor clutch going out makes perfect sense
However with the mpgs every time I have had a loose coupler the fuel trims were way off and the car ran like shit.
My fuel trims are perfect and the car runs good.
The bad gas and too much E85 are rules out and actually o have less E85 than normal so I should be getting better mpgs
 Old 07-18-2019, 08:36 PM   #6
MSMS3's Avatar
Groans: 144
Well, there! You donít have a problem the, right? How did you rule out bad fuel or water contamination?
 Old 07-21-2019, 10:36 PM   #7
Well the problem has been happening over multiple tanks of gas all from different stations.
Water contamination is definitely possible because I buy e85 in bulk and store it in gas containers and lately the seals on the containers have been breaking apart and I think its letting some water and moisture in.
I put some fuel conditioner that helps with water in fuel and also put some fresh e85 in and Im hoping this will help.
Another thing my fiance noticed today was when stepping on the gas a decent amount she said there was a burnt chemical smell coming into the car.
I don't have a great sense of smell and never noticed but she said it was noticeable.
I checked over the engine bay and noticed that the previous owner used some aluminum foil near the turbo as some sort of heat shield and a large portion was burned off.
So i just took the whole thing off and I'm hoping this gets rid of the burnt smell.
 Old 07-22-2019, 09:11 AM   #8
Jeff23spl's Avatar
the heat shield you describe is looking like the factory one attached to the car body that felt off...
ask her if the rpm and speedo was still following each other to make sure it wasn't a clutch smell.
Btw fuel conditionners to get rid of water are usually Methanol very similar to ethanol of the e85....there isn't much you can do to save your stored e85 from water content....But W/M is exactly that but from a separated ''not calculated'' injector
Wife drive 2010 CX7
Oil consumption, leakdown and compression confusing tom10122 Mazdaspeed3/6 General Discussion 3 08-12-2017 07:00 PM
Mercedes pulls potentially confusing self-driving E-Class ad Haltech Automotive News 0 07-29-2016 07:10 AM
Confusing electrical problem ShintaroIchi MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 08-02-2015 12:30 AM
JMF gtx3071 dyno... confusing results bcmurphy87 MazdaSpeed 3/6 - Dyno Sheets/Discussions 236 03-15-2013 03:28 PM
Video: Confusing, but awesome Audi R8 Spyder commercial Haltech Automotive News 0 04-29-2010 11:10 AM
Page generated in 0.34275 seconds with 23 queries
