 Old 07-03-2012, 09:41 AM   #1
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groans: 29
Default fuel leak
so last night i was racing some kid in an SI (lol maybe i'll upload the video later FYHN) and after 4 or so runs i noticed i got some kind of cut abruptly. drove home and stopped somewhere and the car was smelling like gas and wasn't wanting to hold a steady AFR while cruising (kept richening up) so i drove home and parked for the night since it was late and i didn't wanna fuck with it then.
woke up this morning and tried to start it, barely started up took a good 5-7 seconds of cranking it. looked under noticed it was leaking a decent amount of fuel. gonna start to tear it apart and see if i can find where it's coming from.
anyone have any ideas that might save me some time?
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
 Old 07-03-2012, 11:20 AM   #2
jack_hammer's Avatar
Posts: 6,821   (View Stats)
Groans: 549
based on the information you provided, i'd say it's probably coming from a hole of some sort. maybe at a connection, or possibly not. definitely start with the parts through which the gas flows.
it's fun to do bad things
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
Roddiy (07-21-2012), shawn. (07-03-2012)
 Old 07-03-2012, 11:26 AM   #3
EdgeAutosport.com's Avatar
Posts: 6,207   (View Stats)
Check the relief valve or the hardline that feeds the pump both of those have come loose on me.
To find out where the leak is let the car idle and you should be able to see where it is leaking from
The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post:
helmetface (07-03-2012), shawn. (07-03-2012)
 Old 07-03-2012, 11:35 AM   #4
shawn.'s Avatar
Groans: 29
haven't had a chance to jack the car up but i've got a general idea where the leak is coming from. hopefully i'll be able to get things squared away after work tonight! the feed line seems to be tight...looks like the leak is coming from down below further, closer to the undertray.
i mean i am running 50/50 e85 but i highly doubt a hole would form from corrosion due to the ethanol. only been running it 10k miles if that. i know many people have run higher concentrations for longer but it is something that came to mind...
my guess is a fuel line that's been rubbing on something or moved too close to something that's too hot haha
need to get underneath tonight it's just too fucking humid today lol
 Old 07-20-2012, 06:19 PM   #5
massiespeed3's Avatar
Posts: 142   (View Stats)
massiespeed3 has a reputation beyond reputemassiespeed3 has a reputation beyond reputemassiespeed3 has a reputation beyond reputemassiespeed3 has a reputation beyond reputemassiespeed3 has a reputation beyond reputemassiespeed3 has a reputation beyond reputemassiespeed3 has a reputation beyond reputemassiespeed3 has a reputation beyond reputemassiespeed3 has a reputation beyond reputemassiespeed3 has a reputation beyond reputemassiespeed3 has a reputation beyond repute
Did you ever figure anything out?
I've had several issues with my fuel return line, replaced it four times and am giving my car to Mazda this week because it has broke again. I have kmd internals and am starting to wonder if that's part of the problem. No one else seems to be having this problem.
Weekend Worrior: 2009 CWP MazdaSpeed 3
2.1 60ft 13.03 1/4 @ 109.6MPH stock ko4
Daily: 1991 Mazda Miata
massiespeed3 is offline   Reply With Quote
 Old 07-21-2012, 01:48 PM   #6
I fart in my sleep
Rkrise216's Avatar
Posts: 204   (View Stats)
Rkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the worldRkrise216 is the leader of the world
the external fuel pump has a bolt underneath mine just came loose three days ago and was leaking fuel that could be it.
Rkrise216 is offline   Reply With Quote
 Old 07-21-2012, 01:53 PM   #7
Roddiy's Avatar
Posts: 5,388   (View Stats)
Roddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the world
Groans: 279
Groaned at 58 Times in 47 Posts
Just take a lighter to the fuel pool, it will take you straight to the leak.
2010 LSM Speed3
Bolted + Corn + Meth + ACT 6-Puck
#BakeryTuned
Roddiy is offline   Reply With Quote
The Following 2 Users Say Thank You to Roddiy For This Useful Post:
PapaBruno (12-19-2016), Swinger13 (10-21-2012)
 Old 07-22-2012, 11:13 AM   #8
Caldazar's Avatar
Posts: 293   (View Stats)
Caldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond repute
use your nose and eyes.
Fuel leaks are fairly obvious.
if the engine, or the area around the leak is clean and dry you can't miss it
06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver
91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's
Caldazar is offline   Reply With Quote
 Old 07-22-2012, 11:17 AM   #9
shawn.'s Avatar
Groans: 29
it was the stainless steel line under the pump...had a hole somehow. replaced the line and all is well so far.
 Old 10-20-2012, 06:43 AM   #10
Mclovin80's Avatar
Posts: 228   (View Stats)
Mclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the world
What was the part number of the stainless steel line under the pump; did it come with the nut that threads onto the fuel pump, and was it an easy install?
Sorry for all the questions, but I think I am going to have to do this on my car.
Mclovin80 is offline   Reply With Quote
Fuel Leak bschuske Gen2 MS3 General Discussion 14 12-01-2011 02:36 AM
2011-12 Audi R8 Spyder recalled for fuel leak Haltech Automotive News 0 08-11-2011 03:00 PM
Fuel Leak? azokaei MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 12-13-2010 03:09 PM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 10:10 AM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 06-10-2008 01:12 AM
Page generated in 0.58236 seconds with 27 queries
