 Old 02-17-2012, 06:17 PM   #1
dpolseno41's Avatar
Posts: 1,819   (View Stats)
dpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the worlddpolseno41 is the leader of the world
Groaned at 41 Times in 16 Posts
Default Fuel Pressure Drop after load of 2
My fuel pressure is falling out of the sky once a load of 2 is reached. I had KMD internals that were doing the same thing. I cleaned them, reinstalled, no luck. I've gone back to stock internals and overall my pressure numbers are better but pressure is still shitting the bed. Everything looks good in terms of hoses. Perhaps it's the relief valve? Which I can't afford to be bad right now. Outside temperature? I read somewhere it could be related to that. At idle pressure usually hovers around 400psi.
dpolseno41 is offline   Reply With Quote
 Old 02-17-2012, 06:31 PM   #2
SSinstaller's Avatar
Posts: 3,826   (View Stats)
Groans: 51
If your holding pressure until you hit higher loads, I would think it more likely that the in-tank pump is the problem, not the RV..
Is that log with the OEM internals or the aftermarket? It just looks like bad internals to me..
Soon to be installed:
ST manifold w/ port injection : Raduim Engineering PCV Plate : Radium Engineering PCV valve : Radium Engineering Fuel filter : Aeromotive FPR : DCR VVT : TI Automotive F90000262 Fuel Pump : NX 15718 : Split Second AIC
 Old 02-17-2012, 06:34 PM   #3
dpolseno41's Avatar
That's a log with stock internals, KMD internals were even worse. I could of sworn my numbers were fine before I went catless too. I have no clue what's going on.
 Old 02-17-2012, 06:37 PM   #4
Groans: 51
Most likely the KMD's are gone, and your OEM internals aren't up to the task..
Overcoming low baro pressure for load tuning KRheeder MazdaSpeed 3/6 - ECU Computer Tuning 2 01-11-2012 09:32 PM
What causes pressure drop on inercoolers? NinjaT1985 2010 MS3 - Turbo Induction 11 11-17-2011 02:57 PM
Voltage drop at WOT = Fuel Cut??? volodya84 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 05-24-2011 04:02 AM
Drop in Boost Pressure Jujiro_Prodigy_31 MazdaSpeed 3/6 - Turbo Induction 4 01-12-2010 03:04 PM
POLL: Good idea to make the fuel tables the same above a certain load? bast525
Cobb ATR Support
11 09-09-2009 01:41 PM
Page generated in 0.24010 seconds with 22 queries
