 Old 06-09-2011, 05:09 AM   #1
Lakespeed6's Avatar
Posts: 2,396   (View Stats)
Lakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the world
Default Help Not Reading Boost
I have manual boost gauge that is reading normal but when I look at my cobb or my mechanics read tool my boost only reads between 4-6psi all the time. Would this be a bad boost sensor? If so where would I get a new one and where is it located on the engine?
I am also getting lots of knock retard under boost up to 5.2 would this be due to the boost not reading?
Last question. I have a 3" downpipe on the car with a high flow cat. Getting CEL for "O2 sensor slow response time bank one sensor 2" Could this just be since the exhaust is free flowing, or a bad/damaged O2 sensor? If it is a bad O2 sensor where should I order a new one?
Any help would be great. Thanks
Lakespeed6 is offline   Reply With Quote
 Old 06-12-2011, 03:58 PM   #2
Lakespeed6's Avatar
Anyone?
 Old 06-12-2011, 04:34 PM   #3
kmac's Avatar
Posts: 1,792   (View Stats)
When did this start and what does the boost gauge read.
 Old 06-13-2011, 05:58 AM   #4
Lakespeed6's Avatar
Don't know when this started about 1 month ago.
Boost gauge reads normal up to 20psi.
Cobb just reads 2-6psi and flashes.
Would this be a bad MAP Sensor?
 Old 06-16-2011, 06:11 AM   #5
Lakespeed6's Avatar
Anyone have any suggestions?
 Old 06-16-2011, 06:17 AM   #6
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
your connection got fuct.
07 MS3
The original Genpoo Hater
Boost gauge vs. AP boost reading.. which is correct? Unoriginalusername MazdaSpeed 3/6 - Turbo Induction 13 05-23-2011 04:41 PM
DH boost reading k0m MazdaSpeed 3 - Engine, Transmission & Driveline 4 10-08-2009 05:49 AM
Dashhawk only reading 5.66psi boost after SB install RedBliss MazdaSpeed 3/6 - ECU Computer Tuning 4 07-17-2009 11:26 PM
AFR reading with the COBB borderline
Cobb Access Port/Maps
8 09-10-2008 10:24 AM
Page generated in 0.26707 seconds with 22 queries
