MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Jan 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | ![]() ![]() ![]() Sent from my SM-G955U using Tapatalk |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Apr 2015 Location: Ann Arbor Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
Groaned at 9 Times in 7 Posts
| ![]() ![]() ![]() I'm still gonna say battery. While mine did not test fine when it let go, it exhibited the same symptoms. It would only start on a jump and all my electronics would cut out for about a second on takeoff. New battery fixed it. As you know, cold destroys batteries, and mine died like that overnight where the day before it was working perfectly.
__________________ Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Moog endlinks. Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges. |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Jul 2016 Location: Near Charlotte NC
Rep Power: 228 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| ![]() ![]() ![]() Once the engine is running, the battery does nothing. Electronics going glitchy on take-off shouldn't be battery related.
__________________ 2006 MS6 GT - 152k Miles Versatuner, 3-bar MAP, ITV22's CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Russian Bushings in Back, Magnaflow CBE JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/Stage 2 OCC Puppy Power tuning temporarily suspended. Forged build ongoing. Manley H-Tuff & 2618, King Bearings Other rides: 2002 Tacoma ExtCab 2.4L 5spd 2WD - 355k mile Parts Getter 2004 Olds Alero ECOtec 2.2 - Broken (since Christmas 2015) History: 2008 GSX-R 1000 - Stolen (With several runs past 180, I'd probably be dead by now if it wasn't stolen. So, in a way, I'm thankful.) 1988 RX-7 TII - Sold (Megasquirt, streetport, filter-on-turbo SRI, custom TBE, 20psi boost creep on OE turbo, OE TMIC on ice, 13.467 @ 105.44) apex seals said buh bye! 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) |
![]() | ![]() | #4 | ![]() |
| ![]() ![]() ![]() If the battery is so dead it can't hold enough voltage to keep everything going in the car, I would imagine it would cause this. Again I have no proof, but I believe that's what happened in my case. Granted, mine was so dead that as soon as I shut off the car, it had no electronics at all. I had to manually lock the doors.
![]() | ![]() | #5 | ![]() |
| ![]() ![]() ![]() Once an engine is running, you can remove the battery and everything will be fine...if the alternator is good.
![]() | ![]() | #6 | ![]() |
Sent from my SM-G955U using Tapatalk Last edited by dmsoliz1986; 01-13-2018 at 09:40 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | ![]() | #7 | ![]() |
| ![]() ![]() ![]() If the alternator is bad, you usually get a battery light on your dash. This means the system voltage is low. I'm not sure at what voltage that light is triggered. Put a volt meter on your battery with engine off, should be around 12v. Do it again with engine running, should be over 14v.
![]() | ![]() | #8 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 479 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
Usually if the car is on and running and see below 12v it comes on
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned | |
![]() | ![]() | #9 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Lmao thanks guys turns out it was a loose ground that runs off the battery to the carriage Sent from my SM-G955U using Tapatalk |
Display Modes | |
JNC 660 jump starter | Revmatch | MazdaSpeed 3/6 - Car Audio & Electronics | 10 | 11-06-2015 12:48 PM |
Official: 2014 BMW 5 Series starts at $50,425* and gets a new diesel, 5 Series GT starts at $60,925* [w/video] | Haltech | Automotive News | 0 | 05-19-2013 02:40 PM |
