 Old 09-13-2018, 09:33 AM   #1
Rose City Speed6's Avatar
Posts: 44   (View Stats)
Rose City Speed6 is a glorious beacon of lightRose City Speed6 is a glorious beacon of lightRose City Speed6 is a glorious beacon of lightRose City Speed6 is a glorious beacon of lightRose City Speed6 is a glorious beacon of lightRose City Speed6 is a glorious beacon of light
Groaned at 3 Times in 1 Post
Default Help! Thump in driveline
My '06 MS6 has developed a thump in the driveline as you release the clutch. Sound appears to come from left side (not sure) and I can feel it through the clutch pedal. There is no thump when depressing the clutch in neutral.
FWIW, the master/slave cylinder was replaced a few months ago. The flywheel and clutch disc were replaced with stock items about a year ago.
I have a JBR rear engine mount.
Is this a symptom of engine mount problems? Diff mount problems?
Rose City Speed6 is offline   Reply With Quote
 Old 09-13-2018, 11:31 AM   #2
Thor Hammer's Avatar
Posts: 1,783   (View Stats)
Groans: 203
Time to get under the car and check all the mounts. TMM, PMM, RMM, and diff mounts.
LSD BAD? CV Joint? THUMP THUMP AFTER TIRE CHANGE 90210 Gen2 MS3 General Discussion 30 05-30-2013 08:04 AM
Shift Thump? rey_06 MazdaSpeed 6 - Engine, Transmission & Driveline 8 03-20-2012 07:18 PM
Suspension thump on reverse? urbansurfer MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 03-23-2010 02:24 PM
Thump - which mount? Speedsicks MazdaSpeed 6 - Engine, Transmission & Driveline 2 11-13-2009 01:33 PM
Rear end thump. novelist MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 08-26-2008 08:50 AM
Copyright 2008 ; 2018 Cymru Internet Services LLC | FYHN Autosports HQ
Page generated in 0.23554 seconds with 21 queries
