 Old 09-10-2019, 08:04 AM   #1
dave1991phillips's Avatar
Posts: 1   (View Stats)
dave1991phillips is an unknown quantity at this point
Default HGF or not?
Hi every one new member here, I had a 2007 gen 1 3mps/mazdaspeed here in the UK (not sure if it'll be different to a US spec). So heres my issue I'll try not to bore you all. After leaving a car show a week or so ago I noticed the temp gauge go up to about the 3/4 way, so I pulled over not even 20 seconds later, shut the car off and noticed 2 pipes from the coolant tank had been shredded by the belt, after putting the pipes back together the car wouldn't start. Is there anything that would stop the car starting back up? Doesn't seem to be water in the oil or nothing that would say the head gasket has gone apart from the car overheating also there was no smoke from the exhaust before pulling over.
Sent from my SM-G975F using Tapatalk
dave1991phillips is offline   Reply With Quote
Page generated in 0.29477 seconds with 19 queries
