| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | | #1 | ![]() |
![]() Join Date: May 2011 Location: Greenville, SC
Rep Power: 53 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 52
(Thread Starter) | Not Ranked : 0 score Monitoring a few trips back and forth from work since that pull, everything seems normal. Peaks at upper 1800's, doesn't drop below 1800psi until I let off the throttle. This is no more than 3-4 seconds at a time- bit paranoid. But even still, I never saw 1800psi in the WOT log until my foot was off the pedal at the end of the log! How best should I troubleshoot? I'm not sure how to reproduce, and probably shouldn't be doing WOT pulls? phate
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP | SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV | MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 LexTune |
| The Following User Says Thank You to LilGator For This Useful Post: | phate (08-28-2012) |
| ZipTie & Duct Tape Master ![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 2460 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,736
Groans: 124
Groaned at 83 Times in 49 Posts
Did you properly install them? Clean with gas, soak in oil, assemble in oil, then break in properly?
__________________ Killah Built SMAC Tuned car went boom...again![]() Penises...you all know who eats them |
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | LilGator (08-28-2012) |
(Thread Starter) | Not Ranked : 0 score Check, check, check. What is the break in procedure? I primed by starting with gas pedal to the floor- didn't see anything about break in?
![]() | | #4 | ![]() |
Groans: 124
let idle until you get to operating temperature and then take it easy for at least a hundred miles....or did you go WOT right away
![]() | | #5 | ![]() |
| Eth Fiend ![]() Join Date: May 2010 Location: Murhpysboro, IL
Rep Power: 6825 ![]() Thanks: 10,684
Did you happen to pull the spill valve off when you did the internals? If so, did you tighten it down to the exact spot as before? I would first check the internals for scuffing. If no scuffs, then I would look into the relief valve.
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold |
![]() | | #6 | ![]() |
![]() As far as I recall I didn't touch the spill relief valve at all. I'll pull 'er out and check both. Thanks.
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP | SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV | MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 LexTune | |
![]() | | #7 | ![]() |
Pulled pump and checked out the internals, looked like they did out of the box, no scuffing. The relief valve never got touched, and checking it out doesn't look like I can tighten it any more than it was. Re-soaked the internals in gasoline, cleaned and coated in fresh oil. Reassembled, idled and i'll take it easy for a while and get a new WOT pull and see what we're looking at.
![]() | | #8 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8395 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,253
| The Following User Says Thank You to Lex For This Useful Post: | LilGator (08-29-2012) |
![]() | | #9 | ![]() |
![]() Join Date: Mar 2011 Location: Durty Derby, CT
Rep Power: 289 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 797
Groaned at 6 Times in 4 Posts
** When you put this thing back together, let the system prime via the fuel pump - cycle the key on, wait about 5 seconds, turn it off. Repeat a few times. ** Edit... day late, dollar short... Sorry - this for some reason didn't post up last night and I found it tonight.... BTW relief valve is on the fuel rail... My car is currently at the dealer (extended warranty might as well use it) getting the fuel rail done and hopefully the valves cleaned when they inspect them (while its all apart) to replace the failed relief valve.
__________________ 07' Speed6 Velocity Red Mica Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP Anti break stuff: Upper Rear Diff Brace, RMM Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod | |
| The Following User Says Thank You to scubasteve711 For This Useful Post: | LilGator (08-29-2012) |
![]() | | #10 | ![]() |
![]() Join Date: Nov 2009 Location: Westchester NY
Rep Power: 233 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 561
just an idea, bc this all seems odd, but did you kink any of the hardlines?
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge |
| The Following User Says Thank You to speedms6 For This Useful Post: | LilGator (08-29-2012) |
![]() | | #11 | ![]() |
OK, so spill valve is on the pump itself. Relief valve is here: HOW-TO: Replace Relief Valve (RV) I don't know why anything would have changed there but I'll take a look. According to this the test for relief valve is monitoring AP pressure while the car is off? Fuel Pressure Relief Valve Question Of course that thread ended with suggestions to get new internals. I thought I'd skip the PTP / KMD nonsense and go straight to Autotechs... ![]() I'll take a look and make sure.
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP | SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV | MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 LexTune | ||
![]() | | #12 | ![]() |
Monitor fuel pressure while the car is off (~30 minutes after it was running) started at 1233psi and slowly dropped at a rate of 30psi/min. Edit:
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP | SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV | MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 LexTune Last edited by LilGator; 08-30-2012 at 06:28 AM. | ||
![]() | | #13 | ![]() |
After ~10mins of driving watched the pressure with the car off and it climbed to 1774psi before turning around. I assume it's likely not the relief valve. If it's not the relief valve, and not the spill valve, internals look fine...
![]() | | #14 | ![]() |
What part is easiest for you to swap with a local speed3? A complete pump or the RV? At least you'd isolate it to one issue or the other. Don't swap internals, swap the entire pump itself.
![]() | | #15 | ![]() |
The how-to for RV doesn't look terribly difficult, but getting the pump out is only a ~10min job really. I'm pretty tempted to order an upgraded RV and cp-e pump just to swap one at a time and test both ways. But now I'm reading about the in-tank pump and filter...
![]() | | #16 | ![]() |
This makes sense to me:
And so if the pressure with swapped internals is over 1870 on pulls, but the relief valve is opening ~1774 that's where issues are arising? I don't know if I'm looking at this right.
| The Following User Says Thank You to LilGator For This Useful Post: | G26 (08-31-2012) |
![]() | | #17 | ![]() |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
Groans: 39
I have my ptp relief valve for sale. Let me know.
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
![]() | | #18 | ![]() |
Rep Power: 272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 337
FRP drop with aftermarket internals in good shape and decently clean spill valve may indicate some problems in the fuel tank (the ITFP or the fuel filter there).
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B14 PSS, SSR Type-F, Michelin PSS 225/40/R18 US Spec, CS RMM Inserts, AutoExe Street Pads Cobb SRI, SU TMIC, Cobb XLE, NGK LTR7IX, Corksport CAI Box, UR catted DP and res TP, GS EBCS, Autotech internals, GTX3071, Bosch 3BAR MAP Sensor StratiVersaTuned |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score It sounds to me like from your description and other things I'm reading Autotech internals are typically going to give you many spikes over the ~1850psi the stock valve opens at. So no matter what it's probably going to wear eventually. I wonder why this isn't more common though? I know there's no point in replacing it with another stock valve, so I'd go with the PTP anyway. I'll shoot you a PM about yours.
![]() | | #20 | ![]() |
Groans: 39
Depends on other factors I guess, friend of mine had 75k on his stock relief valve, he installed auto techs and 1 week later the oem rv took a shit.
![]() | | #21 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 3802 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,913
Groaned at 9 Times in 7 Posts
Im guessing its the spill valve even if it looks good. I had a very similar problem as you OP swapped the spill valves and was good to go.
__________________ ![]() Auto Tech Fuel pump internals #1 Source! PM Me for Details or call me 303-268-2140 |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | m.a.vega1 (09-28-2012) |
![]() | | #22 | ![]() |
| Not Ranked : 0 score Spill valve in the pump or relief valve in the rail?
![]() | | #23 | ![]() |
The spill valve
![]() | | #24 | ![]() |
That sucks. Getting a 1950psi upgraded valve is only 100psi over stock, but seems to be the only one working for most people. I'm thinking I might just scrap plans and get a BRZ or gen coupe. Kidding. Haha. ![]() Should I pull off the spill valve and clean it, or just swap with another? Where can one be acquired?
![]() | | #25 | ![]() |
Sounds like I need to pick up another OEM pump to replace spill valve.
![]() | | #26 | ![]() |
Acquired a new OEM pump. Swapped the Autotechs in and installed. Doesn't seem to be doing well, in fact it may be worse than it was. Monitoring I'm not even seeing pressures spike past the 1700's, much less hold pressure up to that point or higher. Slowly accelerating to the 1300-1400 range and give it more throttle it dips to 1000 and lower. Just not holding. Bit of driving log attached, and a little example here: Code: Time Accel. AFR Boost BAT Load HPFP Act. HPFP Des. 278.98 0 26.07 -12.06 117.5 0.04 1144.31 291.52 279.12 9.75 26.18 -9.84 118.62 0.16 1087.74 430.75 279.26 14.82 18.95 -7.76 118.62 0.3 994.92 1025.38 279.42 14.82 15.16 -7.11 118.62 0.34 1105.15 1134.16 279.56 16.77 14.47 -6.03 118.62 0.36 1116.75 1224.08 279.72 20.67 14.47 -4.03 118.62 0.46 1255.98 1411.17 279.86 21.45 14.36 -4.6 118.62 0.47 1305.29 1451.78 280 23.4 14.24 -5.03 119.75 0.43 1325.6 1392.31 280.14 23.4 14.81 -3.02 119.75 0.53 1332.85 1521.39 280.28 23.79 14.7 -2.59 119.75 0.56 1392.31 1521.39 280.42 24.96 14.59 -2.02 119.75 0.62 1379.26 1550.4 280.56 26.52 14.59 -1.3 119.75 0.65 1386.51 1679.48 280.7 28.08 14.81 -0.22 119.75 0.69 1409.72 1808.56 280.86 31.2 14.13 0.92 119.75 0.81 1354.6 1808.56 281 31.98 13.9 2.29 119.75 0.85 1319.8 1808.56 281.14 32.76 13.55 3.51 119.75 0.97 1224.08 1808.56 281.28 33.15 12.98 4.29 119.75 1.01 1158.81 1808.56 281.44 33.93 13.55 5.23 119.75 1.05 1155.91 1808.56 281.58 35.88 13.44 5.73 119.75 1.07 1081.94 1808.56 281.74 35.88 13.09 5.8 119.75 1.11 1119.65 1808.56 281.88 35.49 12.4 5.8 118.62 1.11 1084.84 1808.56 282.04 35.49 12.29 5.87 118.62 1.11 1099.35 1808.56 282.2 35.49 12.17 6.02 118.62 1.11 1060.19 1808.56 282.34 30.42 12.4 4.73 118.62 1.06 1071.79 1808.56 282.5 18.72 13.09 -0.3 118.62 0.93 1124 1808.56 282.64 12.87 13.55 -3.6 118.62 0.54 1421.32 1521.39 282.8 0 12.75 -9.91 117.5 0.25 1406.82 430.75 282.94 0 15.62 -11.92 117.5 0.04 1329.95 291.52 283.08 0 22.39 -12.06 117.5 0.03 1332.85 291.52 283.22 0 26.87 -12.21 117.5 0.04 1332.85 291.52 283.36 0 29.29 -12.21 117.5 0.04 1334.3 291.52 283.5 0 29.29 -12.21 117.5 0.04 1334.3 291.52
![]() | | #27 | ![]() |
Datalog
![]() | | #28 | ![]() |
At this point, swap the stock internals back in. The problem is so severe now that the stock internals would rule out the Autotechs. They would hold pressure fine at 5psi.
| The Following User Says Thank You to Lex For This Useful Post: | LilGator (09-12-2012) |
![]() | | #29 | ![]() |
Makes sense, I'll do that today.
![]() | | #30 | ![]() |
Swapped stock internals back in. Not looking good. These were the brand new internals that came with the new pump. Code: Time Accel AFR Boost Load HPFP Act HPFP Des 1.04 0 29.29 -11.99 0.07 511.97 430.75 1.18 2.73 29.29 -11.56 0.08 482.96 430.75 1.32 7.02 22.97 -9.98 0.18 432.2 430.75 1.48 9.36 18.6 -8.83 0.22 448.15 619.29 1.62 10.92 16.08 -7.69 0.32 735.32 1015.23 1.76 14.04 14.93 -6.11 0.36 861.49 1203.77 1.9 16.38 14.81 -5.39 0.38 891.95 1312.55 2.04 16.77 14.24 -5.03 0.43 906.45 1372.01 2.18 16.77 14.36 -4.96 0.43 900.65 1382.16 2.32 16.77 14.59 -4.96 0.44 910.8 1392.31 2.46 16.77 14.47 -5.03 0.44 893.4 1392.31 2.62 16.77 14.59 -4.82 0.45 896.3 1421.32 2.76 16.77 14.59 -4.74 0.45 899.2 1421.32 2.9 16.77 14.59 -4.82 0.45 903.55 1421.32 3.04 17.16 14.59 -4.46 0.46 913.71 1441.62 3.2 22.23 14.7 -3.24 0.51 903.55 1521.39 3.34 23.4 14.7 -2.66 0.56 864.39 1521.39 3.5 27.3 14.59 -1.52 0.61 854.24 1620.01 3.64 29.64 14.59 -0.8 0.68 839.74 1749.09 3.78 30.03 14.7 -0.37 0.69 799.13 1808.56 3.92 29.64 14.59 -0.08 0.73 806.38 1808.56 4.06 30.03 15.04 0.21 0.74 788.98 1808.56 4.22 31.59 14.81 1.07 0.8 788.98 1808.56 4.36 31.98 14.47 1.5 0.83 774.47 1808.56 4.5 33.54 14.24 2.36 0.85 720.81 1808.56 4.64 35.49 14.13 3.29 0.94 696.16 1808.56 4.78 35.49 13.44 4.01 0.97 675.85 1808.56 4.92 35.49 12.63 4.58 1.03 616.39 1808.56 5.08 35.88 13.44 5.08 1.04 603.34 1808.56 5.22 35.88 13.32 5.37 1.07 598.98 1808.56 5.36 35.88 13.21 5.73 1.09 581.58 1808.56 5.5 35.88 12.86 5.73 1.08 559.83 1808.56 5.64 36.27 12.75 5.73 1.09 536.62 1808.56 5.78 35.88 12.75 5.59 1.09 581.58 1808.56 5.92 20.67 12.86 1.35 0.79 648.3 1808.56 6.06 12.87 13.32 -3.24 0.64 728.06 1550.4 6.2 0 13.09 -9.55 0.36 858.59 728.06 6.34 0 13.55 -10.77 0.1 841.19 430.75 6.48 0 14.36 -11.49 0.07 797.68 291.52 6.64 0 15.5 -11.92 0.05 784.63 291.52 6.78 0 19.06 -12.06 0.05 784.63 291.52
![]() | | #31 | ![]() |
Could be the in tank pump going bad, or the filter getting clogged.
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score What do you think I should hit next, replace relief valve or replace in-tank pump? When I read threads where the OP suspects needing to replace in-tank pump, people suggest the RV and that was what fixed the issue for some people. Yet when I read relief valve threads, people are saying their pressure with the engine off is ~65psi or it doesn't build pressure. Mine still builds to 1764psi after I shut the car off. I think I will pull the relief valve off and check it out. It's supposed to be like a check valve, and if I can blow through it then I'll know it's bad.
![]() | | #33 | ![]() |
![]() Join Date: Nov 2011 Location: Raleigh NC
Rep Power: 820 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 835
Groans: 35
Groaned at 25 Times in 14 Posts
__________________ 2007 Black Mica MS3 Go Fast Bits: Tune in progress - AutoTech HPFP Internals - 3.5" JBR WP - CP-E Catted Downpipe - HKS SSQV3 VTA - CNT CBE- JBR EGR Block-off - TB TIG - IM TIG - Ported Stock Intake Mani - NGK Step Colder Plugs - Treadstone TR8L FMIC Core - Custom FMIC Piping Cornering: Koni Yellows - JBR Rear Sway Bar - TR Motorsport C3s - 5mm Front Spacers Shifting: JBR SSP/Solid Bushings/Counter Weight - JBR 88a RMM - JBR 70a PMM - JBR 70a TMM Fiddly Bits: WOLO Model 417 Long Horns - JBR OCC - Spin-on Filter Conversion | |
![]() | | #34 | ![]() |
The "clean" way to check if the in tank is providing adequate fueling is to put an in-line gauge on the feed line to the HPFP. You need a couple of fittings and a gauge since it's low pressure. I would do that before pulling the in-tank pump.
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #35 | ![]() |
I agree that I don't think it's the RV, though.
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold | |
| The Following User Says Thank You to phate For This Useful Post: | LilGator (09-12-2012) |
![]() | | #36 | ![]() |
We can't yet, but if we did assume it's not the RV or ITFP, where do we go from there?
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP | SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV | MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 LexTune | |||
![]() | | #37 | ![]() |
Groans: 35
just a thought, but are you torquing everything in the pump back to where it should be? If the cylinder isn't tight enough it can definitely cause problems.
| The Following User Says Thank You to anavrinIV For This Useful Post: | LilGator (09-14-2012) |
![]() | | #38 | ![]() |
That's a thought, I hadn't torqued that down to a specific number in any of the internals swaps I've done. I have tried getting about as tight as I could and I've also tried not going past where it gets difficult to tighten (there's a pretty obvious point using a ratchet where it hits a wall and you have to start getting pretty tough). Somewhere I read someone had issues when it was over-tightened and recommended not much past hand tightening. Is it 55 ft-lbs? I've got the original pump with new stock internals in the car right now, and I have the Autotechs inside the new pump sitting at my desk so I can torque that to the correct value and swap back and see what happens. If anyone around here needs to pull their HPFP, I've got this thing down. Of course, I may end up being the one guy who figured out how to screw up an FP internals swap, so ymmv...
![]() | | #39 | ![]() |
Groans: 35
I'm just spitting out what few thoughts I have. when I do internals I don't actually torque them to any spec, but I keep going until they really don't want to turn. As long as they're going without a whole lot of fight, I keep turning. Once they kinda "stop" I give them one last hurrah and that's it, just kind of a verification tug. I've done 2 sets, very soon to be ~5 once the other guys get theirs in, and so far I've been successful. There's a chance you have another problem, but can't hurt to eliminate potential issues with your hpfp first. Just seems weird that the itfp would crap at the exact time you change internals.
![]() | | #40 | ![]() |
Should double check the pressure to the pump from the tank... Maybe I missed it, but you said you swapped the spill valve? Also - as an aside, since I've seen a couple threads with this stuff now, check the connection to the fuel pressure sensor on the fuel rail (it is on the pass side of the rail) Been a few people that have seen issues like this where the sensor connection was causing issues.
__________________ 07' Speed6 Velocity Red Mica Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP Anti break stuff: Upper Rear Diff Brace, RMM Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod Last edited by scubasteve711; 09-13-2012 at 10:22 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to scubasteve711 For This Useful Post: | LilGator (09-14-2012) |
| Serious HPFP Issues | dpolseno41 | Mazdaspeed3/6 General Discussion | 19 | 02-18-2012 10:31 AM |
| HPFP internals or new HPFP? | JAGspeed6 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 11 | 11-26-2011 01:34 PM |
| Which HPFP Internals | drewsifer86 | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 12-02-2010 08:24 PM |
