| MazdaSpeed 3/6 - Troubleshoot/Diagnostics MazdaSpeed 3/6 - Troubleshoot/Diagnostics - Have a problem with the car? CEL Code? Want to discuss other issues? Come on in! |
![]() | | #41 | ![]() |
![]() Join Date: May 2011 Location: Greenville, SC
Rep Power: 53 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 52
(Thread Starter) | Not Ranked : 0 score StreetUnit's been dicking around though, I ordered on the 12th... 8 days later it's still processing. Should have ordered from Edge but SU had the removal tool rental.
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP | SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV | MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 LexTune |
![]() | | #42 | ![]() |
| Eth Fiend ![]() Join Date: May 2010 Location: Murhpysboro, Illinois
Rep Power: 6791 ![]() Thanks: 10,658
Just curious, how much does that pump cost?
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold |
![]() | | #43 | ![]() |
| The Following User Says Thank You to LilGator For This Useful Post: | phate (09-20-2012) |
![]() | | #44 | ![]() |
13 days later it finally ships. Hopefully I'll see it Thurs., get this thing installed with fingers crossed.
![]() | | #45 | ![]() |
Swapped in the DW65c. There is a ridiculous high-pitched whine coming from it at idle and until ~1000psi. I primed and drove it a couple miles last night, pressure was pretty rough. 1000-1200 at best. This morning in to work it was a lot better, but we're still not there yet. First couple gears it seemed to be rising and holding but no more than 1400-1500psi range. Saw a peak in the upper 1700's which is the first time in a long time. Fourth gear as I slowly gave it more throttle it would rise to 1300-1400psi and then start to drop down to 900-1000. I'm not fully convinced that it won't be better since it's improved in the few miles I've put on it, but I don't know what the break-in period is like on these? And if it turns out this doesn't do the trick, what do I look at next? RV is fine because it immediately starts building pressure when I turn the car off.
![]() | | #46 | ![]() |
Did you check out and/or replace the filter while you were in there?
| The Following User Says Thank You to phate For This Useful Post: | LilGator (09-28-2012) |
![]() | | #47 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8346 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,230
An electric fuel pump does not have a break in period ... this sounds very strange. Can you iterate in one post what you've swapped out already just so it's nicely summarized?
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Lex For This Useful Post: | LilGator (09-28-2012) |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes, forgot about that part. Filter looked dirty, but didn't realize the one that comes with the DW65c doesn't work. You can't use it with the assembly that slides over the bottom of the pump and clips to hold the regulator in place. This isn't mine, but a pic of that: ![]() This is from a WRX guide for the DW65c, and it shows the filter that comes with the pump- just connects directly to the pump itself. I tried it this way but the regulator really needs that clip to hold it in. I heard a pop when I tried it this way, opened it up and the regulator had popped out. So I put the old filter back on and that's where I'm at now. Can you buy that filter by itself? ![]()
__________________ 2007 Speed6 GT - LPM RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP | SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV | MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports E85 LexTune | |
![]() | | #49 | ![]() |
Once upon a time, in the land of E85, I had a clogged filter. I didn't know it, so I bought an entire ITFP basket. The fuel pump seemed fine, but the filter was NASTY. It was doing similar things to yours, but eventually got so bad I would see fuel pressure drop to 0psi. My original fuel pump was also very loud at the time because it was working overtime trying to pull through the nasty filter.
![]() | | #50 | ![]() |
Is the whole basket the only way to replace the filter? So I've got that on my radar along with the fuel rail pressure sensor and on much lower priority the RV.
![]() | | #51 | ![]() |
Filter: LFB6-13-ZE1 I didn't know what was wrong with mine, so I ordered the entire assembly. Parts shotgun ftw.
![]() | | #52 | ![]() |
Awesome. Got one on the way, worth a shot. No local dealer has it, but OnlineMazdaParts is nearby in Charlotte so it shouldn't take long. Parts shotgun. I like it. I feel like I'm doing parts whack a mole.
| The Following User Says Thank You to LilGator For This Useful Post: | Lex (09-28-2012) |
![]() | | #53 | ![]() |
This gives me a little hope:
![]() | | #54 | ![]() |
So much for that hope. On the drive home I had dips down to 40psi.
![]() | | #55 | ![]() |
Getting worse, making the drive to and from work extremely difficult keeping my eye on pressure watching out for these drops. I can't go more than 30-35mph. Here's a snippet, log attached. Hopefully should see the ITFP filter tomorrow. Having a hard time believing that will cause this... or why it decided to start doing this now. But phate having had the same issue is a good sign. Fingers crossed (again). Code: Time Accel. AFR Boost Load HPFP A HPFP D 3.18 11.7 14.59 -6.39 0.39 1203.77 1273.39 3.32 12.09 14.59 -6.32 0.39 1197.97 1263.23 3.46 12.09 14.81 -6.18 0.39 1186.37 1292.24 3.6 11.7 14.7 -6.25 0.4 1228.43 1292.24 3.74 11.7 14.7 -6.39 0.39 1228.43 1283.54 3.88 11.31 14.59 -6.54 0.38 1206.67 1242.93 4.04 11.31 14.7 -6.54 0.38 1186.37 1232.78 4.18 11.31 14.7 -6.54 0.38 1164.61 1232.78 4.32 11.31 14.7 -6.61 0.38 1155.91 1232.78 4.48 11.31 14.81 -6.61 0.38 1164.61 1232.78 4.62 11.31 14.7 -6.54 0.38 1173.31 1232.78 4.76 11.7 14.7 -6.54 0.38 1171.86 1232.78 4.9 11.7 14.7 -6.46 0.38 1155.91 1232.78 5.04 11.31 14.7 -6.46 0.38 1158.81 1242.93 5.18 11.31 14.7 -6.46 0.38 1164.61 1253.08 5.34 11.7 14.7 -6.39 0.38 1176.21 1242.93 5.48 12.09 14.7 -6.32 0.39 1168.96 1263.23 5.62 12.09 14.81 -6.18 0.39 1182.02 1273.39 5.76 12.09 14.7 -6.25 0.4 1173.31 1283.54 5.9 12.09 14.7 -6.18 0.39 1176.21 1283.54 6.04 12.09 14.59 -6.32 0.39 1173.31 1273.39 6.18 12.09 14.7 -6.18 0.4 1141.41 1273.39 6.32 12.09 14.7 -6.18 0.4 1151.56 1283.54 6.48 12.09 14.7 -6.18 0.39 1137.06 1273.39 6.62 12.09 14.59 -6.18 0.4 1124 1283.54 6.78 11.7 14.7 -6.25 0.39 1126.9 1273.39 6.92 11.7 14.59 -6.32 0.38 1112.4 1253.08 7.08 11.7 14.7 -6.46 0.38 1089.2 1232.78 7.22 11.31 14.7 -6.46 0.38 1060.19 1232.78 7.36 11.31 14.7 -6.54 0.38 1039.88 1224.08 7.5 11.7 14.7 -6.54 0.37 984.77 1232.78 7.66 11.31 14.7 -6.32 0.38 910.8 1242.93 7.8 11.7 14.81 -6.32 0.38 720.81 1232.78 7.96 11.31 14.7 -6.39 0.38 585.93 1242.93 8.12 11.31 14.7 -6.25 0.38 329.22 1232.78 8.26 11.7 14.47 -6.39 0.38 201.6 1232.78 8.4 11.7 14.59 -6.32 0.38 23.21 1232.78 8.54 12.09 18.83 -6.18 0.38 15.95 1253.08 8.68 0 24.92 -8.83 0.24 14.5 707.76 8.82 0 27.68 -10.48 0.15 15.95 430.75 8.98 0 28.83 -10.77 0.11 18.85 430.75 9.12 0 29.29 -10.41 0.12 15.95 430.75 9.26 0 29.29 -10.12 0.14 21.75 430.75 9.4 0 29.29 -9.91 0.16 117.48 430.75 9.54 0 29.29 -10.41 0.16 200.15 430.75 9.68 0 22.62 -10.48 0.13 368.38 430.75 9.82 0 17.69 -10.48 0.13 393.04 430.75 9.96 0 16.31 -10.27 0.14 417.69 430.75 10.1 0 16.08 -10.05 0.16 459.75 430.75 10.24 0 15.96 -10.19 0.16 469.91 430.75 10.38 0.39 15.16 -10.05 0.16 474.26 430.75 10.52 2.34 14.93 -9.26 0.18 472.81 430.75 10.68 3.51 14.47 -8.9 0.23 514.87 539.52
![]() | | #56 | ![]() |
OK, a few updates. Got the filter replaced last night. So far I can give it as much throttle as I want, no scary pressure drops like earlier this week. On a minor note, my fuel level gauge is stuck on E with about a quarter tank filled up, so it looks like I've got to go pull it out again. Now, in doing this I've also noticed I'm not hitting boost targets. In fact, I'm not really hitting boost, couple psi tops. Partly because I've been driving like a grandma for the last month, and partly because I've always watched Act. HPFP on the AP while driving I'm sure it's been like this for awhile I hadn't really noticed until now. Checking for leaks I noticed a good bit of leak in the turbo/downpipe area. Pulled IC and heatshields and found one of the five nuts had worked i's way completely off- it was gone! Another had worked it's way to the end of the bolt. These were the bottom two. The top three seemed fairly snug still. I got a new nut on and wrench tightened not even quarter turns at a time as much as I could, but I can't get a socket on there from up top. Must have to get those from the bottom? Could this have been at least partially the cause of my issues?
![]() | | #57 | ![]() |
![]() Join Date: Dec 2011 Location: Fort Lauderdale, FL
Rep Power: 1150 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,371
| Not Ranked : 0 score MS6FL, would you like to share you experience of having to miss 2-3 nuts missing from your DP or you MS6?
__________________ 2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arm | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors |
![]() | | #58 | ![]() |
Found it. Damn! His bolts were missing?
![]() | | #59 | ![]() |
| The Cone Killer ![]() Join Date: Nov 2010 Location: Miami, Florida
Rep Power: 511 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,720
Groans: 40
__________________ Ariel![]() COBB SRI/TIH/XLE/ECBS/AP/Knob, PnP'ed IM, ETS TMIC, Autotech FP internals, Guardian Angel, M2 DP, JBR SSP/EGR Delete, AWR 88 RMM, SURE Dreadnaught/Juggernaught, Whiteline RSB, MD OCC, IM/TB TIGs, Battery Relocate, Trunk Monkey, ITV 22s, Rotella T6, Eibach Pro kit springs, Powerslot rotors, Hawk HP+ Pads, SS lines, 18x8.5 +42 Focal F16s, 235/40/18 NT05s "Eyes for an eye, Teeth for a tooth." | |
![]() | | #60 | ![]() |
![]() Join Date: Apr 2011 Location: Weston, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,503
Groans: 39
Groaned at 150 Times in 51 Posts
| Not Ranked : 0 score You couldn't even put your face in the turbo area without the fumes stinging your eyes. Sent from my...
__________________ 2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold 2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs |
| The Following User Says Thank You to G26 For This Useful Post: | MS6FL (10-05-2012) |
![]() | | #61 | ![]() |
Got the leak issues resolved. Bolts torqued down, and my extra o2 sensor bung had come off! Now, I've noticed a good bit of white smoke out the exhaust at idle. But only sometimes. Lex should I raise idle on that map a bit? I think I still have issues holding fuel pressure. I need to check the logs I took, and it's not the severe double digit drops I had before replacing the ITFP filter, but it looks like it's dropping down to ~600psi range when I start to lay into it. I'll post up some logs here shortly to verify.
![]() | | #62 | ![]() |
Snippet here, with the full log attached. I don't even know what to think anymore, what is going on? Code: Time Accel AFR Boost BAT Load HPFP A HPFP D 18.3 0 12.98 -11.49 101.75 0.14 1147.21 430.75 18.44 0 12.63 -11.99 101.75 0.08 1079.04 291.52 18.58 0 14.93 -11.99 101.75 0.04 1077.59 430.75 18.72 15.6 15.85 -6.68 101.75 0.09 1032.63 627.99 18.86 27.69 14.7 -2.09 101.75 0.6 1137.06 1521.39 19 31.98 14.01 -0.87 102.88 0.67 1151.56 1769.4 19.14 37.05 13.78 2 101.75 0.94 1081.94 1808.56 19.3 39 12.29 3.29 101.75 1.05 945.61 1808.56 19.44 46.41 13.09 4.87 101.75 1.14 864.39 1808.56 19.58 47.97 12.17 7.31 101.75 1.27 815.08 1808.56 19.72 47.97 11.83 9.61 100.62 1.37 703.41 1808.56 19.86 47.97 12.06 9.75 99.5 1.42 616.39 1808.56 20 47.97 11.94 9.32 99.5 1.39 623.64 1808.56 20.14 47.97 11.94 9.25 98.38 1.36 668.6 1808.56 20.3 47.97 11.71 9.03 98.38 1.36 588.83 1808.56 20.44 47.58 11.83 8.82 96.12 1.34 603.34 1808.56 20.58 47.97 11.83 8.6 96.12 1.33 613.49 1808.56 20.72 47.97 11.83 8.6 96.12 1.32 601.89 1808.56 20.88 48.75 11.71 8.82 95 1.33 672.95 1808.56 21.02 50.7 12.06 10.54 93.88 1.39 651.2 1808.56 21.16 51.09 12.06 10.97 92.75 1.45 601.89 1808.56 21.3 51.48 11.94 11.18 92.75 1.47 581.58 1808.56 21.44 51.48 11.71 11.11 92.75 1.47 556.93 1808.56 21.58 51.48 11.71 11.26 92.75 1.47 522.12 1808.56 21.72 51.48 11.71 10.61 91.62 1.47 525.02 1808.56 21.88 50.7 11.6 9.75 91.62 1.38 616.39 1808.56 22.02 50.31 11.71 9.39 90.5 1.37 627.99 1808.56 22.16 50.31 11.71 9.32 90.5 1.37 574.33 1808.56 22.32 49.92 11.6 9.18 90.5 1.36 593.18 1808.56 22.46 48.36 11.48 9.1 89.38 1.34 675.85 1808.56 22.6 48.36 11.6 9.1 89.38 1.33 686 1808.56 22.76 48.36 11.6 9.1 89.38 1.32 626.54 1808.56 22.9 43.68 11.48 8.6 89.38 1.31 648.3 1808.56 23.04 35.88 11.48 7.81 89.38 1.27 672.95 1808.56 23.18 33.15 11.6 7.02 89.38 1.22 742.57 1808.56 23.32 28.86 11.48 5.87 89.38 1.18 742.57 1808.56 23.46 24.57 11.25 4.58 89.38 1.11 802.03 1808.56 23.6 17.94 12.75 1.07 89.38 0.93 934.01 1808.56 23.74 0 11.94 -7.83 89.38 0.74 1029.73 1560.55 23.88 0 10.91 -11.56 89.38 0.13 1263.23 430.75 24.02 0 12.06 -11.99 89.38 0.06 1221.17 291.52 24.16 0 14.93 -11.99 89.38 0.04 1231.33 291.52 24.3 0 20.56 -11.99 89.38 0.04 1232.78 291.52 24.44 0 24.92 -11.99 89.38 0.04 1235.68 291.52
![]() | | #63 | ![]() |
Any ideas guys, I really don't even know where to start poking next? HPFP internals are good. Spill valve is good. Relief valve is good. ITFP and filter is good. Dips to 500-600psi range at 50% accel pedal.
![]() | | #64 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 7046 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,721
Groans: 412
Groaned at 104 Times in 60 Posts
Is there an inline filter? I have no idea, man. Probably sent from a toilet
__________________ it's fun to do bad things |
| The Following User Says Thank You to jack_hammer For This Useful Post: | LilGator (10-12-2012) |
![]() | | #65 | ![]() |
I don't believe so, at least I haven't heard of one yet.
![]() | | #66 | ![]() |
Groans: 412
yea, i just looked... it seems we do not. i can't help you but here's a bump in case someone can.
![]() | | #67 | ![]() |
![]() Join Date: Nov 2008 Location: Tucson, AZ
Rep Power: 4186 ![]() Thanks: 4,081
Groans: 103
Groaned at 21 Times in 19 Posts
If you are running high concentrations of corn, don't soak the internals in oil. You could have high speed sticking of the internals due to black/sticky death, caused by bad reaction between oil, temps and corn sauce. While my method may not work for everyone, I reassemble my pump dry or with a little bit of lighter fluid, and sometimes if the spill valve is off I won't reinstall it until the pump is on the car; before that I'll squirt some lighter fluid in there and then put the spill valve back on so it doesn't start dry (though priming a couple of times should work just fine instead of that).
__________________ ![]() |
![]() | | #68 | ![]() |
No corn yet, besides the at-most 10% in 93 here. I swapped the Autotechs into a brand new OEM pump and got the same result, as well as swapping the original internals back in. Maybe it's time to put a cp-e pump in just to be sure. I'm really just grasping though, I have no idea what the deal could possibly be.
![]() | | #69 | ![]() |
So fucking pumped right now. Check out this log. I spent the afternoon searching for HPFP threads with issues and read probably all of them. It gave me the motivation to pull the pump out for the 37th time and reassemble just because you never know.
| The Following User Says Thank You to LilGator For This Useful Post: | jack_hammer (10-14-2012) |
![]() | | #70 | ![]() |
What did you do differently?
![]() | | #71 | ![]() |
The only thing I really did differently than other times was the nut that tightens around the internals. I torqued it 3 or 4 times with all I had to get it tighter, just because it was something I hadn't tried before. Maybe that did it.
![]() | | #72 | ![]() |
Groans: 103
Strange; I only go to hand-tight with a tap on the end of the wrench with my palm. I don't torque mine.
![]() | | #73 | ![]() |
That's what I had done the past times, as it goes from hand tightening to a lot of resistance pretty quick.
![]() | | #74 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 706 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,201
Groans: 34
Glad you got it sorted, keep monitoring and report back in a week or so.
__________________ Tuned with by ![]() Su tmic/corksport intake/custom 3" tbe/grimmspeed ebcs/forge bpv/jbr ssp/jbr rsb/Jbr side mount/sure tig set/sure r3 rmm/kmd internals/pg sst (tune in progress)/3 gauge pod |
![]() | | #75 | ![]() |
![]() Join Date: Jul 2010 Location: Lunenburg Mass
Rep Power: 893 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 592
I'm having a similar issue right now. I'm targeting 1750 and right around 4500-5500 RPM I dip into the 1500s-1400s sometimes less. This is also around a 2.4+ load. The autotechs have less than 3k on them.
__________________ 2006 Black MS6 383WHP 385WTQ GTX3076r -- TIAL 44mm EWG -- CP-E Turbo Manifold -- HTP 4" Intake -- CPE Top Mount JBR TB and IM thermal spacers -- Perrin OCC -- SU Boost Tubes -- Greddy Rec BOV-- CP-E Injector seals 3" Downpipe with hi-flow cat -- 3" Magnaflow CBE -- Autotech Fuel Pump Internals -- Grimmspeed EBCS FreekTune -- Snow Performance Meth Injection D10 -- Denso ITV22 -- balance shaft delete -- EGR delete ISC Coilovers -- Sure Torq R6 -- Sure Juggernaught -- Sure Dreadnaught -- Sure Anchors -- Sure Shift Knob | |
![]() | | #76 | ![]() |
Groans: 103
How much corn are you running? I see you have meth AND a GTX30 turbo; if high concentrations are being run, you're probably legitimately running out of fuel. With a high mix of corn, you really don't need meth, btw. If you are running corn and wanted to "fix" this issue on the same fuel mix and other settings on the map, you could neuter the VVT in that RPM range to provide a bit more fueling.
| The Following User Says Thank You to Enki For This Useful Post: | Lakespeed6 (10-15-2012) |
![]() | | #77 | ![]() |
I shouldn't be running out of fuel as of now, only putting down 320WHP or so Virtual Dyno. Tuned back down to 290WHP and same results. I did check/clean my spill valve and looked over my autotechs for scrapes or other issues and they looked clean.
![]() | | #78 | ![]() |
I haven't pulled a new log yet, I'll get some more. Monitoring pressure while driving it is holding well now ~1850psi range. You did verify your relief valve is good by watching pressure build after you shut the car off?
![]() | | #79 | ![]() |
4th gear WOT log attached
![]() | | #80 | ![]() |
| Not Ranked : 0 score Fuel pressure looks good, but holy KR. You need to look for things rattling around in the engine bay, or run some high octane fuel to double check it. You also have a spike in calc'd load when VVT -> 0°. It's an MS6 thing that started with one of the last few releases of ATR. If you keep VVT just above 0 through the top end rev range, it won't spike. Ghetto work around, but it works and you won't lose power. That (the spike) will put you in higher load cells, where you will run less timing = less power. Analysis workbook and screenshot attached.
| The Following User Says Thank You to phate For This Useful Post: | djuosnteisn (11-15-2012) |
| Serious HPFP Issues | dpolseno41 | Mazdaspeed3/6 General Discussion | 19 | 02-18-2012 10:31 AM |
| HPFP internals or new HPFP? | JAGspeed6 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 11 | 11-26-2011 01:34 PM |
| Which HPFP Internals | drewsifer86 | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 12-02-2010 08:24 PM |
