 Old 11-05-2013, 05:54 PM   #1
jnin's Avatar
Posts: 8   (View Stats)
jnin is an unknown quantity at this point
Default Idle issues
Hi guys
I am experiencing some idle issues on my mazdaspeed 6.
I recently installed a FMIC and since then the car idles at 1500rpm when in neutral and rolls on the street. As soon as the car stops the revs are going back to normal...
Any ideas what to look for?
Thanks
jnin is offline   Reply With Quote
 Old 11-05-2013, 05:55 PM   #2
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Need more info, what other mods do you have........
Etipp98 is offline   Reply With Quote
 Old 11-05-2013, 05:57 PM   #3
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Based on that question, I would start by looking for a good mechanic.
MINI H1 6.0 - CAR LED TAILS
 Old 11-05-2013, 05:58 PM   #4
jnin's Avatar
Thanks for the quick reply.
The other mod is a 3" CAI which I have it for a year with no issues. Problem started after the FMIC.
Thanks
 Old 11-05-2013, 05:58 PM   #5
Etipp98's Avatar
You need an accessport. Stock tune is a no go with the mods you have.
 Old 11-05-2013, 06:00 PM   #6
jnin's Avatar
I got an accessport a couple days ago but I havent done anything with that yet as I didnt have time.
So by loading the OTS map which is closer to my mods will fix the issue?
Thanks
 Old 11-05-2013, 06:03 PM   #7
1) FMIC is too big of a change for the ECM's stock tune to compensate for. You are probably running too lean at idle due to increased airflow and the ECM cannot compensate enough to keep LTFTs at bay and AFR @ 14.7. Are you getting any codes/check engine light? I got a lean at idle CEL after I installed my FMIC until I updated my tune.
2) If everything worked before FMIC, and you installed FMIC and now you have issues, it is probably that something isn't hooked up right, you accidentally disconnected something or you have a boost leak at one of the many FMIC couplers.
Thanks
It probably won't fix it, but you will get more information on what the car is doing. You really need to know what your LTFTs are doing and what your AFR is. Download a map close to yours, probably a stage 1, though the 3" intake makes it tricky. Just pick a Stage 1 + intake + IC tune for any intake and that should get you in ballpark.
Last edited by dale_gribble; 11-05-2013 at 06:04 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-05-2013, 06:18 PM   #8
jnin's Avatar
No engine lights nothing at all.
Couplers are tight. I checked the pipping and everything was solid. Other than that car goes a bit better. Intercooler piping is 2.5" and dimensions of IC are 600x300x76 mm
 Old 11-05-2013, 06:27 PM   #9
Etipp98's Avatar
Millimeters huh.....
 Old 11-05-2013, 06:36 PM   #10
jnin's Avatar
yes millimeters.
 Old 11-06-2013, 11:44 AM   #11
ciezczak1's Avatar
Posts: 416   (View Stats)
ciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the world
Groaned at 4 Times in 2 Posts
This happens to me too sometimes any answers to it?
Sent from my SGH-T989 using Tapatalk 2
GT3076/ catless dp/ FMIC/ 3.5" CP-E Intake/ 3" Exhaust/autotech internals/ built block/ 3-port/denso itv22/ 6th-port
ciezczak1 is offline   Reply With Quote
 Old 11-06-2013, 12:44 PM   #12
jnin's Avatar
I ve got it all the time when the car rolls in neutral only
 Old 11-06-2013, 01:13 PM   #13
post a log when its doing it with your ap.
 Old 11-06-2013, 03:20 PM   #14
jnin's Avatar
Will do as soon as I found out how to do it :-)
Issues with rough idle, no boost after intall of bolt-ons 08ms3stock4now MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 02-15-2013 11:28 AM
Report: Scion FR-S, Subaru BRZ rough idle issues require ECU reflash Haltech Automotive News 0 10-05-2012 10:00 AM
29 AFR at idle Zak MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 02-06-2012 02:07 PM
Idle still low after changes in ATR RichInAustinTX 2010 MS3 - ECU Computer Tuning 9 02-06-2012 11:24 AM
Strange Idle Issues after FMIC Install nytmar3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 06-21-2008 12:11 AM
Page generated in 0.33312 seconds with 23 queries
